Jacksonville, FL - HDTV - Page 151 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #4501 of 4529 Old 02-02-2014, 05:42 AM
reds75's Avatar
Quoted: 90 Post(s)
Liked: 106
Does anyone know of a company that installs antennas ,my 18 year old antenna is dying. I live in St. johns county. Thanks for any info.
reds75 is offline
post #4502 of 4529 Old 02-06-2014, 11:01 AM
jangelj's Avatar
I've read through a good chunk of this thread, but wanted to ask a question. I live off of CR 210 south of Jax and would like to get OTA HD channels. I prefer not to mount an antenna on the roof. I checked the tvfool.com site, and it says that I should be able to receive the major networks from Jax with a set-top antenna. Since I am constructing a new house, I figure I might as well mount an attic antenna before insulation gets blown in.
Can someone who lives in this area recommend a specific model that works for them?
Thanks for any advice!
John
jangelj is offline
post #4503 of 4529 Old 02-06-2014, 01:53 PM
reds75's Avatar
Quoted: 90 Post(s)
Liked: 106
jangelj; I live in St Augustine and before my antenna started to die I could get most of the Jacksonville stations. But my antenna was a large yagi. It had elements for vhf and uhf. It was mounted on a 20 ' pole and had a booster. The 2 weak stations are abc 25-1 and 7-1 pbs. Even with this setup those stations sometimes are hard to get. In the summer ,very inconsistent.Cbs 47 and Fox 30 are very strong.I realized I am farther south than you,but Ihope this info helps. I think bigger is safer for better reception.Hopefully someone who lives closer to you can give more accurate info.
reds75 is offline
post #4504 of 4529 Old 02-10-2014, 06:15 PM
trackavsforum's Avatar
Depends if you're more like CR210 Ponte Vedra or CR210 Orangedale; check the antennaweb.org site for help. Generally, you should have no problems with most any decent UHF&VHF (both!) antenna if you aim carefully. But here are two problems I had in a Floridian house (Palm Beach, but still relevant):
(1) Aiming the antenna in the attic space can make a smaller antenna perform better than a large one! Why? If you can't fit the bigger model under the angle of your roof, pointed in *exactly* the right direction, you lose. Typical new Florida truss construction makes this worse, because it may have to fit within the scaffolding triangles (or worse, in the width of just 1 bay), and the roof angle, and point perfectly to boot. (2) Modern truss "joiner-plates" create little square dead spots in their shadows. This means that mounting the antenna as high up as possible doesn't always work, so be prepared to do some fooling around with positions.
Thus, counter-intuitively, I would get a smaller antenna, within whatever range antennaweb.org tells you. Also because aiming is so important, make sure you can reach it after occupancy (or else do a complete job with a TV set on the construction site before you close up the interior). Sorry I can't directly answer your question with a model number: there's no substitute for local, neighborly, intelligence. (Even further away, though on the same angle of CR210@US1, I needed a Winegard GS-2200 with an amplifier for a customer. It was outdoors but had to be as small as possible, thus that model and the amp.)
trackavsforum is offline
post #4505 of 4529 Old 03-02-2014, 09:08 AM
hmunster2's Avatar
Quoted: 95 Post(s)
Liked: 33
Living on A1A beach blvd in St Augustine-anybody have an HDTV antenna that works to pick up Jax HD?
hmunster2 is offline
post #4506 of 4529 Old 06-04-2014, 10:11 AM
reds75's Avatar
Quoted: 90 Post(s)
Liked: 106
I put a huge yagi antenna from Radio Shack,all channels come in but 25-1 ABC. I can live with that. On another note ,channel 47 news is letting go almost every anchor they have. I dont know if I have seen a complete news team canned all at the same time.
reds75 is offline
post #4507 of 4529 Old 06-04-2014, 03:11 PM
grittree's Avatar
Quoted: 335 Post(s)
Liked: 186
25-1 ABC actually broadcasts on ch 10, which is VHF. Assuming your Yagi is UHF, adding and combining a VHF antenna will get that channel, and help with NBC + PBS.
grittree is offline
post #4508 of 4529 Old 09-04-2014, 11:04 AM
reds75's Avatar
Quoted: 90 Post(s)
Liked: 106
antenna seems to have settled in. I now get all channels pretty consistently.
reds75 is offline
post #4509 of 4529 Old 09-09-2014, 06:35 AM
reds75's Avatar
Quoted: 90 Post(s)
Liked: 106
Fox-30 and CBS-47 seem to have been able to put up their new call letters quickly.I doubt this and the other changes they have made will have any effect on the news ratings.
reds75 is offline
post #4510 of 4529 Old 09-14-2014, 09:45 AM
Liked: 0
Problem with NBC HD
hi everyone,
does anyone have an idea why I can watch NBC channel 12-1 DTV over the air using my analog to digital converter, but NOT on my HD digital TV? all the other channels work, and I kept the antenna position facing the same direction (east). i've messed with the aspect ratio with no effect.
thanks!
John in Avondale
John L 2 is offline
post #4511 of 4529 Old 09-23-2014, 10:37 AM
reds75's Avatar
Quoted: 90 Post(s)
Liked: 106
If your getting 25-1 ,you should also be able to get 12-1. I would try a rescan on your tv. if that doesnt work maybe move the antenna direction Slightly.
reds75 is offline
post #4512 of 4529 Old 11-14-2014, 10:18 AM
reds75's Avatar
Quoted: 90 Post(s)
Liked: 106
Strange to see Phil Amato on Fox 30 =47 news. I wonder why he left Wtlv-12? On another note abc25-1 still a Very weak signal ota here in southern Saint Johns county. It comes and goes.
Gator99 likes this.
reds75 is offline
post #4513 of 4529 Old 12-24-2014, 01:19 PM
reds75's Avatar
Quoted: 90 Post(s)
Liked: 106
channel 4 still king of local news ratings.
reds75 is offline
post #4514 of 4529 Old 12-26-2014, 01:25 PM
reds75's Avatar
Quoted: 90 Post(s)
Liked: 106
25-1 is just too weak. I hardly get it at all anymore.
reds75 is offline
post #4515 of 4529 Old 05-04-2015, 10:12 AM
reds75's Avatar
Quoted: 90 Post(s)
Liked: 106
The local network stations with Dish seem to have better Picture quality the last month or so. There is more sharpness and detail in the picture. Maybe less compression or newer equipment.
reds75 is offline
post #4516 of 4529 Old 06-16-2015, 10:31 AM
divinehawk's Avatar
Liked: 0
Anyone having signal issues with WPXC lately?
divinehawk is offline
post #4517 of 4529 Old 07-21-2015, 11:09 AM
reds75's Avatar
Quoted: 90 Post(s)
Liked: 106
In case anyone is interested channel 47 and channel 30 have added more sub channels. The picture quality has suffered a little. The programming seems to be old tv shows.
reds75 is offline
post #4518 of 4529 Old 05-27-2016, 03:33 PM
mvcg66b3r's Avatar
Quoted: 115 Post(s)
Nexstar Broadcasting Group today said it will sell five TV stations in four markets to comply with FCC ownership caps as part of its previously announced agreement to acquire Media General. Nexstar said it anticipates announcing additional station divestitures shortly.
Nexstar is selling WCWJ, the CW affiliate in Jacksonville, Fla. (DMA 47), and WSLS, the NBC affiliate in Roanoke-Lynchburg, Va. (DMA 69), to Graham Media Group for $120 million.
http://www.tvnewscheck.com/article/9...n-four-markets
This would give Jacksonville its third duopoly! Unless Graham plans to sell WCWJ in the auction.
James Calvin Woods - Son of Verta Jane Holland
mvcg66b3r is offline
post #4519 of 4529 Old 06-14-2016, 09:23 AM
Gator99's Avatar
Quoted: 74 Post(s)
Oh, how this thread has died since the early 2000's.
anyway hope all are well here in the Jax market.
thought I would see if anyone was interested in a row of three Irwin Marquee theater seats. selling as I have no need for them any longer, in fantastic shape and the platform is included if you would like it.
for more information see my craigslist post here, but please feel free to contact me on AVS.
https://jacksonville.craigslist.org/fuo/5581035419.html
Jeff G
Jeff
Gator99 is offline
post #4520 of 4529 Old 06-15-2016, 06:40 PM
fcakira's Avatar
Decided to do a re scan of the over the air channels. Got 55 channels. Including all the well known local channels and their sub channels, I also got the following.
18.1 Univision 18.3
20.1 BUZZR, 20.2 ESCAPE, 20.3 GRIT, 20.4 LAFF and 2 shopping channels
21.1 ION, 21.2 qubo, 22.3 ION LIFE, 21.4 SHOP
22.1 RETROTV, 22.2 A1A TV, 22.3 TUFFTV, 22.4 HEARTLAND, 22.5 REV'N, 22.6 FAM, 22.7 LATV, 22.8 SCHAPEL, 22.9 Q-RADIO
A lot of classic tv
Gator99 likes this.
fcakira is offline
post #4521 of 4529 Old 07-22-2016, 07:58 AM
reds75's Avatar
Quoted: 90 Post(s)
Liked: 106
I have lost 25-1 for 1 year now.
reds75 is offline
post #4522 of 4529 Old 11-11-2016, 06:14 AM
chadsmith013's Avatar
Quoted: 1290 Post(s)
Liked: 1181
if anyone is still in this area and still interested...
Any Jacksonville Florida HT people?
Gator99 likes this.
chadsmith013 is online now
post #4523 of 4529 Old 11-24-2016, 01:10 AM
mp12point7's Avatar
Yes. No.
mp12point7 is offline
post #4524 of 4529 Old 12-07-2016, 04:21 PM
Gator99's Avatar
Quoted: 74 Post(s)
By chance does anyone know when Comcast switched over to mpeg4, AVC ?
Sent from my Nexus 6 using Tapatalk
Jeff
Gator99 is offline
post #4525 of 4529 Old 03-01-2017, 04:57 AM
reds75's Avatar
Quoted: 90 Post(s)
Liked: 106
Still cant beat the picture quality of OTA vs cable or satellite . I do wish ABC 25-1 would up the power so I could get it consistently.
reds75 is offline
post #4526 of 4529 Old 04-13-2017, 07:09 PM
Hopefully you didn't try a fresh scan last night -- WJAX (47 virtual) and WFOX (30 virtual) went down at about 12:40am!
post #4527 of 4529 Old 08-13-2017, 03:30 PM
Liked: 0
Does anybody get WRCZ 35 and it's five sub channels over the air? It shows up using the tv listings on zap2it.com and tvguide.com. They have Cozi Tv and Comet Tv on its sub channels.
fcagaki is offline
post #4528 of 4529 Old 08-30-2017, 11:38 PM
One would have to be close to Jacksonville, not too far north or south: Zap2It's 32084 (St. Augustine) OTA doesn't list it, but 32082 (Ponte Vedra) does. Going north, 32041 (Yulee) doesn't list it. If you're looking to aim your antenna, it's in the same tower farm as WJAX-47 and WJCT-7, but with substantially less power. According to Wikipedia, "The station’s transmission tower is located in the Brackridge neighborhood of Jacksonville’s southeastern suburbs just off Florida State Road 115." (WJCT is on Hogan Road there.)
post #4529 of 4529 Old 09-04-2017, 05:24 PM
Liked: 0
I live in a neighborhood off Beach Blvd near 295. I'm about 3.27 miles the antenna farm. Don't get the signal. I wish they would increase the power. I'd love to watch Cozi TV. Dropped DirecTV and am using Tablo to record.
fcagaki is offline
