Greenville, SC - HDTV - Page 381 - AVS Forum | Home Theater Discussions And Reviews
 15Likes
post #11401 of 11404 Old 09-21-2016, 06:29 AM
rrainwater's Avatar
Quoted: 29 Post(s)
Liked: 27
Originally Posted by cpalmer2k View Post
Can anyone with Charter confirm for me whether the ESPN Goal Line/Buzzer Beater HD channel (816) is actually in HD for you or not? I have TiVo, and since July when they switched it over to SDV all I get is a standard definition picture on the HD channel.
I reported it a few weeks ago. They said there is no problem. There is no way to actually report this locally unfortunately. My guess is they will not fix it this season.
rrainwater is offline
post #11402 of 11404 Old 09-21-2016, 07:04 AM
cpalmer2k's Avatar
Quoted: 191 Post(s)
Just making sure the issue wasn't isolated to our area like it was last time. I work with someone whose spouse is a charter tech in the area. I'm passing it on to them. Maybe that will give some results.
cpalmer2k is offline
post #11403 of 11404 Old 09-21-2016, 04:50 PM
tylerSC's Avatar
Quoted: 633 Post(s)
Liked: 146
We always have problem with WLOS drop out on Charter 713. No other channels have problem, so 13 is also a problem on Charter as well as antenna. I wonder if Charter retransmits their OTA signal which can be problematic and subject to interference. Fortunately I have the antenna signal stable and reliable, but it took a bit of work and is a known issue in the Upstate.
tylerSC is offline
post #11404 of 11404 Old 09-22-2016, 07:19 AM
Liked: 0
I just checked. It's letterboxed and standard def. All they have up at the moment is a slate with the next event listed. I'll check it again when they some programming running.
rtripboy is offline
