Austin, TX - HDTV - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 32Likes
post #271 of 7194 Old 02-06-2004, 08:03 AM
bjenkins's Avatar
Originally posted by bonoc
OK, I have to admit TimeWarner is starting to look pretty damn sexy these days - has more HD than D*
I have contemplated making the jump in the past and have tried to come up w/ an estimate of the monthly $$. Here is what I would like:
Base digital package: 51.35
HBO: 10.95
HD Converter (2): 15.98
HD Package: 9.95
total w/o tax: 88.23
How correct is that estimate? Am I leaving anything out? How much is the average TimeWarner cable bill on this forum?
Thanks a bunch.
Base digital package w/ HD DVR: 34.95
HBO: 5.00
HD Converter (1): 7.99
HD Package: 9.95
total w/o tax: 57.89
that's what you'll be paying for your first year as long as you mention that your going to twc from satellite. all you'll need to do is provide a copy of your satellite bill. after the first year, your rate will go up to whatever the rate is at that time. hd dvr probably will be released next week (i'll believe it when it's in my living room ).
bjenkins is offline
post #272 of 7194 Old 02-06-2004, 01:32 PM
eddier's Avatar
My Sanyo Z2 has the same issue when using the DVI output to the 3250HD. The workaround is to "HOT PLUG" the DVI cable into the 3250 after both units are ON.
I believe the HOT PLUG firmware is working correctly.
You will have to do this every time you turn on ether the Z2 or the 3250.
Originally posted by mab34
Does anyone in Austin currently have a Sanyo PLV-Z2 projector hooked up to the Scientific Atlanta 3250HD set box thru the DVI output. Does it work or are you having HDCP compliance issues? I can't get it to work and the cable guys have been out twice with no luck. Thanks for any help/suggestions/experience.
eddier is offline
post #273 of 7194 Old 02-06-2004, 02:17 PM
RussellC's Avatar
The HD DVR won't be able to record HD content will it? If so, how big is the Hard Drive?
RussellC is offline
post #274 of 7194 Old 02-06-2004, 02:57 PM
RussellC's Avatar
Just look on Scientific Atlanta's site and it can record HD!!! AWESOME!!
RussellC is offline
post #275 of 7194 Old 02-06-2004, 03:12 PM
bjenkins's Avatar
not sure which hard drive the twc austin box will have, but there are two versions of the explorer 8000hd. one has an 80GB hard drive, the other 160GB. the 80GB will record 9 hours of HD programming and the 160GB will record 20.
bjenkins is offline
post #276 of 7194 Old 02-06-2004, 03:46 PM
eochs's Avatar
They have 1000 of the 160GB version
eochs is offline
post #277 of 7194 Old 02-06-2004, 04:41 PM
Darthnice's Avatar
And by Monday afternoon how many will they have?
Darthnice is offline
post #278 of 7194 Old 02-06-2004, 05:11 PM
mab34's Avatar
Well I solved the DVI problem by getting the Pace box. No problems at all. I do however want to know when the 8000HD releases, I get the impression it's Monday?
mab34 is offline
post #279 of 7194 Old 02-06-2004, 05:36 PM
billfAustin's Avatar
I went by Time Warner today (Friday) and they claimed they aren't available for a couple more weeks. Has anyone not in the beta program actually gotten one?
billfAustin is offline
post #280 of 7194 Old 02-06-2004, 05:40 PM
mab34's Avatar
how do you get in the beta program???
mab34 is offline
post #281 of 7194 Old 02-06-2004, 10:35 PM
minivette's Avatar
I upgraded to the HDNET, INHD tier from TIme Warner tonight. So far, it's... ehhhh. Nothing to write home about.
If I don't like it after a month or so I'll cancel. However, I did enjoy the Cage fighting match. That was almost worth the $9.95 upgrade.
minivette is offline
post #282 of 7194 Old 02-07-2004, 01:18 PM
barled's Avatar
It is possible that your TV really doesn't support HDCP...but most likely just the bug that several of us have (that TWC is aware of). It works fine on some TVs.
Does it work if you unplug the cable and then plug it back in again? If so, you will find that it continues to work until you turn the cable box off or either change channels or view the "guide"...at which time it stops working again.
Hopefully SA will give us a fix....someday.
Barry
barled is offline
post #283 of 7194 Old 02-07-2004, 01:22 PM
hinesw's Avatar
Just yesterday got this hooked up to my projector (Z2) and cannot get it to work thru the DVI output. It tells me that my HDTV is not HDCP compliant, but I don't think this is true.
I have the same problem. You pretty much have to do a soft reboot of the cable box every time you turn your tv on. A hard reboot (unplugging it) won't work. It's such a pain in the ass that I switched back to component inputs.
To do a soft reboot, hold the pause button down until your mailbox light starts flashing, hit page down, then hit stop 4 times.
hinesw is offline
post #284 of 7194 Old 02-07-2004, 01:44 PM
mab34's Avatar
Thanks everyone for your responses. TWC provided a Pace box for me and that solved the issue. I am now able to use the DVI output successfully. I think this may already have been mentioned, but the cable guy who came to my house said that they have the 8000HD DVR in the warehouse. I guess it's only a matter of days before it is released. Hopefully the HDCP issues will be worked out, we'll see...
mab34 is offline
post #285 of 7194 Old 02-07-2004, 07:51 PM
utstimpy's Avatar
re: the 8000HD
Should be able to pick it up on Monday after 4pm at the front desk. (the front desk closes at 6, FYI)
The money pit:
$3800 spent sofar :p
utstimpy is offline
post #286 of 7194 Old 02-08-2004, 01:25 PM
mab34's Avatar
Good news! How did you find out? Do you happen to know if DVI will be enabled right away?
mab34 is offline
post #287 of 7194 Old 02-08-2004, 01:50 PM
eochs's Avatar
We were able to talk Peter at TWC into releasing it late Monday instead of waiting until Tuesday... DVI is not enabled yet, but probably in a few weeks or so...
eochs is offline
post #288 of 7194 Old 02-08-2004, 03:40 PM
J9_ls1's Avatar
So, we can actually get the 8000 on Monday after 4pm? That is great news!
J9_ls1 is offline
post #289 of 7194 Old 02-08-2004, 04:09 PM
eochs's Avatar
yes, it is true... I was selfishly hoping that nobody would post about that here though, as the line will already be long enough
eochs is offline
post #290 of 7194 Old 02-08-2004, 04:16 PM
mab34's Avatar
When they do enable the DVI port will it be something (a firmware update?) that they can do remotely?
mab34 is offline
post #291 of 7194 Old 02-08-2004, 04:56 PM
J9_ls1's Avatar
Do you have to pay extra for this box? Or is it a free swap out.
J9_ls1 is offline
post #292 of 7194 Old 02-08-2004, 05:29 PM
eochs's Avatar
Yes, it will be a firmware upgrade.
The box will cost the same as the normal DVR box, something like $10 a month more...
eochs is offline
post #293 of 7194 Old 02-09-2004, 11:19 AM
live4ever's Avatar
Is anyone else experiencing an audio drop out problem on HBO-HD ? Whenever I watch this channel every minute sometimes more frequently the sound drops for a sec then comes back. On the regular version of HBO, no problems as is the case for all the other channels including InHD 1/2 etc.
I've already had a TW service rep visit who replaced the 3250HD box with another, I've also went through both coax and optical and the same results.
Thanks for any insight/suggestions.
live4ever is offline
post #294 of 7194 Old 02-09-2004, 11:47 AM
RussellC's Avatar
I just got the HD DVR box at TW, so go pick yours up!!
RussellC is offline
post #295 of 7194 Old 02-09-2004, 01:01 PM
Sardonumsei's Avatar
I have a question about the TW HD DVR. I use the 3250HD right now and have it connected to both a HD projector and an SD set for when I don't want to use the projector. The SD set it connected with the composite outputs. I have read on other threads that the composite and s-video outputs are not functional on the HD DVR. Can someone confirm that on the Austin HD DVR? I would like to know before I switch.
-S
Sardonumsei is offline
post #296 of 7194 Old 02-09-2004, 01:36 PM
eochs's Avatar
Picked mine up right around 12:45 or so... Good stuff... We desperately need the next firmware update for the box though... The firmware on the 8000HD that I got does not allow you to do the pass-through like the 3250HD... If I have the box set to 1080i, go to an SD channel, and press # to stretch it out to fill the tv, everything works fine... If I then switch to an HD channel the picture is still stretched though... This is not how it worked with the 3250HD... Hopefully this will be fixed when we get the DVI enabling firmware...
eochs is offline
post #297 of 7194 Old 02-09-2004, 01:38 PM
Aus10Tech's Avatar
Just picked up one up from TW hooked it up,called to get it activated and was told that there was some "Head End" Problems. I was told to wait an hour or so to see if box starts working. Anyone else having this problem?
thanks.
Aus10Tech is offline
post #298 of 7194 Old 02-09-2004, 01:41 PM
Animgif's Avatar
I'm debating whether it's worth the extra $20/month it'll be for me to add it...hrmmm...
Animgif is offline
post #299 of 7194 Old 02-09-2004, 01:44 PM
utstimpy's Avatar
Hmm, I was under the impression that pass thru was already enabled on the 8000HD. That's disappointing.
Owell, hopefully it will be enabled along with the DVI which should only be ~2 weeks. I can handle that.
The money pit:
utstimpy is offline
post #300 of 7194 Old 02-09-2004, 03:48 PM
atyclb's Avatar
-S
my S-video out is not working. also, if you are using the component out, there isn't even an composite video out available to use.
atyclb is offline
