Austin, TX - HDTV - Page 233 - AVS | Home Theater Discussions And Reviews
 7Likes
post #6961 of 6983 Old 01-11-2015, 07:44 PM
austinsho's Avatar
Quoted: 20 Post(s)
Originally Posted by dtv_junkie87 View Post
Hello Austinites!
I just wanted to say that come January 20, you will be without a weather subchannel; KVUE is replacing the weather info on 24-3 with the new Justice Network:
Yep....one less reason to screw with 24.anything .
To the world, you are just a person. To a rescue dog, you are the world!
http://www.austinpetsalive.org/ - local in Austin
http://adopt-a-small-dog.adoptapet.com/ - national
austinsho is online now
post #6962 of 6983 Old 01-20-2015, 04:17 PM
T-Techster's Avatar
New sub-channel coming this summer. Buzzr TV
http://tvradio.blog.austin360.com/20...air-in-austin/
Cabal0 likes this.
T-Techster is offline
post #6963 of 6983 Old 01-20-2015, 05:31 PM
sivartk's Avatar
How much revenue do they make from these subchannels? How much quality are we sacrificing to the main HD Channel? Will HDTV go the way of music (I.e. mp3's)...where 720p/1080p regardless of bitrate is acceptable?
At no point in your rambling, incoherent post were you even close to anything that could be considered a rational thought. Everyone in this forum is now dumber for having read it.
My Little Theater
sivartk is offline
post #6964 of 6983 Old 01-20-2015, 09:01 PM
austinsho's Avatar
Quoted: 20 Post(s)
I don't think so....when ATSC was in the crib, Rupert Murdoch said he intended to do NO HDTV, but instead split his 6 mhz up into multiple subchannels. He was informed by several honchos in Congress that if he did that, they'd see that he didn't get any digital spectrum. Of course, Congress has recently become much more bidness-friendly, but Fox's 720p is here to stay.
post #6965 of 6983 Old 01-20-2015, 09:01 PM
austinsho's Avatar
Quoted: 20 Post(s)
I wonder if DirecTV folks will even see this one! It didn't add either 62.3 or 62.4.
post #6966 of 6983 Old 01-22-2015, 08:19 PM
Cell247's Avatar
Hi. Does anyone in central Austin, Brentwood/Crestview area get Kbvo or any of the Kcwx channels? As of today I can pick up a new station to me, Retro TV using a Mohu Leaf.
Cell247 is offline
post #6967 of 6983 Old 01-22-2015, 09:21 PM
austinsho's Avatar
Quoted: 20 Post(s)
Not seeing anything new here, near Slaughter and Manchaca Road. I've got an outside Clearstream 2V pointed directly north. What's the channel number for that RetroTV that you're seeing?
post #6968 of 6983 Old 01-22-2015, 10:28 PM
Cell247's Avatar
17-5 RTVE
And another new one to me:
17-6 REVN
Revin as in cars. It shows car stuff all day. I really want KBVO and KCWX which is 2 2.1 and 2.2.
Cabal0 likes this.
Cell247 is offline
post #6969 of 6983 Old 01-23-2015, 07:34 AM
austinsho's Avatar
Quoted: 20 Post(s)
OK, that's going to be KVAT-LD, licensed to Garfield. That's down southeast of the airport.
As for KBVO, it's coming. Right now it's only a light bulb (75 watts), but KXAN has a license to upgrade it to about 13,000 watts IIRC, so hopefully it will soon cover most of Austin, as opposed to about three feet around it's current transmitter.
As for KCWX, its digital signal is on channel 5, so it must have faced many of the challenges that KTBC had in getting ATSC to run properly over VHF. Wiki reports that it has filed an application with the FCC not only for a power increase from 24kW to 83kW, but also has applications in for fill-in translators in both San Antonio and Austin. There appears to have been an application for a delay in construction of this facility ( http://data.fcc.gov/mediabureau/v01/...n/1654171.html ). The owners apparently want to make sure that if they build it, it won't be shut down after the repacking process, where the FCC is trying to reclaim spectrum.
Cabal0 likes this.
post #6970 of 6983 Old 01-23-2015, 09:29 AM
xnappo's Avatar
Quoted: 30 Post(s)
Liked: 54
Hi All,
I have a Ceton tuner card with TWC - for maybe the last three weeks 'channel 12' has been tuning the SD version.
Any advise?
xnappo
xnappo is online now
post #6971 of 6983 Old 02-03-2015, 11:10 AM
Cabal0's Avatar
Originally Posted by Cell247 View Post
17-5 RTVE
17-6 REVN
Happy to report I'm getting these clearly in Pflugerville (Falcon Pointe), although Retro TV doesn't seem to have listings yet on Schedules Direct (email sent), and Rev'n has aspect ratio issues (horizontal squish) with some content.
Also, 24-3 KVUE-DT3 (as mentioned) has changed from AccuWeather to the Justice Network (murder porn). My wife is happy about that one.
Cabal0 is offline
post #6972 of 6983 Old 02-03-2015, 05:30 PM
sivartk's Avatar
With an attic antenna in SE RR (not too far from Falcon Pointe), I can't pick up 17-X. Although I can pick up 2.1/2.2 (KCWX) out of San Antonio
My Little Theater
sivartk is offline
post #6973 of 6983 Old 02-03-2015, 06:36 PM
Cabal0's Avatar
That's weird, it doesn't look like there's much special to it other than being a low-power channel: http://www.tvfool.com/?option=com_wr...&q=call%3dKVAT . Perhaps a terrain issue? It looks to waver from green to purple on that signal map in the 45/130 area, depending on location.
I'm also using an attic antenna with a low-noise preamp, fairly standard setup.
Cabal0 is offline
post #6974 of 6983 Old 02-03-2015, 06:50 PM
sivartk's Avatar
My street is purple even though I'm at one of the higher points in the neighborhood on the side of a hill (probably what is blocking the signal)
My Little Theater
sivartk is offline
post #6975 of 6983 Old 02-04-2015, 08:12 PM
Cabal0's Avatar
Anyone having signal issues tonight? As best I can tell my equipment is all in working order, but I can't pull in any signal from KLRU (PBS), KVAT (17.x), KXAN (NBC), or KNVA (CW). ABC, CBS, Fox, Fox Killeen, and TSTV (29.x) are all fine.
Cabal0 is offline
post #6976 of 6983 Old 02-04-2015, 08:24 PM
austinsho's Avatar
Quoted: 20 Post(s)
Yes...a major power failure in Westlake has knocked out much of Austin TV over the air, and over satellite as well. Only Time Warner Cable, which has a direct link, is working.
Cabal0 likes this.
post #6977 of 6983 Old 02-05-2015, 08:37 AM
bswiz's Avatar
Quoted: 24 Post(s)
Glad to hear it wasn't just me with issues. I was worried my antenna spontaneously combusted or a squirrel ate through my coax or something!
Haven't checked things this morning but I assume all is back to normal.
bswiz is online now
post #6978 of 6983 Old 02-05-2015, 10:24 AM
Cabal0's Avatar
Cool, thanks for the info. Everything was back to normal for me this morning.
On the previous discussion of new channels, it looks like Schedules Direct has updated with guide data for 17-5 Retro TV, for anyone that helps (besides me).
Cabal0 is offline
post #6979 of 6983 Old 02-05-2015, 10:28 AM
austinsho's Avatar
Quoted: 20 Post(s)
Yea, now all I need is for them to change their bloody pattern so that SW Austin is NOT excluded!
post #6980 of 6983 Old 03-01-2015, 10:59 AM
julbrich's Avatar
Liked: 0
Does anyone know the physical QAM Sub Channel for ABC (KVUE) in Austin, Tx on TWC?
I have found the other major networks HD channel but cannot find the sub channel for main ABC channel in HD.
ABC in SD is 20.3.
FOX = 6.61
NBC = 15.2
CBS = 23.1531
ABC = 23.?
julbrich is offline
post #6981 of 6983 Old Yesterday, 09:04 PM
Liked: 0
I live in the Rundberg / Lamar area and can get 17-3 SBN, 17-5 RTVE, 17-6 REVN, 29-1, 29-2, 29-3 (all UT stations), 61-1 Spanish, 62-2 Spanish, 62-3 GetTV, 62-4 Escape
I also get the channel 19's you mentioned but removed them. I've heard KBVO is changing frequencies and power this month (unless it slips again). When it is complete, all of Austin should be able to receive it OTA according to the Engineer.
beastman59 is offline
post #6982 of 6983 Old Yesterday, 09:25 PM
Liked: 0
[quote=T-Techster;31003329]New sub-channel coming this summer. Buzzr TV
May 31, 2015 according to Wikipedia
post #6983 of 6983 Unread Today, 03:41 PM
austinsho's Avatar
Quoted: 20 Post(s)
A bit of news from KXAN....
KBVO should have it's (relatively) high power signal on by the end of the day Friday IF the weather cooperates. If not, then early next week.
KNVA is about to light up its .2 again. This time look for COZI-TV to show up there. That's great news for those of us who like old TV shows. Everything from Miami Vice to the original Avengers. Date on this...on or about April 1.
http://www.cozitv.com/shows/weekday/
