Duluth, MN - HDTV - Page 8 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
Old 05-19-2014, 09:47 PM
veedon's Avatar
Quoted: 597 Post(s)
Liked: 324
Originally Posted by denyart View Post
he said in the original post he had a 4221. There are no VHF elements n a 4221. It is a UHF antenna. That was my main point.
You're right. It is marketed as just a UHF antenna.
I don't know much about antenna design. What is the purpose of the rod-like elements on the 4221, the ones that are paired in an X configuration? The main part of the antenna is just a grid, but there are a few rod-like pieces.
veedon is offline
Old 05-19-2014, 10:08 PM
kokigami's Avatar
well, perhaps I have led you all astray. I appreciate the assistance by the way. My earlier guess at being a 4221 was wrong. It dawned on me that I have probably bought the antenna via Amazon, so I looked in my purchase records. It is this  antenna.,. purchased in 2008. So, perhaps not as good.. probably not, I would guess. Not sure of the shelf life of an antenna..
Will, if weather permits, climb up tomorrow and take a look at the Balun, a term I just googled so I know what to look for.. btw..
The internet is an prosthetic for my brain..
But I am thinking this may be a good time to update the antenna..
kokigami is offline
Old 05-20-2014, 04:25 AM
ProjectSHO89's Avatar
Quoted: 182 Post(s)
Liked: 101
The x-shaped parts are the actual active elements of the antenna are what actually receives the signals. The grid is a reflector which works much like a mirror would for light.
If you have a two-bay DB2-type antenna, that would explain the problem with VHF reception. The Db2 is pretty nearsighted on VHF and it doesn't take much in the way of local interference or signal obstruction to wipe out what little VHF reception it might have offered.
ProjectSHO89 is offline
Old 05-20-2014, 06:32 PM
veedon's Avatar
Quoted: 597 Post(s)
Liked: 324
I was looking at the many different designs of outdoor antennas, and it struck me that the very largest (and purportedly longest range) antennas that have both VHF and UHF capability have designs very much like what I remember from twenty or more years ago, which did not include reflector grids.
Is the use of reflector grids intended to allow the antennas to be somewhat smaller than in the olden days without sacrificing performance? I also noticed that some of the smaller antennas have more elements than the big, old-fashioned antennas.
veedon is offline
Old 05-20-2014, 06:56 PM
denyart's Avatar
I am not an expert on this myself, but I believe they may catually be designed to reflect signals back onto the antenna elements in phase as well as block signals coming from behind the antenna. If you look at the signal pattern for these antennas and compare it to the same X or bowtie antenna without that grid the one without looks like a bi-pole (or dipole?). One thing this can greatly improve on (this grid) is minimizing multipath interference. It was believed by many RF engineers that multipath was going to be a more significant issue with digital TV than it was with analog transmission. Multipath, as well as the propensity of temporary UHF digital transmission, were key reasons so many 4221 style antennas were on the market and poplar.
Win7Ult x64:P8Z77V Deluxe, 8GB DDR3, ATI 6670, i5-3570k, 3 Ceton InfiniTV4 PCIe, Hauppauge 2250, Fractal Arc Midi SSP
denyart is offline
Old 05-22-2014, 09:08 AM
denyart's Avatar
If you determine the weather conditions there are deteriorating your connections (it's not a salt-water lake, so I doubt it, but you never know...) you may consider getting a "boat" antenna. They're kind of a specialty item, and I am not sure how well they work, but here is an example of one that is VHF-UHF and has "good numbers". NOTE: that is just an example. I believe that particular one is using a European 230V 50Hz power supply, so you wouldn't want that exact one unless the power supply would accept US AC 110-120V 60Hz. It is just the idea for a more durable antenna that I wanted to convey. I have also had good luck with the "Metrostar" sealed antenna, but it would kill your reception if you had multipath. Something much more directional helps a ton with reducing multipath (delayed signals being received from nearby reflections, water, water towers, large metal buildings, airport structures, perhaps this city-county thing you are referring to, etc)
denyart is offline
Old 06-03-2014, 03:42 PM
bradhasbrouck's Avatar
Here is the list of FOX21 Translators stations that will likely convert to digital television after September 1, 2015?
K15GT-Hibbing
K47IR-Virginia
K29EB-Grand Rapids
K45JD-International Falls
W45ZI-Ashland
bradhasbrouck is offline
Old 06-05-2014, 02:30 PM
Once the FCC Approves the sale of KBJR-DT and KRII-DT to Quincy Newspapers.
However, All TV Stations in Wisconsin which is owned by Quincy Newspapers
carries ThisTV on a digital subchannel.
Therefore, Is there a chance KBJR-DT and KRII-DT will add ThisTV on a digital subchannel
after the KBJR/KRII is sold to Quincy Newspapers?
Old 06-05-2014, 03:09 PM
unclehonkey's Avatar
Quoted: 165 Post(s)
Liked: 32
The FCC is looking into duopolies so its possible the sale may not go through
possibly. But not on KRII as there is already too many stations on it
unclehonkey is offline
Old 02-04-2015, 04:00 PM
Is there a chance KQDS-DT could be adding a digital subchannel such as BUZZr TV Network and Antenna TV sometime in the near future?
Old 02-04-2015, 09:45 PM
Quoted: 165 Post(s)
Liked: 32
doubt it. They are cheap and would rather put their money into the radio business. The TV is an afterthought. In fact the only station of their cluster that has a subchannel is KDLT in Sioux Falls. They have Cozi
Old 06-03-2015, 03:28 PM
Is there a chance KCWV-TV (Channel 27.1) return to the air with a new tower by the end of this year?
Old 08-01-2015, 06:45 AM
slinger45's Avatar
Quoted: 45 Post(s)
Liked: 40
I know this thread is pretty dead these days but I'm selling my Samsung 72" HLT7288w if anyone is interested. Pm me
slinger45 is offline
Old 08-31-2015, 06:45 AM
Quoted: 33 Post(s)
Question Broadcast Outage?
Does anyone know of a broadcast outage in the Duluth area? I lost all my stations last night at the same time. I troubleshot everything in my system and found no problems. But I haven't been able to find any news online of a power outage at the Antenna Farm in Duluth or anything. Anybody know?
Then to add to things and make me feel like I'm going crazy, I wake up this morning and the local cell tower is down as well as my century link internet service. When it rains it pours...
Update: I heard it could be due to solar flares. Could also be the reason for the local internet and cell outages. Makes sense.
alex_ajb is offline
Old 09-01-2015, 09:58 AM
agus0103's Avatar
Was anybody else watching KQDS at 8 this morning? The local news ended at that time as usual, but instead of going on to Right This Minute, the next regularly scheduled program, a MeTV slate was broadcast along with audio of MeTV promos. This stayed on air for about a minute and a half, at which time Right This Minute began from the start.
Seems to me like somebody might have pushed a wrong button in the control room at KQDS or KVRR, but that's sort of beside the point. The bigger question is why, since no Red River Broadcasting property broadcasts MeTV, would MeTV even be on in the control room in the first place?
agus0103 is offline
Old 10-23-2015, 10:48 AM
Quoted: 165 Post(s)
Liked: 32
AntennaTV coming to KQDS "soon" per the AntennaTV site
bradhasbrouck likes this.
Old 11-16-2015, 02:09 PM
Is there a chance Charter Communications will add KQDS-DT2 (ANTENNA TV) when it launches on
January 1st?
Old 11-16-2015, 02:57 PM
Quoted: 165 Post(s)
Liked: 32
as Jon said over at northpine when you asked the same thing
Haven't heard either way, but cable companies usually do not carry new broadcast DTV subchannels when they first launch. Wouldn't be surprised if it's added later.
Old 11-17-2015, 01:24 PM
weekendtoy's Avatar
Quoted: 170 Post(s)
Liked: 100
I see channel 27.1 is back on the air.
I reject your reality and substitute my own.
weekendtoy is offline
Old 11-17-2015, 10:03 PM
Quoted: 165 Post(s)
Liked: 32
yup been on for about 2 months now
Old 12-25-2015, 09:06 AM
Is there a chance KDLH-DT could be adding a few digital subchannels such as Decades, Heroes & Icons and Buzzr sometime
next year?
Old 12-25-2015, 09:07 AM
Quoted: 165 Post(s)
Liked: 32
next year?
probably not.
taboola here
