Traverse City, MI - HDTV - Page 40 - AVS Forum | Home Theater Discussions And Reviews
post #1171 of 1760 Old 06-12-2009, 10:43 AM
Kamakzie's Avatar
Originally Posted by Mesickstan View Post
WWTV's tower is in Osceola county. WPBN/WTOM & WGTU/WGTQ will switch over after the Stanley Cup game tonight.
So its not a fluke that I'm receiving it? Before when it was on D40 I had to aim the antenna that way.
Kamakzie is offline
post #1172 of 1760 Old 06-12-2009, 10:54 AM
Mesickstan's Avatar
Here's a link to their coverage map : http://www.fcc.gov/fcc-bin/FMTV-serv...DT1248732.html
Mesickstan is offline
post #1173 of 1760 Old 06-12-2009, 11:54 AM
Kamakzie's Avatar
Wow that is a huge coverage map. It goes well south of me.
Kamakzie is offline
post #1174 of 1760 Old 06-12-2009, 01:08 PM
falcon7's Avatar
I was at my folks' place this morning for the switch over and they are west of TC (between Cedar Run and N. Long Lake). They were getting ch. 40 at 70-75% on a good day and 40% and major break ups on most days. They're now getting 9 at over 90% strength. How was your reception of 9 analog?
Stan, analog was snowy....and I am north and west of Cedar Run in Leelanau County .....so far no 9 or 33....I am OK as I have satellite, but many of my neighbors depend on OTA and just trying to help them.
Edit.....I can assure you that coverage map is not accurate
falcon7 is offline
post #1175 of 1760 Old 06-12-2009, 01:32 PM
SonyLCD's Avatar
When did you try to scan Falcon7? WWTV has been off since 12:30PM to do some tower work. They said they would be back on between 4 and 5pm.
SonyLCD is offline
post #1176 of 1760 Old 06-12-2009, 01:37 PM
Mesickstan's Avatar
What kind of antenna are you using? Rabbit ears won't cut it. My Dad has a VHF up in the rafters.
post #1177 of 1760 Old 06-12-2009, 02:51 PM
Kamakzie's Avatar
Oh so digital 9 is off the air?
Kamakzie is offline
post #1178 of 1760 Old 06-12-2009, 05:08 PM
cire2282's Avatar
What did they mess up over at WWTV? It has been out for several hours now and they are not giving a ETA on the fix.
cire2282 is offline
post #1179 of 1760 Old 06-12-2009, 05:46 PM
Kamakzie's Avatar
Wow not off to a good start WWTV.
Kamakzie is offline
post #1180 of 1760 Old 06-12-2009, 07:11 PM
Mesickstan's Avatar
They have tower guys there today to do work in preparation of moving FOX to ch. 32. Channels 9 and 32 will be on the same tower. Things didn't go as planned and the work is taking longer than expected.
post #1181 of 1760 Old 06-12-2009, 07:32 PM
Kamakzie's Avatar
Wonder why they got it up this morning and then they took it down again. Suffice it to say they probably aren't working on it further till tomorrow.
Kamakzie is offline
post #1182 of 1760 Old 06-12-2009, 08:04 PM
cire2282's Avatar
Son of Monte Cristo is on PBS. Enjoying watching that.
cire2282 is offline
post #1183 of 1760 Old 06-12-2009, 08:53 PM
larkor's Avatar
Channel 9 and 29 are on the air.
larkor is offline
post #1184 of 1760 Old 06-12-2009, 09:18 PM
larkor's Avatar
Oops! 29 is off again.
larkor is offline
post #1185 of 1760 Old 06-12-2009, 09:50 PM
Kamakzie's Avatar
Yup 9 is back here. Is 29's signal as strong as 9's?
Kamakzie is offline
post #1186 of 1760 Old 06-12-2009, 09:58 PM
larkor's Avatar
Here in Traverse City, near Best Buy, 29.1 is 97 (out of 100) an 9.1 is 84.
larkor is offline
post #1187 of 1760 Old 06-12-2009, 10:17 PM
Mesickstan's Avatar
17, 29 & 47 are on a tower in Kalkaska county. That would be quite a haul to get to you.
post #1188 of 1760 Old 06-12-2009, 10:19 PM
Kamakzie's Avatar
Yeah I'm just tickled pink that it appears that 9 and its sub-channel will work here. That way if WWMT does some kind of a preemption I can still get 9.
Kamakzie is offline
post #1189 of 1760 Old 06-12-2009, 10:27 PM
Mesickstan's Avatar
All channels: 7, 9, 17, 29 & 47 at 100% on a Channel Master 7000 converter. Roof mounted Winegard YA-1713 VHF and CM 4228 UHF antennas; CM 7777 preamp.
post #1190 of 1760 Old 06-12-2009, 10:47 PM
knightc2's Avatar
Just rescanned and lost all but 33.1...WTF?
I originally was getting all three stations at the Kalkaska tower farm and now PBS and ABC are gone. Only 5% signal for 29.1 and nothing for PBS. 9, 10 and 7 are only at 5% as well but I knew they were going to be tough to pull in especially since I am using a homemade UHF coat hanger antenna at the moment.
knightc2 is offline
post #1191 of 1760 Old 06-13-2009, 06:13 AM
SonyLCD's Avatar
Good Morning Forumites,
I thought that WPBN was keeping channel 50 on the air..but it was gone this morning. Also, is anybody getting WGTU or are they still off the air?
SonyLCD is offline
post #1192 of 1760 Old 06-13-2009, 06:36 AM
Mesickstan's Avatar
Work is still being done on 29 and PBS goes off the air at midnight. You'll need a VHF antenna now for 7 & 9.
post #1193 of 1760 Old 06-13-2009, 06:39 AM
Mesickstan's Avatar
50 is working for me. I'm recording off it as Tivo's guide hasn't caught up with the all the changes, yet. Yes, WGTU is down again.
post #1194 of 1760 Old 06-13-2009, 06:53 AM
pianomany2k's Avatar
Nothing wrong with coat hangers!
Wonder if my amplified rabbit ears will pick up anything in my direction with a decent signal...
pianomany2k is offline
post #1195 of 1760 Old 06-13-2009, 07:21 AM
knightc2's Avatar
I'll try it later today and see what I get. I know I need VHF for 7 and 9 but I did get them in analog, albeit very poorly, before the switch with my cardboard and coat hanger antenna. I though that I at least might have a chance. My homemade antenna is similar to the Channel Master 4221 so it can pick up high band VHF. EDIT: I looked and the 4221 performance and it isn't so hot at VHF. The 4228 is much better at high band VHF and that was the one I was thinking of. That would explain the poor VHF although I did get snowy analog so again, I though I had a decent chance.
I also have a Terk HDTV amplified antenna and a cheap monoprice.com antenna to try out as well. I am going to buy a high gain VHF or combo antenna at some point but wanted to wait and see what the switch over would bring before I invested in anything.
knightc2 is offline
post #1196 of 1760 Old 06-13-2009, 08:55 AM
Kamakzie's Avatar
Is 9 off again or is it just me?
Kamakzie is offline
post #1197 of 1760 Old 06-13-2009, 08:59 AM
Mesickstan's Avatar
They're up.
post #1198 of 1760 Old 06-13-2009, 09:13 AM
Kamakzie's Avatar
They're up.
Guess it was a fluke for me yesterday with the antenna pointed towards Grand Rapids and still picking it up.
Kamakzie is offline
post #1199 of 1760 Old 06-13-2009, 03:26 PM
cire2282's Avatar
The switch wasn't the greatest for me. All I get now is CBS, FOX (9.1,9.2), and PBS(21). Lost ABC(13) and can't get NBC(7) still. I did get it some last night, but I am guessing it will be a constant struggle. Been gone all so do know if they worked on it at all today. Hopefully in a month or so, I will be able to get a VHF antenna that will work set up in my room. Renting and therefore can't put it on the roof.
cire2282 is offline
post #1200 of 1760 Old 06-13-2009, 05:22 PM
falcon7's Avatar
using an all-channel stacked antenna. most of these people have no intention of putting the money into a tower and large yagi on a motorized mount. ...just not worth it. I cannot understand why 9 and 33 just ignored a lot of their northern viewers.
falcon7 is offline
