Roanoke, VA / Bluefield, WV - HDTV - Page 206 - AVS | Home Theater Discussions And Reviews
 1Likes
post #6151 of 6157 Old 12-03-2014, 10:24 AM
eacalhoun's Avatar
Quoted: 14 Post(s)
Originally Posted by Trip in VA View Post
Ouch. If they have no fiber to cable and satellite companies, then a catastrophic failure in the transmitter would take them out across the board. Wonder what happened. Seems like the wrong time of year for a lightning strike.
Not really related, but I have never thought WOAY had its transmitter in a good location--the tower WSWP is on seems like a much better location.
http://www.rabbitears.info/tvdx/sign...tuner1/WBRA-TV
- Trip
I actually thought WSWP was on Flat Top (near Winterplace Ski Resort on the Mercer/Raleigh County line), but I looked and it's ENE of Beckley. Is there ANY TV on Flat Top? I know WJLS-FM is on Flat Top.
Eric Calhoun
"If it was simple, anyone could do it" - Roy Clark from Hee Haw
eacalhoun is offline
post #6152 of 6157 Old 12-03-2014, 10:37 AM - Thread Starter
Trip in VA's Avatar
Quoted: 144 Post(s)
Liked: 75
Send a message via AIM to Trip in VA Send a message via Yahoo to Trip in VA
To my knowledge, there is no TV on Flat Top.
Here's a coverage map for WJLS-FM: http://www.rabbitears.info/contour.p...Y&appid=291082
And here's what 1000 kW on channel 25 would look like from Flat Top: http://www.rabbitears.info/contour.php?appid=317&map=Y
- Trip
eacalhoun likes this.
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is online now
post #6153 of 6157 Old 12-08-2014, 11:32 AM
eacalhoun's Avatar
Quoted: 14 Post(s)
WOAY Apparently Still Off the Air -
This is simply amazing, but sad. According to FB posts, ABC-affiliated WOAY in Oak Hill-Beckley is still off the air - for almost 2 weeks now. Think of all the lost revenue from Christmas advertising. No doubt, WVNS (CBS/FOX) and WVVA (NBC) have picked up some local news viewers.
Eric Calhoun
post #6154 of 6157 Old 01-08-2015, 11:10 AM
lburgguy's Avatar
I have a quick question here. I have a DB-4 on my roof here in Lynchburg aimed at Poor Mountain and I get all of the four majors just fine (54 miles away!!). I'd like to add an antenna to pick up WBRA, I'm guessing it's called a dipole?? I'd then join the two antenna inputs. Could someone point me to a cheap/quick/easy solution? Thanks in advance!
lburgguy is offline
post #6155 of 6157 Old 01-08-2015, 12:06 PM
bernieoc's Avatar
Quoted: 27 Post(s)
I know you are all tired of CH3 questions - but maybe I have missed something.
I am in Altavista - high end of town - get all Roanoke/Bedford channels perfect with a UHF and a channel 3 only antenna joined in the attic.
Channel 3 is perfect - except when it is not - Every night at approximately 6:10 PM terrible horizontal interference occurs - lasts about 15 minutes. We also record a lot of channel 3 and many of the recordings have the same 15 minute breakups. These are usually evening shows. It has also happened in the morning with children's shows when we happen to tune to the, but did not pay attention to them.
Question - do I have a neighbor running some electrical equipment regularly for 15 minutes?
I know I can not control external stuff - but is there anything I can do to filter/clean the signal - or could I send $100 to PBS and ask them to switch to a UHF channel.
I do not expect a solution - just had to say it.
Bernieoc
bernieoc is offline
post #6156 of 6157 Old 01-16-2015, 07:16 PM
DixieGent's Avatar
Lowband VHF Yagi TV Antenna Channels 2-6
What I use is a low band VHF antenna such as the AntennaCraft Lowband VHF Yagi TV Antenna Channels 2-6(Y5-2-6) available from Solid Signal for $30. It's a low cost solution if your existing antenna has the connections for an add on antenna. Also, your amp must be compatible with VHF. Be forewarned, low band VHF antennas are LARGE. Hope this helps.
DixieGent is online now
post #6157 of 6157 Unread Today, 05:59 PM
DixieGent's Avatar
WSET Data Stream and Dish ViP 622 OTA Reciever
I have OTA reception of WSET, as well as through Dish Network. OTA reception of WSET fed direct from the antenna into my Sony Bravia HDTV is perfect. However, when fed through the ViP 622 receiver, I get lots of skipping, breakups, and voice sync issues. The WSET HD reception direct from Dish is also experiencing skipping and breakups, but not as bad as from the OTA feed. Of course I have rebooted many times, checked the cables, etc. and tried to research the problem on the Intetnet. All other channels are OK.
Is anyone else with Dish locals experiencing this on WSET? This just started in the past couple of weeks.
One post from 2006 on DBSTalk, with a similar issue, implied this type of problem maybe "...something being dropped in the data stream that Dish tuners could not compensate for."
Thanks for any feedback.
