Grand Rapids, MI - HDTV - Page 268 - AVS Forum | Home Theater Discussions And Reviews
Old 02-13-2014, 01:23 PM - Thread Starter
bonscott87's Avatar
Thanks.  Don't know why then that WMC isn't picking up the guide data for 50-1 or 50-2.  Kamakzie, 15.1 doesn't come in at my location so doesn't show up in the guide so I don't know if it has full/proper guide data or not.  I may try to manually add it and see if it shows up.  I may also try a zip code farther north and see if 15.1 will appear and if it has guide data.
Scott
bonscott87 is offline
Old 02-13-2014, 03:43 PM - Thread Starter
bonscott87's Avatar
Got is resolved!
Did some research online and the issue with just one channel missing guide data (when it should have it) with WMC is resolved (sometimes) by doing the TV setup again and/or choosing a zip code nearby.  So I reran the full TV setup which took about 15 minutes and that seemed to resolve the issue, 50.1 now has guide data.
Hope this helps anyone else that might have the same issue.
On another note, really enjoying Ion Life, has many cooking and "HGTV like" shows.
Who needs cable.  ;)
Scott
Old 03-18-2014, 01:19 PM
grnerd's Avatar
I hate to be that guy, and I don't blame you for blasting me, but I am also daunted by reading 269 pages of posts looking for an answer. So here goes...
I live in Eastown, and am in the process of cutting the cable. What are your recommendations for an antenna that will pick up CBS from the south as well as the other networks? I don't know a whole ton about antennas in the first place, but I do know that the indoor one I picked up does not get CBS, and that just will not work for my wife smile.gif Her morning routine involves a cup of coffee and the CBS news. I really do not want to have to get one that we have to rotate, so is there an omni directional one that will pick up from both directions?
Secondly, when an antenna claims to have a 30 mile range, for example, does that mean that WOTV which is 27 miles away will come in clearly, or will it be fuzzy?
Thank you in advance for your recommendations!
grnerd is offline
Old 03-18-2014, 01:55 PM
TV8
TV8's Avatar
There is no such thing as fuzzy. That is an analog term, in digital It is a perfect picture if there is enough signal for the decoder to function. Anymore than it needs does no good except it will give you more margin for variations in signal strength due to weather. If the signal is right at the edge you will see pixelization, a little less signal and all you see is black. Antennas tend to exaggerate the range they are good for. Just about any traditional antenna will pull in a signal 30 miles away however.
Mike L.
TV8 is offline
Old 03-18-2014, 07:21 PM
veedon's Avatar
Quoted: 761 Post(s)
Liked: 465
People in your local area will be able to offer advice about specific channels, but the first thing to know is what the physical channel numbers (RF numbers) are for the stations in your market. That will tell you whether you need an antenna that has VHF capabilities. VHF signals tend to travel farther than UHF, but it is often hard to receive VHF with an indoor antenna. Sometimes you can receive VHF with a traditional dipole (rabbit ears), if you are reasonably close to the transmitter.
The following link shows the info for your area. It looks as though there are several VHF stations.
http://www.rabbitears.info/market.php?request=station_search&callsign=wood
For details about transmitter locations, try a site such as TVFool.
veedon is offline
Old 03-23-2014, 10:36 AM
XZphotog's Avatar
I live in Eastown and have a rooftop antenna. It's the three piece antenna known as the "Royal 17" made specifically for the Grand Rapids area. For 3, 8, 13, 17, 41, and 64 it works great. WGVU is good, but does break up sometimes. I have an analog era antenna, though, designed to pick up WGVU on 35, their current channel is 11. Channel 43 does not come in at all.
You could try installing a single antenna in your attic, if you only want the Middleville stations (3, 8, 17, 41, 64) or call Ottawa-Kent antenna service for a rooftop installation. They have a redisigned Royal 17D that should pick up WGVU very well.
XZphotog is offline
Old 03-23-2014, 12:32 PM
dave73's Avatar
I looked at where 43's tower is located (WZPX on RF 44), you basically need another antenna, or rotate your set to point toward their tower. Keep in mind that WLS-TV Chicago can interfere with WZPX, as both stations broadcast on RF 44. Don't even get me started on this one, as WLS-TV interferes with my Ion station on 1st adjacent RF 43 (WCPX 38.1 - 38.6), & still does to this day (mainly after sunset) in Gary, IN. I highly doubt Ion Media would even consider seeing if they could move their tower closer to the other Grand Rapids stations, since they can claim to cover 2 markets (Grand Rapids & Lansing) with their signal (even if only part of each market).
dave73 is offline
Old 03-23-2014, 10:40 PM
Rduce's Avatar
I am curious if any one has a Tivo OTA setup out there. My main concern is how well the GUIDE data is and if it covers all the channels. I am thinking about cutting the cord and getting a TIVO or similar device as I have seen that Channel Master has come out with a OTA DVR, however it does look to have a few teething problems to work out. Thanks in advance!
Rduce is offline
Old 03-24-2014, 08:37 PM
Gassy56's Avatar
Guide info from TVGuide is no longer OTA, but via internet connection.
Gassy56 is offline
Old 03-25-2014, 12:50 PM
Dominic26's Avatar
Quoted: 54 Post(s)
I am about 5 minutes from you, Beltline/Leonard area. I have a med sized VHF/UHF antenna that dates back to 1996. I had it put on the roof with a rotator (which I rarely need to use for TV). Mine points to Gun Lake where the majority of the transmitters are. I get channels 3, 8, 13, 15, 17, 35, 41, 43, 54 and 64 plus all of their sub-channels. It also doubles as my FM antenna. As I said, rarely I will need to turn it because maybe 35 or 13 is dropping. I mostly use the rotator for HD Radio.
Dominic26 is offline
Old 04-20-2014, 05:45 PM
Rduce's Avatar
I realize that, what I am wondering does the TIVO guide cover all the subchannels here in the locals Like MeTV, THis TV ect.
Rduce is offline
Old 04-20-2014, 06:19 PM
unclehonkey's Avatar
Quoted: 281 Post(s)
Liked: 60
check zap2it for your zip code. Tivo basically uses the same guide data as zap2it. I have a Tivo and it works great with subchannels.
Kalamazoo zip shows the folllwing
3-1 & 3-2 CBS, CW
8-1 thru 8-3 NBC, BOUNCE, WX
10-1 thru 10-3 (NBC from Lansing)
17-1 thru 17-3 FOX, ANTENNA, THIS
35-1 thru 35-4 PBS
41-1 & 41-2 ABC, RADAR
43-1 thru 43-6 ION
47-1 & 47-2 (FOX Lansing)
50-1 (My Network)
52-1 thru 52-3 PBS
53-1 & 53-2 (ABC from Lansing)
54-1 thru 54-3 TCT
64-1 thru 64-3 Religion, ME, RETRO
unclehonkey is offline
Old 04-21-2014, 07:11 PM
Channel 2012's Avatar
Quoted: 27 Post(s)
I've noticed that (for a while now) the standard definition version of channel 7 (WWMT-DT2, The CW7) is all squished. They basically just took the widescreen version of the channel and crushed it horizontally to "fit" the 4:3 aspect ratio. Does anyone know why this happened or made any effort to contact WWMT?
Channel 2012 is offline
Old 04-22-2014, 11:12 AM
John J.'s Avatar
It sounds like you don't have your TV set correctly or the TV is ignoring the 16x9 flag that is set. Check your "format" setting. We do the same thing for 8-3, 15-2 and 41-2 for Radar which is 16x9.
John J. is offline
Old 04-22-2014, 03:44 PM
Rduce's Avatar
Not seeing in any other aspect other widescreen 480i on my sets. As stated, you may want to check your aspect ratio settings.
Rduce is offline
Old 04-22-2014, 03:45 PM
Rduce's Avatar
3-1 & 3-2 CBS, CW
35-1 thru 35-4 PBS
43-1 thru 43-6 ION
50-1 (My Network)
52-1 thru 52-3 PBS
54-1 thru 54-3 TCT
Thank you for the info!
Rduce is offline
Old 04-22-2014, 06:18 PM
Quoted: 27 Post(s)
Negatory. I'm talking analog cable - nothing besides 480i and 4:3 can be carried and as such, there is no aspect ratio control whether I'm watching on our 20+ year old standard definition tube set or through the analog standard def tuner on the computer through windows media center in XP, the result is the same. Could this be an anomaly that charter caused to this channel? Could it be only manifested on the analog version of the channel and correct on the digital version (even the digital standard definition version)?
Old 04-22-2014, 08:11 PM
Rduce's Avatar
Probably should contact your cable provider about the problem. OTA displays in the proper ratio.
Rduce is offline
Old 05-05-2014, 09:04 PM
Gassy56's Avatar
CW7 is encoded to 480i 16:9 widescreen from a full 1080i HD master control signal. If your set or cable company or satellite company is displaying it as you state then their method of receiving the signal or the way they are encoding it is the problem.
If Sinclair ever pops for the PSIP license for the new encoder, 3.1 will remain 1080i and 3.2 CW7 will become 720p. Maybe someday. Didn't happen for the year before I retired.
Gassy56 is offline
Old 05-12-2014, 06:29 AM
Rduce's Avatar
For those of you in the Kalamazoo area FOX17 is now running a LPTV translator off a tower in Oshtemo using channel 30.
Rduce is offline
Old 05-31-2014, 01:43 PM
Quoted: 27 Post(s)
I figured as much. It's too bad that they can't fix such a glaring problem, but since they're probably going to be phasing the rest of the analog stuff out anyway, it's probably not a priority for them.
I hope they fix it up, for the hour a month that I watch analog sdtv, it's quite annoying to have to look at.
Old 06-02-2014, 07:51 PM
Quoted: 27 Post(s)
Another quick update on the "charter squished analog channels" issue, it looks like channel 13, WZZM, has also joined the ranks of the CW7 in "crunched analog video hell", and it too now appears to be nothing more than the 16:9 version of the channel squished to 4:3.
Old 06-23-2014, 03:58 PM
Gassy56's Avatar
Since Charter is killing all RF and going IP delivery, it won't matter anymore. LOL
Gassy56 is offline
Old 06-23-2014, 05:13 PM
texasbrit's Avatar
Quoted: 47 Post(s)
Liked: 34
Have you called WZZM and talked to the station engineer? Or emailed them?
They are usually very concerned about problems like this....
And have you checked with other people to see if they are seeing the same issues?
texasbrit is offline
Old 06-24-2014, 10:42 AM
vando45's Avatar
Charter went all digital at my house last night. Are you still having the issue? Did you have to get a box?
vando45 is offline
Old 06-24-2014, 03:18 PM
Quoted: 27 Post(s)
Post charter
I have been seeing the looping announcement on channel 14 that they're discontinuing analog in late July. I guess with these channels being messed up, it's about time they put them out of their misery.
Seeing as both WZZM and WMMT are having the problem, I'm inclined to think the issue was on Charter's end.
Old 06-24-2014, 04:59 PM
texasbrit's Avatar
Quoted: 47 Post(s)
Liked: 34
Yes, but the station engineer is the best person to talk to Charter and sort out the issue...
Old 07-08-2014, 12:46 PM
Quoted: 27 Post(s)
Post digital
Well, we just got hooked up with Charter's free year lease on a couple of their Pace DC550DR digital tuners. The problem does not appear to be present when using these units and since they're discontinuing their analog service here in a few weeks anyway, I think it'll be fine if we just let it go. Those DC500DRs are barebones little units (and the standard def out of the coaxial port absolutely sucks), but they get the job done.
Old 07-11-2014, 06:21 AM
Liked: 0
Antenna Newbie Question
Hi, I live in Belding and would like to use an antenna to get OTA. So far I have tried about 6 different indoor antennas and have not been able to pick up a single station. I live in an area surrounded by large oak trees so that may pose a problem. I have a 1-1/2 story house and would like to put an antenna in the attic space on the south side of the house because the roof is very steep and I don't feel comfortable climbing up there. The house is aluminum sided with a asphalt shingled roof. I have heard people talk about a "Royal 17D" antenna that is made for West Michigan, can it be purchased locally and if so any idea where to get it the cheapest? Is that even the best solution for me? Sorry for all the basic/vague questions but this is all new to me. Any help would be appreciated. I put a like to my TV Fools report below.
http://www.tvfool.com/?option=com_wr...e1c6ab47595335
mflanders300 is offline
Old 07-11-2014, 07:18 AM
texasbrit's Avatar
Quoted: 47 Post(s)
Liked: 34
I'm not going to be of much help with a solution, because your reception situation is to say the least very challenging. If you look at your TV Fool report you can see the problems.
First, none of the stations can be received with an indoor antenna. TVFool suggests a few could be received with an attic antenna, but you need a rooftop antenna to get at least all the major networks. The stations are in several different directions. And to top it off, NBC is on VHF. So the implication is, you would need a good VHF/UHF combo antenna (or two separate ones) mounted outside, and with a rotor.
Let's see if anyone else has a more hopeful analysis.
The "Royal 17D" is a multi-element antenna that was made to try to pick up stations in multiple directions, which is typically the problem in your area. But as far as I know it has not been made for years, and since the stations have changed frequency the elements would be incorrect for the new frequencies.
