Grand Rapids, MI - HDTV - Page 269 - AVS Forum | Home Theater Discussions And Reviews
post #8041 of 8172 Old 07-11-2014, 06:26 AM
Bozzmonster's Avatar
Quoted: 16 Post(s)
I agree with your analysis. I dealt with some of the same signal levels in my former house. You'll need an outdoor antenna for any success. Wish I had better news!
Bozzmonster is online now
post #8042 of 8172 Old 07-11-2014, 06:37 AM
Liked: 0
Is the height of the outdoor antenna critical or does it just need to be outside so it is not shielded be the siding, roofing, etc.? I have a shed near the house that would be much easier to install an antenna on but is much lower than the roof of the 1-1/2 story house.
mflanders300 is offline
post #8043 of 8172 Old 07-17-2014, 03:59 AM
Rduce's Avatar
Well, of course, the higher you have your antenna the better signal reception you are going to have. I am on the Northwest side of Kalamazoo and have an antenna on my single story ranch house, perhaps total height is 15 to 18 feet and I get all those offered in my area, including WZZM, with my OTA setup. Of course I have a very good mid-range antenna.
Rduce is offline
post #8044 of 8172 Old 08-07-2014, 12:56 PM
TV8
TV8's Avatar
Quick Guide to Antennas
In the Grand Rapids area there are 4 major stations that are VHF. That is unusual. So, unusual you will see "digital antennas" marketed all over the internet that are actually UHF antennas. This is because most major markets are all UHF. In the Grand Rapids-Kalamazoo-Battle Creek-Holland -Muskegon area you will need an outside antenna preferably 25 feet above ground. That antenna can be of 2 types, a rotor and VHF/UHF antenna, or an "area special". For VHF reception make sure you are using a boom and spoke type antenna. Round or winged antennas or any others that are marked as amplified digital antennas do not work well with VHF signals (3, 8, 13 and 35). There is no such thing as a "digital antenna", we still broadcast an RF signal that is just modulated differently than the old analog days. RF is RF and there is no difference in the antennas. In the Muskegon area you will easily pickup 13 but may have trouble with 3 and 8. The only solution there is to go higher with the antenna. As you approach the lake shore from Holland to Ludington you may have problems picking channel 3, RF channel 8, this due to interference from the PBS station across the lake in Milwaukee. If this is happening to you the best solution is to finely tune the direction of your antenna to minimize channel 8 Milwaukee while still receiving channel 8 virtual 3, Kalamazoo. It helps to have a higher gain antenna with a good front to back ratio. Also, this is a situation where antenna height may be a disadvantage. Have the antenna as low as possible, while still picking up your local channels. One last thing to watch out for is a mast mounted pre-amp. They are not needed for VHF if the RG 6 cable is less than 100 feet, and can cause a great deal of problems if you are close to an FM station's tower. The amp will overload and you will lose channels 3 and 8. If you need additional signal to feed multiple TVs, then use an amplified splitter in the house. These are made to have about 7 db of gain on each outlet and are designed to make up for cable and splitter losses only.
Mike L.
TV8 is offline
post #8045 of 8172 Old 08-07-2014, 08:18 PM
rcoe's Avatar
Quoted: 12 Post(s)
I am located just north of Hastings right on M37 and am looking to put an antenna up in the next week or so. I have been looking into the Hd Stacker, I am on a hill and will be mounting it on a 40' tower I have setup for wimax internet. Is this antenna going to be a good match for my location or should I look into other alternatives? I am hoping my height combined with the right antenna will mean I do not have to go through the extra hassle of a rotator.
Optoma HD33
120" Elite ultra white screen
Denon 4311
INuke 3000
MiniDsp 2x4
SVS PB12 plus/2 & (2) SI HT18 in miniMartys
rcoe is offline
post #8046 of 8172 Old 08-11-2014, 09:17 AM
Liked: 0
I'm at a location in GR where the WOOD and WWMT transmitters (which transmit on VHF 7 and 8 respectively) at compass headings (clockwise from True North) of 160 and 167 degrees respectively. Based on this chart, with a single-channel Yagi (designed to pull in channel VHF 8) in the attic (thus UNDERNEATH the roofing) aimed at a heading of 163.5 degrees, would I be able to reliably pull both WOOD and WWMT on that single Yagi? I suspect I would need separate Yagi antennae for WZZM and WGVU, each single-channel Yagi models tuned to 13 & 11 respectively and pointed approx. NNW and WNW respectively?
Stevie-C is offline
post #8047 of 8172 Old 10-20-2014, 08:29 PM
Dominic26's Avatar
Quoted: 54 Post(s)
All night I have gotten no signal from 64 WLLA. Does any one know if something is wrong over there? I enjoy watch a little METV in the evening.
Dominic26 is offline
post #8048 of 8172 Old 10-21-2014, 01:30 PM
Dominic26's Avatar
Quoted: 54 Post(s)
I just got off the phone with some one at WLLA. They had an equipment failure last Saturday. They are hoping to get the part and be up on the air again by Thursday or Friday.
post #8049 of 8172 Old 10-23-2014, 05:13 PM
Rduce's Avatar
How odd, they have never been off the air watching thru my local cable company. Love my MEtv!
Rduce is offline
post #8050 of 8172 Old 10-23-2014, 05:32 PM
texasbrit's Avatar
Quoted: 47 Post(s)
Liked: 34
That's probably because the failure is in the transmitter or somewhere else in the transmitting system, and the cable company gets the signal via cable/fiber from the station which works fine, whereas of course if the transmitter is down there will be no OTA...
texasbrit is offline
post #8051 of 8172 Old 10-24-2014, 10:15 AM
Dominic26's Avatar
Quoted: 54 Post(s)
As of Friday, 1PM, WLLA is still down OTA.
post #8052 of 8172 Old 10-24-2014, 03:17 PM
Rduce's Avatar
On OTA as of 6:15pm
Rduce is offline
post #8053 of 8172 Old 10-24-2014, 03:27 PM
Rduce's Avatar
New Problem
I am having a problem with WGVU channel 35.1. A couple of weeks ago I found that when ever I tune to the 35.1 channel OTA, the audio is silent, this happens on both my Sony televisions. Looking thru the tv's menu I noticed that for some reason the audio switched to the alternate audio channel, which is empty. I switch it the primary audio channel and everything is fine until I turn it off or tune to another channel and come back to the PBS primary channel. If I tune to any of the subchannels the audio is fine and does not switch to the alternate channel. I sent an email to the engineer at the station to ask if they were doing something different that might cause the problem, but he never returned my email. Any ideas out there?
Rduce is offline
post #8054 of 8172 Old 10-24-2014, 08:15 PM
Dominic26's Avatar
Quoted: 54 Post(s)
On OTA as of 6:15pm
Yes. It was back on OTA at 4:30PM.
post #8055 of 8172 Old 12-21-2014, 01:47 PM
Liked: 0
Posted in another thread, difficult setting up in new home
Posted this in another thread but thought I'd put it here to see if I could get any help! Just moved into a new home in Byron Center, getting really frustrated setting up OTA broadcast -- getting ZERO channels currently. Moved out of apartment in Wyoming where I used a cheap indoor amplified antenna and got more channels then now even though I am closer to the towers by about 5 miles. Here is my setup:
RCA ANT751 in attic, pointed to 135 degrees (towards Middleville area) as given by iphone compass
2-way splitter in basement
Run to 2 TVs, one in master bedroom and one in living room, both Samsungs
Wiring is all RG6, probably 50ft from antenna to splitter in basement, then 30 ft from splitter to each TV. After setting up the first TV I got 2 channels, with both hooked up getting none from either. All major networks are within 20 miles, most in the same general direction. Some questions:
1) Does the type of splitter matter? It is a cheapie RCA model. Or should I just go with no splitter? The living room TV is what I am really concerned with more than anything else.
2) Should I consider a different antenna? Definitely room for a bigger one in the attic, I just didn't think it would matter considering my vicinity to the towers and the good reviews of the ANT751.
3) There is a treeline along the back of the house, but again I wouldn't expect to get ZERO channels?
4) I installed the F-connectors on the coax cable that is being inputted into the splitter, again used cheap RCA connectors, should I use something different?
Additional note: before even installing the splitter, I brought one of the TVs in the basement and put the coax lead from the antenna directly into this TV to test, and still the number of channels still wasn't great.
Thanks!!
mddb is offline
post #8056 of 8172 Old 12-21-2014, 05:59 PM
veedon's Avatar
Quoted: 785 Post(s)
Liked: 481
Wiring is all RG6, probably 50ft from antenna to splitter in basement, then 30 ft from splitter to each TV. After setting up the first TV I got 2 channels, with both hooked up getting none from either. All major networks are within 20 miles, most in the same general direction. ...
Thanks!!
Have you tried connecting just one set and moving the antenna around in the attic to determine the best location? With an attic installation, you can get funny things going on due to reflections.
You have several VHF stations in your area, but the antenna that you have does have VHF elements, so that is probably not the problem,
Have you tried your old indoor antenna, just to see how it fares?
veedon is offline
post #8057 of 8172 Old 01-02-2015, 06:44 PM
Liked: 0
You will need a larger antenna that one is below the average size to get most of our local channels. You will need a VHF antenna, that one is primarily a UHF antenna. To get 3, 8 and 13 you need VHF.
You will also likely want to install it outside and as high up as you can reasonably have it. If you have a chimney attaching it to that will be best.
I have installed this antenna to get channel 3 an RCA Ant3036WR, it is certainly large but gives excellent reception of many of the difficult channels.
You may need a combo of three antennas pointed in different directions to get all of the channels available in our area. Try this site to understand where everything is situated in our area: antennaweb.org
kmead is offline
post #8058 of 8172 Old 01-18-2015, 03:40 PM
Dominic26's Avatar
Quoted: 54 Post(s)
WHERE is channel 3 (WWMT) OTA??? the AFC Championship game starts in 3 minutes!!!!
post #8059 of 8172 Old 01-18-2015, 03:42 PM
Kamakzie's Avatar
It's working here.
Kamakzie is offline
post #8060 of 8172 Old 01-18-2015, 03:46 PM
Dominic26's Avatar
Quoted: 54 Post(s)
Originally Posted by Kamakzie View Post
It's working here.
I just called and they said signal is fine. Both my TV's are NOT getting a signal. Any thoughts.
post #8061 of 8172 Old 01-18-2015, 03:49 PM
Dominic26's Avatar
Quoted: 54 Post(s)
I just synced my rotator. All is well. Must have gone out of sync with ice last week.
post #8062 of 8172 Old 01-18-2015, 03:51 PM
Kamakzie's Avatar
I'm glad all is well for you now
Kamakzie is offline
post #8063 of 8172 Old 01-22-2015, 04:55 PM
Dominic26's Avatar
Quoted: 54 Post(s)
Quick question. Do we use "true" or "magnetic" value for direction of the antenna. Trying to figure out for FM radio stations.
post #8064 of 8172 Old 01-27-2015, 06:50 AM
grizzledbiker's Avatar
Quoted: 2886 Post(s)
Liked: 1328
Who provides the better PQ, Uverse or Comcast?
sent via HTC ONE M7
grizzledbiker is offline
post #8065 of 8172 Old 02-18-2015, 09:48 AM
Dominic26's Avatar
Quoted: 54 Post(s)
Quick antenna question. My antenna is roof mounted and I have been turning the antenna for 96.1 FM a couple of nights after work. When I put it back toward Gun Lake, it is going too far. Syncing it will fix the problem. I'm thinking it's a cold weather issue not a rotator issue. This happens around 10PM, obviously freezing out. Any thoughts.
post #8066 of 8172 Old 03-13-2015, 07:46 PM
Dominic26's Avatar
Quoted: 54 Post(s)
Quick signal question. I am now feeding six devices (2 TV's; 3 FM tuners; 1 HD HomeRun) from my rooftop antenna. Right now I have 4 splitters in different spots. Signals are good enough now, but I don't want to risk problems later. Would a 6 way splitter outside the house be better? This way I could split the signal at one spot only and cut the run on 3 of the devices to less than half, with each device now having a single cable back to the splitter. I was thinking of this one http://www.monoprice.com/Product?c_i...seq=1&format=2 . What does anybody think?
post #8067 of 8172 Old 03-22-2015, 04:28 PM
Liked: 0
Combining OTA antennas
I live in Kentwood Mich 49508.
I have a Wineguard HD7084P mounted at the top of a 10' mast to the roof of my ranch.
Most of my channels are south, CBS, NBC & Fox.
One channel, ABC, 13, is 180 degrees from the others.
signal strength is in the 40s but fluxuates from good to pixilated to not there. Time of the year and time of day are factors.
I can turn the antenna 180 degrees toward ABC 13 (335 Degrees) and signal strength is in the 70s but NBC is gone.
I'm looking at adding a 2nd antenna facing North for channel 13.
Any advice on doing that?
Do I need an identical antenna to do that?
Kevin
sixpac440 is offline
post #8068 of 8172 Old 03-27-2015, 02:14 PM
Dominic26's Avatar
Quoted: 54 Post(s)
Kevin
Kevin,
Could you post the TVFool chart for your address. That's the first place to start. Then can you describe in more detail how the antenna is mounted. You say a 10' pole on a Ranch. I am assume it has a rotator based on movement. How high is it off of the ground, are there trees around it? Most importantly (I made this costly mistake once), how far is the rotator motor from the antenna?
Dominic
post #8069 of 8172 Old 08-06-2015, 10:48 AM - Thread Starter
bonscott87's Avatar
Wow, been months since we've had a post here. That's either good or bad. LOL
My question is for Charter users out there, specifically in the Kzoo/Portage area.
How is Charter these days? Internet solid? TV service not go out every time it drizzles? My experience with them is from 15 years ago and they were terrible. I've heard they are much better now but wanted to see what people think.
I cut the cord 5 years ago and have an OTA rooftop antenna. Between recent storms and rust (over 30 years old) it's about done with and replacing it with installation isn't cheap so I've been shopping around. I have Uverse for Internet now and adding TV there is an option but they *still* don't have have The CW so that's a non-starter plus they aren't cheap. Charter though has a deal for $60 that includes both Internet (at triple the Uverse speed) and TV for $5 cheaper then Uverse for Internet alone. No contracts. So when it goes up in a couple years I either get a deal or cut 'em and play Charter and AT&T against each other, or cut the cord again.
So Charter seems like a pretty decent deal, just looking to see what people's experience with them lately is.
Scott
bonscott87 is offline
post #8070 of 8172 Old 08-06-2015, 02:03 PM
Channel 2012's Avatar
Quoted: 27 Post(s)
Thumbs up Better than ever
They're better than ever and about as good as it gets as far as cable companies go. Internet access has been upgraded for most neighborhoods from 20Mbps to 60Mbps and they're even giving out DOCSIS 3 compliant cablemodems now free of rent as long as you stay with them. TV service is okay, but there's no more unencrypted analog or digital channels, so everyone is forced to rent a cable box. Stability in general has been excellent as well with no noteworthy outages.
If you've already got an antenna that picks up most of the networks you want, I'd skip the television service and just go with Charter's internet and telephone. For any TV you do want to watch, the Genesis addon for XBMC on your home theater computer fully makes up for that with availability and selection superior to Netflix streaming or Hulu.
Channel 2012 is offline
