Grand Rapids, MI - HDTV - Page 272 - AVS Forum | Home Theater Discussions And Reviews
post #8131 of 8159 Unread 04-30-2016, 06:11 PM
TV8
TV8's Avatar
Originally Posted by Gassy56 View Post
A question for TV8. WXSP in Kalamazoo on 50 has no guide data. Are there plans to add that in the future? Also, my Samsung Smart TV ids the channels as 50.3, 50.4, and 50.5. My cheapie Insignia ids them correctly as 50.1, 50.2, and 50.3. Any idea why the Samsung is wrong?
Call WOOD TV and ask for the Chief Engineer. I am recently retired from there so I can't help you. The multiplexer at those sites are quite old and quide data drops out. I doubt those stations will be around much longer than next year. They will probably be put into the spectrum auction currently going on with the FCC.
Mike L.
TV8 is offline
post #8132 of 8159 Unread 04-30-2016, 06:17 PM
Gassy56's Avatar
Thank you for the reply. The PSIP data showed up a couple days ago and now the Samsung tv correctly ids it as 50.1, 50.2, and 50.3. Programming guide data is there also. I had contacted them a week or so after my post here and the CE replied they would look into it. Took a couple weeks or so to work again, but it might have involved replacement equipment, re-licensing, or a body to get to Kalamazoo.
Gassy56 is offline
post #8133 of 8159 Unread 06-20-2016, 09:08 AM
tobybul's Avatar
Grand Rapids, MI
Cascade/Forest Hills
Hi. Have not posted for a while but just wanted to mention the problem am having. I've had OTA for about 7 years. I had the 3-element antenna area special called Royal 17 by AntennaCraft. Last year, my antenna man convinced me to upgrade to a 2-element. Overall it works fine but there are days (nice days at that) where 35, 3 and 13 are either pixellated or totally out - like yesterday.
The current setup has a preamp at the antenna.
Just wondering if anyone experiences what I experience and any suggestion to keep it stable. Thanks.
tobybul is offline
post #8134 of 8159 Unread 06-20-2016, 10:42 AM
rabbit73's Avatar
Quoted: 294 Post(s)
Liked: 100
Hi, tobybul
Please post a link to your tvfool report so that we can see what the signals look like at your location.
this where you do the report
http://www.tvfool.com/index.php?opti...pper&Itemid=29
the link is in bold type near the top of the report
your report should look something like this
http://www.tvfool.com/?option=com_wr...e2cb27520e4354
If you can not measure it, you can not improve it.
Lord Kelvin, 1883
www.megalithia.com/elect/aerialsite/dttpoorman.html
rabbit73 is offline
post #8135 of 8159 Unread 06-20-2016, 10:56 AM
rabbit73's Avatar
Quoted: 294 Post(s)
Liked: 100
What does the "2-element" antenna look like?
What preamp are you using?
What direction is the antenna aimed?
What are the callsigns?
35, WGVU PBS, real channel 11, virtual channel 35.1, 279 degrees
3, WWMT CBS, real channel 8, virtual channel 3.1, 188 degrees
13, WZZM ABC, real channel 13, virtual channel 13.1, 322 degrees
Is that right?
Lord Kelvin, 1883
rabbit73 is offline
post #8136 of 8159 Unread 06-20-2016, 11:47 AM
rabbit73's Avatar
Quoted: 294 Post(s)
Liked: 100
I see a lot of trees in your area; any in the signal paths?
Lord Kelvin, 1883
rabbit73 is offline
post #8137 of 8159 Unread 06-24-2016, 11:25 AM
Dominic26's Avatar
Quoted: 42 Post(s)
I'm not far from there, those trees are to his North. Channel 3 is to his South, almost a perfect 180 degrees. Channel 3 is 174 degrees for me, 35 is 262 and 13 is 323. His settings can not be far off from mine.
Dominic26 is offline
post #8138 of 8159 Unread 06-30-2016, 05:00 AM
kab123's Avatar
Is anyone having issues with WOODTV this morning? actually I think it started late last night.... I'm getting a really low signal with no picture or very spotty reception.
kab123 is offline
post #8139 of 8159 Unread 06-30-2016, 05:22 AM
rcoe's Avatar
Same here was bad enough that I was thinking I might need to climb the tower to check things out. Looks like it is on their end.
Optoma HD33
120" Elite ultra white screen
Denon 4311
INuke 3000
MiniDsp 2x4
SVS PB12 plus/2 & (2) SI HT18 in miniMartys
rcoe is offline
post #8140 of 8159 Unread 06-30-2016, 10:01 AM
vando45's Avatar
I was getting pixilation and freeze-ups on Charter cable as well.
vando45 is offline
post #8141 of 8159 Unread 07-01-2016, 08:12 AM
John J.'s Avatar
It appears there were/are some atmospheric conditions affecting the WOOD signal.
http://aprs.mountainlake.k12.mn.us/
http://www.dxinfocentre.com/tropo.html
John J. is offline
post #8142 of 8159 Unread 07-17-2016, 03:05 PM
Liked: 0
First post ... hoping for advice ...
Trying to get local channels (NBC, ABC, CBS, FOX) here in Wyoming Michigan and not having much luck at all. I tried the best indoor options from RCA Flat (17xx), a Terk Trinity and a ClearStream from Best Buy (which was the best). Did not try a Wineguard (saw at Home Depot) before I gave up to try to get smarter.
Found the TV Fool site and got a report confirming the distance is 31 miles or less (can't post a link to the report because I'm new).
I started with a 40 mile antenna thinking the Walmart a few miles away showed everything was 25 miles or less from the store. The others were 50 or 60 and all amplified and I could not get ABC ever, FOX always and the other two hit or miss. I'm guessing an indoor antenna isn't going to work at my house.
So then I got to thinking that I have an old DISH on my roof ... with a mounting pole and coax running in to the house. I could put an antenna on this I think.
Would that work? If so any ideas on a good antenna choice ... one that isn't "fussy" maybe???
Looking forward to feedback! Thanks in advance!!!
GRJimbo is offline
post #8143 of 8159 Unread 07-28-2016, 07:16 AM
wb8tgy's Avatar
Reuse of dish antenna mount and coax
Yes you can reuse the coax cable from your old dish antenna, and the mast your dish antenna is on (take the dish down if your not using it). I'm not from the GR area, so I'm not an expert (but I do get most the GR stations at my house between Lansing and Charlotte). Your CBS/CW and NBC stations are South of your location and are on VHF channels 7 and 8, and one of your ABC stations is Northwest of your location and is on VHF channel 13 (your other ABC station is SE and on UHF). If you have a old set of "rabbit ears" indoor antenna you could try them to pick up these three VHF stations indoors. If you put up an outside antenna you will want one that covers both VHF and UHF. There is one type of UHF antenna that also works on the higher VHF channels, some call it a "bow tie" antenna, and the smaller version of it has four bowties on it with a metal screen behind the bowties. That said it's a directional antenna and I'm not real sure your going to get all the stations in GR with that pointed in one direction from your location. If you put a rotor under it so you can move the antenna I bet that would work great for you. I think the local electronic supply house in GR is Bursma Electronics they may be able to help you with antenna choices.
The other stations in your market are all on UHF with PBS being NW of you I think, and Ion being SE. Your Fox station is also south of you near your CBS/CW and NBC stations.
You could try one of the Omni directional disk antennas on top of your mast outside. I bet that would work better than anything you have tried inside.
Hope this helps.
wb8tgy is offline
post #8144 of 8159 Unread 07-28-2016, 03:13 PM
Liked: 0
NoBC with indoor antenna ...
I like reusing the mounting for sure!
Two weekends ago I tried 5 antennas ... the five best I could buy locally. By far the ClearStream model was best with 20 channels but no ABC anywhere. I have since discovered that a house with aluminum siding is going to be an issue ... my daughter in Milwaukee get all the channels with a really cheap RCA antenna but it seems like the towers are really close to her.
According to the ClearStream website the 2V model should get most everything (including ABC) and it is a multi-directional antenna. Maybe any antenna will work outside?
My dish pole is on the south west corner of the house ... 10' off the ground ... if I pointed an antenna towards the south east it would be facing a bunch of big trees.
Any ideas would be appreciated.
GRJimbo is offline
post #8145 of 8159 Unread 07-28-2016, 03:14 PM
Liked: 0
Oops ...
Meant no ABC!
GRJimbo is offline
post #8146 of 8159 Unread 07-29-2016, 09:09 AM
wb8tgy's Avatar
Ten feet isn't up very high, but being outside should work better for you. I did some looking and it seems your PBS station is on channel 11 VHF, sorry I thought they were on UHF (I can't get that station from my house).
The trees shouldn't hurt you at all on the VHF stations, they could on UHF, but try with your current mast before trying to relocate it to another place to avoid the trees. I don't know what to tell you on your ABC options being your between the two stations. One option would be to get a separate high VHF antenna and point it at channel 13's tower and run a separate coax cable for that one antenna. One of the bowtie antennas pointed toward ABC WOTV on channel 20 may work fine for getting everything in that general direction.
The TV Fool web site should be able to tell you if WZZM channel 13 or WOTV channel 20 looks the easiest to get from your location.
wb8tgy is offline
post #8147 of 8159 Unread 07-29-2016, 03:30 PM
Dominic26's Avatar
Quoted: 42 Post(s)
Have you tried running a report yet at ww.tvfool.com ? Post your results so we can see them. Also 10 feet is not very high. Height is not an issue for satellite since it is pointing into the sky. I ran tvfool reports in 2 to 3 spots in Wyoming. It shows some channels not having LOS, instead being 2 edge. In each case I raised the height to 20 ft off the ground and and all the stations went to LOS. Depending on where you are height may be your issue.
Dominic
post #8148 of 8159 Unread 07-29-2016, 04:21 PM
Liked: 0
Dominic
The tvfool link is this ... tvfool.com/?option=com_wrapper&Itemid=29&q=id%3de2cbf361162c9 c
If I'm reading this right I should be look towards 148 degrees more or less to get ABC, NBC, CBS and FOX ... with ABC the hardest to get. The ClearStream Indoor Amplified pulled all but ABC. This was in the front of the house with a big window due north ... although I put all the indoor antennas I tried on a 25' coax and moved around the house.
I have a Dish mast on the roof right now and a cable running in to the basement ... this would be 10' off the ground. If I go at 148 degrees it is straight in to a big maple tree with a couple much bigger oaks behind that. If I point it north (mast on the west side of the house) I pretty much have a clear viewuntil the back yards across the street ... but those stations are all further down the list which I think is less likely to get.
I have a RCA ANT800F antenna (outdoor flat amplified) and a ClearStream 2V sitting on the table to try next. Thinking that getting outside of the aluminum siding could be a big difference.
Or maybe I'm chasing the wrong thing and should be getting the old school style antenna???
GRJimbo is offline
post #8149 of 8159 Unread 07-29-2016, 04:24 PM
Liked: 0
TVFool link ..
I need one more post to include a link ...
GRJimbo is offline
post #8150 of 8159 Unread 07-29-2016, 04:26 PM
Liked: 0
Full TVFool link ...
Here is the full TVFool link to my antenna report ... http://www.tvfool.com/?option=com_wr...e2cbf361162c9c
Basically I could not get either ABC station that are in the yellow section, I got all channels in the green section with the ClearStream indoor nicely.
GRJimbo is offline
post #8151 of 8159 Unread 07-30-2016, 01:06 PM
Liked: 0
I'm over by Cornerstone University. I have a medium antenna mounted on my roof with a rotator. It works perfect. I use it for TV and FM radio. I have had the antenna and rotator for 20 yrs going back to my days in Rhode Island so you see it can last a long time. I use the rotator more when I listen to FM radio, although that can change from location to location. I get channels 3, 8, 13, 15, 17, 35, 41, 43, 54, and 64 plus all their sub channels for a total of 34 channels. Hope this helps.
Dominic
Dominic ... your reply earlier this year was to a person who lives 3-4 miles from me based on comparing TVFool reports (small world).
Question, when you say you have a "medium antenna" could you describe it based on something I could buy at say Home Depot or Menards or the like? Or maybe point me to a website to see what is working for you?
Lowes has a RCA ANT751R (I would think is small 'ish) and a 3037XR (7' long and 8' wide which I would call big).
GRJimbo is offline
post #8152 of 8159 Unread 07-30-2016, 03:29 PM
Liked: 0
Update!
I have a ClearStream 2v (from Best Buy) clamped to a chair on my front porch facing north ... and I'm getting ABC, NBC, CBS and FOX plus 19 other channels all clear with no pixilation!
I was thinking the antenna should be facing South and East according to TV Fool but what works works.
The ClearStream website tells me there are 10 more stations to be had, maybe mounting this on the old Dish mast will get those too ... although I can live without QVC I think.
GRJimbo is offline
post #8153 of 8159 Unread 07-31-2016, 07:21 AM
Dominic26's Avatar
Quoted: 42 Post(s)
Jim,
What I have is your typical "old fashion" antenna that was common on rooftops since the 1950's. Medium just means the size of the elements. I had a LARGE Radio Shack I tried in RI that was almost 8 -10ft long! My problem back then was all the transmitters were NE of my location. I was at sea level with hills on the North and East of town and the ocean on the South. In those days I could only get a CT PBS station no matter what antenna I used, no Providence RI stations. Size only matters if distance is a problem.
More important is height. Some of your green is 1 and 2 edge, no Line of Sight (LOS). That means there is something (ie: ridge, hill, building etc) between your antenna and the transmitters. If you run your address again and increase the height to 20 ft I am willing to bet all those 1edge and 2edge stations become LOS and your NM (noise margin) goes up, all meaning a stronger signal. They may come in now, but when the weather changes you may see a difference. Look through some of the old posts. When it's cold and snowy will not be the time to increase your antenna's height. I am speaking from experience and the frustration of having been there.
The only reason I use the antenna I have, I've had it since the 90's. Long story short, it went into storage in 1999 for the Radio Shack and came into use when we moved to GR in 2008.
Dominic
post #8154 of 8159 Unread 07-31-2016, 05:43 PM
Liked: 0
Thans to all!!!
Between answers here and past posts I have OTA channels!
So this gets me to another question ... how does everyone know what is actually on these OTA channels?!
I'm hoping there is a website that I register on that I can mark the channels I actually receive and want to watch and then I can see a listing whenever I login.
Any suggestions on what works?
GRJimbo is offline
post #8155 of 8159 Unread 08-02-2016, 04:58 AM
Dominic26's Avatar
Quoted: 42 Post(s)
Glad to help. As for the channels, the main are 3, 8, 13, 15, 17, 35, 41, 43, 54, and 64. Each has it's sub channels. I am on the way to work but can post some more info tomorrow for you.
post #8156 of 8159 Unread 08-02-2016, 05:47 AM
alesch1's Avatar
TitanTV is a good TV listings site
alesch1 is offline
post #8157 of 8159 Unread 08-18-2016, 07:02 PM
kab123's Avatar
Looks like the CW (WWMT 3.2) got updated to HD today...
kab123 is offline
post #8158 of 8159 Unread Yesterday, 12:17 PM
Liked: 0
New to the area of Kalamazoo
I'm new to the area of Kalamazoo. I live North West of Kalamazoo by 20 miles or so (as the crow flies). Since I'm going to be actively involved in the community, I would like to be able to watch local programming. That is the biggest priority. The problem that I've been having is that tuning in the low frequencies VHF (WWMT 3.1 or WOOD 8.1) was very troublesome. I would get a spotty unreliable picture. I received 42 stations overall, but some came in well and some did not. But since I am in the Western Michigan market, I really wanted to focus on Grand Rapids and Kalamazoo stations.
My setup is;
Antenna - Clearstream 4V
Splitter - PCT MA2-2P
The lines that come out of the splitter go to:
HDHomerun
Directly to the TV.
I had the antenna pointing due south, basically towards South Bend, Indiana. So today (8-28-2016) I re-pointed my antenna, two more of a southeastern position. Now I am receiving 3 and 8 (WWMT/WOOD) very well, but I dropped 10 stations that I may or may not have wanted. WNIT 34.1 was one that I liked, mostly for the morning cartoons my 3 year old loved, but now that I've read configured my antenna, I lost that one. I seem to have lost a lot of religious stations, but I am perfectly fine with that. They did not interest me at all. WCWW 57.3 was a station that was kind of cool too, but not a necessity.
My question is, if I want to pick up those South bend stations, should I get a Yogi rotational antenna and a diplexer and combined the signals and see what happens? Or do I Leave it as it is, (it is doing what I want it to do) and set up another TV/ Room to a rotational antenna? Or is there another idea that I am not thinking about because I am too much of a rookie? My TVfool.com info follows. (add that to tvfool.com because I have no posts, I am not allowed to give a real link)
/?option=com_wrapper&Itemid=29&q=id%3de2cb644c35feb 3
And coming from an area in the mountain which would not receive a single station, to this one, I am so happy. South Western Michigan is like the mecca for OTA stations.
Willyazoo is offline
post #8159 of 8159 Unread Today, 05:19 AM - Thread Starter
bonscott87's Avatar
You realistically can't pick up South Bend and the GR/Kzoo market at the same time since SB would be pretty much due south of you and the antenna farm for most of the stations in this market would be just about due east of you (they are at Gun Lake). If you want to get them both at the same time then you'd need to set up two separate antennas pointed in both directions and combined. Otherwise you could use a rotor but if you plan to record OTA shows on something like a Tivo then that is probably not a solution. I honestly don't think there is anything in SB you can't get here, unless you are a Notre Dame fan or want to watch the Bears or Colts on Sunday vs. the Lions. So I'd try pointing your antenna more to the east, check out TVFool to get an exact location. Pointing that way should get you in line for ION who has their tower more toward Lansing and would be east of your location. Probably not close enough for other Lansing stations but you never know. If you are close enough to Lake Michigan and had a tall enough tower pointing the opposite way you might even pickup Milwaukee stations at times, I'd think too far away for Chicago though.
WNIT I believe is PBS and we of course have the same channels, 35 in GR and 52 in Kzoo. Both are the exact same PBS programming you'd find on WNIT or any other PBS in another market.
WCWW .3 looks like it's Bounce according to Wikipedia? If so that's a subchannel of Wood TV8.
We have a ton of subchannel fun here in the GR market as well. Note that the CW is a sub of channel 3 (3.2)
3.3 Comet TV
8.2 Bounce TV
8.3 Laff
17.2 Antenna TV
17.3 This TV
41.2 Get TV
41.3 Grit TV
41.4 Radar
6 ION stations on 43
4 (maybe 5) PBS channels on 52 (or 35, pick whichever comes in best, they are the same)
64.2 ME TV
64.3 Retro TV
I've probably missed some as well.
Good luck and have fun!
Scott
bonscott87 is online now
