Chattanooga, TN - HDTV - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #361 of 2212 Old 12-19-2005, 06:47 AM
wmessin's Avatar
is ABC back on? I checked earlier yesterday but wasn't getting anything.
They better get it fixed before the bowl games start up on ABC.
GEAUX LSU Tigers!!!!
wmessin is offline
post #362 of 2212 Old 12-19-2005, 07:50 AM
maharg18's Avatar
I just checked and it looks like they're still not back...
maharg18 is offline
post #363 of 2212 Old 12-19-2005, 11:29 AM
wmessin's Avatar
WTVC's chief engineer replied quickly to an email I sent to him this morning about their signal issue:
Wayne,
Hopefully by the end of the day today WTVC-DT will be back on the air. We are in the process of increasing the power from 200KW to 575KW, and had an antenna failure on Friday. The tower crews are working on fixing the problem now.
Thanks for your interest.
Dennis W. Brown, CPBE
Manager of Operations & Engineering
WTVC-TV / DT
Chattanooga, Tennessee
wmessin is offline
post #364 of 2212 Old 12-19-2005, 01:42 PM
jwerner's Avatar
Hey thanks for posting! I'm new to this thread...just purchased an OTA HDTV receiver yesterday. I can pull in everything (95%) but Fox and ABC in DT. (60%) My newbie thinking assumed a new antenna would be needed. Looks like ABC (WTVC) may work better for me tonight and Fox well....
jwerner is offline
post #365 of 2212 Old 12-20-2005, 11:17 AM
jwerner's Avatar
WTVC (DT) still doesn't pick up for me. Missed Monday night football last night in HD. Is anyone/everyone else having a problem?
jwerner is offline
post #366 of 2212 Old 12-20-2005, 11:48 AM
72ScoutNGa's Avatar
Hey jwerner, Where abouts are you located. I'll have my VBox USB HDTV receiver in tomorrow so i'll test it out then. I noticed you have a SonoTube. How does that work for you? PRetty easy to build?
72ScoutNGa is offline
post #367 of 2212 Old 12-20-2005, 12:24 PM
maharg18's Avatar
I just checked and it's coming in just fine here. Whether they are at full power or not I don't know.
maharg18 is offline
post #368 of 2212 Old 12-20-2005, 01:22 PM
jwerner's Avatar
Ringgold. I'm getting about 50% or notta to WTVC-DT which baffles me as I get 95% to 3.1 & 12.1. Aren't the towers within a couple of miles of each other?
Yes, I have a 18" sonotube about 5 feet high. It's about 6.5 cuft internally. A 15" Adire Audio "Tempest" is mounted on the bottom. The Tempest is connect to a 380watt plate amp. The room is 20X40 but it will get loud and deep. The bass sounds effortless as the overall QTC is about .5. (not boomy at all) I have a 4.5cuft ported enclosure tuned to 22hz too. Its a lot louder but doesn't have the SQ of the sonotube.
Yes, the sonotube is easy to build esp. if you have a router with a circle jig. Cut two end caps per side and use liquid nails to bind. Super easy and strong. I got the sonotube from a concrete supply place downtown Chattanooga. They had a spare piece they sold me for $20. Overall, I'm very happy. I've got $350 in the whole project and am convinced my setup will destroy anything Tweeter, Best Buy, Circuit City sells under $1000!
jwerner is offline
post #369 of 2212 Old 12-20-2005, 03:13 PM
ColdBrew's Avatar
Coming in for me at 84-88. I think that is up from 80.
ColdBrew is offline
post #370 of 2212 Old 12-20-2005, 04:30 PM
johndl123's Avatar
JWERNER ch 3 and 9 are less then 1500 ft apart. I live about 4 miles north of them.
I also have a house in Spring City and I can get ch 9 good and ch 3 signal is so poor you cant watch it.I'm talking about SD in Spring City.HD here on Signal Mountain.
johndl123 is offline
post #371 of 2212 Old 12-20-2005, 06:01 PM
esaletnik's Avatar
Channel 9 is nowhere near where it used to be. It used to be 86% consistently with no dropouts at all. Monday night football went from 30-50 % with frequent dropouts. Right now it's ranging between 0-40% with no picture.
esaletnik is offline
post #372 of 2212 Old 12-20-2005, 08:47 PM
jwerner's Avatar
For me, over 2 hours, WTVC-DT has been working great. Guess they fixed the tower as "wmessin" pointed out. Thanks for all the info and feedback guys.
This new PBS programming is nice. I'm thinking now is as a good time as ever to get into DT OTA in Chatt. Good stuff good thread. Cheers.
jwerner is offline
post #373 of 2212 Old 12-22-2005, 06:15 AM
TiVo_Al's Avatar
I'm fairly new to the area and am in Ringgold.
With a little Phillips indoor antenna (Don't know the number, but it has rabbit ears and a rotatable square for UHF) I can get everything except FOX. I do have to rotate the square for PBS.
Does anyone know Fox's plans? I really hope they have something lined up by the time NASCAR rolls aroung.
TiVo_Al is offline
post #374 of 2212 Old 12-22-2005, 07:15 AM
ColdBrew's Avatar
You can read about WDSI a lot in this thread, but basically what they are doing now (digital only no HD) is all they have plans for. They are currently broadcasting DT, but that isn't the norm... They seem to be down more than up.
ColdBrew is offline
post #375 of 2212 Old 12-22-2005, 08:34 PM
jikkme's Avatar
I am in Soddy Daisy near Soddy Lake (right off the Hixson Pike exit). I sit behind a hill cutting off my direct LOS to the Signal Mountain towers. I'm getting ready to take the plunge into OTA HD, but the more I read the more confused I get. A lot of people locally are getting CM4228 antennas, but from what I read, the local affiliates (ABC, NBC, CBS) all broadcast in VHF, and the 4228 is a UHF antenna. Am I wrong on that? If not, is there anyone in my general area that can give me an idea on what type directional antenna to use for VHF reception?
Thanks in advance
jikkme is offline
post #376 of 2212 Old 12-23-2005, 06:20 AM
maharg18's Avatar
Thanks in advance
Actually all the local stations are UHF on the digital channels, with the exception of WRCB which is on channel 13. The 4228 does a good job of pulling in ch 13 too, which is why it's a very popular antenna around here.
maharg18 is offline
post #377 of 2212 Old 12-23-2005, 02:03 PM
jikkme's Avatar
Ahh... that helps a lot.
jikkme is offline
post #378 of 2212 Old 12-25-2005, 02:36 PM
esaletnik's Avatar
Anybody having a problem with channel 9 broadcasting the basketball games in HD. It seems the red is lagging and leaving shadows. I'm wondering if this is a local problem or nationwide.
post #379 of 2212 Old 12-26-2005, 06:10 PM
johndl123's Avatar
I haven't got a useable signal from ch 9 for a few days now. Am I the only one/ I live on Signal Mountain and usualy get it good.
post #380 of 2212 Old 12-26-2005, 06:42 PM
ColdBrew's Avatar
You might want to try reseting your receiver and rescanning the channels.
ColdBrew is offline
post #381 of 2212 Old 12-26-2005, 07:57 PM
wmessin's Avatar
This problem is persisting tonight on monday night football. it's a local problem...not nationwide.
I called WTVC and spoke to some woman in the newsroom who said "thanks" when I told her what was going on. I'll put a call into the chief engineer tomorrow. This problem is not only on HD programming, but through commercials and everything.
wmessin is offline
post #382 of 2212 Old 12-26-2005, 08:23 PM
esaletnik's Avatar
I had the same problem. Had to do some antenna rearranging to get to register 63%. used to be 89%. All other stayed at 90%.
post #383 of 2212 Old 12-26-2005, 08:25 PM
esaletnik's Avatar
Hope they get it fixed before the bowl games. I feel like I shoud be watching it with 3-D glasses.
post #384 of 2212 Old 12-27-2005, 07:06 AM
ColdBrew's Avatar
LOL yeah that was what I was thinking too.
ColdBrew is offline
post #385 of 2212 Old 12-27-2005, 07:09 AM
72ScoutNGa's Avatar
Hey Guys,
Did anyone record the MNF game last night? SD or HD i don't care; i just wanted to see it! I know there was a lot of history and old clips shown last night but my PC missed the recording (power outage). I was hoping someone local had it. Thanks
ANdy
post #386 of 2212 Old 12-27-2005, 09:38 AM
srrobinson2's Avatar
Last night's game in HD was eerie! Everyone had blue auras around them. I'm calling today to complain. If this isn't fixed in time for my bowl game, I will be peeved!
srrobinson2 is offline
post #387 of 2212 Old 12-27-2005, 04:32 PM
indian123's Avatar
sent dennis brown and e-mail and he replied back that thier was nothing wrong with thier hd program i guess he didn't watch the football game or basketball game .
indian123 is offline
post #388 of 2212 Old 12-27-2005, 06:16 PM
wmessin's Avatar
I couldn't get him on the phone so I sent him an email and copied the GM on it, so hopefully that will get them seriously looking into this. I noticed the problem is still there tonight.
The problem is only on network feeds. It persists through HD and non-HD programming provided it's coming from ABC and not natively from Chattanooga. Even the network commercials are showing this problem.
Anyway, should be interesting to see what Mr. Brown says this time.
wmessin is offline
post #389 of 2212 Old 12-27-2005, 06:27 PM
ColdBrew's Avatar
I did the same.
ColdBrew is offline
post #390 of 2212 Old 12-27-2005, 07:55 PM
I did the same.
I left Dennis a VM, but got no reply. I sent him and the GM an email tonight. I wonder if they even have an over the air receiver and monitor....
How can they have any type of quality control process? It appears that they do not. I've never had a response from Mr. Brown in the past, so I decided to forward my message to Calvin Sneed also. Maybe he can investigate his own place of employment.
