New Orleans, LA - HDTV - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #181 of 8255 Old 01-11-2006, 02:28 PM
Ben Hardy's Avatar
Quoted: 16 Post(s)
Liked: 25
I'm afraid I don't have any information on ABC HD broadcasts returning to New Orleans, but WBRZ-DT (13.1/2.1) the ABC affiliate in Baton Rouge, puts out a very strong signal. If you REALLY want to see the Super Bowl, pick up a CM 4228 and point it towards B. R. You may also be able to access the NBC (33.1) station as well. No telling how long WDSU-DT will be out of service too.
Ben Hardy is offline
post #182 of 8255 Old 01-11-2006, 02:53 PM
rgathright's Avatar
Quoted: 219 Post(s)
Liked: 26
Due to Katrina my HDTV's are in Texas and I only have analog sets at home. I am having a lot of interference with Channel 4 via my antenna.
Anyone else having this problem?
Sony XBR-75X850C - Living Room
Samsung UN60J6300AFXZA - Bedroom
rgathright is offline
post #183 of 8255 Old 01-12-2006, 06:06 PM
jmproductions's Avatar
8.1 is working just in time for "24" can you tell i'm happy...i'm about to switch back to basic and fast internet only with charter. to me it is not worth the extra $60 a month for their HD package.
jmproductions is offline
post #184 of 8255 Old 01-25-2006, 05:50 PM
raouliii's Avatar
Charter Northshore has put WGNO-DT (ABC) back up on their system. The DT channel has had no signal since Katrina. Unfortunately, it is 480i only. Comparing the WGNO analog channel, to the WGNO-DT channel they are carrying, it appears to be a much cleaner signal. The WGNO website indicates that the ABC-DT OTA signal is being broadcast on 49.2, which is a subchannel of WPXL-DT (PAX). The website further indicates that it should go HD prior to the Super Bowl. We can only hope they meet the deadliine.
Those who would give up essential liberty to purchase a little temporary safety, deserve neither liberty nor safety. - Benjamin Franklin
raouliii is offline
post #185 of 8255 Old 01-26-2006, 12:53 AM
joabruno's Avatar
I have terk hdtvs ota antenna. I live in Metairie. I recevie all channels except NBC DT with 100% strong signal. Do I need a pre amp or do I not need one since I am receiving my channels with good signal? What exactly does pre amp do and what is a good one to get if I need one? Also does anyone know what is going on with NBC DT 6.1? I am not receiving it.
joabruno is offline
post #186 of 8255 Old 01-27-2006, 09:04 AM
nfunk's Avatar
I am thinking of going HDTV over the air reception. I live in Laplace and was wondering if anybody in this area has been able to receive HDTV.
I can only install and indoor or attic mount antenna. My attic is large and is 20 feet tall.
I have seen that majority of the N.O. HDTV stations are about 30 miles.
What type of antenna would I require?
Any informaton is greatly appreciated!
Nick
nfunk is offline
post #187 of 8255 Old 01-27-2006, 10:48 AM
NOHDjunkie's Avatar
WDSU (6.1) is not on the air, neither is PBS (12.1). All the others are, albeit ABC and WB are on loaned bandwidth from the independent channel 49.1. (49.2 and 49.3 respectively)
the ABC (26.1) and WB (38.1) won't be back on their own transmitter for a while. There is no news from WDSU DT (6.1) as to when they will be back up and transmitting a digital signal.
The Temp ABC on 49.2 says they will have the ABC HD signal up and running on 49.2 in time for the Superbowl.
If you are getting a good signal without an amp you shouldn't need one when the others eventually come online.
However, if you do get a signal amp or preamp (and a rotor) you may be able to get either the Baton Rouge DT stations and or the Biloxi DT stations. WMMV.
Jim
__________________
NOHDjunkie is offline
post #188 of 8255 Old 01-27-2006, 10:53 AM
NOHDjunkie's Avatar
Nick
The Channelmaster 4228 is considered the antenna of choice for many (around $75 with shipping) Google it.
As long as you don't have a Metal roof it should work fine for the New Orleans stations. But outside placement would be better. A preamp wouln't hurt either.
Jim
__________________
post #189 of 8255 Old 01-27-2006, 05:31 PM
rgathright's Avatar
Quoted: 219 Post(s)
Liked: 26
I second the suggestion of getting the CM 4228. I have it in my attic in Pearl River now and it is great. Try to mount it as high as you can in you attic and get a compass to aim it. I am using the CM pre-amp with it.
post #190 of 8255 Old 01-27-2006, 09:02 PM
raouliii's Avatar
It looks like WGNO-DT (ABC) went 1080i sometime today. WoHoo.
Actually, ABC is 720p. My bad.
raouliii is offline
post #191 of 8255 Old 01-27-2006, 09:13 PM
TVSaurus's Avatar
Are they still using 49.2 for OTA?
TVSaurus is offline
post #192 of 8255 Old 01-27-2006, 10:18 PM
joabruno's Avatar
Thanks for the ressponse. Your info was a big help. What do you mean when you said WMMV at the end of your reply??? Any suggestions on a rotor and a pre-amp???
joabruno is offline
post #193 of 8255 Old 01-27-2006, 10:19 PM
joabruno's Avatar
49.2 YES. It better be 1080i for Super Bowl or I will be some pissed
joabruno is offline
post #194 of 8255 Old 01-29-2006, 06:01 PM
mpf03's Avatar
I am brand new to HDTV OTA. I live in Lacombe and have an old antenna
on the roof which was able to pick up WWL on 36.1 at 95% . I notice everyone is talking about WWL on 4.1 and I am not receiving anything there. That is the only
HD channel I get. What am I doing wrong. If I am getting WWL on that old antenna shouldn't I be getting other channels. I would appreciate any help I can get. Thanks
mpf03 is offline
post #195 of 8255 Old 01-29-2006, 06:04 PM
Xayd's Avatar
since ABC and ESPN are the same company and likely use the same gear, it will be 720p just like ESPN's sports are.
Xayd is offline
post #196 of 8255 Old 01-29-2006, 08:28 PM
ChrisPC's Avatar
I think he meant "YMMV": Your Mileage May Vary.
ChrisPC is offline
post #197 of 8255 Old 01-30-2006, 06:52 PM
jlegulu's Avatar
Does anyone know if there is a problem with ABC on channel 49.2. I have good signal strength, but only see a black screen. I have a picture on 49.1 and 49.4. If it is a receiver problem I would like to get it straightned out before Sunday. I am using the Directv HD converter with OTA input. All other channels are fine.
jlegulu is offline
post #198 of 8255 Old 01-30-2006, 07:40 PM
TVSaurus's Avatar
I just had the same problem with WLOX on the Gulf Coast. I quick email to the station Engineer had the problem fixed right away only to have it come back a few days later. It seems that WLOX upgrade their computer software that provides the OTA signal and the upgrade wasn't good so it forces the computer to reboot on occasion. I can get a signal but no picture. It only happens with an OTA though not on cable. It was the PSIP generator computer that was causing the problem. Maybe this is the same thing you're encountering.
TVSaurus is offline
post #199 of 8255 Old 01-30-2006, 11:11 PM
joabruno's Avatar
I receive UPN 54.1 with 100% signal strength and it broadcasts in 1080i. The broadcast picture sucks. Looks horrible! Don't understand because signal is 100%. Is anyone else having this problem????
joabruno is offline
post #200 of 8255 Old 01-31-2006, 08:33 AM
KebCam's Avatar
I noticed that on Sunday night. I tried tuning in 26.1, and found ABC 26 on that channel. I guess they moved it back there.
KebCam is offline
post #201 of 8255 Old 02-01-2006, 06:45 AM
raouliii's Avatar
I don't receive WUPL-DT (UPN) out of slidell but it should be understood that UPN has a somewhat limited HD schedule. Their HD lineup is weekdays from 7 to 9 pm only. Times outside of this is likely just upconverted SD with pillaring. If the programming that you're referring to as looking horrible is true HD (16:9, 1080i with no pillars) then that would lead me to believe they have a poor network feed, equipment or personnel.
raouliii is offline
post #202 of 8255 Old 02-01-2006, 08:34 AM
NOHDjunkie's Avatar
It is still being broadcast from 49.2 but it is remapped to appear as channel 26.1
(name branding)
I live in lacombe as well. It could be a bad matching transformer, might need a preamp? who knows?
Sent you a PM, Maybe we can get together and I can give you a hand
Jim
__________________
post #203 of 8255 Old 02-01-2006, 10:10 PM
joabruno's Avatar
What do you mean by pillaring?
joabruno is offline
post #204 of 8255 Old 02-02-2006, 07:23 AM
jlegulu's Avatar
WGNO website said that OTA signal would be up on 26.1 Wednesday. As of right now I have no signal on this channel. I'm in Metairie and wondering if anyone is picking up this station. WGNO is not answering the phone this morning. If they are having problems, hope they get it fixed before Sunday.
jlegulu is offline
post #205 of 8255 Old 02-02-2006, 07:35 AM
Bulldogger's Avatar
Quoted: 235 Post(s)
Liked: 55
I'm not getting it, 26 either.
Never become so involved with something that it blinds you.
Bulldogger is offline
post #206 of 8255 Old 02-02-2006, 08:26 AM
TVSaurus's Avatar
I get nothing on 26.1 or 49.2 for WGNO. I'm on the MS Gulf Coast.
TVSaurus is offline
post #207 of 8255 Old 02-02-2006, 09:21 AM
NOHDjunkie's Avatar
WGNO is channel 50.1 remapped to 26.1
do a scan or manually input 50.1
They started OTA HD broadcasts with the primetime shows last night.
Jim
__________________
post #208 of 8255 Old 02-02-2006, 10:22 AM
KebCam's Avatar
I'm in Gretna, and am getting the WGNO signal on 26.1 in HD. Was able to watch Lost last night...
KebCam is offline
post #209 of 8255 Old 02-02-2006, 10:31 AM
raouliii's Avatar
The DT OTA channels broadcast in a true HD format, 16:9; either 1080i or 720p. However, when they are broadcasting a program that is SD format, 4:3, 480i, black, grey or graphic pillars are added on each side of the SD material and it is upconverted to the HD format. When you see pillaring, with few exceptions, it is upconverted SD and not true HD content.
raouliii is offline
post #210 of 8255 Old 02-02-2006, 12:17 PM
thebigtymer's Avatar
I tried a rescan and manual input. I'm having trouble getting it as well.
I had no problem picking it up before they did the remapping. I think some of us are having trouble handling the new remapping. I contacted WGNO, and they say they're having no trouble on their end.
thebigtymer is offline
