Lafayette, LA / Beaumont, TX / Lake Charles, LA - HDTV - Page 334 - AVS | Home Theater Discussions And Reviews
 4Likes
post #9991 of 10017 Old 09-24-2014, 09:33 AM
BPTTV's Avatar
Quoted: 13 Post(s)
POOR KLFY has signal issues thanks to the FCC. It and adj channel WAFB9 were full power under the analog rules...and had no problems but DTN interference curves were made assuming a 30ft high rcv antenna....and thus KLFY and WAFB were HIGHLY neutered in digital ERP....and any tropo that causes a cochannel to show up or impulse noise close to the rcving end will cause signal drop outs, etc....the FCC really needs to increase VHF hi (AND LOW) ERPs to a decent levels and throw out their idiotic interference level ideas for adj channels (but then anything -15dbC or higher inside the desired channel causes drop outs...one of the BIG problems with ATSC TV)....KPLC is running 65KW and actually has better coverage than their analog signal did...but KLFY is no where near that ERP (only 20KW).....WAFB is even worse (5.5!) and does not cover all of the Baton Rouge area (and its closer to BTR than KLFY is to LFT)...
BPTTV is offline
post #9992 of 10017 Old 09-24-2014, 04:41 PM
mp11's Avatar
Originally Posted by BPTTV View Post
If the connections seem ok then likely it is the power supply going south.....it looks like the specs are 12V DC...I take it there is no way to check the PS with the antenna connected (via a T or a specially cut piece of coax which would give you access to the center conductor for VOM testing)?? personally, I would go with an outside antenna and a CM7777 amp...you would be amazed at the extra signal you will get...with a 20ft high mounted VU90 (like the CM3016), it was picking up Houston stations 90+ air miles away!Of course no reason to have a lowband antenna right now...but that change after the repacking depending on the market
OK thanks, I actually have a CM 3671 w/CM 7777 that is used for DXing. It's been so long since I actually had a closeup look at the 7777-is there a way to connect an additional coax to feed my non-DXing TV from the 7777?
mp11 is offline
post #9993 of 10017 Old 09-25-2014, 02:08 PM
BPTTV's Avatar
Quoted: 13 Post(s)
Ahh if you mean is there a way to connect a second TV to the 3671/7777 setup, yes....merely install a coaxial splitter (rated at 50-900MHz) between the "DX" TV and the Power Supply that feeds the 7777...then use the splitter to feed a coax run to the other TV as well as the current coax to the "DX" TV...you will only lose 3db in signal levels....
BPTTV is offline
post #9994 of 10017 Old 09-25-2014, 04:12 PM
pierreboudreaux's Avatar
Just wanted to report KLFY is back to normal for me. Nothing I did...
pierreboudreaux is offline
post #9995 of 10017 Old 09-27-2014, 10:44 AM
BPTTV's Avatar
Quoted: 13 Post(s)
Maybe KLFY was having issues...
KAOB 27.2's channel is screwed up (it always seems to be one thing or another)...they are running some John Wayne movies (Chisum is one) and the audio is HORRIBLE! When it has played before, it was ok...but the last two showings (including today) has hum and LOW audio level...the local spots have been better overall....but then the other subchannels have audio levels issues......
You would THINK someone would fix the issues (aspect ratio on 27.2 and the audio issues as well as leveling ALL the sub-channels audio)....its not that HARD....
BPTTV is offline
post #9996 of 10017 Old 10-05-2014, 11:44 AM
BPTTV's Avatar
Quoted: 13 Post(s)
Kfdm 6.1
Still seeing a LONG lag in decode on 6.1 when tuning to it...takes longer than 4.x or 12.x for the channel to pop up...wonder what is going on??
Also anyone catch that LONG dead air during the Cowboys game today?? With less than 2 mins left in the 2nd quarter they went to black and stayed there for what seems like 5+ minutes..and then 6.2 ran a promo for 6.1...about programming on Monday but the voice over said "Later today on KFDM" HUH???? Someone in Master Control was not watching what they were doing it would seem....(yeah I know the promo was probably loaded wrong into the server or automation...still..............)
BPTTV is offline
post #9997 of 10017 Old 10-10-2014, 05:49 AM
hdtv6's Avatar
I don't see a long decode delay here in Anahuac.
I stopped at KFDM yesterday to visit and found out that the dead air was caused by sun spots. CBS was supposed to program the satellite system to use the backup satellite during the time that the main CBS satellite signal was out during the sun spot activity. But they forgot to do so. And, of course, the backup satellite receiver was on the wrong channel (different football game).
KFDM and the CW cross promote all day long, so it is not unusual for a promo to talk about the other channel. All the promos (commercials for TV shows) are produced so they can run on either station thus saving server disk space. So, I doubt that this was an error at all.
BTW: All Sinclair stations, including KFDM/CW are programmed by Sinclair Corporate computers "somewhere out there" (I forget the exact location, but you can bet that it's not Beaumont, Texas).
Remember that all above information (except for the sun spot problem) is how things were done when I was still working there. Your mileage may vary.
R
hdtv6 is offline
post #9998 of 10017 Old 10-11-2014, 04:38 PM
BPTTV's Avatar
Quoted: 13 Post(s)
Good to see you again Richard...the lag I see does not happen all the time...need to track it more but I see it as much as a 3 second delay before the screen shows anything...weird...I'll do some more noting..
In other notes:
The FCC issued its 3rd NPRM in the LPTV transition to digital...Amazingly, they "conclude" to put off the required move from September 1, 2015 to a later date but still require the Class As to move...also the sharing plan (yeah that will work well) would only "guarantee" a LPTV to have enough b/w in such arrangements for a SD channel..lovely...
Someone really threw the money around evidently....
BPTTV is offline
post #9999 of 10017 Old 10-12-2014, 09:19 PM
BPTTV's Avatar
Quoted: 13 Post(s)
Wow, the Trinity River sends Dallas' waste waters down and now they send the Ebola infected things down here..
http://www.watchfox29.com/content/ne...ZdRFlFgfg.cspx
BPTTV is offline
post #10000 of 10017 Old 10-25-2014, 05:40 PM
BPTTV's Avatar
Quoted: 13 Post(s)
KEBQ showing same thing 4.2 is!
KEBQ LP9 is showing the same football game that is on Bounce on 4.2..UTEP vs UTSA.......
Wonder how they pulled that off..I have seen 9 cut away for some non commercial ads at times while the game is still on 4.2...so I am beginning to wonder....
BPTTV is offline
post #10001 of 10017 Old 12-24-2014, 11:08 AM
mp11's Avatar
What happened to OTAhead? Haven't seen a post since August. As busy as this place once was...seems to be on life support now.
mp11 is offline
post #10002 of 10017 Old 12-24-2014, 08:33 PM
MIKE D-CO5's Avatar
Christmas and the Holidays happened. That and nothing really new has come about ota channels in our area.
MIKE D-CO5 is online now
post #10003 of 10017 Old 12-25-2014, 12:00 AM
BPTTV's Avatar
Quoted: 13 Post(s)
MMM let's see....
12.1 a few nights ago was broadcasting MeTV (but not the same feed as 12.4 was showing!!!!) A text msg to one of the 12 engineers cleared that up but I wonder how long that HAD been going on
12.5 seems to be locking up more often..right now, it is stuck on a slide before the beginning of Family Guy....good work guys
22 is showing more black than anything...Black SCREEN that is.....it swapped Soul of the South back to 9 (who watches that .....seriously, NOONE except US knows 9 even exists!)...and the Spanish programming on 22 is not even interesting....the license (if you can call it that) is still in limbo...for those not in the know, 22 claimed and filed for a digital license in 2012....and got a license to cover (that means they built the digital plant and it was on the air!)....1st lie...but they never have...still in analog (and a horrible analog too)....then they tried to renew the DIGITAL license...and got caught....they are now asking for a STA to keep the analog on the air (though it should not have been since 2012!!!) and claims they "forgot"...and was going to renew the digital at the "new" tower site....which I think was proposed to be 4s old tower...and I bet Sinclair doesnt know about that (lie #2 or 3 depending on how you look at it)...and they ID improperly...(only as KUMY...not KUMY-LP, which is not a legal ID or transmission..no analog license exists...nor KUMY-LD as they are not digital!!)...really painted themselves into a corner here...expect a fine from the FCC..
27?? dont get me started...audio all over the place on all subchannels....27.2 still SQUEEZING sides in on 4x3 so you have to make the TV go WIDE to see it in proper aspect....and that makes all the other channels look wide or fat!!! The terrible audio is.....terrible.....If the owner (and I never can spell his name right) wants to run a TV station, GEESH man, get it right..its NOT THAT HARD to set audio levels...whoever is doing local spots needs to be shot....a DVD they play MAY have somewhat ok audio but the 1st spot set they go too is MUFFLED and DISTORTED..In fact, 27.2 showed "Its a Wonderful Life" before NBC did..as well as "Miracle on 34th Street" AND "the Santa Clause" but they did NOT have permission from the owners to do so...and the audio on all three was low with the highs rolled off....One day they are going to get a BIG fine (not from the FCC but from the movie owners!)
In the time I typed the above, I just flipped back to 12.5..the static slide saying "this program contains some material....." Bla bla bla..the one before Family Guy and American Dad get shown...sure enough, its still there....and the episode would be over in 2 minutes anyway...so they wasted 30 mins (how many spots did they not run??)....wow.....
I remember in the 70s and 80s...the engineers and MC ops took pride in the on air signals...now, noone seems to give a s.......I bet Harold and Charlie are spinning in their graves..(EDIT: Some folks thought I may have slighted Richard on the above...NO, one thing, Richard is still among us..and we hope for a long time....and this happening is due to corporate actions....however, before the massive groups started consolidating MC and other programming from one location, the control was more local..Radio has gone down the same path....what you here on a CC/iHM station here, you'll hear the same (garbage) else where...when I was living in Dallas, I went to the Dayton (OH) hamvention..the largest hamfest in the US....A friend of mine, an EE at TI, and I were riding in his rental to grab some lunch...he mentioned about a local FM he USE to love to listen to when he was in town but "lately" they had started to sound like all the others, including KEGL in Dallas...sure enough, the TOH came up and "Wxxx, Dayton.... A Clear Channel radio station" I looked at him and said "Need I say more??"
Time to pack up and move....this market is headed downhill fast (radio was 1st---now TV)
BPTTV is offline
post #10004 of 10017 Old 12-30-2014, 05:01 PM
BPTTV's Avatar
Quoted: 13 Post(s)
Just noticed KFDM added 6.3!!! 'GRIT' Tv channel...wish it had been Antenna or THIS......the movie playing right now looks grainy though....obviously 480i....
(Hint hint for adding something to 4; Antenna TV would be great)..
BPTTV is offline
post #10005 of 10017 Old 12-30-2014, 06:35 PM
unclehonkey's Avatar
Quoted: 94 Post(s)
Liked: 26
Sinclair added Grit in most of their markets today
unclehonkey is online now
post #10006 of 10017 Old 01-05-2015, 08:22 PM
mvcg66b3r's Avatar
Quoted: 26 Post(s)
Liked: 1
Potential Sinclair subchannel shuffle in Beaumont:
KFDM: 6.1 CBS (1080i HD), 6.2 FOX (720p HD), 6.3 Bounce (480i SD), 6.4 Grit (480i SD)
KBTV (spun off): 4.1 ????
Sinclair could buy KIPS-LD and move CW there.
One person's craziness is another person's reality. - Tim Burton
mvcg66b3r is offline
post #10007 of 10017 Old 01-05-2015, 08:29 PM
MIKE D-CO5's Avatar
God what a mess. I hope they don't do that ,it would really screw up my ota channels and guide information on my DISH hopper.
post #10008 of 10017 Old 01-05-2015, 09:03 PM
Quoted: 94 Post(s)
Liked: 26
disregard what he is saying. He is living in "mythical land" that any current Sinclair duopoly will be nuked.
Apparently he feels the need to poison each market with a Sinclair station with that crap (folks seem to do that at radiodiscussions)
MIKE D-CO5 likes this.
post #10009 of 10017 Old 01-06-2015, 07:50 AM
mvcg66b3r's Avatar
Quoted: 26 Post(s)
Liked: 1
The posts I made here and on other threads are just pure speculation on just what might happen in these markets, with the FCC's crackdown on JSAs/SSAs and the impending incentive auction. Some of you may have been offended, and for that I apologize.
post #10010 of 10017 Old 01-14-2015, 06:21 PM
BPTTV's Avatar
Quoted: 13 Post(s)
Yeah, saw where Sinclair had agreed to put it on a lot of their stations....HORRIBLE quality video...and a lot of times they aspect ratio is wrong (Like 27-2!)...
I never liked grits....and this channel fits the name well...They even edited a showing of "The War Wagon"....Something 27-2 doesn't do (but then I wonder if 27 is paying the royalties for some of their matertial...it's all off DVD and right in the middle of a disk track change but not at a good point, they may go to commercials.....yeah I know they are a low power...but cmon.....I've seen better on small stations)....
Still say Antenna TV would have been better.....Bounce doesnt make sense...they will show movies that are more white orientated....(it has one or two black actors but the main leads are white, etc)....if they are trying to program for the black community, they are not doing it right IMHO.....is 4.2 on cable anyway? There is NO promotion of it on any other channel like the CW gets cross promoted on 6.1 and 29.1..
BPTTV is offline
post #10011 of 10017 Old 01-14-2015, 06:30 PM
BPTTV's Avatar
Quoted: 13 Post(s)
Remember, 4.1 on 40 has more power than 6.1 on 25...so why would they spin off the better signal?? Could swap channels but 40 is likely going to have to move anyway with the repacking garbage....so I doubt anything will happen until then..
KIPS?? you must be joking.....it could not make it to South Beaumont and barely to KBMT's studios...
BPTTV is offline
post #10012 of 10017 Old 02-26-2015, 05:08 PM
BPTTV's Avatar
Quoted: 13 Post(s)
KFDM signal??
Anyone else notice drop outs on KFDM tonight? They were fine earlier...but around 6pm, I switched from watching national news to 6.2 to watch KOTH and there was massive pixelation..12.1-12.4 (which usually gives me the most signal issues) was no problem and neither was 4.x..even 27.x was ok...
At one point, lost 6's RF signal all together...moved the antenna in a serious move and finally got it back...
Thought maybe it was 6.2 choking but on 6.1 and 6.3, saw the same issues.....so must have been RF related...hope the IOT is not about to die..
Never have had issues with 6.x's signal before...and no new local issues afaik....
weird
BPTTV is offline
post #10013 of 10017 Old 04-01-2015, 04:44 PM
JoesBros's Avatar
The last couple of days I've had issues picking up all of KBMT channels and KAOB signals. I've done nothing different to my antenna. All I receive is KBTV KFDM and KITU. UPDATE: I bought a signal booster and started picking up all of the 12's again but nothing from KAOB I'm assuming they are down.
JoesBros is offline
post #10014 of 10017 Old 04-05-2015, 07:35 PM
MIKE D-CO5's Avatar
I put a cheap Aspen distribution amplifier from Solid Signal on my ota antenna, that is split to like 5 different things that need ota and I can now pick up KAOB 6 channels too. I also can get Mytx and Telemundo Fox without drop outs. The signals are still low, like 60s to 70s ,but no drop outs . OF course I get not guide data for these channels from DISH ,since they don't seem to care anymore about ota sub channels. I notice KAOB doesn't even get psip data over my tv tuner either. I thought all ota channels were supposed to put out psip data ?
post #10015 of 10017 Old 04-06-2015, 12:01 PM
JoesBros's Avatar
I never had any issues with KAOB until now. Even with a booster still nothing so I have no clue. I notice 12.5 and 12.6 not doubling up like they normally do.
JoesBros is offline
post #10016 of 10017 Old 04-10-2015, 09:37 PM
BPTTV's Avatar
Quoted: 13 Post(s)
KAOB is cochannel with K27JJ out of Warren which carries 12.1-12.4....(both directional away from each other)...tropo changes that and causes any DTV decoder to mute....OR a full power DTV on 27 somewhere is coming in as well...but I just looked and no KAOB either...mmmmmm interesting..lightning maybe?
As to EPG, no, that is optional....PSIP on Low Power digitals (LD) just requires the virtual channel to be shown...anything else is up to the station's discretion..
Also 27.2 always shows movies in squeezed format so you have to tell the TV to manually go wide..and then it shows the movie in the right aspect...(HELLO???? Someone needs to fix that)
Just caught an RMT EAS on 29.1 for the first time...horrible....(well audio was great BUT)....NO scroll!! WTH????
BTW if you see ENGLISH in the scroll of 12.x, there is a long story behind it.......it was almost Klingon
BPTTV is offline
post #10017 of 10017 Old Today, 07:49 PM
MIKE D-CO5's Avatar
Bought a second Aspen distribution amplifier from Solid Signal for my Dad & Mom and plugged it into their ota coax fed from a diplexor -just like mine at my house in Nederland. They live about 5 miles down in Pt.Arthur and have had ota drop outs for years since I hooked up their DISH satellite and ota antenna. Even their strongest ota channels would fluctuate. This amplifier worked on their setup as well and now they are getting no drop outs on ota channels and they even get 7.1 from Lake Charles that I don't get. I fixed their old coax that had been in their attic last summer because they were having satellite channel drop outs . I looked at the coax and it had frayed piece that was actually sparking . Now no satellite or ota drop outs. They have a coax run that is about 100 ft of coax from the roof and the dish to down inside their great room. This amplifier that I paid $16.50 for , is doing the job and it has fixed years of problems with their reception.
post #10018 of 10017 Unread Today, 08:00 PM
MIKE D-CO5's Avatar
According to Wikipedia page KAOB is a low powered station in Beaumont,Tx and is broadcasting on channel 27.
It consists of 6 channels:
27.1 is Conexzion tv
27.2 is Vidor Television
27.3 is Family channel
27.4 is Punch tv - ( I get spanish speaking when I view this one)
27.5 is PBJ tv.
27.6 is Tuff tv.
