Birmingham, AL - HDTV - Page 158 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #4711 of 4738 Unread 09-30-2014, 04:38 AM
Quoted: 565 Post(s)
Liked: 312
Originally Posted by bhambrad View Post
So Far I have at times been able to pull in 8.1 CBS Montgomery, 19.1 CBS Huntsville, 32.1 ABC Montgomery and a religious channel at 29.1
I picked up a CM 7777 and it showed better signal strength over the 7778, but the image didn't appear on my tv. I found a titan 1 7778 in my garage that I purchased about 10 years ago to pull in abc and never used it because I lost my power supply. It is on par with the CM 7777 (within a db or so) so I am going to return the 7777. I think my CM 3044 4 port dist amp is messing things up. I have tried direct and doesn't have enough gain. I am averaging -20.5 - 22.5 or so on 19.1 CBS from my attic from the preamp showing solid "digital" on the signal meter. And suggestions after that? I need to feed at least 2 (preferably 3 tvs). I can't pull in anything distant right now (sunday afternoon football game time) only at night and it's sporadic at best.
Is moving your antenna out of the attic onto the roof not an option?
JimP is online now
post #4712 of 4738 Unread 09-30-2014, 04:45 PM
bhambrad's Avatar
Quoted: 21 Post(s)
It would be the last resort. I live in a subdivision and it wouldn't be ideal for several reasons.
bhambrad is offline
post #4713 of 4738 Unread 09-30-2014, 05:29 PM
bhambrad's Avatar
Quoted: 21 Post(s)
Originally Posted by 4bama View Post
I use this for a distribution amp that takes the output of my Dish receiver and feed it through a 4-way splitter to 4 TV's scattered in my house...be worth a try. It's has a 36db gain with adjustable power output and an FM trap switch that I set as "Out":
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
Are you using any kind of pre-amp or just this amplifier?
bhambrad is offline
post #4714 of 4738 Unread 09-30-2014, 05:54 PM
kodaker's Avatar
ABC 33/40 and Uverse
Uverse apparently didn't know that 33/40 was switching to 68.2 today. They have no listings for 33/40 and so recording can't be done. Wonder when this will be corrected.
kodaker is offline
post #4715 of 4738 Unread 09-30-2014, 07:03 PM
tigerfan33's Avatar
Quoted: 59 Post(s)
Liked: 31
I'm not familar with Uverse but can you go into settings add the channel to your favorites list. It is channel 67 on Directv should be the same channel on Uverse.
tigerfan33 is offline
post #4716 of 4738 Unread 09-30-2014, 07:05 PM
kodaker's Avatar
The TV station put out a notice that to get the guide info back, you have to power the DVR off and on. It worked.
kodaker is offline
post #4717 of 4738 Unread 09-30-2014, 11:03 PM
D. Shadow's Avatar
although i don't live in the Birmingham DMA (besides watching live streams from ABC 33/40's website when severe weather breaks out in the area (hint. the April 27 2011 tornadoes) which eventually rolls into Georgia); but from what i've recently read from wikipedia, seems like Sinclair may "save" WCFT-TV channel 33 by selling it to Howard Stirk Holdings for $50,000 (possibly re-launching it into an independent station in the near future) while on the other hand fully dissolving WJSU channel 40 all together
http://rbr.com/sinclair-and-stirk-en...-tv-fire-sale/
http://www.tvnewscheck.com/article/7...3-Deals-18-75M
and one other question thats popped in my head (though it could be a "dumb" one...sorta), why cant they just convert WBMA-LD into a full power station like for example "WBMA-TV" so that way it will actually cover the entire market plus, there would be no reason to place ABC on a subchannel of a lesser network station (like MyNet or The CW)
D. Shadow is offline
post #4718 of 4738 Unread 10-01-2014, 03:05 AM
Trip in VA's Avatar
Quoted: 237 Post(s)
Liked: 89
Send a message via AIM to Trip in VA Send a message via Yahoo to Trip in VA
That's not how TV licensing works. Sinclair would have to file for a new full-power TV station, participate in an auction to win the channel, and then build it. And there's a freeze on new TV stations, so that's not something that can be done.
Even if they did that, suddenly Sinclair would own three stations in the market, putting them in violation of the ownership rules, requiring them to shut down or sell the new full-power WBMA. ABC would be back on WABM again, defeating the purpose.
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is online now
post #4719 of 4738 Unread 10-01-2014, 05:49 AM
4bama's Avatar
Dish Network vs OTA antenna
Well, of course I don't use a pre-amp with the Dish receiver...it's in my basement and provides its own power/amplification to the dish, so I only use the amplifier to boost its output to other TV's, some about 100' from the Dish Receiver.
Now for my OTA antenna (see my signature below) I do use the CM-7777 pre-amp, the antenna Pre-amp is about 100' from the basement where the pre-amp power supply is located, and I also use that amplifier to boost the output of the pre-amp to my TV's, also some about 100' from the basement.
Dish 622 DVR, B'ham locals via Dish, Montgomery locals OTA, Winegard on 70' tower + CM7777 preamp
4bama is offline
post #4720 of 4738 Unread 10-01-2014, 04:07 PM
Tom Servo's Avatar
Did they actually shut WCFT down on schedule? I've heard from multiple sources that WBMA-LD and WJSU are both still on the air.
Sent from my Droid DNA using Tapatalk 4
Tom Servo is offline
post #4721 of 4738 Unread 10-01-2014, 05:45 PM
D. Shadow's Avatar
WCFT is "silent" for the time being until its sold off to HSH (Howard Stirk Holdings), WBMA-LD is still on since thats the main ABC station for the market....but WJSU is shut down for good
post #4722 of 4738 Unread 10-01-2014, 05:58 PM
Tom Servo's Avatar
Thanks for the information. Last I heard this evening around 6 pm was that 40.1 was still on.
post #4723 of 4738 Unread 10-01-2014, 06:50 PM
RickD_99's Avatar
Just checked out the ABC-HD PQ on DirecTV channel 67 and compared it to 68-2 OTA and to my surprise I found that the OTA PQ looked substantially better (given that someone earlier posted that DirecTV was getting a fiber feed of the channel). Of course I just turned 60 this past July so that fact might have some relevance to this observation
I live off Valley Avenue in Homewood so I have been using a Mohu Leaf non-amplified indoor antenna for my OTA needs. I was able to get all locals except WBMA-LD. So for me it's great that I can now get the ABC-HD signal OTA when rain fade knocks out my DirecTV.
My <somewhat> 3D YouTube Channel: https://www.youtube.com/user/davisrick393/videos
RickD_99 is offline
post #4724 of 4738 Unread 10-01-2014, 06:52 PM
D. Shadow's Avatar
speaking of which, the last wikipedia update (from someone who lives near the 2000ft tower of WCFT) the station is still on the air re-transmitting WBMA-LD/ABC programming; havent heard (or read) anything concerning WJSU channel 40 still being on.
Tom Servo likes this.
post #4725 of 4738 Unread 10-02-2014, 12:30 PM
bhambrad's Avatar
Quoted: 21 Post(s)
40-1 is still broadcasting that Heartland Network channel. The others are showing up but black screen.
bhambrad is offline
post #4726 of 4738 Unread 10-11-2014, 02:06 PM
D_Thomas's Avatar
Liked: 0
On the FCC website, an application was accepted for filing on 10/1/2014 to assign the WJSU-TV license to HSH Birmingham.
So it appears that Sinclair is selling off both WCFT-TV and WJSU-TV to Howard Stirk Holdings. If all this is approved, HSH would have coverage across the entire DMA (except for WBMA-LD that Sinclair retained).
D_Thomas is offline
post #4727 of 4738 Unread 10-11-2014, 07:02 PM
Tom Servo's Avatar
Does anyone know anything about Howard Stirk Holdings' plans for the station(s)? They own a CW affiliate in SC and an NBC in Flint, Michigan. HSH is wholly owned by conservative political commentator Armstrong Williams. I haven't really heard any word on what potential programming might be.
WCFT's purchase agreement is kind of interesting, and answers some questions I had about who is getting what. HSH will get the "antenna and transmission system" as well as the license, for $50,000. They will pay $4,000 a month to Sinclair for tower lease, studio space and a STL link to keep the broadcasts alive and keep the license active. Part of the agreement also states that HSH will not elect to invoke must carry for the station. I'm not exactly sure what that means as far as whether all cable companies in the DMA will carry the signal or not.
WJSU's agreement seems similar, but I didn't see anything about paying Sinclair for studio space or anything like that. The license and antenna/transmission system will cost $50,000.
post #4728 of 4738 Unread 10-13-2014, 04:19 AM
Trip in VA's Avatar
Quoted: 237 Post(s)
Liked: 89
My guess is that they're having HSH hold the stations at minimal cost (with minimal programming--maybe just infomercials?) just to hold onto them in case the ownership rules get thrown out in court or updated under a new President and Sinclair can buy or operate the stations after all.
- Trip
N4MJC
RabbitEars
post #4729 of 4738 Unread 12-04-2014, 05:23 AM
tigerfan33's Avatar
Quoted: 59 Post(s)
Liked: 31
Looks like another change in pq ABC WABM. Back to the same sharp pic when they first changed over.
Did they dump some unneeded sub channels?
post #4730 of 4738 Unread 12-04-2014, 05:40 AM
RickD_99's Avatar
Just checked it out and I agree it looks great. I prefer 1080i me self but this proves how good 720p can look when presented properly.
RickD_99 is offline
post #4731 of 4738 Unread 12-04-2014, 12:45 PM
Tom Servo's Avatar
James Spann posted on Google+ thee other day that ABC is back on WJSU. It's on 40.2.
Sent from my A700 using Tapatalk
post #4732 of 4738 Unread 12-04-2014, 01:10 PM
bhambrad's Avatar
Quoted: 21 Post(s)
AWESOME! How did they swing that? Anyone have the info? It looks SO much better! #happycordcutter
bhambrad is offline
post #4733 of 4738 Unread 12-05-2014, 05:33 AM
Liked: 0
Hello. Is anyone having trouble picking up WIAT 42?
I haven't been able to pick it up for some time. I am 58 miles south of transmitter using CM 7777 and CM 4228 for uhf. I use separate vhf antenna for 23.1. I receive channels ,6, 13, 17, 21, 23, 40, and 68 from Birmingham market but can not get 42.
Squareace is offline
post #4734 of 4738 Unread 03-23-2015, 12:30 PM
Liked: 0
kimberly, al 35091
I'm trying with a couple of different indoor antennas and can't seem to get 10-1 or 13-1 (NBC), even though they are the same distance/degree as Fox, CBS, etc. I'm using a homeworx flat antenna (amped) and a GE "bar" antenna that is amped for up to 40 miles. Any reason why it wouldn't be picking up the PBS and NBC stations, even though FOX, ABC, and CBS come in fine with at least a "GOOD" signal?
Chris
littlechris1977 is offline
post #4735 of 4738 Unread 03-24-2015, 06:00 AM
Liked: 0
Chris
Bumping for help.
post #4736 of 4738 Unread 03-24-2015, 11:43 AM
Liked: 0
Chris
Not sure. Try a different tv or converter box to rule that out. Try a different antenna if one is available.
post #4737 of 4738 Unread 03-24-2015, 12:14 PM
ohio41's Avatar
Bumping for help.
10 and 13 broadcast on VHF; others are UHF. You need a VHF capable antenna.
ohio41 is offline
post #4738 of 4738 Unread 03-29-2015, 07:03 PM
Liked: 0
I'm having trouble picking up nbc13. I'm in Trussville using a Winegard FL-55YR FlatWave. I have now issues with the other channels. For the people that can get it, what antenna are you using.
beau_cephus is offline
post #4739 of 4738 Unread 06-28-2015, 06:36 PM
bhambrad's Avatar
Quoted: 21 Post(s)
Have you been able to pull in NBC 13? That indoor antenna is amplified, right?
bhambrad is offline
