Birmingham, AL - HDTV - Page 22 - AVS Forum | Home Theater Discussions And Reviews
 7Likes
post #631 of 4781 Old 06-26-2004, 12:26 PM
BrettTRay's Avatar
Has anyone had any luck receiving B-Ham Hdtv OTA from Gadsden?
Any info would be great
Mitsubishi WS 55313
Dish 811/301 w/ AEP, Voom, HD pack, Locals, OTA locals
BrettTRay is offline
post #632 of 4781 Old 06-26-2004, 12:52 PM
jafo9's Avatar
Originally posted by bearmur
Fox is not vhf-hd(channel 50). Channel 5 is ABC Tuscaloosa channel 33. If you get 33 and have a low band vhf antenna pointed the same way then you can get channel 5(33-1,33-2). 40-1 will be channel 9 and is waiting of FCC approval for a CP. You will not get it with an indoor antenna.
bearmur: thanks for the reply. i was always the slow one in the family. i know this has been covered but i think i'm finally getting it. i was looking at the channel and not the frequency assignment in antennaweb and confusing myself. it looks like a handful of the ota stations broadcast one channel in vhf and the other in uhf. is there an advantage to that? thanks again, brian.
jafo9 is offline
post #633 of 4781 Old 06-26-2004, 01:17 PM
bearmur's Avatar
FCC assigned the channel. Our owners found VHF channels that would fit in digital. They are cheaper to operate, so we ask if we could change.
bearmur is offline
post #634 of 4781 Old 06-26-2004, 03:41 PM
jafo9's Avatar
bearmur: thanks for the info
on another note. anyone have any suggestions as to where to buy an antenna for my attic around here in b'ham. i think i'm gonna take the plunge and put one in my attic. thanks all, brian.
jafo9 is offline
post #635 of 4781 Old 06-26-2004, 05:54 PM
Mike4AU's Avatar
jafo9--go to Forbes Distributing for the Channel Master OTA. A lot of us are using the CM 4228.
Mike4AU is offline
post #636 of 4781 Old 06-26-2004, 06:26 PM
jafo9's Avatar
thanks mike4au
are they open tomorrow (sunday)? also, any recommendations for vhf and a combiner? also, will i need an amp to run from the attic of a 2 story house to the first floor? thanks, brian.
jafo9 is offline
post #637 of 4781 Old 06-26-2004, 08:07 PM
Mike4AU's Avatar
Brian, I am pretty sure that Forbes is not open on Sundays.
I am, by far, not an expert on OTA installations. That said, I ran 100 feet of RG6 from my attic (2 story house) down to my basement and back up thru the floor to my STB, without a pre-amp.
From what I have gleaned so far, some folks have needed a pre-amp and some have not.
Feel free to PM me and I will try to help.
Mike
Mike4AU is offline
post #638 of 4781 Old 06-27-2004, 05:50 AM
rkr0923's Avatar
BrettTRay, I'm not in Gadsden but close by in Boaz. I do get CBS and NBC OTA, and a few others like PBS, UPN I think, but no FOX or ABC
rkr0923 is offline
post #639 of 4781 Old 06-27-2004, 08:19 AM
BrettTRay's Avatar
I was on the Fox 6 website and it said that they went live in june with 720p. Yet on here people have said that it would be august at the least. Does anyone know if they have already started with the HD feed OTA yet.
Mitsubishi WS 55313
post #640 of 4781 Old 06-27-2004, 08:56 AM
taz291819's Avatar
Fox Network has not started sending a HD signal yet, so no, Fox 6 is not sending a true 720p, just an upconvert.
Currently testing 3D with Sammy DLP, shutter glasses, and HTPC
taz291819 is offline
post #641 of 4781 Old 06-27-2004, 01:35 PM
hartwise's Avatar
Originally posted by jstuck
Hopefully...
I was wondering if any of you guys are in Tuscaloosa. If so, what sort of signals with what sorts of antennas. We are moving into the Hillcrest area and would like to start investing in HD. We're using a satellite for their packages but would also like locals. Any advice would be appreciated!!!
I'm in Tuscaloosa (Alberta City area) and get strong signals for ABC, CBS, NBC, PBS and channel 68 (UPN?). I'm using an older Radio Shack VHF/UHF antenna with a Channel Master 7777 preamp. Before I added the preamp I was able to get a good signal with CBS but NBC and PBS were never strong enough to be stable. I can't get FOX and Channel 21 (WB?) comes and goes.
Since you are a bit further away from the towers you may have more trouble getting everything but I think you should be able to with a good long range antenna. You should be able to get ABC with just a pair of rabbit ears. I experimented with rabbit ears just to see if I could get ABC when they went live and had no trouble picking up the signal.
hartwise is offline
post #642 of 4781 Old 06-27-2004, 05:24 PM
Bullsteak's Avatar
Question about ABC:
I'm pulling in a strong OTA signal for channel 33 out of T'town. With the right VHF antenna, pointed in the right direction, I should be able to get the HD signal, right?
I made a feeble attempt about a month ago with a couple of indoor VHF antenna's, but had to take them both back. I 'm getting the itch to get set for MNF, so I want to get the proper equipment in order to know that if I can't get it, then I just can't get it.
Bullsteak is offline
post #643 of 4781 Old 06-27-2004, 07:33 PM
bearmur's Avatar
Yes. I get it over 80 miles away.
bearmur is offline
post #644 of 4781 Old 06-27-2004, 07:41 PM
Bullsteak's Avatar
Wow, you get it all the way from Munford? That gives me hope! I'll review the forum for your setup and will get to work on it right away.
post #645 of 4781 Old 06-28-2004, 06:34 AM
jafo9's Avatar
just wanted to post an update on my attic antenna in cherokee bend south. i bought a cm 3018 which is a combo u/v/f antenna. it a has about 8dB UHF gain vs. about 12 for the 4228. installation wasn't too bad although at 113 inches long its fairly ackward to mount. i used a pvc pipe for the mounting rod. right now i get all the channels listed on antenna web in the ~260 degree direction in the yellow, green and red zones. i haven't gone back up to tweak it and its probably pointing too far east. my sir-t165 didn't pick up 33 on its initial scan. the next step is for me to try and adjust the aiming. i also bought an indoor amp (cm but i dont' remember the #) which i'll probably install after i run a power line to see if it makes any difference. also, i didn't pick up 6.1 (50) on my scan last night. was fox down?
thanks for everyone's input.
jafo9 is offline
post #646 of 4781 Old 06-28-2004, 10:17 AM
SteveHorn's Avatar
Did anyone have problems getting Crossing Jordan (NBC DTV 52.1) in HD last night? The pix I got was a smaller but properly proportioned 16:9 version (bars on top, bottom, sides). Other HD channel broadcasting HD material (PBS 10.1) appeared fine (42.1 was not in HD at that time). I called chan 13 and asked the news desk to ask the control room to "throw the HD switch". She told me that there "is no switch" and that "it was always on". I thought this odd, based on past posts here. Anyway, the pix never in that hour to my knowledge (I left HD and went to 13 on satellite to prevent burn in of the pix) changed to an HD pix. Just curious.
SteveHorn is offline
post #647 of 4781 Old 06-28-2004, 10:39 AM
bearmur's Avatar
Both of nbc's hd shows last night were sd. NBC problem not NBC13.
bearmur is offline
post #648 of 4781 Old 06-28-2004, 05:00 PM
SteveHorn's Avatar
Bearmur, thanks for the NBC info. I guess we're still on the leading/bleeding edge if the networks are having issues with HD. Well, one thing is for sure: NBC 13 knows at least one person was paying attention. Too bad the news desk couldn't tell me what you did. Some irony there...
post #649 of 4781 Old 06-28-2004, 06:31 PM
THancock's Avatar
Bearmur:
I'm not getting DD sound (only PLII) on the HD broadcasts from 33.1. Is there a problem that you're aware of?
Tom
THancock is offline
post #650 of 4781 Old 06-29-2004, 03:53 AM
bearmur's Avatar
I am not getting 5.1. I checked with Gary yesterday. He said ABC may have changed something on their end that he would call and check.
bearmur is offline
post #651 of 4781 Old 06-29-2004, 07:23 AM
Mike4AU's Avatar
Do I Need a pre-amp?
I am receiving all locals via a CM 4228 (W/O a pre-amp) mounted in my attic. When it is stormy, I get some pixelization, mainly on ABC. Would a pre-amp stop or reduce that pixelization? If so, what do you think about a CM 7777.
I will admit that part of me wants to leave well enough alone. I feel fortunate to receive all locals, especially given the problems that others are having.
What do you guys think? Thanks!
Mike4AU is offline
post #652 of 4781 Old 06-29-2004, 09:44 AM
bearmur's Avatar
If I was getting ABC on a 4228 I would add a VHF antenna & a cm 7777 to improve the signal. If I was not going to add a vhf antenna I would not disturb my system for fear I would not be able to get it set up again.
bearmur is offline
post #653 of 4781 Old 06-29-2004, 10:33 AM
Mike4AU's Avatar
Interestingly, I tried to get ABC with a separate VHF and was not successful. I just left it up, next to the CM 4228. Then one day I rescanned for locals and ABC came in on the 4228. I don't even have a lead connected to the VHF.
I am tempted to add the pre-amp, but I am reminded of the old saying re "if it ain't broke, don't fix it!" I think you and I are on the same page.
Mike4AU is offline
post #654 of 4781 Old 06-29-2004, 11:20 AM
THancock's Avatar
If you did anything, an in line signal amp would be cheaper and easily removed/returned if it didn't help.
Tom
THancock is offline
post #655 of 4781 Old 06-29-2004, 11:36 AM
celliott's Avatar
Anyone tried a Channel Master 3671? I think I am going to go get one this week and mount on the roof. That and a Channel Master 0064 amp. Any thoughts on these two products? I live in Vestvia on Wisteria, So far indoor antenna's havent worked worth anything. I am hoping to get ABC, CBS, FOX, and NBC. Does anyone think that I will need a rotor motor for the antenna? Or should this be enough?
celliott is offline
post #656 of 4781 Old 06-29-2004, 11:54 AM
celliott's Avatar
OK, I didnt do my research very good. The 3671 over 10 feet long. Any other suggestions on a UHF/VHF model that might pick abc from vestavia?
celliott is offline
post #657 of 4781 Old 07-04-2004, 07:41 AM
jafo9's Avatar
did anyone else see the braves play the red sox on the braves hd channel last night on charter cable. i've never seen that channel before on the charter line up. it looked more like 480p but still pretty cool and no commercials.
jafo9 is offline
post #658 of 4781 Old 07-04-2004, 08:48 AM
Bham Slugger's Avatar
I just noticed the added channel this morning....... just in time for the Braves-Red Sox game at noon today. It is sandwiched between ESPN HD and Discovery HD.
If Charter could only add the other two locals, HDNET and INHD, we'd be set!
Bham Slugger is offline
post #659 of 4781 Old 07-04-2004, 09:05 AM
Doctor J's Avatar
Mr Eliott
Your 1st source should be antennaweb (I'm not priviledged to post url)
(google search will put you there quickly)
If you put in your Derby Downs address you will see that ABC-DT 5-1 is not listed.You are "down" below the ridges and reception will be iffy.
The ABC-33 tower is west of you {south of Jasper} and unless you are up on Panorama Dr or Shades Crest Rd reception is difficult.
If you have a CLEAR west view options include an outside tower with either a DEEP FRINGE class combo antenna or two antennas adding a VHF only or even better a single channel {5} VHF antenna and using a Channel Master Titan 7777 preamp. A single antenna would require a rotor to see north (UHF) and west (VHF).
Stark Electronics (again no url allowed) has an infinite selection of antennas online. Forbes Distributing on 4th ave south can be a local source of most mainline equipment.
Good luck! I've tried multiple options and ABC 33-40 is a no-show in Magnolia Ridge.
Doctor J is offline
post #660 of 4781 Old 07-04-2004, 12:20 PM
David Richardson's Avatar
I had the opportunity to work closer with the Samsung HD Directv STB. Switching back and fourth from the LG (Hughes, Zenith, Sony) version the difference in tuners was significant. No PBS with zip set to 00000 on the Sammy, and frequent breakups on half the other channels. I was able to pull in ABC 5.1 with the channel master 2001 on both.
The Sammy certainly had a Digital tuner that was less than acceptable. May work for some locations where the moon lines up with the ocean currents and the wind blowing in from town but I would find a version of the LG if you plan on buying one today.
Dave
David Richardson is offline
