San Francisco, CA - OTA - Page 159 - AVS Forum | Home Theater Discussions And Reviews
 165Likes
post #4741 of 14985 Old 06-19-2009, 10:09 PM
Larry Kenney's Avatar
Quoted: 513 Post(s)
Liked: 80
Originally Posted by Bill View Post
How can KGO drop the strength down to only 24 kW? What is ERP?
ERP is Effective Radiated Power... the power that is equal to the transmitter output, minus line loss, times antenna gain and height advantage. That is the standard used by the FCC for all stations. I have no idea what the KGO transmitter is putting out, but their authorized power is 24,000 watts ERP. That's all the FCC would approve for them at their antenna height.
Remember, High VHF takes a lot less power to cover the same area as a UHF station. KGO at 24 kW digital is equivalent to their 316 kW analog on channel 7, since digital is measured as average power, analog was measured as peak power.
Stations on Low VHF needed even less power to cover the same area.
Unless you've studied electronics, this is all difficult to understand, but it all has to do with the frequency characteristics.
Larry
SF
My complete SF Bay Area DTV Station Lists: http://www.choisser.com/sfonair.html
Lots of Broadcasting links and information: http://www.choisser.com/broadcast.html
Live reception scans from my HD Home Run receivers: http://www.larrykenney.com/hdhr/
Photos and info on my antennas: http://www.larrykenney.com/tvantennas.html
Larry Kenney is offline
post #4742 of 14985 Old 06-19-2009, 10:15 PM
Quoted: 513 Post(s)
Liked: 80
Originally Posted by DPlettner View Post
...an Antennacraft Y10-7-13 VHF high-band antenna just below the CM4228, and joined the antennas using the CM7777, as shown in the picture below. Now KGO is my strongest signal .
That's exactly the same combination I'm using, minus the preamp. I use a simple coupler instead. I'm too close to Sutro and all of the signals overpower any preamp I've tried. It would be nice to have one to help pull in the Sacramento stations.
I think you'll find that you've got a winning combination there, Dave.
Larry
SF
post #4743 of 14985 Old 06-19-2009, 10:43 PM
DPlettner's Avatar
Larry
SF
Actually it was your recommendation in the Yahoo group that helped me decide to buy this antenna, so thanks for the recommendation. If Fry's had any high-band UHF antennas, I would have purchased what they had, but they only had UHF and UHF/VHF antennas, so I ordered the Y10-7-13 from Solid Signal.
I did try turning off the FM trap on the CM7777 figuring that it might be nice to connect the antenna to my AVR for FM, but turning off the FM trap did have a negative effect on signal strength. Even though FM is not close to high-band VHF, some of the FM stations must have harmonics that are interfering with KGO.
-Dave
DPlettner is offline
post #4744 of 14985 Old 06-20-2009, 07:21 AM
dr1394's Avatar
Quoted: 130 Post(s)
Liked: 65
DTV signal levels in Milpitas. Photos could be better, I just used an old digital camera pointed at the spectrum analyzer.
Channel 7, 11 (analog) and 12 (the strongest at 40 dB above the analyzer noise floor)
Channel 19 and 22 (analog)
Channel 27, 28 (analog), 29, 30 and 33
Channel 34, 36, 38, 39, 40 (analog) and 41
Channel 43, 44, 45, 49 and 50
Channel 51 and 55 (MediaFLO)
Close-up of the multipath on Channel 36, KICU-DT
Ron
HD MPEG-2 Test Patterns http://www.w6rz.net
dr1394 is online now
post #4745 of 14985 Old 06-20-2009, 08:35 AM
Trip in VA's Avatar
Quoted: 686 Post(s)
Liked: 195
Send a message via AIM to Trip in VA
Nice pics, dr1394.
I'm amused with the wide variation in the San Jose signals (I can't remember the name of the mountain). KICU-36 has a ton of multipath resulting in some really serious distortion, 50 and 51 look equally tilted but in opposite directions, but 49 looks okay.
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is offline
post #4746 of 14985 Old 06-20-2009, 08:39 AM
DEEPFRINGEGUY's Avatar
Originally Posted by Grandude View Post
What is really strange is the last one regarding Ch2. It would appear that it would be the very hardest for me to receive up here in north Santa Rosa but it actually is the only one with a very strong, reliable signal coming from Sutro. I do get ch4 and 11 but not strong enough to count on for viewing.
I sure hope the move to the top of Sutro will result in better signals across the board. In the meantime I have Dish and Comcast basic so not lacking for 'stuff' to watch this summer.
KTVU (44) will be at 1000kW by late September or mid-October, when the work on Sutro is finished; according to their engineering dept.; and this pdf doesn't show the 1000kW plot.
I'm enthusiastic about the Sutro antenna work. I think our reception is going to be
very good on most stations.
If we're lucky, maybe we'll get KCSM (43) PBS up here in SR.
- DFGY
DEEPFRINGEGUY is offline
post #4747 of 14985 Old 06-20-2009, 09:35 AM
wintertime's Avatar
Quoted: 66 Post(s)
KICU (also 30 on digital) and KTEH (50) are on Monument Peak; KSTS (49) and KDTV (51) are right next door on Mount Allison. I wouldn't expect you to remember those mountain names!
Patty
wintertime is offline
post #4748 of 14985 Old 06-20-2009, 09:39 AM
wintertime's Avatar
Quoted: 66 Post(s)
http://www.broadcastingcable.com/art..._DTV_World.php
"In the race to sign up station partners, RTV, which marks its fourth anniversary next week, has 88 affiliates currently on-air (it recently inked deals with Multicultural Broadcasting stations in New York, Los Angeles and San Francisco), while This TV has 70 on air since it launched in November."
That would be KCNS 38. Dunno when they plan to start airing Retro TV. You can get a sneak preview of the programming on the Retro TV website.
Patty
post #4749 of 14985 Old 06-20-2009, 09:59 AM
TPeterson's Avatar
Quoted: 242 Post(s)
Liked: 30
Hmm...then I wonder why their website lists KRON?
TPeterson is offline
post #4750 of 14985 Old 06-20-2009, 10:09 AM
wm_tell1's Avatar
I checked the programming for KRON4 through the retrotv website and KRON4 is definitedly not retro. Perhaps the website error is due to KRON4 broadcasting on RF38 while KCNS38 broadcasts on RF39.
wm_tell1 is offline
post #4751 of 14985 Old 06-20-2009, 11:45 AM
wintertime's Avatar
Quoted: 66 Post(s)
Their website is out of date. KRON dropped Retro TV some time ago.
Patty
post #4752 of 14985 Old 06-20-2009, 12:47 PM
Grandude's Avatar
very good on most stations.If we're lucky, maybe we'll get KCSM (43) PBS up here in SR.- DFGY
I'll consider myself very lucky if I get all the major network channels including any PBS channel in HD. Channel 22 from Cotati seems to be only transmitting SD on programs which I want in HD like the Operas from time to time.
I'm curious about where you live. I'm in the flats adjacent to the WF Arts center and wish we would have bought on top of one of the hills when we moved here 9 years ago. Seems I would have better reception from Sutro if we had done so. But of course, maybe I couldn't afford one on top of the hill anyway.
The picture I get from ch2 OTA now seems to be a bit better than that supplied by Dish. I haven't compared it to Comcast yet.
Brian...reporting from the left coast...
Grandude is offline
post #4753 of 14985 Old 06-20-2009, 05:27 PM
I'm in south-east Santa Rosa; and I'm up about 800ft above sea-level.
I do pretty well with OTA. I can't really complain. I'm getting more stations than I
did with analog and my older antenna rig. Much more when Sutro is finished.
I get KNTV very well here; it's one of my best stations; watching U.S. Open in HD is
nice. I get the more powerful Sac. stations; KSPX, KQCA, KMAX in the mornings; but, I lost KVIE when they went to VHF. Might need to go up a little higher...
post #4754 of 14985 Old 06-20-2009, 06:15 PM
dr1394's Avatar
Quoted: 130 Post(s)
Liked: 65
Nice pics, dr1394.
- Trip
It's because Milpitas is pretty much underneath the Monument Peak and Mount Allison stations and at the same time, the antenna is (probably) pointed at Sutro/Mount Bruno (putting the San Jose stations almost exactly 90 degrees off axis).
The pics are from the distribution system at my place of work. I'm not sure what kind of antenna is on the roof, but I guess it's some VHF/UHF combo that came with the building. There's a big 38 dB distribution amp and then a huge patch panel with dozens of splitters. Every cubicle and lab in the building has a drop. I'm also not sure how many splitters my particular drop goes through, it's too much of a rats nest to trace the cable.
The system was installed when we were developing ATSC tuner DVD recorders. It's hardly used now.
BTW, the multipath on KICU is a good tuner benchmark. The old Samsung SIR-T165 has a lot of trouble, but my AMD/ATI T316 (6th generation) ATSC tuner/demod evaluation board has no problem at all decoding the signal.
Ron
post #4755 of 14985 Old 06-20-2009, 06:19 PM
Brian Conrad's Avatar
Quoted: 1521 Post(s)
Liked: 821
So I'm wondering how long stations like KTVU, KRON and KPIX are going to continue identifying with their non-existent low-VHF channel? Shouldn't CBS5 now be CBS29?
Brian Conrad is offline
post #4756 of 14985 Old 06-20-2009, 06:29 PM
ProjectSHO89's Avatar
Quoted: 258 Post(s)
Liked: 129
No. Won't happen.
Under the FCC rules, any station that had a full power analog station will continue using that identifier regardless of the actual channel used to carry their broadcast.
That's what the rule is and it probably will never change.
ProjectSHO89 is online now
post #4757 of 14985 Old 06-20-2009, 06:32 PM
Quoted: 258 Post(s)
Liked: 129
-Dave
Double the FM frequency and it falls right into the 7-13 channel range.
An FM trap should help anyone who has both high-VHF channels and an FM-rich environment. It's especially important if there is an inexpensive amplifier in use.
post #4758 of 14985 Old 06-20-2009, 09:32 PM
Quoted: 513 Post(s)
Liked: 80
Ron
Thanks, Ron, for the very interesting display of signals across the band.
I appreciate you taking the time to photograph and upload the pics for us.
Larry
SF
post #4759 of 14985 Old 06-20-2009, 09:44 PM
Quoted: 513 Post(s)
Liked: 80
Dave, glad to hear that it was my recommendation for the new antenna. I've been very happy with its performance.
When KNTV was transmitting from Loma Prieta we couldn't get it, so the "Antenna Doctor" (my he rest in peace) suggested adding an FM trap. After that KNTV was perfect all the time from 55 miles away. The trap is still in the circuit even though KNTV is now transmitting from only 5 miles away, and I'm glad that it is. It's probably the reason I'm able to get KVIE on 9 and KXTV on 10.
There are five FM stations transmitting from Sutro, so those second harmonic signals are real strong here.
Larry
SF
post #4760 of 14985 Old 06-20-2009, 11:05 PM
TPeterson's Avatar
Quoted: 242 Post(s)
Liked: 30
N.B.: The FM trap can't filter out the second harmonics after they exist. It can however prevent them from coming into existence if they're actually created locally from the fundamental frequencies by harmonic distortions in non-passive electronic components. (Hence ProjectSHO89's comment above about "inexpensive amplifiers")
Dave's setup may well have reduced FM harmonics in his high-VHF spectrum by using a trap to keep those FM stations out of his mast-mounted broadband amplifier where they would otherwise generate at least some harmonics. But Larry's amp-less antenna setup should be more nearly immune--unless the FM stations actually overload the (non-broadband) first-stage amplifiers of his TV tuners.
post #4761 of 14985 Old 06-21-2009, 07:59 AM
Trip in VA's Avatar
Quoted: 686 Post(s)
Liked: 195
That may be so, but evidence suggests that FM traps are very helpful in upper-VHF reception, whatever the reason.
- Trip
N4MJC
RabbitEars
post #4762 of 14985 Old 06-21-2009, 10:48 AM
garycoleman's Avatar
i lost KTVU and KGO after the transition. WTF?
garycoleman is offline
post #4763 of 14985 Old 06-21-2009, 11:25 AM
bobby94928's Avatar
Liked: 391
Did you do a rescan? They both changed channels, KTVU to channel 44 and KGO to channel 7.
Bobby
bobby94928 is offline
post #4764 of 14985 Old 06-21-2009, 09:33 PM
MarioMania's Avatar
What's a FM trap??
Are they cheap for DTV
MarioMania is offline
post #4765 of 14985 Old 06-21-2009, 10:06 PM
TPeterson's Avatar
Quoted: 242 Post(s)
Liked: 30
Ask Google and ye shall receive.
post #4766 of 14985 Old 06-21-2009, 10:36 PM
MarioMania's Avatar
thanks..I will check
How far does KFTL-CA go in San Francisco?? I'm in Vallejo..I just want to know how far can it reach with only 90 KW power..I got that for the Wiki
and the other 2 Translators Channels..How can I look them up without knowing the Station's
K02OA 2
K15ET 11
post #4767 of 14985 Old 06-21-2009, 10:54 PM
wm_tell1's Avatar
Originally Posted by MarioMania View Post
What's a FM trap??
An FM trap is a band reject filter that typically has at least 20dB of rejection in the FM band (88 - 108MHz). They used to be very common and stocked by B&M electronics parts houses and Rat Shack. Rat Shack has discontinued them but they are still available from online sources for less than $10.
wm_tell1 is offline
post #4768 of 14985 Old 06-21-2009, 10:55 PM
pixelation's Avatar
It seems that I now have a watchable KGO signal off my UHF based DB2 clone. Any idea what have changed? Could the aux antenna turns out to be better than the main?
Reporting from Sunnyvale.
pixelation is offline
post #4769 of 14985 Old 06-21-2009, 11:24 PM
avnstf's Avatar
hm...speaking of KGO, I was just watching a junk science summer drama ("Impact") on 7, and I noticed these moving rose-colored dots - or probably longer than dots - that I at first thought were part of the particular scene. Then I noticed them later, and realized they were some kind of mess-up, usually appearing in almost vertical lines...I've never seen that before...
didn't noticed them in the second hour of the program...Tony
OTA only. For signal strength at your location: FCC DTV reception map
TVGOS data: Sony 250 from 5.1?, LG3410a from my DTVPal setup here, not any more.
avnstf is offline
post #4770 of 14985 Old 06-21-2009, 11:45 PM
TPeterson's Avatar
Quoted: 242 Post(s)
Liked: 30
My bet is that they looked a lot like the artifacts that toast0 mentioned a couple of pages ago.
