San Francisco, CA - OTA - Page 383 - AVS Forum
 34Likes
post #11461 of 11490 Unread 11-15-2014, 03:35 PM
Larry Kenney's Avatar
Quoted: 97 Post(s)
Liked: 33
Conditions have been the same here... normal to slightly worse than normal. The Walnut Grove VHF stations that I usually get, KVIE and KXTV, have both been missing for the past few days, and KOVR has been iffy. Only KMAX and KQCA have been coming in.
I asked Keith about KTVJ 4 a while back and he wrote that he's been extremely busy with his regular job and hasn't had much time for working on the TV stations. He did get new software installed, so there is now a x-9 channel on all of the One Ministry channels, like K03HY here on Mt. Tam. He also put in a better receiver for North Bay TV on channel x-8. (It does look a lot better and no longer has break up.) He is going to add programming information to his stations next, then he says he has to work on San Jose channel 2 up at Loma and 5 in Monterey to get those on the air before he has time to work on 4. He has no idea when he'll get that on the air.
Edit: Oh, he also is working on improving the signal between his studio in Santa Rosa and Mt. St. Helena to help stop the signal from pixelating and sometimes disappearing on his stations. Conditions this past week caused him to lose signal several times.
Larry
My complete SF Bay Area DTV Station Lists: http://www.choisser.com/sfonair.html
Lots of Broadcasting links and information: http://www.choisser.com/broadcast.html
Check out photos and info on my antennas: http://www. larrykenney.com/tvantennas.html
Larry Kenney is offline
post #11462 of 11490 Unread 11-15-2014, 06:54 PM
Calaveras's Avatar
Quoted: 193 Post(s)
Liked: 104
Originally Posted by 888CALLFCC View Post
Not anymore...
For the past week, everything has been normal with almost no changes on any channel here.
I guess it depends on where you're located. Conditions have been anything but nominal here this last week. I've had more trouble with the locals this week than at any time so far this fall. Conditions to Salinas have been especially good. Sutro has been up and down like crazy.
Chuck
Calaveras is online now
post #11463 of 11490 Unread 11-15-2014, 07:21 PM
Calaveras's Avatar
Quoted: 193 Post(s)
Liked: 104
That'll be interesting. K02QX is predicted by TV Fool to be 10 dB stronger than KFTY. If that turns out to be true I'll lose KFTY and gain K02QX. The only previous experience I had with a TV station on/near Loma was KKPX analog on 65 and it wasn't very strong.
Chuck
post #11464 of 11490 Unread 11-16-2014, 06:02 PM
Quoted: 97 Post(s)
Liked: 33
Distant signals are waaaay down here today. KMAX and KQCA are just making it over the cliff edge at 16-17 dB, when they're normally 22 dB or higher, KEMO is only coming in at 17 dB and it's normally 22 to 23, KRCB is pixelating at 15 to 16 dB and KTNC from Mt. Diablo is only 19 dB when it's normally about 23. KDTS from Mt. Diablo and all of the other stations from Walnut Grove are all below the cliff edge, and there's no sign of KAXT and KEXT from the South Bay either.
Larry
post #11465 of 11490 Unread 11-16-2014, 07:29 PM
888CALLFCC's Avatar
Quoted: 37 Post(s)
Liked: 25
Larry
At 6:20pm here in Hayward. Everything (all channels) seems normal. Except KTLN & KEMO are slightly less signal, but no dropouts.
KEMO is 39% when normal is 52% , KTLN is 50% normal is 90%
As strong as KEMO is, KRCB is gone.
888CALLFCC is offline
post #11466 of 11490 Unread 11-17-2014, 01:03 AM
Quoted: 97 Post(s)
Liked: 33
The low dip in signal strength mentioned earlier slowly improved over the course of the evening and signals as of 11:30 pm pretty much back to normal. Both KEMO and KTNC have actually gone above normal. KEMO is up to 25 dB, 8 dB better than it was earlier this afternoon, and KTNC is at 24 dB, a 5 dB improvement.
I wish I knew more about what causes these large changes in signal strength. I find it really interesting to follow.
Larry
post #11467 of 11490 Unread 11-17-2014, 10:07 AM
Calaveras's Avatar
Quoted: 193 Post(s)
Liked: 104
Larry
I made a couple of graphics to illustrate what I think is going on. I used the terrain plot between me and KION on Mt. Toro. I used colors similar to what TV Fool uses for signal strength. Green is the area that is LOS to the transmitter. Magenta is the area that relies on signal refraction. Dark magenta is the strongest and pale magenta is the weakest.
The first graphic shows how much signal is getting to me with atmospheric bending of the signal. KION typically runs SNR 20 dB under these conditions.
The second graphic shows the atmosphere bending the signal putting me in the darker magenta area. KION often jumps to SNR 31 dB and I've seem the signal strength go up 20 dB or more.
It's also possible to bend the signal up making KION drop out.
I'm sure there are many factors that determines whether you can benefit from atmospheric bending or not. I suspect that the smaller the angle required to bend the signal to you the larger the swing in signal strength you're going to see. The mountain KION has to refract over is 80 miles away so it doesn't take much bending to see a big increase. I bet a few hundredths of a degree is all it takes.
OTOH, if the mountain the signal has to refract over is fairly close by, then the bending angle will have to be large and you won't see much if any difference.
I'm going to take a shot at making some graphics to illustrate what I think is going on between me and Walnut Grove, a path that seems to be affected mostly negatively by signal bending.
Chuck
ID:	371025   Click image for larger version
post #11468 of 11490 Unread 11-17-2014, 02:00 PM
Calaveras's Avatar
Quoted: 193 Post(s)
Liked: 104
Here's an analysis of KQCA when the signal bends down.
The first graphic shows the terrain path from KQCA to me. The red line is drawn to show the down tilt of the KQCA antenna intersecting the horizon at 60 miles out. Many broadcast stations are set up this way to put the most power at the edge of the service contour. Out to 25 miles you don't need as much power so it doesn't matter if you're not in the main lobe.
The second graphic shows what might happen with some bending of the signal by the atmosphere. The signal reaching my first edge 6 miles away is already reduced with no bending because the main lobe of the antenna is 2600 feet lower.
The third graphic shows the KQCA vertical antenna pattern. My first edge is about .6 degrees above the center of the main lobe of the KQCA antenna. This is shown by the green line. The signal is already 3.7 dB down from the peak. With such a steep slope on the vertical pattern it doesn't take much bending the signal down to drop the strength. Bending .45 degrees drops the signal 15 dB.
The only way to fix this problem is for the antenna to be lower gain which will produce a wider beamwidth so when the signal bends it doesn't drop as much.
I think this explains why the Walnut Grove signals often drop in strength and rarely go up much.
KVIE has the lowest gain antenna and is the only Walnut Grove station that doesn't have any drop outs.
Chuck
Name:	KQCA Bending-None.jpg
ID:	371425   Click image for larger version
Name:	KQCA Bending.jpg
ID:	371433   Click image for larger version
post #11469 of 11490 Unread 11-17-2014, 03:15 PM
Quoted: 97 Post(s)
Liked: 33
Thanks for the diagrams, Chuck. (You do nice work!)
Now that you've explained the results of bending, what is it in the atmosphere that causes the bending? That's the part I don't understand. I know there are D, E and F1 and F2 layers in the atmosphere, which give us long distance reception on the lower frequencies, but I don't think they come into play very often for signals up in the TV bands... at least not out here on the west coast. So there has to be other conditions in the atmosphere that cause the bending of the TV signals. I know about inversions, but I don't think we are experiencing any right now, yet the signals are up and down like a yo-yo.
Like yesterday, the signals from Mt. St. Helena, Mt. Diablo and Walnut Grove were all way down again today, but are now beginning to go back up. Even KMAX, which is in here 99% of the time, dropped below the cliff edge for about 10 minutes at about 11 o'clock this morning. The channel 21 signal has varied from a high of 27 dB SNR last night to a low of 13.7 dB SNR in just a 12 hour period.
Larry
post #11470 of 11490 Unread 11-17-2014, 05:39 PM
Calaveras's Avatar
Quoted: 193 Post(s)
Liked: 104
Larry,
I don't know the physics behind it but where different temperature layers in the atmosphere meet they cause the signals to stay within one temperature layer. The angle of incidence has to be very small, often <1 degree or the wave will pass right though the atmosphere out into space.
I used to receive real time images on 1700 MHz from the NOAA polar orbiting satellites. Large swings in signal strength were common when the satellites were under 2 degrees in elevation indicating the signal was interacting with the atmosphere. I never saw this above 5 degrees of elevation and rarely above 2 degrees.
I wish I could monitor some of the stations I get here and plot the results. You'd be amazed at the large variations over rather short time periods.
Chuck
post #11471 of 11490 Unread 11-17-2014, 06:34 PM
dr1394's Avatar
Quoted: 20 Post(s)
It's the difference in the index of refraction between different temperature/humidity layers of the troposphere.
Ron
HD MPEG-2 Test Patterns http://www.w6rz.net
dr1394 is online now
post #11472 of 11490 Unread 11-17-2014, 06:40 PM
dr1394's Avatar
Quoted: 20 Post(s)
More reading material.
http://en.wikipedia.org/wiki/Tropospheric_propagation
Ron
post #11473 of 11490 Unread 11-17-2014, 07:29 PM
Quoted: 97 Post(s)
Liked: 33
Ron... Thank you! That Wikipedia information is exactly what I was looking for! It does a good job of explaining what's happening to the signals around here.
Larry
post #11474 of 11490 Unread 11-18-2014, 08:39 AM
Calaveras's Avatar
Quoted: 193 Post(s)
Liked: 104
Larry
In that article I found a link to WA5IYX's TV DX page:
http://www.qsl.net/wa5iyx/dtv-capt.htm
You might enjoy looking at TV DX from Texas.
Chuck
post #11475 of 11490 Unread 11-18-2014, 01:02 PM
888CALLFCC's Avatar
Quoted: 37 Post(s)
Liked: 25
Chuck
I have that Digital Stream converter box too. The "Manual Tuning" mode is a great feature.
It will capture and save station ID,.... long after the signal is gone.
I do 24 hour tests with it to identify weak channels.
post #11476 of 11490 Unread 11-18-2014, 07:08 PM
CherylJosie's Avatar
Quoted: 39 Post(s)
Liked: 37
Reception in the flatlands of Fremont was much better last year. Might be trees or maybe the wire on the balcony is damp? Been out there for a few years...
CherylJosie is offline
post #11477 of 11490 Unread 11-18-2014, 10:42 PM
Otto Pylot's Avatar
Quoted: 218 Post(s)
Liked: 264
FWIW, I haven't seen any issues at all down here in the Evergreen Area of San Jose, but then again I'm not looking at the stations some of you are. On a different note, what is the deal with the little scroll I'm seeing on KPIX about Dish dropping CBS and Showtime? I'm OTA only so I'm out of the loop as far as satellite shenanigans.
Otto Pylot is online now
post #11478 of 11490 Unread 11-19-2014, 01:40 AM
888CALLFCC's Avatar
Quoted: 37 Post(s)
Liked: 25
Originally Posted by Otto Pylot View Post
what is the deal with the little scroll I'm seeing on KPIX about Dish dropping CBS and Showtime? I'm OTA only.
It's a money thing.... Local networks charge pay tv carriers for permission to carry the channel (resale), pay tv companys charge customers for the service of pay tv.
Any disagreement on costs per channel / customer, and the pay tv company will dump that channel. It's the nasty current state of pay tv.
The only sure way to get local channels (free of charge) is with a tv antenna.
The days of counting on pay tv .. to deliver your local channels are over.
You can always watch the CBS networks, KPIX-5 & KBCW-44 over the air .. free of charge.
post #11479 of 11490 Unread 11-19-2014, 02:02 AM
Quoted: 97 Post(s)
Liked: 33
I received an email from Keith of One Ministries asking me to check to see how my Sony was functioning on channel 3. My Sony, and only my Sony out of all the TVs in the house, would lock up on any of the channel 3 sub-channels, go to black for about 5 seconds and then come back to life. It would last about 5 seconds and then lock up again.
Keith switched from static PSIP to dynamic PSIP tonight and it fixed the problem! So if anyone else out there was having a lockup problem, check your TV now.
Larry
post #11480 of 11490 Unread 11-19-2014, 02:13 AM
Quoted: 97 Post(s)
Liked: 33
He's pulled in some really good DX. I wish we had those conditions out here on the West Coast! We'd have a lot more fun!
It will capture and save station ID,.... long after the signal is gone. I do 24 hour tests with it to identify weak channels.
I have that same "Manual Tuning" mode on my Insignia converter box. It's great for working with weak stations. As you said, it will save the PSIP information for a station even after the signal disappears. I wish TVs had that manual feature. That converter box still has the best receiver in the house, too. It can lock onto weak signals and pull them out of the noise better than any of the other tuners.
Larry
post #11481 of 11490 Unread 11-19-2014, 02:42 AM
888CALLFCC's Avatar
Quoted: 37 Post(s)
Liked: 25
Larry has the mystery of RF 13
I have the mystery of RF 31 ... (It would be the first Sacramento UHF) station to pull over the rock hill. All others remain at zero 21,25,46,35 nothing.
post #11482 of 11490 Unread 11-19-2014, 08:29 AM
Calaveras's Avatar
Quoted: 193 Post(s)
Liked: 104
There's a slight chance that RF 13 could be KTNV in Reno but it's much more likely to be KCBA on Fremont Peak. There are no other choices.
In your case RF 31 is almost certainly KSMS on Fremont Peak. Hayward is within its service contour. It runs 1000 KW with nearly full power in your direction. It's the highest power UHF station by far in Salinas. If you can't receive the big gun UHF stations in Walnut Grove it is simply impossible to receive the low power KMUM 31 north of Sacramento. I've seen it just once here. I receive KSMS almost all the time and I'm only seeing 35 KW ERP off the side of its antenna.
Chuck
post #11483 of 11490 Unread 11-19-2014, 09:18 AM
Otto Pylot's Avatar
Quoted: 218 Post(s)
Liked: 264
Thanks. I saw an article in the paper this morning stating that. It's been crawling along the bottom of my tv for about a week now. Fortunately, we've never had cable or sat cause OTA reception for us is dead-on-balls and trouble-free. Gotta feel for the folk who are paying for their television only to end up being used to play one corporation against another.
post #11484 of 11490 Unread 11-19-2014, 03:41 PM
888CALLFCC's Avatar
Quoted: 37 Post(s)
Liked: 25
Chuck
RF 31 shows up when KVIE, KEMO, KTLN and others show surges. So the signal enhancement must be local bending down ALL signals in the canyon area.
I am "behind" Cal state Hayward at a lower elevation. Fremont Peak is totally blocked from here. VHF does work, UHF is a mess. Including KICU & KTEH
A few years ago, I contacted both KICU & KTEH about signal service problems here only 9 miles away.
They only could boost power to maximum allowed. And they did.
Still, If you "walk in front of" the yagi on the roof, the signal will drop out.
Thats UHF signals in a canyon for ya.
post #11485 of 11490 Unread 11-20-2014, 12:59 AM
Quoted: 97 Post(s)
Liked: 33
I thought I might have a good chance of finding out what the mystery station was earlier tonight. The channel 13 signal was getting stronger, bit by bit, but peaked at 14.3 dB SNR and then started going back down. Sometime I'll find out.
Larry
post #11486 of 11490 Unread 11-21-2014, 01:51 PM
Calaveras's Avatar
Quoted: 193 Post(s)
Liked: 104
You must be in a deep hole to have problems with those high power stations just 9 miles away. What does your terrain plot look like to KICU?
I've attached my terrain plot from KUVS to my house which is located a bit over 100' down the hill so I'm severely blocked to it. KUVS has about 60KW in my direction and is 14 miles away. The plot accurately shows the hill I'm behind. I have no trouble at all receiving KUVS at my house with even a small outdoor antenna. My antennas are located about 20' down the hill so at 70' the antennas stick up above the hill by 50'.
Chuck
post #11487 of 11490 Unread 11-21-2014, 03:14 PM
Calaveras's Avatar
Quoted: 193 Post(s)
Liked: 104
Ben sent me the info needed to make the plot which is attached.
Looks to be a 2 edge path but barely. Unfortunately your antenna would have to be at 150' to get a 1 edge path according to TV Fool.
A 2 edge path is much more difficult than a 1 edge path.
Chuck
post #11488 of 11490 Unread 11-21-2014, 03:56 PM
888CALLFCC's Avatar
Quoted: 37 Post(s)
Liked: 25
Chuck
You notice the difference ? My plot is mostly downhill .... skimming the ground clutter edges.
Your plot has a elevation advantage.
The high power stations are do-able. The low power ones are not.
I would expect the same type of plot for Walnut Grove UHF ... that is totally cut off to zero signal.
I have found a sweet spot to KEMO that works well. With no issues.
Not a good location for DX 'ing long range signals.
post #11489 of 11490 Unread 11-21-2014, 08:53 PM
Calaveras's Avatar
Quoted: 193 Post(s)
Liked: 104
Yes, and I can see why. After seeing your terrain plot to Walnut Grove there is no doubt in my mind that whatever signal you're seeing on RF 31 has to be KSMS.
Chuck
post #11490 of 11490 Unread Yesterday, 12:33 PM
Quoted: 39 Post(s)
Liked: 37
Replacing the outdoor cable fixed it. The insulation was deteriorated. Apparently the installer did not bother to use exterior cable.
BTW I am using an 8-bay channel master on a 3rd floor balcony of a northish-facing apartment in the flatlands. Tricky to aim and subject to weather leaves etc. disturbance, but otherwise working OK again.
