San Francisco, CA - OTA - Page 384 - AVS Forum
 34Likes
post #11491 of 11497 Old Yesterday, 12:31 AM
888CALLFCC's Avatar
Quoted: 38 Post(s)
Liked: 25
Originally Posted by Larry Kenney View Post
I thought I might have a good chance of finding out what the mystery station was earlier tonight. The channel 13 signal was getting stronger, bit by bit, but peaked at 14.3 dB SNR and then started going back down. Sometime I'll find out.
Larry
I see RF 13 & RF 8 (KSBW) a little "higher than normal" tonight. @ 11pm
11/24
888CALLFCC is offline
post #11492 of 11497 Old Yesterday, 12:21 PM
Calaveras's Avatar
Quoted: 193 Post(s)
Liked: 105
11/24
I saw huge signals coming from Salinas this morning around 10 am. KMUV analog was full quieting and K29AB was almost full quieting. KION was about 25 dB above average and SNR 32 dB, a number seen only on KSBW previously. KQET on RF 25 (1.8 KW ERP) was as strong as the KOVR usually is and was overriding KOVR for awhile. Overall everything from down there was 20-30 dB above average. Signals were dropping by 11 am. Most other signals were below average.
Chuck
Calaveras is online now
post #11493 of 11497 Old Yesterday, 02:15 PM
Larry Kenney's Avatar
Quoted: 99 Post(s)
Liked: 33
I tried to post last night, but the AVS site was having problems and I couldn't save my post.
After seeing Ben's post I took a look around the channels and the Walnut Grove stations were all above average. The two VHF stations were much stronger than usual. Stations from up north in Marin and Sonoma and from the South Bay were just at their average levels.
This morning signals are all about normal here.
Larry
My complete SF Bay Area DTV Station Lists: http://www.choisser.com/sfonair.html
Lots of Broadcasting links and information: http://www.choisser.com/broadcast.html
Check out photos and info on my antennas: http://www. larrykenney.com/tvantennas.html
Larry Kenney is offline
post #11494 of 11497 Old Yesterday, 04:46 PM
Quoted: 99 Post(s)
Liked: 33
Since I posted a couple hours ago, signals from Walnut Grove have gone through the roof! Both VHF stations - 6 and 10, and five of the UHF stations - 3, 13, 21, 35 and 46 are all above 20 dB SNR right now. KMAX is coming in at 29.5 to 30 dB! KTNC from Mt. Diablo is also 3 dB stronger than usual at 26 dB.
Both KSPX 29 and whatever station is coming in on channel 13 are SO CLOSE to being detected for the first time, but neither one can get past 14.5 dB to make it over the cliff edge.
Despite the extra strong signals from the east and northeast, the signals from up north and down south are still at about normal levels.
Larry
post #11495 of 11497 Old Yesterday, 04:57 PM
bobby94928's Avatar
Liked: 137
I've been getting KFTY, 3, off of my CM 4228! Unbelievable!
Bobby
bobby94928 is online now
post #11496 of 11497 Old Yesterday, 09:34 PM
SFischer1's Avatar
Quoted: 110 Post(s)
KGO Problems?
To: HDTV-in-SFbay@yahoogroups.com
Sent: Tuesday, November 25, 2014 7:53 PM
Subject: [HDTV-in-SFbay] ABC 7-1 Reception Issues
In all my years of flawless OTA HDTV, last night and tonight ABC 7-1 has been breaking up very badly. It happened last night about the same time, around 7:45pm. It lasts for a few minutes and is then fine for the rest of the evening. Anybody else experiencing this? I don't see this on the other stations.
KGO VC 7 RF 7 has a translator on RF 35 from Mt. Allison, are you sure that you are not using it. Problems often occur with RF 35.
The chart for KGO VC 7 RF 7 shows no glitches, but as the samples are ~ 30 minutes apart it is not definitive.
http://ruka.org/~toast/atscdata/chart.php?c=7
Could there be something in your house that is in use at that time that is causing interference?
I will ask on avs.
Any problem with RF 7 would be very unusual.
SHF
SFischer1 is offline
post #11497 of 11497 Old Today, 08:58 AM
Calaveras's Avatar
Quoted: 193 Post(s)
Liked: 105
It's puzzling to me as to why you don't receive KTNC much better. You're just 30 miles away and I assume you can see Mt. Diablo from your roof. It's seems like it ought to be max SNR all the time. Unfortunately I didn't measure KTNC when I was there. That probably would have answered it.
KTNC is 80 miles from here, almost LOS and the SNR is typically 31 dB, although it does drop at times to as low as 25 dB. KTNC and KTXL are about the same signal strength here.
