San Francisco, CA - OTA - Page 426 - AVS | Home Theater Discussions And Reviews
 67Likes
post #12751 of 12773 Old 06-25-2015, 09:11 PM
PeninsulaMark's Avatar
Quoted: 324 Post(s)
Liked: 39
Question KRON-TV Channel 4.1 going bye bye
Well, it's breaking up and going completely off the air for up to 45 seconds. Freezes, multiple boxes, audio tones, no signal. Worse than KNTV ever was.
Is it my TV ?
PeninsulaMark is online now
post #12752 of 12773 Old 06-25-2015, 10:52 PM
SFischer1's Avatar
Quoted: 253 Post(s)
Liked: 40
Is it my TV ?
Yes it is your TV. RF 38 looks fine.
Code:
G:\HDTV>REM FullStream3.bat Working 6/23/2015
G:\HDTV>REM
G:\HDTV>REM 1) Use HDHomeRun Config (GUI) to choose the physical channel.
G:\HDTV>REM Ctrl-C to stop after 30 seconds.
G:\HDTV>REM
G:\HDTV>Date /T
Thu 06/25/2015
G:\HDTV>Time /T
10:36 PM
G:\HDTV>"C:\Program Files\Silicondust\HDHomeRun\hdhomerun_config" 101A7308 set /
tuner0/filter "0x0000-0x1FFF"
G:\HDTV>"C:\Program Files\Silicondust\HDHomeRun\hdhomerun_config" 101A7308 save
/tuner0 sample3.ts
-- Video statistics --
825518 packets received, 0 overflow errors, 0 network errors, 0 transport errors
, 0 sequence errors
Terminate batch job (Y/N)? n
G:\HDTV>REM
G:\HDTV>Pause
Press any key to continue . . .
SHF
SFischer1 is online now
post #12753 of 12773 Old 06-26-2015, 09:43 AM
Quoted: 324 Post(s)
Liked: 39
Fischer:
Think you missed it, as it stopped spontaneously after 31 minutes. Then all was fine. It was real, and all channels are fine now.
post #12754 of 12773 Old 06-26-2015, 10:02 AM
Otto Pylot's Avatar
Quoted: 502 Post(s)
Liked: 378
Interesting. I'm usually the one who complains about 11.1 and I haven't seen any issues for quite some time. We don't watch 4.1 that much but I haven't seen any "KNTV-like" issues with it either.
Otto Pylot is online now
post #12755 of 12773 Old 06-26-2015, 02:18 PM
SFischer1's Avatar
Quoted: 253 Post(s)
Liked: 40
Fischer:
You mentioned KNTV so I applied that test. That also had the purpose of showing a "good" channel to compare with the "bad" one KNTV. I now include the date and time and I am looking for a way to include the PSIP.
I also checked Toast0's chart for RF 38 and it is a little ragged at times.
Remember that his samples are ~ thirty (30) minutes apart.
If you hover over the data points after clicking "strength" you will see a large difference from high to low.
The Symbol Quality does not drop suggesting that no problems were occurring.
KRON is second station after KMTP that I would suspect that problems do happen.
SHF
post #12756 of 12773 Old 06-26-2015, 05:55 PM
maxreactance's Avatar
Quoted: 67 Post(s)
Is it my TV ?
Probably not...it was completely off the air when I tuned
in at about 5am before going to work. Later that day it
was fine, so they are probably having problems, depends
on when you hit it...
maxreactance
maxreactance is offline
post #12757 of 12773 Old 06-26-2015, 06:59 PM
SFischer1's Avatar
Quoted: 253 Post(s)
Liked: 40
Hi,
I got the output format of the HDHR full stream capture to include:
  • Date
  • Time
  • RF Channel
  • Streams
Followed by a series of dots to indicate no problems.
Code:
G:\HDTV>REM FullStream3.bat Working 6/26/2015
G:\HDTV>REM
G:\HDTV>REM
G:\HDTV>ECHO OFF
Fri 06/26/2015
06:48 PM
auto:12
3: 11.1 KNTV HD
4: 11.2 COZI
tsid=0x018D
631770 packets received, 0 overflow errors, 0 network errors, 0 transport errors
, 0 sequence errors
FullStream3.bat
Code:
REM
REM
ECHO OFF
ECHO --------------------------
Date /T
Time /T
"C:\Program Files\Silicondust\HDHomeRun\hdhomerun_config" 101A7308 get /tuner0/channel
"C:\Program Files\Silicondust\HDHomeRun\hdhomerun_config" 101A7308 get /tuner0/streaminfo
REM pause
"C:\Program Files\Silicondust\HDHomeRun\hdhomerun_config" 101A7308 set /tuner0/filter "0x0000-0x1FFF"
"C:\Program Files\Silicondust\HDHomeRun\hdhomerun_config" 101A7308 save /tuner0 sample3.ts
REM
Pause
SHF
post #12758 of 12773 Old 06-27-2015, 06:51 PM
Quoted: 324 Post(s)
Liked: 39
KRON is so messed up now, cannot watch it. Boxes, beeps, no signal, etc. All other channels fine.
post #12759 of 12773 Old 06-27-2015, 07:19 PM
SFischer1's Avatar
Quoted: 253 Post(s)
Liked: 40
MyHD is fine with KRON VC 4 RF 38.
As is Fusion.
BUT, HDHR will not display any of the three streams and the full stream capture will not work.
Code:
 G:\HDTV>REM
 G:\HDTV>REM
 G:\HDTV>ECHO OFF
Sat 06/27/2015
07:17 PM
auto:38
3: 4.2 KRON-SD
4: 4.1 KRON-HD
5: 4.3 KRONSD2
tsid=0x0179
0 packets received, 0 overflow errors, 0 network errors, 0 transport errors, 0 s
equence errors
That's all that appears, none of the dots for good packets and the file remains zero bytes.
TSReader cannot see anything from the HDHR tuner.
I am stumped. Call the station for help, wait no one is there like KMTP.
EDIT: My old HDHR tuner cannot see KRON but the new one can.
TSReader output perhaps in a few minutes.
OPPS: It's my laptop software or wireless or ...
RF 38 is fine on my old HDHR on my HTPC.
SHF
post #12760 of 12773 Old 06-27-2015, 07:53 PM
SFischer1's Avatar
Quoted: 253 Post(s)
Liked: 40
[s]KRON needs new HDHR for capture / view[/s]
Hi,
I got my new HDHR to capture the full stream for KRON and TSReader was able to analyze it. It is attached.
I cannot see anything wrong but something must be as my old HDHR sees nothing. Experts of TSReader output may see the problem.
EDIT: Updated firmware and software for both old and new HDHRs. No change. Will check later.
Spoiler!
SHF
post #12761 of 12773 Old 06-27-2015, 11:26 PM
SFischer1's Avatar
Quoted: 253 Post(s)
Liked: 40
Turned power of on all my hardwired network devices and starting with the wireless router turned power back on.
KRON and all the other stations are back. So on my part, a false report about KRON.
SHF
post #12762 of 12773 Old Yesterday, 12:08 AM
Larry Kenney's Avatar
Quoted: 272 Post(s)
Liked: 40
I wonder what's going on with KMMC channel 40. It was back on a few days ago, but now it's off again. Maybe they found that they still had interference problems.
Larry
My complete SF Bay Area DTV Station Lists: http://www.choisser.com/sfonair.html
Lots of Broadcasting links and information: http://www.choisser.com/broadcast.html
Check out photos and info on my antennas: http://www. larrykenney.com/tvantennas.html
Larry Kenney is offline
post #12763 of 12773 Old Yesterday, 12:42 AM
Quoted: 324 Post(s)
Liked: 39
SHF
15 minutes after I posted, KRON normalized. How expensive is your testing equipment.
post #12764 of 12773 Old Yesterday, 06:00 AM
SFischer1's Avatar
Quoted: 253 Post(s)
Liked: 40
Well, the need for a HTPC with Wireless (Optional) Networking being the base system strongly suggests that the desire for a HTPC is the determining cost. My 37" HDTV with a DEAD ATSC Tuner is my system monitor.
http://www.newegg.com/Product/Produc...-015-_-Product
You could get by for $84 + Shipping and Handling and an Ethernet cable if you have a computer. Software runs on various systems.
http://www.silicondust.com/products/...merun-connect/
SHF
post #12765 of 12773 Old Yesterday, 12:16 PM
Quoted: 324 Post(s)
Liked: 39
KRON 4.1 is very crappy again now.
post #12766 of 12773 Old Yesterday, 01:57 PM
SFischer1's Avatar
Quoted: 253 Post(s)
Liked: 40
I am unsure if this applies as my antenna is in a different place than yours (And sucks better with more gain).
Spoiler!
TSreader showed a larger number of errors. Perhaps another report later.
SHF
post #12767 of 12773 Old Yesterday, 07:44 PM
888CALLFCC's Avatar
Quoted: 118 Post(s)
Liked: 26
KNTV is breaking up again tonight, every three to ten minutes. Central horizontal lines, under one second per episode. No audio disruptions . . . yet.
Confirmed, RF 12 has problems, worse than the last report.
SHF
I see KNTV breaking up tonight (Sunday) 6:55pm, every 4 seconds, a complete picture of boxes, then a 4 second recovery.
A slower timed breakup (On their end) The audio holds steady, the picture does not.
They have some issues.
888CALLFCC is offline
post #12768 of 12773 Old Yesterday, 07:56 PM
Quoted: 324 Post(s)
Liked: 39
Watching KNTV for the past ten minutes. No breakups yet.
post #12769 of 12773 Old Yesterday, 08:39 PM
SFischer1's Avatar
Quoted: 253 Post(s)
Liked: 40
I captured KNTV's full stream starting at 8 PM for ~ 30 minutes. Only TWO (2) errors seen.
Spoiler!
SHF
post #12770 of 12773 Old Today, 01:27 PM
Barube's Avatar
Sorry if this issue has been addressed before - I could not find anything using this forum's search engine.
My problems are also with NBC bay area channels 11.1 & 11.2. For about the past 1 1/2 weeks or so I get a picture , but no sound. This has always happened once in a while, but would only last a day or two. The problem had gotten worse in the last couple of months, but has never been without sound for this long. There is no problem with my tv or converter box - every other channel comes in fine with sound.
Anyone else have this problem ? Any solutions ?
Barube is online now
post #12771 of 12773 Old Today, 03:35 PM
SFischer1's Avatar
Quoted: 253 Post(s)
Liked: 40
It's possible that KNTV's attempts to discover the problems they have had for some time that have made some changes that affect only some HDTV sets. If there have been others having this problem there would have been a loud response.
I will do a long full stream capture of KNTV from ~ 5:25 PM to ~ 6:15 PM to cover both network and local programming. Please report if you have any problems if you are able to watch during this period.
Before that, if you can, do a double scan. First disconnect the antenna and the full scan should produce no channels. Then reconnect the antenna and do a second scan which should have all channels appear.
I will do a quick scan of KNTV and go back as see if I have a TSReader output from long ago to compare with.
Looking at the KNTV TSReader report for 6/9/2015 I see two audio channels defined.
If you have selected the second audio channel which is often used for Spanish, then long periods of silence would be expected as they only try to have the Spanish audio supplied for Sports programming. Other periods sound would be missing.
SHF
post #12772 of 12773 Unread Today, 03:57 PM
SFischer1's Avatar
Quoted: 253 Post(s)
Liked: 40
KNTV has problems right now big time
I just did a HDHR Full Channel Capture of KNTV and it has lots of problems.
Spoiler!
SHF
post #12773 of 12773 Unread Today, 04:32 PM
Barube's Avatar
SHF
Thanks for you help.
Guess what ? I just turned on channel 11 and suddenly there is audio for the first time in more than a week that I know of. It was not working a couple of hours ago. The last time I had sound on this channel about 10 days ago, it came back on for about 1 day and then went out again until today.
I will go ahead and perform the double scan.
