San Francisco, CA - OTA - Page 453 - AVS Forum | Home Theater Discussions And Reviews
 95Likes
post #13561 of 13565 Old 02-05-2016, 06:15 PM
dmo580's Avatar
Originally Posted by Larry Kenney View Post
A lot of people have been having problems with KPIX lately. I don't know if this is a new situation or if people are just now trying to tune in the channel for the Super Bowl game. Anyway, I've received several emails asking for help. If you get KGO, KNTV, KTVU, KQED, KRON, etc. you should get KPIX. KPIX is being transmitted form the same antenna as KTVU and KRON... the three signals are combined into the one antenna. Since you're not receiving it, you have multipath problems for KPIX's frequency. You'll need to find a place where the reflections are reduced so that the main signal is not ruined by them.
Some of the antennas you see for sale are really not that good, no matter what the stores and ads say. You're 45 miles from the transmitter, so you should use an antenna that's outside. Several of us on here would be happy to recommend a good antenna if you want to replace the one you got. Also, indoor antennas in general don't work well, and they're not made for distant reception. Remember... up on the roof as high as possible is what will bring in the best signal.
Larry
Thanks but unfortunately living in an apartment complex makes it hard to have your own roof and an outdoor solution becomes problematic.
Actually I've never gotten KPIX for the past 3 months I've moved here. It's just odd. KGO, KTVU all look great though and I've never had signal issues even when the weather sours or when I put the antenna behind the TV and not next to the window. I know indoor is certainly not great, but at the same time my setup should be well within reach for an indoor antenna to pick up KPIX. Maybe I'll try dangling the antenna off the patio or something
dmo580 is offline
post #13562 of 13565 Old 02-05-2016, 11:17 PM
888CALLFCC's Avatar
Quoted: 157 Post(s)
Crazy as it sounds, In my apartment, at that time, I put a outdoor model "Under the bed" and it worked. Such as models like RCA-751
It all depends on location. (In my case it was Redwood City)
Over the past 10 years or so, I've seen a huge decline in quality ... of consumer electronic items such as antennas, etc.
Bad soldered electronics, shoddy coax cable, blown capacitors, extreme small base footprint, (That tips over and crashes to the floor) > (Think Terk antennas)
I cant imagine these items lasting any duration with kids & pets.
With that said, the possibility of failing equipment can't be ruled out. Even "moving" to a new address can damage items in transit.
I'd purchase a new antenna ... from a retailer that has a good return policy in case things don't work out.
888CALLFCC is offline
post #13563 of 13565 Old Yesterday, 03:48 PM
SFischer1's Avatar
Quoted: 328 Post(s)
Liked: 46
New HD Farallones Cam in testing mode perhaps.
Hi,
I was able to find the Golden Gate Bridge but not Sutro. Visibility was too poor towards San Francisco.
And alas NO BIRDS!
I suspect that it will come and go as the message that it was going to be replaced is still displayed. Just dismiss it. The URL may also be changing. What is being showed is not live, the water is not moving.
http://legacy.calacademy.org/webcams/farallones/
SHF
SFischer1 is offline
post #13564 of 13565 Old Yesterday, 09:12 PM
Quoted: 16 Post(s)
Liked: 4
That's amazing that you have such consistent reception at 110 miles distance!
As for the improved reception, the fire must have thinned out the trees and foliage enough to make the difference.
Except for the exceptional conditions seen a couple of weeks ago, conditions have been normal to poor for the Walnut Grove stations here.
Larry
I don't remember any trees, in the old panoramic picture, from his property.The rain or wet earth , has dramatically improved my VHF reception from walnut grove.
slowrench is offline
post #13565 of 13565 Old Today, 08:15 AM
Calaveras's Avatar
Quoted: 780 Post(s)
Liked: 188
There were plenty of trees and other vegetation in both the Walnut Grove and SF directions. I'm thinking about doing a post fire 360 degree panorama with the camera mounted up on the tower. It's a bunch of work and I'll have to get a friend over to help.
Chuck
Calaveras is online now
