San Francisco, CA - OTA - Page 475 - AVS Forum | Home Theater Discussions And Reviews
 154Likes
post #14221 of 14754 Old 09-21-2016, 05:19 PM
Otto Pylot's Avatar
Quoted: 1397 Post(s)
Liked: 873
Problems with KGO-7
Does anyone have an idea on what's going on with KGO 7.1. I've never seen it pixellate and break-up this bad. Started around 5pm with the news.
Otto Pylot is offline
post #14222 of 14754 Old 09-21-2016, 05:41 PM
SFischer1's Avatar
Quoted: 499 Post(s)
Liked: 62
I see that KGO VC 7 RF 35 got 185780 missed packets at ~ 5:30 PM.
KGO VC 7 RF 7 got a large number of transport errors (104) at 7 AM.
It is hard to tell with samples thirty minutes apart, the intense test for RF 7 just started and looks clean.
SHF
SFischer1 is offline
post #14223 of 14754 Old 09-21-2016, 05:52 PM
Otto Pylot's Avatar
Liked: 873
Thanks. Seems to be ok now at 5:50pm. I was very surprised to see KGO this bad. "Stuff" happens I guess.
post #14224 of 14754 Old 09-21-2016, 08:30 PM
Larry Kenney's Avatar
Quoted: 491 Post(s)
Liked: 76
Thanks for the Walnut Grove antenna info, Chuck. I've saved it for future reference.
The signals I receive from Walnut Grove are way out of line for what TVFool says they should be. They show KQCA way lower than the VHFs, 13 and 31, and that's the way it is under the unusual conditions I had yesterday, but normally KQCA is best. Weird, huh? KOVR has always been weaker than 6, 10, 31 and 58 here. About half the time it's below the cliff edge, while the other four are normally coming in.
Last night as the signals weakened a bit, KQCA started to get stronger again. This morning it was back to being the strongest of the group.
I used to see KCRA in here solid until the KGO translator when on the air, then I'd see if occasionally, but for the past few months I haven't seen it at all. I get some signal on 35 that holds at about 13-14 dB, but I don't know if it's KCRA or KGO that I'm receiving. I have never seen the KGO translator here. The KTVU translator either, for that matter, but I get KAXT 1 and KEXT 27 about 80% of the time.
It's these interesting reception situations that have kept me interested in TV reception since I was a kid back in New Hampshire. You never know what might happen.
Larry
rdvegas likes this.
My complete SF Bay Area DTV Station Lists: http://www.choisser.com/sfonair.html
Lots of Broadcasting links and information: http://www.choisser.com/broadcast.html
Live reception scans from my HD Home Run receivers: http://www.larrykenney.com/hdhr/
Photos and info on my antennas: http://www.larrykenney.com/tvantennas.html
Larry Kenney is offline
post #14225 of 14754 Old 09-22-2016, 11:32 AM
PaulamI's Avatar
Quoted: 91 Post(s)
Haven't gotten my GetTV for several weeks now, used to get it on both 4.3 and 14.3. Something change?
PaulamI is offline
post #14226 of 14754 Old 09-22-2016, 12:23 PM
Calaveras's Avatar
Quoted: 1135 Post(s)
Liked: 260
Just checked it and it's on 4.3, 14.3 and 64.3. Rescan your TV?
Chuck
Calaveras is online now
post #14227 of 14754 Old 09-22-2016, 04:16 PM
PaulamI's Avatar
Quoted: 91 Post(s)
They're still on my tuner, just says low signal strength. And Journey to the Center of the Earth is on tonight!
PaulamI is offline
post #14228 of 14754 Old 09-24-2016, 11:09 AM
Liked: 0
Originally Posted by 888CALLFCC View Post
I also own the "Digiair pro". You may have the overload step attenuator on ... and not even know it .... Turn it off for true readings.
Hi Ben – There does not seem to be anything related to a step attenuator when I look at my menu options. Or maybe I am lost in the terminology. The options are:
Single channel mode
Selected channels mode
Spectrum mode
Sound On/Off
Power to Antenna>off (current setting)
Power to Antenna>5V
Power to Antenna>12V
Select channels
Setup>Contrast
Setup>Auto Power off
Setup>CCIR System
Setup>Signal Type
Originally Posted by SFischer1 View Post
"DeLorme Topo North America 9.0".
I see it on Amazon and it looks like a fun tool to monkey around with. If I had more things I could use it on that I could benefit from I would consider buying it. I typically use my money on gambling, booze and cheap women and then I squander away the rest.
With my setup I think I am in really good shape with my attic mount system. It is only this one channel I wanted to try and tweak. I don’t care much about the other 2Edge channels.
Originally Posted by Calaveras View Post
dBm=-108.75 dBm + dBuV
Great. And for what it is worth, I did do a google search even before I posted the question. I gave up after my 5 minute rule expired as all the pages I saw led me around for too long with out getting to the point, which is why I asked here. Much appreciated for you to cut to the chase for me.
Next steps…Fog Fest on a clear day today, and am still walking in the direction of getting a pre-amp in place.
-Eric
j_iliz is offline
post #14229 of 14754 Old 09-26-2016, 05:43 PM
SFischer1's Avatar
Quoted: 499 Post(s)
Liked: 62
Wildfire ignites in Santa Cruz mountains on Loma Prieta peak
http://www.ksbw.com/article/wildfire...ntains/3859834
The pictures show the fire is right in the field of transmitters.
SHF
post #14230 of 14754 Old 09-29-2016, 12:19 AM
Quoted: 491 Post(s)
Liked: 76
Conditions have been varying a lot since this afternoon and now into the evening. I've seen some of the Walnut Grove stations get as high as 29 dB SNR and then drop down to 16-17 dB and then climb back up again. KOVR reached 22 dB and KCRA was watchable for a while when it got above the cliff edge into the 15-16 dB range. I was also able to detect KTFK 64.1, .3 and .4 for a while. KQCA 58, which has been solid in the 19-20 dB range for the past week, dropped below the cliff edge for most of the day. It's been interesting to watch all of the changes.
Larry
post #14231 of 14754 Old 09-30-2016, 09:55 AM
Quoted: 491 Post(s)
Liked: 76
The FCC is proposing a phased repack by DMA. Here's the story from "TV Technology":
http://www.tvtechnology.com/news/000...-repack/279539
Larry
rdvegas likes this.
post #14232 of 14754 Old 09-30-2016, 01:05 PM
Calaveras's Avatar
Liked: 260
Larry
The TSPPN outlines a 10-phase transition and announces that TV stations will receive confidential letters with their final channel assignments shortly after the final stage rule is satisfied so they can finalize equipment orders.
So stations that have to move will be assigned new channels and have no choice what the are? A UHF station may end up on low or high VHF?
Chuck
post #14233 of 14754 Old 09-30-2016, 06:07 PM
Trip in VA's Avatar
Quoted: 603 Post(s)
Liked: 165
Send a message via AIM to Trip in VA
Chuck
No, but a station on a UHF channel may be assigned to a different UHF channel. Only stations that bid to receive money can be moved to a lower band.
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is offline
post #14234 of 14754 Old 10-04-2016, 09:10 PM
OTnA's Avatar
Quoted: 20 Post(s)
REV'N is now on KFTL 28.5
OTnA is offline
post #14235 of 14754 Old 10-05-2016, 06:40 PM
PeninsulaMark's Avatar
Quoted: 633 Post(s)
Liked: 78
Thumbs down KNTV Ch. 11.1 audio & video issues just started again
Started five minutes ago. Worse than the Olympic disruptions. Includes total screen severe pixellation.
PeninsulaMark is offline
post #14236 of 14754 Old 10-05-2016, 08:21 PM
SFischer1's Avatar
Quoted: 499 Post(s)
Liked: 62
I have seen big problems with Toast0's KCSM VC 60 RF 43 graph for many days.
I ran a test the other day with perfect results.
EDIT: At ~ 9 PM 10/5/2016 KCSM VC 60 RF 43 was useless.
KCSM's Transmitter has a problem, don't touch your antenna. I will post when they fix it. SHF 10/8/2016
It appears that shifting Toast0's antenna just a little bit has changed his reception for RF 43.
So, if you move your antenna expect problems. When my antenna was taken down for termites the installer put it back up using the same bolts onto the same holes and I have seen no differences.
http://www.avsforum.com/photopost/sh...hp?cat=2165469
SHF
post #14237 of 14754 Old 10-05-2016, 08:53 PM
RayGuy's Avatar
Quoted: 733 Post(s)
Liked: 596
As is Retro. I am receiving two 28.5 channels.
RayGuy is offline
post #14238 of 14754 Old 10-05-2016, 08:59 PM
SFischer1's Avatar
Quoted: 499 Post(s)
Liked: 62
I ran a test for ~ 60 minutes and it was all good, no problems.
SHF
post #14239 of 14754 Old 10-05-2016, 10:06 PM
Quoted: 633 Post(s)
Liked: 78
Thumbs down
SHF
It is now occurring less often, maybe every 3-5 minutes, A & V, briefer, and less severe.
PM
post #14240 of 14754 Old 10-07-2016, 12:50 AM
Dizzman's Avatar
not sure if this is the correct forum here... but i live in south san jose and am just stepping (cheaply) into OTA reception. cord cutting... all that jazz. and my main concern at the moment is really just warriors Niners and sharks.
so here is the question... whats a cheap entry level antenna? Indoor or outdoor?
any and all guidance is appreciated.
thanks.
just hanging out, rollin with the flow.
Dizzman is offline
post #14241 of 14754 Old 10-07-2016, 07:02 AM
Calaveras's Avatar
Liked: 260
thanks.
Please add a link to your TV Fool report to your post above. We need to know what the signals are like at your location. South San Jose is likely to require an outdoor antenna. There's no such thing as an entry level antenna. Your location will dictate what antenna you need. Which channels carry the Warriors and Sharks?
Chuck
post #14242 of 14754 Old 10-07-2016, 07:37 AM
ADTech's Avatar
Quoted: 123 Post(s)
Liked: 65
Warriors - CSN Bay Area
Sharks - CSN California
Perhaps a few regular season games might be broadcast OTA...
At least the NFL hasn't contracted with the subscription-based providers for most of their games.
Tech support for Antennas Direct
ADTech is offline
post #14243 of 14754 Old 10-07-2016, 12:19 PM
Dizzman's Avatar
ok, here is the TV fool report.
http://www.tvfool.com/?option=com_wr...e2cb82b38948f9
So as it seems most local sports are on CSN (which if i am figuring right is not OTA) what options are there? just a few straggler games here and there?
i was looking at the Solid Signal HDB4X and attaching it about 15-20' off the ground. i have some trees, but pretty much an unobstructed view up the valley towards the cluster of stations at 330 degrees on the tv fool report.
new to all this cord cutting. SO far my plan is OTA (with a tivo) and hulu. any other suggestions are all appreciated.
Dizzman is offline
post #14244 of 14754 Old 10-08-2016, 06:52 AM
Calaveras's Avatar
Liked: 260
The good news is that all the SF stations are strong and line-of-sight. The HDB4X is a UHF only antenna and you need a high VHF antenna for 7 and 11. I'd try a Winegard HD7694P. That should receive the stations in Fremont even pointed towards SF because they are so strong.
If local sports is your main thing then you're stuck with cable.
Chuck
post #14245 of 14754 Old 10-08-2016, 12:55 PM
Dizzman's Avatar
what about this one?
http://sfbay.craigslist.org/sby/ele/5816698210.html
its a Channel Master Advantage 100
trying to keep things cheap at present. so leaning to used.
do i stand a chance with an indoor one?
Dizzman is offline
post #14246 of 14754 Old 10-08-2016, 03:25 PM
Calaveras's Avatar
Liked: 260
You could use that antenna but unless you're looking for the religious station on channel 2 all those large elements will go to waste.
I cannot recommend an indoor antenna for anyone 44 miles from the transmitters.
Chuck
post #14247 of 14754 Old 10-08-2016, 03:28 PM
Dizzman's Avatar
ok thanks. one thing... i can see 7 on the list (KGO) but i cannot for the life of me see 11. am i blind? which channel is 11?
thanks again.
Dizzman is offline
post #14248 of 14754 Old 10-08-2016, 04:18 PM
SFischer1's Avatar
Quoted: 499 Post(s)
Liked: 62
thanks again.
KNTV Virt 11 RF 12 (NBC)
Number eight from the top.
When looking at antennas you need the RF channel, not the Virtual one.
SHF
post #14249 of 14754 Old 10-08-2016, 07:04 PM
SFischer1's Avatar
Quoted: 499 Post(s)
Liked: 62
Larry Kenney maintains the list of stations here.
The first link is for the Virtual Channel Sort.
The list sorted by RF channel link is at the top of that list. Here also is a link:
http://www.choisser.com/sfonair2.html
SHF
post #14250 of 14754 Old 10-09-2016, 12:39 AM
Dizzman's Avatar
will i need any kind of amplifier or the like to boost it all do you think?
i am feeding it into a TIvo premiere.
thanks for all the help.
I feel like a total fool in all of this. for context, i have worked in AV for the last 25 years. projectors, video walls, sound, lights, control... i am all over this stuff...
this is the kind of stuff i build in my day job...
but this stuff... oy! no idea at all.
So thanks again.
Dizzman is offline
