San Francisco, CA - OTA - Page 515 - AVS Forum | Home Theater Discussions And Reviews
 199Likes
post #15421 of 15432 Old 06-27-2017, 12:19 PM
888CALLFCC's Avatar
Quoted: 220 Post(s)
Liked: 31
Originally Posted by MikeekiM01 View Post
When tuning/aiming your antenna for signal strength, do you guys have a "favorite" channel to use to measure your aim to Sutro, Fremont and San Bruno?
Absolutely, ... On your tvfool listing report, use the last Green, yellow, or red station on the location you are tuning. (Example) .. So if you have all yellow and two red stations, for Sutro tower,
you pick the red stations, force tune those without scanning, Tune antenna to those, Then, scan-in the rest.
888CALLFCC is offline
post #15422 of 15432 Old 06-27-2017, 12:36 PM
Liked: 1
Another noobie question... As mentioned earlier, I am getting all of the main networks with my indoor Mohu Leaf 50 antenna... ABC, CBS, FOX, NBC... I had mistakenly assumed that it was only a UHF antenna, but I just realized it's a VHF/UHF antenna...
Am I right in assuming that if I go with a bow-tie style UHF only antenna (without the VHF adapter), that I will effectively lose ABC and NBC? (KGO and KNTV)?
MikeekiM01 is offline
post #15423 of 15432 Old 06-27-2017, 12:42 PM
888CALLFCC's Avatar
Quoted: 220 Post(s)
Liked: 31
"Force tuning" .. example tricks using a Digitalstream converter box. "Antenna mode" , etc.
1. Push the . "dot" button (or pound button) on the remote keypad. Up pops RF on the tv screen blue box. Enter RF channel.
For "antenna meter" (After RF entry)
1. Push the (star button) or meter button on the remote.
post #15424 of 15432 Old 06-27-2017, 12:54 PM
888CALLFCC's Avatar
Quoted: 220 Post(s)
Liked: 31
Yes, you want a UHF-VHF antenna. The easy way to tell is UHF antenna elements are generally 1 foot or less. High VHF band antenna elements are around 2-3 feet long.
And low VHF band antennas are 8-9 feet long.
SO ... The muho leaf antenna is a UHF only antenna, using the cheap - unshielded 3 foot coax as a VHF antenna. .... Notice the cable size ? Thats Not shielded RG-6 cable.
Using the cable itself as the antenna ... is a very wimpy design of low quality. It may ... or may not work.. depending on location.
post #15425 of 15432 Old 06-27-2017, 01:25 PM
lifespeed's Avatar
Quoted: 120 Post(s)
Both of those channels are available on UHF from Fremont repeaters, I receive KGO and KNTV and do not have a VHF antenna. You may still want to put up VHF because KRON is going from RF 38 to RF 7 on Sutro after the repack, but it was also sold to a new owner, so who knows what content it will end up broadcasting.
Lifespeed
lifespeed is offline
post #15426 of 15432 Old 06-27-2017, 01:31 PM
lifespeed's Avatar
Quoted: 120 Post(s)
Looking at Sutro I would also check KPIX, even though it is a 1MW transmitter. There is a low power analog station on the same channel, RF 29, in Salinas that may be a source of interference. Likely your location is better than mine relative to this and other reception problems.
Edit: if you go with a bowtie you may be able to aim 5 to 10 degrees east of SF to improve Fremont reception with little degradation of Sutro signals thanks to the broad beam. I'm betting (with your money and time, LOL) this would work and free your Tivo from antenna rotors or dual antennae with a switch . It is what I tried first, and came within a gnat's eyelash of 100% dropout-free success. But I am behind a hill with markedly worse reception conditions than you.
Lifespeed
post #15427 of 15432 Old 06-27-2017, 07:26 PM
Calaveras's Avatar
Quoted: 1244 Post(s)
Liked: 269
Nobody can answer this question with any certainty. I don't understand why you're asking it anyway. If you want to receive VHF then you need an antenna designed for VHF. If you want to go UHF only and try compromise pointing then you can try a UHF only antenna. The bowtie antennas are not designed for VHF. Sometimes they work on VHF if the signal is strong enough but a paperclip will also work as an antenna if the signals are strong enough.
After I conducted a few pointing tests in the South Bay I no longer recommend compromise pointing there. Too much multipath. Even if it works for you you'll be dealing with reduced Signal Quality which may come back to bite you.
Once you have your antenna installed and receive all the stations you want you should go back and check the signal Quality of each station. It should be in mid 20's dB or 80's%. You don't want SQs <20dB because that's not enough margin to be reliable in many cases.
Chuck
Calaveras is offline
post #15428 of 15432 Old Yesterday, 10:58 AM
888CALLFCC's Avatar
Quoted: 220 Post(s)
Liked: 31
[QUOTE=kkpm
Keith
KB5JVM[/QUOTE]
What ? Why ?
Did .... "North bay tv" .... get replaced with an infomercial channel ? .... 45-8 .. & ..12-8
post #15429 of 15432 Old Yesterday, 11:34 AM
lifespeed's Avatar
Quoted: 120 Post(s)
Chuck
I agree with all the above. That said, trying compromise pointing is basically a zero-cost experiment (aside from a bit of one's time) with huge benefits in the context of automated DVR recording. If it doesn't work, re-aim and or install a rotor. Or compromise pointing could be implemented with a rotor, and direct aimed if the experiment doesn't yield 80% signal quality.
For context, I get about 80% signal quality from many Sutro stations in my south bay location using the DB4e bowtie aimed 45 degrees west at Mt. Allison. There are a few Sutro and San Bruno stations with signal quality around 70% however, and in the interest of rock-solid reception I added a Yagi aimed at Sutro (already had the DB4e at this point) each with a dedicated tuner. But my signal strength conditions are relatively poor one-edge over a nearby hilltop, with as much as 20dB less noise margin than @MikeekiM01 .
Given the improved signal conditions at his location it is a worthwhile experiment.
Lifespeed
post #15430 of 15432 Old Yesterday, 12:32 PM
Calaveras's Avatar
Liked: 269
Today the FCC granted the Legal STAs filed by KKPX and KEZT-CD saying they can't build a station on Channel 14 and by KSEE on Channel 16 because of interference to land mobile stations. I don't know what comes next. It may be possible to squeeze KEZT in somewhere else in the Sacramento market but I don't see where else KKPX can go in the San Francisco market unless it's low VHF.
Are there other options available to the FCC? Land mobile accepts more interference? Someone has to find another site?
Chuck
post #15431 of 15432 Old Yesterday, 08:39 PM
888CALLFCC's Avatar
Quoted: 220 Post(s)
Liked: 31
Chuck
They can move to channel 6.
bye bye k-love radio
post #15432 of 15432 Old Today, 12:52 AM
Larry Kenney's Avatar
Quoted: 544 Post(s)
Liked: 82
Chuck
I'm back from my trip to Spain and Portugal. It was a fantastic experience and i had a lot of fun, plus I took 1,427 photos I've got to work on for my web site... sometime.
I just read the last couple of weeks worth of posts here on the thread so I'm caught up again.
My first comment has to do with KKPX. I was wondering if they were going to accept channel 14 and make the best of fighting with the land mobile stations or filing with the FCC. Apparently they're going with the later choice, but, as you said, Chuck, where are they going to go? The band will be full once all the moves are made. This will be interesting to watch.
Larry
My complete SF Bay Area DTV Station Lists: http://www.choisser.com/sfonair.html
Lots of Broadcasting links and information: http://www.choisser.com/broadcast.html
Live reception scans from my HD Home Run receivers: http://www.larrykenney.com/hdhr/
Photos and info on my antennas: http://www.larrykenney.com/tvantennas.html
Larry Kenney is online now
