San Diego, CA - HDTV - Page 32 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #931 of 1102 Old 02-10-2011, 12:54 PM
domino92024's Avatar
Quoted: 100 Post(s)
Liked: 191
Originally Posted by coyoteaz View Post
I'm not aware of any firmware that allows a Moto TA to work on a Cisco headend. They use different protocols.
According to Cisco, their headend SDV equipment provides open protocols that support multiple vendor solutions, whatever that means.
domino92024 is offline
post #932 of 1102 Old 02-19-2011, 05:50 PM
Ennui's Avatar
Cox service guy today said hold off on installing TA's. They are having some trouble with them so wait a week or two (or until they are "necessary").
99.5% Dark Matter
Ennui is offline
post #933 of 1102 Old 02-19-2011, 10:19 PM
Quoted: 100 Post(s)
Liked: 191
Like when you start getting "Channel unavailable. Try again later" messages when you try to tune channels mapped to SDV.
post #934 of 1102 Old 02-19-2011, 11:11 PM
WackyPacks's Avatar
Quoted: 14 Post(s)
Liked: 38
Here in LA when Time Warner implemented SDV, the SDV channels on my Tivo would display a message saying "Searching for signal on: Cable In. See "Messages & Settings"/Troubleshooting " for info." I knew something was odd because those channels never returned even after a few days, yet all the others worked fine.
WackyPacks is offline
post #935 of 1102 Old 02-20-2011, 10:58 AM
Quoted: 100 Post(s)
Liked: 191
Which TiVo? With or without Tuning Adapter?
post #936 of 1102 Old 02-20-2011, 02:03 PM
WackyPacks's Avatar
Quoted: 14 Post(s)
Liked: 38
Tivo HD, but I suspect the same message would appear on a Premiere. When tuned to a SDV channel without a tuning adapter, the message would appear. Obviously when using a working tuning adapter, the channel would appear as usual.
post #937 of 1102 Old 02-20-2011, 08:38 PM
bgooch's Avatar
By Mike Freeman Sunday, February 20, 2011 at 6 a.m.
Eight months ago, Cox Communications started talks to end cable's monopoly for carrying San Diego Padres baseball games in the local market, bringing hope to satellite TV and AT&T U-Verse subscribers that they, too, would have access to Padres games for the 2011 season.
But with opening day just a month and half away, there has not been an agreement reached between Cox and other pay TV providers that would allow access to Channel 4, which carries the Padres games. The drawn out nature of the talks has led analysts to speculate that AT&T, DirecTV and others are balking at the per subscriber fees that Cox is seeking for Channel 4.
http://www.signonsandiego.com/news/2...20/cox-padres/
bgooch is offline
post #938 of 1102 Old 02-20-2011, 09:49 PM
Tom Wellman's Avatar
Quoted: 28 Post(s)
Liked: 41
I can't say I'm holding out hope for this season.
And the FOUL!
Tom Wellman is offline
post #939 of 1102 Old 02-26-2011, 09:45 AM
muffinmcfluffin's Avatar
Quoted: 86 Post(s)
Liked: 80
I'm trying to get CBS OTA, but I haven't been able to for about a month. The SDSU game is coming on in a little over an hour. Any suggestions here? I get every other basic cable channel OTA, but not this one.
muffinmcfluffin is offline
post #940 of 1102 Old 02-26-2011, 11:20 AM
Daranman's Avatar
It and ABC are a tough get with most indoor antennas, because they are in the high VHF band. I live in Mission Valley, so I don't get a clean line on sight to Mt. Soledad, and had success with a Channel Master 2016 outdoor antenna in my attic by pointing it directly at Mt. Soledad, but its still not as great as the signals from Mt. Miguel. (I put some rabbit ears outside my window, and was able to get both KFMB and KGTV, but only sporadically.)
I know its already too late for the game, but you might want to get a good directional antenna, especially if you are in a tough, obstructed location.
Daranman is offline
post #941 of 1102 Old 02-26-2011, 12:49 PM
Ennui's Avatar
I don't know where you are located, but I get CBS from LA on 2.1. This is in western San Marcos.
99.5% Dark Matter
Ennui is offline
post #942 of 1102 Old 03-18-2011, 11:28 AM
owhymesd's Avatar
So I'm finally ditching my cable and am looking for some advice on OTA and what my options are. I have a Samsung LCD HDTV that is less than a year old. I live in a rental so a rooftop antenna isn't an option. I have been using a Roku and Netflix for most of my TV viewing. I don't really watch that many channels but would like to get major networks without having to pay Cox.
owhymesd is offline
post #943 of 1102 Old 03-18-2011, 11:29 AM
owhymesd's Avatar
Will an indoor antenna work for me?
If so, what should I get?
Will my TV auto-program find the channels or will I have to do configuration?
owhymesd is offline
post #944 of 1102 Old 03-18-2011, 11:30 AM
owhymesd's Avatar
Sorry but I need 3 posts for the URL...
owhymesd is offline
post #945 of 1102 Old 03-18-2011, 11:30 AM
owhymesd's Avatar
owhymesd is offline
post #946 of 1102 Old 03-18-2011, 02:33 PM
holl_ands's Avatar
Quoted: 177 Post(s)
Liked: 99
Your TVFool report shows lots of signal strength for San Diego & Tijuana (CW) digital TV stations.
Here's a list of the better Indoor antennas from which to chose, although most any cheap
RabbitEars+UHFLoop should also get the job done....avoid the "Flat" RCA antennas.
Location, location, location.....and let us know if you have any problems:
http://www.avsforum.com/avs-vb/showthread.php?t=1037779
Yes, you'll probably need to search for channels...and repeat search after moving antenna around
if you don't get all of them the first time (CW could be more difficult).
With those signal levels you MIGHT get lucky and get a few L.A. stations, but
Ch7/9/11/13 will probably be overwhelmed by the much stronger local Ch8/10/12.
holl_ands is offline
post #947 of 1102 Old 03-18-2011, 06:25 PM
coyoteaz's Avatar
6 is unlikely to cause problems with 7 because they're 92MHz apart (center to center). However, KZTC-LP on 7 will destroy KABC, and KSDX-LD on 9 will get KCAL. KTTV and KCOP stand a slim chance if the tuner in use has good adjacent-channel filtering.
coyoteaz is offline
post #948 of 1102 Old 03-20-2011, 04:20 PM
holl_ands's Avatar
Quoted: 177 Post(s)
Liked: 99
You're right, so I removed Ch6 from my list...but Ch8 will kill Ch7 all by itself...
post #949 of 1102 Old 03-28-2011, 10:09 AM
owhymesd's Avatar
Thanks for the assistance. I went with the Winegard SS-3000, hooked it up over the weekend and it works great! Now I just have to figure out how to hook into the existing cabling under the house without disconnecting my Internet or getting eaten by critters. :-)
owhymesd is offline
post #950 of 1102 Old 03-28-2011, 04:33 PM
ProjectSHO89's Avatar
Quoted: 127 Post(s)
Liked: 90
Keep in mind that, in almost all cases, you cannot combine your OTA signal with the cable internet service on the same cable at the same time....
ProjectSHO89 is offline
post #951 of 1102 Old 03-28-2011, 09:37 PM
Quoted: 100 Post(s)
Liked: 191
Ya can if you first filter out signals >800MHz and <40MHz.
post #952 of 1102 Old 03-29-2011, 04:19 AM
Quoted: 127 Post(s)
Liked: 90
Generally, internet service is not restricted in CATV systems to under 40 and over 800 MHz. The CATV operator may choose to use any slice or chunk of the downstream spectrum for IP signaling while reserving the lowest frequencies (under 42 MHz) for the upstream traffic. DOCSIS 3.0-compliant systems may use downstream frequencies between 50 and 1002 MHz with the operator specifying which downstream channels are for IP traffic.
Unless you have specifics for a particular system and can work around them, you can't merge the signals.
post #953 of 1102 Old 03-29-2011, 11:02 AM
owhymesd's Avatar
So it looks like the cable comes from the Cox box into a 3 way splitter. One of those goes to my Internet, the other 2 to other outlets. As long as I leave the Internet as is I should be able to remove the other two cables from the splitter, use the antenna as the input and add a splitter off that line for the other 2 outlets, right? That way nothing is traveling over the same system but I can still use the existing wiring. If not, I'll buy multiple antennas before I crawl under the house.
owhymesd is offline
post #954 of 1102 Old 03-29-2011, 12:55 PM
Quoted: 100 Post(s)
Liked: 191
With bandwidth restraints in the 54MHz-860MHz as they are, I've yet to see a cable company put its downstream Internet traffic below 800MHz.
post #955 of 1102 Old 03-29-2011, 01:52 PM
coyoteaz's Avatar
When I lived in Phoenix, Cox had their downstream at 579MHz/channel 83.
coyoteaz is offline
post #956 of 1102 Old 03-29-2011, 03:30 PM
Quoted: 127 Post(s)
Liked: 90
Like I said, you have to KNOW what the cable company is doing.... And they all have the flexibility to screw up our best estimates.
post #957 of 1102 Old 03-29-2011, 04:01 PM
kevin120's Avatar
Quoted: 18 Post(s)
Liked: 30
It varies my TWC system carries them at:
783MHz
789MHz
795MHz
801MHz
but I have seen where wideband has been carried down in the FM band for instance TWC cleveland:
105MHz
111MHz
117MHz
TWC NYC uses:
297MHz (CISCO CMTS' only)
303MHz
309MHz
315MHz
321MHz
kevin120 is offline
post #958 of 1102 Old 03-29-2011, 09:33 PM
Quoted: 100 Post(s)
Liked: 191
783MHz
789MHz
795MHz
801MHz
105MHz
111MHz
117MHz
TWC NYC uses:
303MHz
309MHz
315MHz
321MHz
I stand corrected.
post #959 of 1102 Old 04-10-2011, 09:00 PM
JoeM's Avatar
Anybody know anything about "LATV", the new Telemundo subchannel (33-2) in Tijuana/San Diego ?
JoeM is offline
post #960 of 1102 Old 04-10-2011, 11:20 PM
sandog's Avatar
It's been there for about two weeks. I though Mexican station could not have sub-channels. I guess TV Azteca broke that rule.
sandog is offline
