San Diego, CA - HDTV - Page 37 - AVS | Home Theater Discussions And Reviews
 1Likes
post #1081 of 1101 Old 10-18-2012, 07:06 AM
rdvegas's Avatar
Quoted: 60 Post(s)
Liked: 35
KNSD gets COZI
The NBC Nonstop sub-channel on KNSD 39.2 will become COZI TV on the first of January 2013. Lots of off-net programs, such as Marcus Welby MD, will be aired daytime. Conflicting reports surface about the nighttime schedule. Will the current lifestyle programs on Nonstop continue in primetime, or will they move aside for more former network repeats?
COZI TV is from NBC, and will air initially on their Owned and Operated cluster stations, including KNSD. However, affiliates are being sought in other markets for the morphed Nonstop into COZI diginet.
Cozi up to your tv for some more retro programming.
Wanting a strong FCC to say no to the Wireless lobby. Keep the tv broadcast band for ota television broadcasters.
rdvegas is offline
post #1082 of 1101 Old 06-17-2013, 07:00 AM
rdvegas's Avatar
Quoted: 60 Post(s)
Liked: 35
Somebody please yawn.
rdvegas is offline
post #1083 of 1101 Old 06-17-2013, 11:38 AM
domino92024's Avatar
Quoted: 86 Post(s)
Liked: 185
Y - A - W - N !!
domino92024 is online now
post #1084 of 1101 Old 06-17-2013, 12:19 PM
michaeltscott's Avatar
Quoted: 1638 Post(s)
Liked: 953
saylormd likes this.
Mike Scott (XBL: MikeHellion, PSN: MarcHellion)
"Think of the cable company as a group of terrorist (sic)." -- hookbill
michaeltscott is offline
post #1085 of 1101 Old 07-03-2013, 03:00 PM
Gandu's Avatar
Quoted: 30 Post(s)
Liked: 54
Been looking around at the BroadbandReports TimeWarner Internet Services forum and I have a couple of questions specific to TWC San Diego.
1. Do we have IPv6 ?
2. Do we have 8 channel downstream bonding with a DOCIS3 modem? (Motorola SB6141)
Gandu is offline
post #1086 of 1101 Old 07-24-2013, 12:08 PM
Quoted: 86 Post(s)
Liked: 185
Stolen from the S.D HDTV forum:
Cox’s motto: “HD is FREE!” And their fine print always reads “Cox Advanced TV
(formerly Digital Cable) and paid subscription to Digital HBO, Cinemax, Starz,
and/or Showtime required for respective premium HD channels. Other HD channels
require subscription to Cox Advanced TV and service Pak with the standard
version of the channel.” *Oh, really*?
Cox’s “Plus Pak” contains 39 channels, all HD. 2/3 of those HD channels have SD
versions in various tiers or “Paks.” Yet Cox charges extra for access to those
HD channels. I get the SD version of the DIY network, BTN and the PAC-12 Net on
the “Sports & Information Pak” yet I must pay extra for the HD channels,
contrary to Cox’s stated policy. I get The Cooking Channel in SD in “Variety
Pak”, but not the HD version since it is in the “Plus Pak.” I get the SD
versions of 16 of the “Plus Pak” channels, yet must pay for the HD versions.
And WHY does this “Plus Pak” price vary depending on which DVR you have? Do you
have a TiVo or HTPC? Then, the “Plus Pak” is FREE! Have a Cisco 8642HDC or
8742HDC WHDVR? Then it’s $5/month for the “Plus Pak.” Have the new 6-tuner Cisco
9865HDC WHDVR? Then the same “Plus Pak” is $10/month. Why, Cox? Why? That’s like
selling a bag of potatoes for FREE to redheads, for $5 to blondes, and for $10
to brunettes.
Why, Cox? Why?
post #1087 of 1101 Old 11-05-2013, 10:33 PM
hdtvfan2005's Avatar
Not much activity in this thread. sandiegohdtv.org is still up, however the old domain (hdtv.forsandiego.com) is no longer working. Then again, I think it is ok for sandiegohdtv.org to be the only domain as MyBB only works with one domain, which is why I cannot have both domains working. Attachments have been fixed for quite some time. :)
hdtvfan2005 is offline
post #1088 of 1101 Old 11-06-2013, 07:52 AM
TheMightyQuinn's Avatar
Thanks for the update.
I've been using a 4-bay Mclapp w/o reflector in my attic and am amazed how clear LA comes in from Mira Mesa. When I scan for channels I can pull up to 80 channels (including subchannels). Unfortunately I lose some channels in poor propagation conditions. I get quite a bit of Mexican stations which can interfere with LA stations.
I've been thinking of adding a reflector to help with LA stations and attenuate the Mexican stations. I'm hoping, since the San Diego stations (which are in the same direction as the Mexican stations) are much closer, a reflector would still allow me to receive the San Diego stations.
Which leads to my question: if a reflector can enhance my gain in the forward direction by X dB, does it also attenuate the back gain by X dB? Is there a relationship between forward gain improvement and back gain attenuation?
TheMightyQuinn is offline
post #1089 of 1101 Old 11-06-2013, 09:10 AM
holl_ands's Avatar
Quoted: 165 Post(s)
Liked: 98
Adding a Reflector to an M4 Super-4-Bay provides Front/Back and Front/Rear Ratios in excess of 18 dB.
Charts for two difference M4 sizes are provided here:
http://imageevent.com/holl_ands/multibay/4bayrefl
Compare to M4 without Reflector:
Note that Hi-VHF Gain is only 3.5 dBi....but SWR is Good. When adding mclapp's Double Angle Reflector Hi-VHF Gain increases to about 9 dBi....but SWR becomes Excessively high....that can cut into that Gain improvement by increasing the Noise Figure (reduced Sensitivity).
F/B Ratio is difference between Gain directly FORWARD (90-deg Azimuth in Charts) and Gain directly opposite (270-deg).
F/R Ratio is difference between Gain directly FORWARD (90-deg Azimuth in Charts) and highest Gain Lobe in the Rearward Sector.
BTW: You'll also see initial results for the Free-Form 4-Bay (FF4) improvement to the M4, allowing the Inner and Outer Bowties to have DIFFERENT parameters: I have posted results for the same sized Double Angle Reflector as used in mclapp's M4 (which was as much as 1 dB better on low-mid channels) and will post barely better results for a slightly taller version today...stay tuned over the next week or two when I analyze WIDER Reflectors, which I hope will provide several tenths of a dB (maybe 1 or 2 dB????) improvement:
http://www.digitalhome.ca/forum/showthread.php?p=1871570
I'm also working on changing the M4's (or FF4's) Reflector to an entirely different design that will fix the excessive SWR on Hi-VHF when adding a Reflector...but it results in about 3 dB loss of UHF Gain, so you probably have no interest in it....you should use a SEPARATE Hi-VHF Antenna, such as the Hi-VHF Hourglass-Loop with Reflector of your choice:
http://imageevent.com/holl_ands/loops/hivhfhourglassloop
Or perhaps one of the Hi-VHF Folded Dipole Yagi designs:
http://imageevent.com/holl_ands/yagis
holl_ands is online now
post #1090 of 1101 Old 11-08-2013, 12:41 PM
Thanks for the reply. Man that's a lot of antenna modeling. Part of my job is beta testing a fullwave EM solver. I'll see if I can model one of these designs next year.
post #1091 of 1101 Old 12-04-2013, 09:43 AM
humdinger70's Avatar
Quoted: 129 Post(s)
Liked: 89
TWC is updating the boxes. I just got ODN 7.2.0_5 early Tuesday morning (12/03/2013). Guide is now wide screen as are all other menus.
Other changes:
FF/REW compensation is back. Default is NORMAL (I believe).
Cablecards are being updated to handle six tuner boxes (like TiVo's Roamio unit).
humdinger70 is offline
post #1092 of 1101 Old 02-11-2014, 02:26 PM
Quoted: 129 Post(s)
Liked: 89
post #1093 of 1101 Old 10-03-2014, 08:54 PM
bgthree's Avatar
Wow... I was reading the last couple pages of the thread to "get up to date" on OTA tv in San Diego and didn't realize it was 2 years old. I thought this was one of the biggest populations in the country?
Anyway, I came here to find out what setups people are using to get all the local HD channels all the time, and preferably the LA networks too. Someone posted about a 4 bay McLapp somethin or rather working ok, followed by someone replying in detail but unfortunately in Greek.
Are there any updated resources for getting OTA tv to work as well as possible in SD? Thanks for any nudges in the right direction.
bgthree is offline
post #1094 of 1101 Old 10-03-2014, 09:46 PM
holl_ands's Avatar
Quoted: 165 Post(s)
Liked: 98
With TV Stations coming from 3 locations in SD County, at least 2 in Mexico plus L.A. (if you are lucky), it all depends on LOCATION, LOCATION, LOCATION. And whether you have the luxury of being able to mount the Antenna on the Roof....or are forced....or desire to try an Attic, Balcony or Indoor Antenna....
To begin with, enter your location into www.tvfool.com and copy/paste the URL (Web Address) at the top of the Results page into a post in this thread....then we can see what you're up against and what is "doable".
post #1095 of 1101 Old 10-04-2014, 12:14 PM
sdsalsero's Avatar
KEY INFO
- channels 8 and 10 broadcast from Mt Soledad (La Jolla), both are VHF
- channels 15, 39 , 51 and 5/69(?) broadcast from Mt San Miguel (Spring Valley), all are UHF
- channel 6 broadcasts from Tijuana, in UHF
- UHF requires small antennas, VHF requires big
MY GENERIC SUGGESTIONS
- mount the antenna(s) outside!
- buy a $10-25 Channel Master UHF antenna and point it towards Mt San Miguel. If possible, angle it towards Tijuana enough to pick-up channel 6, too
- buy a $20 VHF antenna and point it towards Mt Soledad;
you might be able to leave this antenna inside since VHF penetrates buildings better
- buy a VHF-UHF combiner (not a generic combiner) and connect the UHF antenna on the UHF-only side and the VHF antenna on the VHF-only side. This way the two antennas are not interfering with the other's signal
MY PERSONAL SETUP
- I live within a few miles of Mt Soledad and so I can get away with a single UHF antenna pointed halfway between Mt San Miguel and Tijuana; the wholly-unoptimized-for-VHF antenna still picks-up a usable VHF signal :-)
sdsalsero is offline
post #1096 of 1101 Old 12-10-2014, 07:32 AM
rdvegas's Avatar
Quoted: 60 Post(s)
Liked: 35
Is anyone seeing programming on KSEX channel 43, rf 42? If so, what?
One person reports that they air plenty of infomercials on their four sub-channels. But do they ID as KSEX 43?
rdvegas is offline
post #1097 of 1101 Old 01-18-2015, 08:51 PM
rdvegas's Avatar
Quoted: 60 Post(s)
Liked: 35
ABC and Scripps partner with KATZ to launch "LAFF" on KGTV 10.2 on, or soon after, 15 April.
http://deadline.com/2015/01/laff-net...ps-1201352773/
rdvegas is offline
post #1098 of 1101 Old 04-08-2015, 03:22 AM
www.sandiegohdtv.org is still alive but changes are coming.
post #1099 of 1101 Old 04-12-2015, 11:49 PM
One change is the ability to post your own home theater setups.
post #1100 of 1101 Old 04-24-2015, 10:58 AM
San Diego HDTV was down for a little while earlier today for a new forum software upgrade.
http://www.sandiegohdtv.org/community/
The existing link will redirect over to the new forum, so all should be well. Still need to do some minor changes, but I am soft launching for now.
post #1101 of 1101 Unread Today, 10:53 PM
JoeM's Avatar
KTTV to vacate RF channel 11 ?
I thought it was strange when I saw that LA's KTTV was on a sub-channel of RF 13 (KCOP). I thought it might be because K35dg was finally to go digital in June and would use channel 11. Then I did some searching and found this, although it is a bit dated: http://www.coax.tv/EXEC_NAB2011.pdf
JoeM is online now
