Orlando, Central FL - BHN/Spectrum - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 236Likes
post #91 of 20115 Old 04-14-2004, 08:47 AM
Gilley's Avatar
From what I understand, DVI really shows an improved image with fixed pixel displays such as DLP, LCD, and plasma. A tube based standard RPTV usually will not show much, if any, improvement, which likely explains why you are not seeing much improvement in PQ. If you do decide to keep using the DVI, order a $20 cable online and return the $100 Monster Cable. There won't be any PQ difference since it is all digital.
Gilley is offline
post #92 of 20115 Old 04-14-2004, 12:22 PM
NewtoHD's Avatar
Any suggestions on a site to find a $20 DVI cable?
NewtoHD is offline
post #93 of 20115 Old 04-14-2004, 12:43 PM - Thread Starter
avNeophyte's Avatar
Try Pacific Cable.
avNeophyte is offline
post #94 of 20115 Old 04-14-2004, 01:53 PM
waltmapb's Avatar
For the past few days I have no audio from my Samsung TS-160 OTA receiver on WFTVHD channel 9.1. There is audio on the sub channel 9-2. Tried a rescan with no success. Anyone notice this problem?
waltmapb is offline
post #95 of 20115 Old 04-14-2004, 05:04 PM
LJCullen's Avatar
Thanks for info on where to buy the cables ..
I have Sony TV KV32HS500 -- and I am sure the picture will not improve to much but I was interested in the ability to switch the 4:3 to 16:9 without having to cycle thru different inputs on the TV -- rather let the cable box do it for me ..
Besides its something new and I am still learning about all this stuff -- and getting ready for that 49 in Sony I have my eye on
LJCullen is offline
post #96 of 20115 Old 04-14-2004, 06:19 PM
RudyT's Avatar
I bought my DVI cable here. I have shopped here several times and always
had good luck. Note I am not guarantying the lowest cost.
http://www.cablesnmor.com/dvi-cables.html
RudyT is offline
post #97 of 20115 Old 04-15-2004, 05:44 PM
tjtracey's Avatar
Any one having problems with the audio on channel 9-1? It has been out all week. Figured it was a problem at the station, now I'm starting to wonder. 9-2 audio works great (as do all other O-T-A channels). I am using a Samsung HDTV DirectTV receiver w/ additional antenna. Never had this problem.
Anyone have insight?
Thanks...
tjtracey is offline
post #98 of 20115 Old 04-15-2004, 06:05 PM
RogRacer's Avatar
Just a follow up to my BHN signal-level problem....seems like that was, in fact, the problem. Unfortunately, I wasn't home when he got to the house, but he told my wife he "boosted the signal". Not sure how he would do that, but it seemed to have done the trick. BTW....he was shocked that I got the Pace 550 to work with my Samsung HLN over DVI....he didn't think that was possible.....Anyway, thanks for the advice, Greg.
RogRacer is offline
post #99 of 20115 Old 04-15-2004, 06:29 PM
jrs98's Avatar
Can anyone recommend a decent OTA receiver for a low price? I only want an OTA tuner w/an antenna in my attic, not a DirectTV solution. I am thinking about getting a samsung t351 (I think i got that number right) on ebay but I read several reviews that said the failure rate of this model is abnormally high. Any suggestions would be great. I'm looking to spend $200 or less on the receiver (hence the decision to get a used one!)
Jeff in East Orlando
jrs98 is offline
post #100 of 20115 Old 04-15-2004, 06:47 PM
RthurDent's Avatar
Anyone getting CSI digital? My off the air receiver is getting a full strength signal, but no video or sound. The non digital on channel six is ok. The dang thing quit about 15 minutes into the program. Also they lost their second channel with the weather data.
C-band Satellite Junkie
RthurDent is offline
post #101 of 20115 Old 04-15-2004, 08:52 PM
Paul_Seng's Avatar
Same thing happened here. I thought it was me and my antenna from the winds we have had the last few days. Guess it was something else.
Paul Seng
Paul_Seng is offline
post #102 of 20115 Old 04-15-2004, 11:08 PM
Kid_Digital_NYC's Avatar
I lost CSI mid broadcast also.
Kid_Digital_NYC is offline
post #103 of 20115 Old 04-16-2004, 04:12 AM
Mike I's Avatar
That is really strange, becuase I had no problem last night at all, not even one break up which is unsual for KMG
Mike I is offline
post #104 of 20115 Old 04-16-2004, 05:01 AM
WGW
WGW's Avatar
RE CSI
Suspect a PSIP problem. No KMG picture from my DST-3000, but my MDP-100 PC card that is connected to same OTA antenna was receiving picture just fine. DST-3000 is really picky about PSIP whereas MDP-100 is fairly tolerant. Problem had not been fixed when I went to bed last night. Haven't checked this morning.
WGW is offline
post #105 of 20115 Old 04-16-2004, 07:11 AM
jswil's Avatar
[quote]Originally posted by tjtracey
[b]Any one having problems with the audio on channel 9-1? It has been out all week. Figured it was a problem at the station, now I'm starting to wonder. 9-2 audio works great (as do all other O-T-A channels). I am using a Samsung HDTV DirectTV receiver w/ additional antenna. Never had this problem.
I am using a Samsung TS-160 receiver and have had no audio on channel 9.1 and channel 27.1 for the past week. Looks like a PSIP problem that is effecting TS-160 receivers.
jswil is offline
post #106 of 20115 Old 04-16-2004, 08:10 AM
WGW
WGW's Avatar
Re: Channel 9-1 Audio MISSING?
No problem with audio on 9-1 or 9-2 with either DST-3000 or MDP-100 using OTA.
WGW is offline
post #107 of 20115 Old 04-16-2004, 10:18 AM
jrs98's Avatar
Hello,
Are any of you successfully using the Terk Antenna that clips onto your Satellite Dish for pulling in OTA HDTV?
THank you,
Jeff in east Orlando
jrs98 is offline
post #108 of 20115 Old 04-16-2004, 03:39 PM
waltmapb's Avatar
No audio on my TS-160 on 9-1 or 27-1. The DTC-100 works fine.......
Maybe someone has a contact at WFTV. It seems to be a Samsung problem. I wonder if it affects other Samsung models?
waltmapb is offline
post #109 of 20115 Old 04-16-2004, 04:14 PM
Joe C5's Avatar
For the audio issue you might check to make sure you are not stuck on some SAP channel. I had this happen a couple of time on my Zenith. I would go select the other audio channel and all would be well again. Probably the PSIP, but it's something to look into while you wait...
Joe C5 is offline
post #110 of 20115 Old 04-18-2004, 03:16 PM
jjakaitis's Avatar
Anyone have a solution for OTA in the Heathrow/Lake Mary Area. Trying to decide what to use with the DirectV reciever. Whether indoor antenna or something in the attic. any sugestions from anybody would be apprciated.
jjakaitis is offline
post #111 of 20115 Old 04-20-2004, 02:12 PM
waltmapb's Avatar
Yesterday the 9-1 audio returned in Dolby 5.1 on the Samsung TS-160 receiver. Today the channel 27-1 audio is back also. I had e-mailed the engineer at WFTV so maybe he did something...........
waltmapb is offline
post #112 of 20115 Old 04-20-2004, 05:15 PM
Panth1's Avatar
I would like to congratulate WKMG and WFTV for being fine affiliates and not passing network programming.
Your service (monopoly) is greatly appreciated.
Panth1 is offline
post #113 of 20115 Old 04-22-2004, 06:36 AM
ctbjr1309's Avatar
As I read posts by TW customers who have HD DVR's up and running and as I count down the days to the arrival of my HD TiVo, I'm wondering if Greg (or anybody else for that matter) can provide an update on the status of these HD DVR boxes for Bright House customers in Central Florida. Any info, definitive or speculative will be most appreciated.
ctbjr1309 is offline
post #114 of 20115 Old 04-22-2004, 10:25 AM
gmclaughlin's Avatar
To my knowledge, there are no cable operators who have the S/A 8000 deployed using Pioneer's Passport software. We've encounters some bugs in testings, but they're getting resolved.
We haven't scheduled an exact date yet, because software fixes are impossible to predict. Shouldn't be too much longer though.
Greg
gmclaughlin is offline
post #115 of 20115 Old 04-22-2004, 01:58 PM
ebockelman's Avatar
Is anyone having problems with the PSIP data on WRBW (UPN 65) today? I just activated my HR10-250 (HDTV Tivo) and get the "searching for signal on antenna in" when I tune to 65-1. Program data is in the guide for 65-1. I get a picture on 41-1, but there is no guide data there.
ebockelman is offline
post #116 of 20115 Old 04-22-2004, 02:19 PM
RobHT's Avatar
I just activated my HR10-250 (HDTV Tivo). . .
I am so jealous! I am waiting to see what Brighthouse has to offer for an HD PVR before sinking the $$ into the HD DirecTivo.
How do you like it?
RobHT is offline
post #117 of 20115 Old 04-22-2004, 04:58 PM
Joe C5's Avatar
ebockelman - This is the way is has been for as long as I can remember. Apparently WRBW can't (or won't) change their PSIP data stream to end back up on 65, and DTV can't (or won't) change the guide. Just the way it is I'm afraid. Maybe someday when more folks have Digital they will be bothered to fix it
Joe C5 is offline
post #118 of 20115 Old 04-22-2004, 07:22 PM
mhdiab's Avatar
Quoted: 62 Post(s)
Liked: 39
INHD blackout on BHN.
Greg - can you explain the blackout rules? Is it established by BHN or by FSN?
I am not that surprised that the inhd game tonight was blacked out, but considering that you don't carry FSN that carried the game I am wondering why it was blacked out - or is it because of proximity to arena and not because of other tv carriers??
mhdiab is offline
post #119 of 20115 Old 04-22-2004, 08:29 PM
PeterShipp's Avatar
Just thought I would share an anecdote. I was at a customer's house that has Adelphia digital cable. As I was flipping though the digital channels I notice a logo from the past on one of the channels, TechTV. The channel was right, but it still has the ZDTV logo, for those of you who don't know, was the name of the channel over three years ago!!! How sad is it that- Adelphia can't even keep the channel logos up to date!
Peter Shipp
ISF, HAA, SBCA, CEDIA Certified
ps@aecustom.com
PeterShipp is offline
post #120 of 20115 Old 04-23-2004, 09:43 AM
mwk
mwk's Avatar
Greg, it would have been great if you and Sunshine did some of the Tampa playoff games in HD. Seems you all missed a good chance to promote HD
Mike
mwk is offline
