Atlanta, GA - OTA - Page 15 - AVS Forum | Home Theater Discussions And Reviews
 30Likes
post #421 of 3703 Old 02-04-2005, 01:23 PM
DennisZ's Avatar
OK, I ordered mine from there this afternoon. Since they are in Tennessee, I should have it Tuesday or Wednesday.
again thanks
Denny
Denny
DennisZ is offline
post #422 of 3703 Old 02-04-2005, 01:30 PM
DennisZ's Avatar
Another question. After the amp power supply can I split the signal thru a splitter to my two recievers?
Denny
Denny
DennisZ is offline
post #423 of 3703 Old 02-04-2005, 01:54 PM
plasmamaniac's Avatar
Location: Peachtree City, Ga. (25 Miles South of Atlanta)
Yes, you can split an OTA signal with a simple splitter.
plasmamaniac is offline
post #424 of 3703 Old 02-04-2005, 04:08 PM
thepicman's Avatar
Denny
Yes, but you should check signal levels and basic success before splitting the signal. Insertion loss is fairly high with a splitter. YMMV
thepicman is offline
post #425 of 3703 Old 02-06-2005, 11:49 PM
Chanibus's Avatar
FOX did well w/ the Super Bowl imo, I didn't have any noticeable problems throughout the whole program? You guys have as smooth as a experience as me?
Chanibus is offline
post #426 of 3703 Old 02-07-2005, 05:28 AM
I have a splitter and I don't have any signal loss and I have heard that the most would be 2-4 DB in signal loss if any.
post #427 of 3703 Old 02-07-2005, 06:57 AM
philipgomez's Avatar
Super Bowl looked and sounded great except for the dumb "pylon-cams."
Phil G
American by birth, Mac user by choice.
philipgomez is offline
post #428 of 3703 Old 02-07-2005, 07:02 AM
Yes, the Super Bowl did look good but those "worm" cams and "pylon" cams did nothing for me at all, they've got to go.
post #429 of 3703 Old 02-07-2005, 08:58 AM
Douwe's Avatar
I have a DISH-811 and DISH-911 hooked up to OTA ... I pull *every and all* stations in with no problem and good signals
... with the exception of FOX WAGA (which used to be fine up until a week or so ago).
Obviously the SuperBowl was therefore in Standard Def ugh.
Does anyone have any suggestions?
Douwe is offline
post #430 of 3703 Old 02-07-2005, 09:01 AM
buzgz's Avatar
At the very best, half the signal is going somewhere else, so the minimum signal loss would be 3dB (-3dB=1/2). Then there is the possibility (certainty ?) of additional loss in the connections, connectors, etc.
buzgz is offline
post #431 of 3703 Old 02-07-2005, 09:09 AM
buzgz's Avatar
Are you saying that the FOX signal level has changed ? I haven't noticed anything unusual, and I watched some of the SB OTA last night.
buzgz is offline
post #432 of 3703 Old 02-07-2005, 09:11 AM
Yes, you need to put in your location in your profile.
post #433 of 3703 Old 02-07-2005, 09:13 AM
You also have to do a rescan because of PSIP and PID information changes which causes a need for rescanning to lock in the new signal.
post #434 of 3703 Old 02-07-2005, 09:23 AM
Douwe's Avatar
Location is North-Fulton almost on border with Forseyth (141/statebridge)
I did delete all channels and the rescan, on both machines. When tuning in initially the signal is high and subsequently falls to 0. Both machines do get a lock on the signal.
I guess it could be a multi-path issue (??) but would that not be strange because almost all stations come from towers at the same location in Atlanta?
Douwe is offline
post #435 of 3703 Old 02-07-2005, 10:19 AM
Yes, but it may not have as strong a signal or too strong of a signal.
post #436 of 3703 Old 02-07-2005, 10:52 AM
Douwe's Avatar
Where I get confused is the fact that I have been picking up WAGA just fine. I do not understand what may have changed.
I also do have a amp in it (from the get-go) and turning it on/off does not help any with the problem.
Douwe is offline
post #437 of 3703 Old 02-07-2005, 02:37 PM
buzgz's Avatar
I live in the midst of the antenna forest, and have a rotor. I record the optimum direction to each station, and this can change from season to season. I've always guessed it was tree leaves, but anyway the optimum pointing direction can change.
I don't know how far from the tower you must be for this not to be a problem.
Another thing I've noticed is that even when pointing in the correct direction, it sometimes takes 15-30 seconds for my OTA receiver (Samsung) to lock on.
buzgz is offline
post #438 of 3703 Old 02-09-2005, 12:08 PM
Douwe's Avatar
All of a sudden I got WAGA back again ... yesterday night my daughter wanted to watch American Idol in HD switched to the OTA channel and bingo there it was in full glory.
Figures, it wasn't there for the SuperBowl but is there to watch American Idol of all shows (not trying to offend anyone)
Still miffed to why though as what is causing this.
Douwe is offline
post #439 of 3703 Old 02-09-2005, 12:23 PM
thepicman's Avatar
If you have not lived with your current setup for more than a year, you really can't be surprised by seasonal changes. My OTA reception gets better the more green leaves are on the trees. This would seem to be opposite of what is expected. Your problem could be caused by a leaking O-ring on one of your outdoor Fconnectors. It could be caused by a neighbor 3 doors down playing an electric guitar through an old tube amp. My signal level for Fox is always nearly pegged. One Sunday morning I went to watch something and I had no signal, then it started fluxing like mad, up and down the scale. We watched for a few seconds and then I realized my next door nieghbor was mowing his front lawn. He was LOS between my antenna and the towers. The RF from the mower was causing the signal to go whacked. A year ago, WSB would come in fine until about the middle of the 3rd quarter of MNF and then the signal would drop. Never figured out why, but it always happened ~11PM. That was a year ago, this year it did not happen. A neighbor causing it? who knows?
Anyway, OTA reception is mostly Voodoo. YMMV
TPM
post #440 of 3703 Old 02-09-2005, 01:11 PM
I had some problems and cut down 4 trees because my HR10-250 was pixellating but I still had problems. I found out the problem with my HR10-250 was hard drives so I ran SpinRite software against them and now it works perfectly and I never have a problem with OTA reception and I live about 35 miles southwest of the antenna location near Emory U. Both of my 2 HR10-250s now function perfectly with OTA so I guess I am lucky.
post #441 of 3703 Old 02-15-2005, 05:33 AM
Wakey's Avatar
For those asking about splitting an OTA signal..
Yes you can do it, a 900 mghtz splitter is fine also.
I have split 4 ways 2 different times with no ill effects.
Splitting after an amp is also fine..
Wakey is offline
post #442 of 3703 Old 02-17-2005, 02:48 AM
COEX-Pilot's Avatar
I live not to far from you (just up the road on 141 by 2 miles). My video signal is always rock stable but on CBS I get audio dropouts. Sometimes quite often, sometimes occassionally but never do they completely go away on CBS (WGCL),
No problems on FOX, NCB etc. ANY IDEAS?
COEX-Pilot is offline
post #443 of 3703 Old 02-17-2005, 05:25 AM
When you get the audio dropout on CBS try doing a channel up and then channel back down to CBS to lock the station in again. Sometimes the signal does not get locked in properly. I had that problem on my Samsung and when I did the channel up & back down I would lock it in with no problem. I heard it was an encoder/decoder problem but I will have to do some searches to find out exactly which thread I was in that discussed this type of behavior.
post #444 of 3703 Old 02-17-2005, 07:05 AM
I find that the channel up/down trick works when the audio sometimes gets out of sync on an HD program after coming back from a SD commercial.
I don't know who actually makes the set-top-box I'm using because it is branded by Epson. It came with my Epson Livingstation LS47P2. Does anyone know how to go about finding out how makes it?
Phil G
post #445 of 3703 Old 02-17-2005, 05:03 PM
Quoted: 392 Post(s)
Liked: 333
I noticed all of a sudden yesterday that I no longer get the DTV WAGA in Atlanta, the Fox station OTA. Yesterday I saw finde signal strentgth liek the carrier signal was there, but no station. I rescanned channels today and it finds it but again, blank. Any one else having this issue? I e-mailed them, but have yet to hear anything.
LG 65C7P
Denon x7200WA
Oppo BD-203
Klipsch RP-280F / RC-62ii / RP-140SA / RS-35 / RS-25
Dual PSA V1800s
kluken is offline
post #446 of 3703 Old 02-18-2005, 04:28 AM
Quoted: 392 Post(s)
Liked: 333
Ok fixed my problme, seems just resanning alone did nto fix it, I actually had to DELETe the channel and let it get rediscovered from scratch. Did I mention I hate this E* 921!
LG 65C7P
Denon x7200WA
Oppo BD-203
Dual PSA V1800s
kluken is offline
post #447 of 3703 Old 02-25-2005, 12:27 PM
rdwalt's Avatar
What's the best way to let the good people at ABC know they need to flip the HD switch when they forget? I hated to watch the last 15 minutes of LOST in SD.
"If you never did, you should. These things are fun and fun is good."- Dr. Seuss
rdwalt is offline
post #448 of 3703 Old 02-25-2005, 12:30 PM
No, you never mentioned that you hate your E* 921!
post #449 of 3703 Old 02-25-2005, 01:22 PM
Crwaters's Avatar
Call the news line and ask to speek with the engineer on duty.
You think YOU got it bad? I was at the Aliance on Wednesday so I had to tape Lost, West Wing, AND Alias all SD on VHS for cryin out sideways!... Oh the humanity!!!
AND
I screwed-up the fricken timer setting so that I only taped the last two minutes of Lost...
woe is me!
Cory
the play was ok. It was in RD (real definition)
We're selling our Photo Annuals and giving the proceeds to Curesearch so they can fight cancer in kids. Please have a look.
Crwaters is offline
post #450 of 3703 Old 02-25-2005, 07:52 PM
jackshakes's Avatar
there are ways to get the shows you missed in hd
jackshakes is offline
