Atlanta, GA - OTA - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 31Likes
post #541 of 3719 Old 04-16-2005, 07:43 PM
DDisney's Avatar
Originally posted by philipgomez
Thanks, ToddD. That is a great reply to the Atlanta Towers question.
I looked at the satellite picture on Google maps and noticed the same shadow but it's a bit hard to see the actual towers from the images. My wife thinks I'm nuts...but I just had to ask. I also didn't know that WGPB will broadcast from Stone Mountain. I see that tower on the way to work and always wondered whose that was up there. Do you know the reason for them not broadcasting from it until 2007?
I think we are very fortunate to live in one of the top markets for DTV & HDTV in the US.
Well, we are not in such a great market for digital PBS IMO. While channel 30 broadcasts digital, I can get not a peep of a signal from them in Lawrenceville, while I get the major broadcast stations with little problem. The story I hear is that the holdup on the main PBS station (WGTV) is that the State of Georgia is holding the PBS Atlanta area digital signal hostage to wait for the rest of the state's PBS stations to be equipped.
DDisney is offline
post #542 of 3719 Old 04-20-2005, 07:28 AM
carmex's Avatar
Originally posted by carmex
My problem is with ABC. I can't find WSB-DT at all, it's just never detected by my tuner.
As a follow up to this, I finally got WSB-DT to come in. It just required adjusting my antenna a bit to the west. It's a bit of a tradeoff, as CBS's signal starts to fall a little as WSB's comes in. Fox's signal actually drops much more sharply. I finally reached a compromise which allows all the channels to come in with a pretty stable signal... that is until a plane flies overhead. I've noticed that for some reason air traffic really disrupts my signal from Fox. None of the other stations seem affected, but perhaps that's just because Fox's signal is the weakest. I would pick up a rotor so I could fine tune, but as others have stated, I plan on getting a PVR sometime in the future and if the rotor can't be controlled automatically by the PVR then it wouldn't be of much use. What other solutions do people have for this? All I can think of is getting a 2nd antenna which would not go over well AT ALL with the wife.
As a side note, I picked up an in-line signal amplifier from Radio Shack and it did seem to help boost and stablize my signals but didn't solve all my problems.
carmex is offline
post #543 of 3719 Old 04-20-2005, 12:20 PM
plasmamaniac's Avatar
Location: Peachtree City, Ga. (25 Miles South of Atlanta)
I have a rotor and I can fine tune the channels. Yes you might not be able to do that when you are away but when you are home or if you know what you will be recording you can set it in advance so that the recording will come out okay. CBS is different than all of my other channels, so I set it for the other channels when I am going to be recording from any one of them but if while I am going to be gone and I want to record CBS I set the rotor to that location so it will be able to pick it up. Also, you can fine tune it with weather conditions or growing trees etc. I think it is worth it's weight in gold.
plasmamaniac is offline
post #544 of 3719 Old 04-28-2005, 02:18 PM
dustbuny's Avatar
Being closer to the towers usually makes it harder to pick up reception. The farther away you are the easier it is to get all of your OTA channels on one antenna. Most of the installations i've seen inside the perimeter required a rotor or a couple of hours of fine tuning.
dustbuny is offline
post #545 of 3719 Old 05-08-2005, 07:42 AM
salange's Avatar
Another newbie here- my HD set arrived this morning. I've read through a lot of posts but I wanted to present my specific situation for advice anyway. I am a DirecTV subscriber, so I think I'm going to wait for their changeover in the fall. I just need to decide whether to fool around with an antenna in the meantime.
I am ITP, about two miles east of where the connector crosses 20. There are plenty of tall trees in my backyard in the direction of the antennas (from NW to NE) according to AntennaWeb. Am I likely to be able to get away with a settop like the Silver Sensor? AntennaWeb and posts in here seem to indicate I might need a rooftop to deal with ghosting issues. If that's the consensus, I'm not sure its worth the effort for me so I'd probably just go without until DirecTV gets things going on their end. Any advice would be much appreciated!
salange is offline
post #546 of 3719 Old 05-08-2005, 08:08 AM
tombarry's Avatar
Don't bother with a Silver Sensor. I have one and my RS double bow tie works better.
tombarry is offline
post #547 of 3719 Old 05-14-2005, 08:16 AM
Terence's Avatar
Hi guys,
I'm new to the OTA HD world and need some help from you gurus here. Here is my current state below.......
2 - ABC, can get about 79-82%.
5 - Fox, can get about 79-82%.
11 - NBC. can't get it.
12 - CBS, can't get it.
14 - Pax. deleted.
17 - TBS. can get about 79-82%.
43 - UPN. Comes in alright. Occasional drop outs.
46 - WB. can't get it.
I'm using this (upstairs) indoors, but i think i might have go outside or in the attic. Also with a radio shack 10db amplifier.
DB2 HDTV Antenna from antennasdirect.com
As you can see below from antenna web i do not live to far from the towers.
* yellow - uhf / WATL-DT / 36.1 / WB / ATLANTA GA / 294° / 16.8 25
* yellow - uhf / WAGA-DT / 5.1 / FOX / ATLANTA GA / 292° / 16.3 27
* green - uhf / WGCL-DT / 46.1 / CBS / ATLANTA GA / 294° / 16.9 19
* red - uhf / WSB-DT / 2.1 / ABC / ATLANTA GA / 283° / 17.3 39
* red - uhf / WUPA-DT / 43.1 / UPN / ATLANTA GA / 279° / 17.1 43
* red - vhf / WXIA-DT / 11.1 / NBC / ATLANTA GA / 282° / 15.5 10
* red - uhf / WTBS-DT / 17.1 / TBS / ATLANTA GA / 294° / 16.8 20
* blue - uhf / WPBA-DT / 21.1 / PBS / ATLANTA GA / 283° / 15.8 21
So any suggestions would be great!
Tee
"Enjoy Movies & Music"
My Home Theater
Terence is offline
post #548 of 3719 Old 05-15-2005, 07:16 AM
Your problem is probably multipath and not signal strength. Sometimes if you are too close to the towers, you can get multipath problems. Also, sometimes the strength can be too great and therefore you may have to get a variable strength attenuator from Radio Shack.
I would move the antenna outside on the roof temporarily to see if that improves your reception. Outside is always better than inside, higher is better normally than lower. There is no such thing as an HDTV antenna. They just say that as a promotional device to help sell that antenna and then charge you more.
Also, move the antenna directionally to see what that will do. I have an amp and a rotor and I can fine tune my channels anytime I want.
post #549 of 3719 Old 05-15-2005, 08:51 AM
Terence's Avatar
Thx plasmamaniac,
I will try it when i get off today.
It has been a while since i have seen your post until i ran into this thread. Hope all is well.
How are those AR Phantoms treating you?
Tee
My Home Theater
Terence is offline
post #550 of 3719 Old 05-15-2005, 09:22 AM
Terence, what do you mean when you said "How are those AR Phantoms treating you?" What are you referring to exactly?
post #551 of 3719 Old 05-15-2005, 11:35 AM
Terence's Avatar
Sorry plasmamaniac,
I got you confused w/ someone else. Although i do remember you asking for an SVS demo back in Jan of 04. I pm'ed you but never got a response. I guess that is how your member name popped in my head.
Tee
My Home Theater
Terence is offline
post #552 of 3719 Old 05-15-2005, 02:35 PM
Yes, I wanted one of those and lost your response. Do you still have one? My fault. I have been busier than a one arm paper hanger in a wind storm, or a long tail cat in a room full of rocking chairs.
post #553 of 3719 Old 05-15-2005, 08:10 PM
Terence's Avatar
Plasmamaniac not only do i have one, i have two (20-39 PC+) of them in my HT.
So what did you decide to go with?
Tee
My Home Theater
Terence is offline
post #554 of 3719 Old 05-16-2005, 06:19 AM
I bought the PB12 Ultra-2 and it really rocks my world. I mean it literally blows my Klipsch RSW-15 away and I thought that it was awesome but this things rattles my windows, moves paintings around, etc. I watched Elektra the other night and I couldn't believe it. Absolutely worth the money.
post #555 of 3719 Old 05-16-2005, 06:36 AM
rdwalt's Avatar
Anyone else having audio sync problems on CBS 46? I've been seeing a delay in the audio the past few days.
"If you never did, you should. These things are fun and fun is good."- Dr. Seuss
rdwalt is offline
post #556 of 3719 Old 05-16-2005, 07:39 AM
Terence's Avatar
WOW decided to go big i see! Great stuff, now back to our regular schedule programing.
Tee
My Home Theater
Terence is offline
post #557 of 3719 Old 05-16-2005, 08:56 AM
Yes, this thing weighs around 200 pounds, it is absolutely fantastic.
post #558 of 3719 Old 05-18-2005, 02:03 PM
Kevinw's Avatar
Quoted: 14 Post(s)
Yes I have also. realy annoying. Particularly in closeups.
Samsung KS 8000
Samsung UBD-K8500 BDP
Yamaha RX-A1060
Fluance XL7F main
Mirage Nanosat surrounds
JVC JL-F45 turntable
Kevinw is offline
post #559 of 3719 Old 05-18-2005, 03:48 PM
Terence's Avatar
****UPDATE****
Well i did and experiment, I put the antenna in the attic and p/u 4 extra channels 30, 36, 46, & 69 no 11. I brought it back down into the HT and could only keep 46 and lost the other 3. My HT attic (bonus room over the garage) is sealed off from the main attic, so I have to figure out how to run the cable from the main attic to the HT. I'm thinking I might have run the cable from the outside to the HT. I rather leave it indoors but if i might be forced to go outside. American Idol was awesome last night, and CSI Miami looked & sounded great too! CSI-M had some subsonic bass in it that was shaking my seat really good. I never knew they mixed the 5.1 tracks that well for TV shows.
I notice minor audio drop outs, but i'm then only getting 67% max right now.
Tee
My Home Theater
Terence is offline
post #560 of 3719 Old 05-18-2005, 06:27 PM
Crwaters's Avatar
Getting lots of dropouts on ABC DT tonight. Didn't have any the other night watching ABC...
Anybody else?
CW
We're selling our Photo Annuals and giving the proceeds to Curesearch so they can fight cancer in kids. Please have a look.
Crwaters is offline
post #561 of 3719 Old 05-18-2005, 06:52 PM
philipgomez's Avatar
I'm watching Alias on ABC DT and the sound seems fine, 5.1 Dolby.
The commercials (in SD) have two little flickering pixel areas near the top, just left of center and on the top right. They disappear as soon as the HD kicks in. I've seen these before.
The sound may be an issue with your setup... that's just a guess though.
Phil G
American by birth, Mac user by choice.
philipgomez is offline
post #562 of 3719 Old 05-18-2005, 08:47 PM
DN7335's Avatar
I watched Lost with no problems tonight (other than the show ending when I didn't want it to)--
DN
DN7335 is offline
post #563 of 3719 Old 05-19-2005, 07:20 AM
joeld100's Avatar
yeah, no problems here with lost or alias. Can't wait till next wednesday
joeld100 is offline
post #564 of 3719 Old 05-19-2005, 03:13 PM
porterhaus's Avatar
Kevinw,
I see your location is not too far from me (Flowery Branch) and roughly in the same general direction from the towers. I have been wondering if I have a decent chance of getting good OTA HD reception. If so, what equipment (antennae, tuner, etc.) might work best. I have been having allot of problems with the HD channels from Charter. I just want to know what your experience has been and what seems to work for you, etc. Also, any information from others in this area. Thank you.
If you remember the 70's...you weren't really there!
porterhaus is offline
post #565 of 3719 Old 05-19-2005, 05:13 PM
Linda Britt's Avatar
Any info? Station trouble or snafu?
Life's a roller coaster. Wear a seatbelt and don't stand up on the hills...
Linda Britt is offline
post #566 of 3719 Old 05-19-2005, 07:01 PM
Crwaters's Avatar
Wasn't that a drag? Seemed like they were trying to get it to fire-up. Kept switching audio formats for th first half.
Just not my week for TV I guess.
I'm bummed nobody else had problems with reception on ABC yesterday.
Analog reception problems were more livable.
Crwaters is offline
post #567 of 3719 Old 05-20-2005, 05:14 AM
Kevinw's Avatar
Quoted: 14 Post(s)
Originally posted by porterhaus
Kevinw,
No reason you can't get good reception. For our area I recomend Channel Master 4228 or Antennasdirect's DB8. Most likely you will need a amp also. On the roof placemant is a must.
In my neighborhood there are 4-5 of us with antennas. All different.
2 of us have Dish and 2 have Direct. If you need an expert contact :
Satellite Bob
(770) 605-3146
Heard good things about him on the Atlanta Yahoo forum and from my
neighbor that used him for an install. If he cant get you a signal, no one can.
Samsung KS 8000
Yamaha RX-A1060
Fluance XL7F main
Kevinw is offline
post #568 of 3719 Old 05-20-2005, 05:22 AM
Kevinw's Avatar
Quoted: 14 Post(s)
I am thinking we had weather related problems last night. NBC signal kept jumping around. finally had to switch to SD to watch the ER finale.
Samsung KS 8000
Yamaha RX-A1060
Fluance XL7F main
Kevinw is offline
post #569 of 3719 Old 05-20-2005, 05:30 AM
Terence's Avatar
Bad News!
I just talk to Satellite Bob, and he dealing w/ some family issues that will keep him teid up for a while. So he won't be able to assit us at this time.
Tee
My Home Theater
Terence is offline
post #570 of 3719 Old 05-21-2005, 04:08 AM
porterhaus's Avatar
Thanks for the information. One other question: Is Braves HD available on satellite/OTA or on cable only? Thanks.
