Erie, PA - HDTV - Page 117 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #3481 of 3518 Old 09-22-2013, 08:47 AM
jacko15's Avatar
Quoted: 141 Post(s)
Liked: 125
Anyone here been able to find CBS channel 35's clear QAM signal on the basic cable. Used to be 35-1. Either moved or eliminated by TWC. Trying a scan right now, will update if I find it.
edit:
Found it, 115-1
Now it's back to 35-1
jacko15 is offline
post #3482 of 3518 Old 09-26-2013, 07:05 PM
Bismarck440's Avatar
Quoted: 821 Post(s)
Liked: 153
Any of your channels in HD there? I picked up the News on WFXP, & programming on WJET (finally) didn't seem like an HD signal though didn't note if it was 480i signal.
Edit Per Wiki I see 35 & 12 are in HD along with WJET, musta been watching SD programming at the time.
Bismarck440 is offline
post #3483 of 3518 Old 09-27-2013, 08:04 AM
jacko15's Avatar
Quoted: 141 Post(s)
Liked: 125
A lot of WJET and Fox66 are still SD on Clear QAM. Especially old shows. The network feeds are usually in HD.
jacko15 is offline
post #3484 of 3518 Old 10-11-2013, 07:07 AM
jrm2's Avatar
Hi,
I live in Harborcreek, near the lake, and was wondering what a good antenna would be for getting the Erie stations that are broadcast from up near peach street (according to antennaweb.org I should just need a "small multidirectional antenna"). I am hoping an indoor or attic mounted antenna will work. What do people in Erie use? Anyone in Harborcreek with good results?
jrm2 is offline
post #3485 of 3518 Old 10-11-2013, 04:41 PM
jacko15's Avatar
Quoted: 141 Post(s)
Liked: 125
Go to Best Buy and pick up a couple of their better antennas. Try them in different locations to see what kind of reception you get and how many channels. If they don't work, you can return them. We went through a similar drill for my brother-in-law several years ago in western Millcreek.
jacko15 is offline
post #3486 of 3518 Old 10-14-2013, 05:27 AM
jrm2's Avatar
I ended up going to radio shack and asking them which antenna's got returned the least. I also went to walmart and tried an RCA flat antenna and a Clearstream 2 antenna. Out of all of them the Radio Shack one "RadioShack Amplified HDTV Antenna" worked the best, it was also the cheapest. I was really surprised I get about 13 channels including some from Canada. The flat antenna from RCA worked 2nd best, and I could only get 2 channels on the Clearstream even though it was by far the most expensive of the antenna.
I couldn't get WICU/NBC (12.1) with any of the antenna's which I think is kind of weird considering I get WSEE and they appear to be from the same direction and same distance away.
iirc these are the channels I was able to get (6.1, 9.1, 9.2, 9.3,9.4,24.1,35.1,35.2,50.1,50.2,50.3,66.1) A couple of them don't come in all the time like the station from Canada and a station called Bounce, but I get ABC/CBS/Fox/CW so I am really happy this worked out.
I bought 2 hdhomerun's from amazon and hooked them up to my wireless network and I put Window's 8 with Media Center on an old laptop and am using that as a DVR and a program called PLEX to stream the recorded content to Roku's on the other TV's. I was really afraid it wasn't going to work out but so far everything looks to be working!
Now I just have to return all my cable boxes and sell my hdhomerun prime.
jrm2 is offline
post #3487 of 3518 Old 10-14-2013, 08:14 AM
jacko15's Avatar
Quoted: 141 Post(s)
Liked: 125
Glad you found a way to cut the cord. We needed two antennas to get my brother-in-law going, he was in an apartment where we needed to use two different windows to cover the directions. If you ever find a way to get WICU/NBC, stop back and post.
jacko15 is offline
post #3488 of 3518 Old 10-17-2013, 03:07 PM
Quoted: 821 Post(s)
Liked: 153
Since the digital era we find that upper VHF is NOT prime real-estate, especially with the Low Power WICU throws, that was the strongest station in Erie in the analog era. If I get a 12 here it's WMFD (Virtual 68 .1 & .2). Is this antenna capable of VHF & what is the RS model #?
I have issues here with WOIO & WJW that desired to stay on VHF after the switch.
Bounce should just be a sub.
post #3489 of 3518 Old 10-17-2013, 05:27 PM
jrm2's Avatar
I will get the model number off the box tomorrow or this weekend, unfortunately I am not able to get it at the moment. The antenna is capable of getting VHF it has a UHF loop and 2 telescoping rabbit ears for VHF, that being said however, I have not messed with them to try and get any vhf channels. The antenna is supposed to be omni-directional iirc but I have to situate it pointing in one pretty specific direction to get any decent signals.
jrm2 is offline
post #3490 of 3518 Old 10-17-2013, 07:04 PM
Quoted: 821 Post(s)
Liked: 153
I've always gone this route in experimenting, I'm in a condo (fortunately) with an outdoor antenna that hadn't been removed in the reroof, nor has the Cable Company disabled the wiring to it. I run a second large 120 mile VHF/UHF Yagi in the attic that has seen better days for my upstairs sets, my thoughts have been to replace it with something smaller & movable, though always ended up returning the indoor antennas as I only get 2 or 3 Stations out of Cleveland optimum on them. I was going to try a Grey- Hoverman that I would also be able to swing toward Erie or Toledo if needed.
Edit.... Then again if you have aluminum siding that also could pose an issue too.
post #3491 of 3518 Old 10-18-2013, 03:01 AM
ProjectSHO89's Avatar
Quoted: 261 Post(s)
Liked: 129
What was the model number of that Radio Shack antenna?
A ClearStream 2V aimed to the southwest should have been a slam dunk unless you did something wrong or have a weird location.
I've tested the flat RCA vs a C2V extensively and the C2v is a superior antenna when aimed properly. However, if you're indoors, the less directional characteristics of the flat panel sometimes works out due to the randomness of indoor signals.
ProjectSHO89 is offline
post #3492 of 3518 Old 10-18-2013, 06:35 PM
tylerSC's Avatar
Quoted: 765 Post(s)
Liked: 171
The Clearstreams are the better antennas at Best Buy, but usually cheaper online. Perhaps they may price match Amazon if cheaper.
tylerSC is offline
post #3493 of 3518 Old 10-21-2013, 05:20 PM
Tonya Federoff's Avatar
Trying to cut the cord on high priced tv. Our neighbor out here in the woods in North Springfield said he had an antenna & when it turned into digital his antenna stopped working. We wanted to try getting an antenna but he said don't waist your money it will not work. Does anybody know what kind of antenna will work ?.
Tonya Federoff is offline
post #3494 of 3518 Old 10-22-2013, 07:15 AM
jacko15's Avatar
Quoted: 141 Post(s)
Liked: 125
jacko15 is offline
post #3495 of 3518 Old 10-23-2013, 02:45 PM
shooter21198's Avatar
I know some of us still look at this thread every now and then.
WJET and Fox 66 finally started their broadcast in HD.
I will never watch WICU again.
Time Warner Cable North East Ohio
SA 4250 HDC no more
Cisco 4742 HDC
Let's Go Bucs!
shooter21198 is offline
post #3496 of 3518 Old 10-27-2013, 10:53 AM
jrm2's Avatar
This is the information on the Antenna I have. I bought it from Radioshack.
Radioshack Amplified HDTV Antenna
Cat. No: 1500254
Neither the antenna or the box it came have any other model information.
If you search on Radio Shacks website for 1500254 you will find it.
I can't guarantee it will work the best for anyone else but of the 3 antenna I tried, it worked the best for me. It is powered and I need to turn the amplifier all the way up.
Hope this helps someone else.
jrm2 is offline
post #3497 of 3518 Old 11-15-2013, 07:09 AM
jacko15's Avatar
Quoted: 141 Post(s)
Liked: 125
Is anyone with TWC in Millcreek that has a Samsung box having trouble changing channels? Often when I change channels the station I switch to will be a black screen with no sound. If I shut everything off and turn it back on the station comes in. This is intermittent, so tech support is no help. I have a second SA box that is working fine. Any input would be appreciated.
jacko15 is offline
post #3498 of 3518 Old 11-15-2013, 07:20 PM
Quoted: 821 Post(s)
Liked: 153
Cat. No: 1500254
Interesting this model was hyperlinked to E-Pay link & it came up as just the supply (don't ya just hate when the PC & websites try to do your thinking for ya?)! frown.gif
TWC carries the Erie DMA Stations as far west as Madison OH, although all of Ashtabula County is considered being in the Cleveland DMA (although only about 20 miles from the state line to your transmitters, but around 65-70 to the Cleveland farm... go figure. I personally don't have cable but from my area the ridge plays havoc at times with the Cleveland Farm.
Edit: Ashtabula County Ohio is in the Cleveland DMA, not the Erie DMA as I posted... ooops (a typo on my end, I knew the answer, just wrote it wrong).
post #3499 of 3518 Old 12-25-2013, 02:06 PM
lacubs's Avatar
anyone know why 66 HD is down?
lacubs is offline
post #3500 of 3518 Old 06-23-2014, 04:12 PM
kayfam's Avatar
New QAM channel assignments
On the off chance anyone still follows this thread, Time Warner recently moved all the QAM channels assignments for the locals. The following list shows both the virtual and actual channel assignments.
WJETDT: virtual 24.1 actual 71.3
WSEEDT: virtual 35.1 actual 74.1
WICUDT: virtual 12.1 actual 74.2
WQLNDT: virtual 54.1 actual 77.1
WQLNDT2: virtual 54.2 actual 77.2
WQLNDT3: virtual 54.3 actual 77.3
WFXPDT: virtual 66.1 actual 77.4
Anyone running Windows Media Center will understand why I posted both. Time Warner as a rule sends incorrect PSID information resulting in the wrong frequencies being assigned to the virtual channels. One example of this is both WSEEDT and WICUDT getting the wrong info and being assigned 77.1 (WQLNDT frequency) for the former and 77.4 (WFXPDT frequency) for the latter. I don't know if other equipment is affected but I suspect yes depending on the age and maker of said products (run of the mill QAM capable TV for example).
All this may be academic come August since Time Warner is supposed to completely overhaul the lineup and move to a new national lineup which also includes encrypting all over the air local network channels with some exceptions being made for public access channels. The only way to get around this is with the use of a cablecard device or getting a DTA (Digital Tuning Adapter) from Time Warner, the DTA is free for now http://www.timewarnercable.com/en/re...-adapters.html but at some point in the future there will be a "minimal" fee for each and every device after that point. I wish I could be a little more precise on the date in question but some of the information varies from one division to another.
kayfam is offline
post #3501 of 3518 Old 06-23-2014, 06:46 PM
scnrfrq's Avatar
Quoted: 25 Post(s)
I still follow this thread, but it sure is quiet. I didn't realize TW was making all those changes so soon. They did their usual bad job of not notifying customers about the latest QAM changes. Who knows what will happen when Charter (Comcast) takes over soon.
scnrfrq is offline
post #3502 of 3518 Old 10-20-2014, 03:19 PM
scnrfrq's Avatar
Quoted: 25 Post(s)
TW Very Slow Now
If anyone is still on this thread, have you noticed lately that the DVR responses to the remote is very slow? Sometimes takes 2-3 seconds for a response in the guide or list. Just came back from vacation, and it wasn't like that before. Did they do an update of some kind?
scnrfrq is offline
post #3503 of 3518 Old 11-02-2014, 06:32 PM
EGV_bill's Avatar
Erie Programming Guide
Hi - I live in the Chicago area and have had good luck with my DTVpal DVR. My parents in Erie are interested in cutting the cord. They are looking at the new Channel Master models or Tivo. My question is on the availability of programming guide information (for a DVR without a guide service - like the Channel Master DVR). Does anyone know if the Erie channels - especially PBS - feed guide information through PSIP (I think it is called PSIP - used to have TVGOS)? Also - should we be looking at any other DVR options besides Channel Master and Tivo?
Bill
EGV_bill is offline
post #3504 of 3518 Old 03-14-2015, 01:17 PM
kayfam's Avatar
WLEP-LD Off Air
Hoping that someone still monitors this thread, I was wondering if anyone has noticed that WLEP is off the air as of todays date 3/14/2015? It's that or my outdoor antenna took a hit with all the lousy weather. Hoping if someone can confirm or deny if for no other reason to save me a trip to the roof and that's not going to happen for a while till this lovely weather clears up
kayfam is offline
post #3505 of 3518 Old 03-15-2015, 12:32 PM
wabbit01's Avatar
I haven't been able to pickup those stations for a month or so.
wabbit01 is offline
post #3506 of 3518 Old 03-17-2015, 10:42 AM
kayfam's Avatar
Thanks for the reply wabbit01.
I didn't think they had been missing that long, but then again I never did watch much of anything on WLEP. I was just scanning through the channels and noticed the station(s) missing. That and not being able to find any info regarding the stations status got me to wondering if it was a reception issue related to my outdoor antenna.
What info I did manage to come across was the owner was having issues securing programing. It's likely it might have shut down, but that's just a guess on my part.
kayfam is offline
post #3507 of 3518 Old 03-21-2015, 03:43 PM
Inundated's Avatar
Quoted: 115 Post(s)
Liked: 40
I read somewhere, I can't remember where, a few months back...that WLEP was in serious danger of shutting down. I guess it happened.
Inundated is online now
post #3508 of 3518 Old 03-22-2015, 06:59 PM
unclehonkey's Avatar
Quoted: 315 Post(s)
Liked: 65
WLEP was sold in June last year to LocusPoint which is a company who wants to give up signals for the auction
WLEP-LD Erie, PA (DMA Rank #149 ) has been sold to LocusPoint Networks (Bill deKay, Ravi Potharlanka) for $2.5 million from Hapa Media Properties, LLC (Kevin Joel Bae, President).
unclehonkey is offline
post #3509 of 3518 Unread 09-21-2015, 10:18 AM
mvcg66b3r's Avatar
Quoted: 107 Post(s)
Changes are coming soon to the lineups of WICU-TV and WSEE-TV.
Erie's NBC and CBS affiliates, both owned by Lilly Broadcasting, will no longer broadcast separate newscasts on weekday mornings and evenings.
The move, which will begin Oct. 12, means WICU and WSEE will air an identical newscast at 6 p.m. Mondays through Fridays. They'll do the same for their weekday 11 p.m. newscasts.
WSEE and WICU also will merge their morning weekday newscasts into one program, with one set of anchors.
http://www.goerie.com/changes-come-t...v-news-lineups
It they can merge the newscast, they might as well merge the stations. Let's see if Lilly can pull off what other broadcasters have done/are doing in smaller markets:
WICU: 12.1 NBC (1080i HD), 12.2 CBS (720p HD)
WSEE: 35.1 CW (1080i HD), possible call sign change to WBEP
--OR--
WSEE: 35.1 CBS (1080i HD), 35.2 NBC (720p HD)
WICU: 12.1 CW (1080i HD), possible call sign change to WBEP
James Calvin Woods - Son of Verta Jane Holland
mvcg66b3r is offline
post #3510 of 3518 Unread 03-23-2017, 03:32 AM
scnrfrq's Avatar
Quoted: 25 Post(s)
Anyone still out there? Anyone have any experience with changing over to Spectrum? Anyone sign up with Velocity Net fiber yet?
scnrfrq is offline
