Rochester, MN - HDTV - Page 112 - AVS Forum
 1Likes
post #3331 of 3358 Old 10-20-2014, 05:55 PM
Liked: 0
My elevation is 1,104 feet... a bit higher than LaCrosse, WI.. but dont really see anywhere, where it tells me if that elevation will pick up certain channels. I get the feeling I really need to just try it.. and see.. to find out one way or the other.
ccgaskell is online now
post #3332 of 3358 Old 10-20-2014, 05:56 PM
Liked: 0
My elevation is 1,014 feet... a bit higher than LaCrosse, WI.. but dont really see anywhere, where it tells me if that elevation will pick up certain channels. I get the feeling I really need to just try it.. and see.. to find out one way or the other.
post #3333 of 3358 Old 10-20-2014, 06:43 PM
AMF8270's Avatar
Elevation of your location and the intervening terrain matters
My home is in west Rochester up on the hill (1,130 feet) above the gravel pit you pass when you approach town from the west. TVFool says I'm 1.7 miles farther from the LAX Fox transmitter than you, and my signal strength of the LAX Fox (channel 17) is shown to be 24 dB stronger than yours. No doubt the 116 ft difference in elevation makes the difference. 'sorry to say this, but don't get your hopes up too much.
AMF8270 is offline
post #3334 of 3358 Old 10-20-2014, 07:17 PM
Liked: 0
May I ask what kind of antenna you have ?
how it is mounted - tri pod vs J bar ?
where it is mounted ? roof top vs attic..
use of AMP, pre AMP or whatever else might affect reception..
THanks for sharing and the heads up on lowering my expectations.. unfortunately, bleakness is setting in...
post #3335 of 3358 Old 10-20-2014, 09:51 PM
mattdp's Avatar
Quoted: 13 Post(s)
What matters is not really your elevation, but local obstructions blocking the signal. I would assume the Assisi Heights ridge is in line with LaCrosse.
In case you wanted to know the gory technical details of diffraction:
http://www.hdtvprimer.com/antennas/siting.html
http://www.hdtvprimer.com/antennas/sizing.html
mattdp is offline
post #3336 of 3358 Old 10-21-2014, 06:18 AM
Liked: 0
Thanks Mattdp.. a lot of interesting reading there. I will start researching rotators and the type of base I want.. tri pod vs j bar.. etc , best deals on RG6 cable..how much I need.. amps and splitters... and form a plan. I have watched enough DIY install videos that "maybe" I am willing to tackle this thing myself.. I may call a local place for an estimate.. just to compare. Glad ai happened across this forum, and should i venture into the land of antenna owner, I will be sure to post my results... but will continue to gather data from anyone willing to share..
post #3337 of 3358 Old 10-21-2014, 11:55 AM
Liked: 0
Hi I am new.
Someone needs to start up a business around Rochester for the set up of antennas and watch the money roll in. Charter has a huge monopoly. The only place I could find is in Byron and they are busy. (go figure). Anyway would I need a Rotator on an antenna if i got a multi-directional antenna?
zoobella99 is offline
post #3338 of 3358 Old 10-21-2014, 05:13 PM
Xeriph's Avatar
Charter Clear QAM
Just noticed tonight my dual tuner HDHomerun can no longer tune to the local clear QAM channels on Charter. At first I thought maybe Charter moved them so did a scan and only 105-1 was found. It appears to be the small video on the previews channel. Anyone else noticing clear QAM issues or have any insight?
Xeriph is offline
post #3339 of 3358 Old 10-21-2014, 05:39 PM
mattdp's Avatar
Quoted: 13 Post(s)
Working on it
How busy? Did they give you a "were backed up until.."
Most every antenna picks up best from the front and has more limited reception from the back. You'll get essentially zero signal from the sides. You wouldn't need a rotor for the Rochester/Austin/Mason City stations because they are relatively close together. You'd get a solid signal on 56 in any direction (because it's so close), but for distant stuff like LaCrosse, Eau Clare or the Twin Cities, you would need a rotor.
Could you post a TVFool.com report? That will determine what's actually available.
As fortold by another member a page or two back, Charter drops all Clear QAM when they go all digital.
mattdp is offline
post #3340 of 3358 Old 10-21-2014, 06:23 PM
Xeriph's Avatar
Thanks, not sure how I missed the clear QAM discussion. Guess it is time to change settings to 100% OTA. It is pretty crappy Charter is choosing to encrypt local channels while claiming they have to make these changes in the transition to all-digital. Cuz everyone knows you can't go all-digital without adding encryption to the existing digital channels!
Xeriph is offline
post #3341 of 3358 Old 10-21-2014, 06:28 PM
mattdp's Avatar
Quoted: 13 Post(s)
I believe they are moving to a completely "switched" system where channels get delivered to a particular node only by request of the cable box. Hence axing fixed Clear QAM assignments is technically necessary.
mattdp is offline
post #3342 of 3358 Old 10-21-2014, 08:10 PM
Xeriph's Avatar
Understandable, but from a technical standpoint I still wonder if they could have continued with locals in clear QAM and the rest of the channels switched...if they wanted to? That would have allowed people to tune in to local channels on secondary TV's in the household without the need for box.
Xeriph is offline
post #3343 of 3358 Old 10-22-2014, 12:14 AM
Gronnie's Avatar
Quoted: 20 Post(s)
Liked: 30
So when does our internet speed go up?
Gronnie is offline
post #3344 of 3358 Old 10-22-2014, 07:15 AM
Liked: 0
They just told me it was going to be a while before they could come out and give me a quote of any kind but I was welcome to come in the store and chat.
Originally Posted by mattdp View Post
Working on it
post #3345 of 3358 Old 10-22-2014, 07:18 AM
Liked: 0
Have any of you worked with Denny's antennas. He recommended two antennas for me, just not sure if there is something better
His message said:
The signals are rated moderate in strength at your location. In the attic I wouldn't go with anything less than the HD Stacker antenna. Along with the antenna I recommend the CM 7777 preamplifier.
Outdoors you can use the EZ HD antenna with the CM 7777 preamplifier.
Install the antenna aiming South.
You can expect quality reception from ABC, NBC, CBS, FOX, PBS plus all sub channels offered by these stations. About 14 channels total.
If you have any questions or if I can assist you further please don't hesitate to contact me.
Best Regards,
Denny Duplessis
post #3346 of 3358 Old 10-22-2014, 07:31 AM
mattdp's Avatar
Quoted: 13 Post(s)
Denny's HD Stacker is his own product. It's a legitimate antenna, but it's a ripoff at $129. Add a 7777 at $72 and you're at $201
Here's a better antenna system:
Solid Signal HDB 91X UHF antenna $46.99
Antennacraft Y-10-7-13 VHF antenna $43.99
RCA TVPRAMP1R Preamplifier $21.99
$112.97
Both antennas I recommended should have more gain than the stacker and from what I know the TVPRAMP1R is actually a clone of the 7777 (per some technical teardown threads on another forum).
mattdp is offline
post #3347 of 3358 Old 10-22-2014, 07:53 AM
Liked: 0
Denny's HD Stacker is his own products. It's a legitimate product, but it's a ripoff at $129. Add a 7777 at $72 and you're at $201
$112.97
Thanks a million.
post #3348 of 3358 Old 10-22-2014, 11:09 AM
tachmn's Avatar
The RCA TVPRAMP1R Preamplifier is on sale at Menards through 10/25 for $19.62.
The RCA programmable rotor VH126R is also on sale for $55.59.
(Menards has a 20% off sale on RCA products every so often.)
zoobella99 likes this.
tachmn is offline
post #3349 of 3358 Old 10-22-2014, 01:27 PM
Liked: 0
Thanks a million.
If you buy those 2 antennas, what brings them together into one ? I have heard the term combiner.. is that an additional cost item ? and do you hook the two antennas together in this somewhere on the roof top ? or is that done in the house where you connect to the splitter ?
post #3350 of 3358 Old 10-22-2014, 01:42 PM
mattdp's Avatar
Quoted: 13 Post(s)
The RCA TVPRAMP1R and CM 7777 can run separate UHF/VHF inputs from or one combined feed. In cases where you don't need a preamp, PICO MACOM makes a $6 passive combiner called a VUSJ. You would install either right at the antenna.
mattdp is offline
post #3351 of 3358 Old 10-22-2014, 06:53 PM
AMF8270's Avatar
I've tried the VUSJ and was disappointed in its ability to pass the UHF side. Is there a better performing one ? It can be more than $6, but let's stay below professional level devices.
AMF8270 is offline
post #3352 of 3358 Old 10-22-2014, 07:09 PM
Liked: 0
I need to know your thoughts. I talked to the owner of the only Antenna store in the Rochester area; Campion Antenna Service LLC tonight. I live in the NW part of Rochester near Holy Spirit church, he said ball park figure for an antenna, amp, grounding and hook up would be $450-$500. Seems a bit steep but what are you thoughts? I tried getting out of him what kind of antenna he uses and he didn't say. Just a 6 foot yard antenna and an amp. If I needed something bigger it would be $750. He says I might expect some channels to work real well and some to not work as well some days. Is this just the way of the world of antennas or just his? ( I am from the cities and could get reception using an indoor antenna with no problem ever).
post #3353 of 3358 Old 10-22-2014, 07:14 PM
AMF8270's Avatar
For LAX I have an 8-bay Channelmaster in the attic of my garage looking through the roof towards 105deg, using the Channelmaster 7777 preamp. It receives 17, 30, and 48. The antenna's just resting against a wooden strut holding up the roof, with a couple of nylon tie-wraps to keep it from moving! I've also got a Y10-7-13 to pick up channel 8, but it doesn't work as well now as it did years ago. It's on a J bar in the same attic looking through the roof towards 85deg, but may have shifted a bit.
For Rochester, I have a 4-bay Channelmaster in the same attic looking through the gable end's wood walls with vinyl siding towards 190deg using another Channelmaster 7777. It receives 10, 18, 20, 36, 42 and 46. Like the other UHF antenna, its just resting on a piece of wood, and tie-wrapped to prevent movement. It's a 4-bay because when the digital transition occurred, channel 36 was transmitted from farther west, which required an antenna that could receive well across a span of about 45deg to pick up all of the stations. This restricted me to a medium strength antenna with the broader pickup, thus the 4-bay. Some time later, 36's transmitter was moved to the same tower that transmits 20 and 46. So now an antenna is required to receive across a span of only about 12deg. So if I was to put up a new antenna, I'd probably put in an 8-bay and not need the preamp at all.
If you can put in an 8-bay facing south, it might pick up all of rochester's locals, and you might not need a preamp, depending on how many loads you have.
AMF8270 is offline
post #3354 of 3358 Old 10-22-2014, 09:23 PM
mattdp's Avatar
Quoted: 13 Post(s)
That doesn't include a rotor, correct?
This is what has me thinking seriously about a business. I've heard numbers in that ballpark before.
Let's assume they install Winegard. Their biggest combo antenna is the 7698 ($120). Add on a Winegard Boost XT Preamplifier (their only preamp model) at $52.00 and you're at $172. Figure another $100 for mounting hardware, cabling, etc. So that's ~$300 in materials (for the $750 install). $400 if that includes a rotor.
For reference, I spec'd out a full (no rotor) fringe install for $184. The parts list is attached as a spreadsheet.
Digital TV requires 16db signal-to-noise ratio to decode. Above 16, it just works. Dipping below 16, you'll get dropouts. And constantly below 16, you'll see a signal on the TV's signal meter but no picture.
Atmospheric noise decreases a tad at night and you will occasionally get some tropospheric ducting to enhance signal. When the leaves drop off the trees, UHF reception in particular can improve (depending on your location). Thus, the worst time for reception the middle of the day in summer.
Any competent installer should be able to install a large enough antenna at proper height/location as to make those small variations unnoticeable (barring really weak fringe stations of course). Looking at your TVFool report, there's almost no way you're not getting Rochester stations no matter what you do.
Windy days and trees can cause variable multipath which can cause breakups. I've never had it be an issue with an outdoor directional antenna. Planes are another source of variable multipath, but again... this has never been an issue for me.
IIRC, KAAL was on 33 from their old "out west" tower initially, started multicasting on 36, then jacked up the ERP and took 33 offline. Gotta love the old analog days when Rochester had five different towers over a 75 degree span.
mattdp is offline
post #3355 of 3358 Old 10-26-2014, 10:24 AM
Liked: 0
I had Campion Antenna come out to my house to give me an estimate on a solution for my house. He (pretty sure his name was Dan) said it would probably be about $450 to install for my case. He would give me a written estimate if I wanted, but I told him no since that price was fine by me. The model number of antenna he was going to install is a Winegard 7694.
Unfortunately I can't have an outside antenna due to a covenant issue, which truly upsets me because my only other solution is an attic install. I have no clue even where to begin with that one. I was basically shut down to the size of the Winegard 7694, which would be running north/south and be 6 foot long.
So if anybody could give me any pointers on an attic install, I would appreciate it. I would probably have to do all the work myself, which I really don't want to monkey around with, so hurry up mattdp, and get to starting your own business! Would very much rather pay someone to do it for me than having to do it myself.
Isaka Jones is offline
post #3356 of 3358 Old 10-28-2014, 12:42 AM
tachmn's Avatar
This FCC link http://www.fcc.gov/guides/over-air-r...n-devices-rule discusses preemption of restrictions on placement of television broadcast antennas.
A key section of the document is:
The rule does not apply to common areas that are owned by a landlord, a community association, or jointly by condominium or cooperative owners where the antenna user does not have an exclusive use area. Such common areas may include the roof or exterior wall of a multiple dwelling unit. Therefore, restrictions on antennas installed in or on such common areas are enforceable.
tachmn is offline
post #3357 of 3358 Unread Yesterday, 05:35 PM
Liked: 0
Hi mattdp,
I'm thinking of installing the system you listed below. Could I do an attic install? Thanks
$112.97
quark317 is offline
post #3358 of 3358 Unread Yesterday, 06:12 PM
mattdp's Avatar
Quoted: 13 Post(s)
Signal levels are certainly low, but not impossible. You may need a roof mount, but I'd try an attic install first - you could probably eek out ABC 6, PBS 15, FOX 47 and NBC 10. CBS 3 may take a roof mount. I assume you're on the north side of a hill? I'd try an attic install - VHF facing KTTC exactly and UHF pointed at KIMT. If KIMT is too unreliable, you could also try pointing the VHF at WKBT 8 out of LaCrosse.
mattdp is offline
User Tag List
