Rochester, NY - HDTV - Page 88 - AVS Forum | Home Theater Discussions And Reviews
 7Likes
Old 07-03-2015, 08:25 AM
gregoryperkins's Avatar
Quoted: 209 Post(s)
Liked: 76
What plan are you on? I will check mine when I get home. 6 up would be great. The one up that I had killed my usability if I upload anything large to the google.
gregoryperkins is offline
Old 07-03-2015, 08:34 AM
larrude's Avatar
Greg, What plan are you on? The standard and below are all 1Mbps upload, the others are all supposed to be (before this upgrade) 5Mbps. When I moved to the Extreme ( which TWC did complimentary???), I had to update my router and modem; they were too dated and did not work with the higher speeds. It was well worth the cost of the equipment. The router had to be at least 10 years old, a Linksys WRT54G
larrude is offline
Old 07-03-2015, 10:27 AM
Quoted: 209 Post(s)
Liked: 76
I guess standard. I got it in 1998, so whatever they had then. I have a docsis 3 Motorola and a gigabit router.
Thanks for the info.
Old 07-03-2015, 04:51 PM
Quoted: 209 Post(s)
Liked: 76
no significant change, 17 down, 1.3 up.
Old 07-03-2015, 07:06 PM
Steve Mehs's Avatar
I'm on Ultimate 50 x 5, with an Arris TG1672 16 x 4 eMTA bridged to my own Cisco RV320 router. Last night I rearranged some of the crap on my desk and powered down my two UPS units. When everything came back online and I did a speed test I had the bump in speed, which I did not have earlier in the week, so power cycling your modem may be required.
On the Ubee modems I know you can see exactly what the modem is provisioned at, I have not poked around in the config page of the Arris enough to see if the same info is made available. Probably in the neighborhood of 62 x 6.5.
Time Warner Cable – Signature Home Premium View w/Epix, Sports Pass, HD Pass, Spanish Tier, Cisco Explorer 8642HDC, Cisco Explorer 8742HDC Both Running ODN 7.3.0_29
DirecTV – Premier, HD Extra Pack, NFL ST Max, NHL CI, MLB EI, Whole House DVR, HR34-700 Running 0972, HR24-200 Running 0802
Steve Mehs is offline
Old 07-04-2015, 06:40 AM
Quoted: 209 Post(s)
Liked: 76
Yeah, I power cycled the modem too. Since I own it, I wonder if it is necessary?
Old 07-05-2015, 11:18 AM
larrude's Avatar
I saw the last two posts and power cycled my modem also (I just installed it about 6 weeks ago). Not a huge bump, but the 33 Mbps down improved a little and the 5.3 or so up also improved.
http://www.speedtest.net/result/4482703046.png
larrude is offline
Old 07-06-2015, 07:02 AM
lflorack's Avatar
Quoted: 63 Post(s)
Liked: 58
I have the Extreme Plan (30/5), and owned Motorola SB1641 (8-Channel) Modem and Linksys EA6900 (AC1900) Router: I've seen an increase too:
http://www.speedtest.net/result/4484427666.png
Lee
Links: System Diagram / System Pix
Klipsch: (2) RF-83, (1) RC-64, (2) RVX-54, (2) RSX-5, SVS: (1) SB13-Ultra
Yamaha: Aventage RX-A2010, CDC-685, Samsung: UN55B8000, Oppo: BDP-93
Apple: AppleTV, Roku: Roku3, Amazon: FireTV Stick, Roomie: Roomie Remote
ACP: J15BLK 1.5 kVA Power Conditioner/UPS, CinemaQuest: Ideal-Lume Std
See links for system details.
lflorack is offline
Old 07-12-2015, 05:58 AM
shibez's Avatar
I think i got a slight bump(on standard)
I havent checked my speeds since i downgraded to standard from extreme...but i just checked now and i think my upload got a 1Mbps increase. (from 1) Possibly the download too..I don't remember what standard is supposed to be. Also note that my house was all rewired last summer when i moved here. And i am using a docsis 3 arris modem with TW's built in wireless router.
Update: looked at my bill..i have turbo, not standard.
check my about me to see my HT gear
http://www.avsforum.com/avs-vb/member.php?u=7747546
shibez is offline
Old 07-12-2015, 11:41 AM
MPNASCAR24's Avatar
Quoted: 33 Post(s)
The speeds for standard internet are 15 mbps for download & 1 mbps for upload. Looks like you did get an increase in speed.
MPNASCAR24 is offline
Old 07-12-2015, 04:53 PM
shibez's Avatar
Ok i just looked at my bill...Looks like i have the Turbo Upgrade. so i dont think i have a speed bump. kind of lame.
shibez is offline
Old 07-13-2015, 10:55 AM
MPNASCAR24's Avatar
Quoted: 33 Post(s)
According to TW's Website turbo gives you 20 mbps for download & 2 mbps for upload. I took another look at your posted speeds & it looks like you got a very small increase. Maybe?
Old 07-13-2015, 01:23 PM
Quoted: 209 Post(s)
Liked: 76
Anyone having RR mail problems? Mine stopped working this morning sometime before 10. I got a bunch of odd failures last night too.
Old 08-18-2015, 07:57 AM
shibez's Avatar
Whats the best Cable Modem(docsis3) to buy for TWC?
Preferred with Wireless Built in...Like i am now "renting" from TWC. But if the prices exceed 100 bucks i will just dig around for my old wireless router to pair with it.
Thanks in advance
shibez is offline
Old 08-18-2015, 12:05 PM
Quoted: 209 Post(s)
Liked: 76
I have the Motorola SB6121, I got it from amazon warehouse deals in 2013 for $52 before it was officially supported. No problems so far.
Old 08-19-2015, 11:54 AM
larrude's Avatar
I recently updated by equipment. After research, I purchased a TP-LINK Archer C9 AC1900 Dual Band Wireless AC Gigabit Router, 2.4GHz 600Mbps+5Ghz 1300Mbps, 1 USB 2.0 Port & 1 USB 3.0 Port, IPv6, Guest Network router - ( I did not want an all in one in case I wanted/needed to replace one or the other) and the ARRIS SURFboard SB6141 DOCSIS 3.0 Cable Modem, both from Amazon. Current price for the two is around $220.
The modem works, very well, I can't say anything about it since I basically plugged it in and it has worked ever since.
The router is fantastic - strong signal throughout the house, super easy setup (I just gave it the same name as my old router and kept the same password and all my items, TV, Iphones, Ipads, Kindles, NEST thermostat, etc) just worked. My download and upload speeds went from 17down/3 up to 37down/6.3up.
I was using TWC's modem and a Linksys wrt56G router
larrude is offline
Old 08-19-2015, 02:35 PM
lflorack's Avatar
Quoted: 63 Post(s)
Liked: 58
I agree with having separate a modem and router and I agree with not using TWC's modem or modem/router. Although I have a different router (I have a linksys that's similar in features and speed to yours), but I have the same modem. It's been super-solid and I'm getting the same speed as you are. http://www.speedtest.net/my-result/4595564664
larrude likes this.
lflorack is offline
Old 08-21-2015, 04:54 AM
Quoted: 209 Post(s)
Liked: 76
The amazon deal of the day are Motorola Arris docsis modems for $39 to $69. The $69 model has a wifi router.
Old 08-21-2015, 08:13 AM
lflorack's Avatar
Quoted: 63 Post(s)
Liked: 58
The ARRIS SURFboard SB6141 DOCSIS 3.0 Cable Modem that I have is normally $88 for new. This is a certified refurbished unit for $49.99. Depending on your level of nervousness regarding refurbed units, this is a great deal.
lflorack is offline
Old 11-25-2015, 06:45 AM
tshaff09's Avatar
AntennaTV coming
Not much action in the Rochester thread...
So 31.2 is going to have Antenna TV in Jan.. this is good, since wgrz can be a bit iffy..
GetTV is going away then per Rabbitears? Maybe 46 would add/change to that.
tshaff09 is offline
Old 12-08-2015, 11:34 AM
Quoted: 89 Post(s)
Liked: 5
I cut my cord back a few years ago, on the recommendation of this site, I got a Winegard unidirectional antenna that I mounted in my garage in Perinton. I get NBC,ABC,CBS,WXXI, Fox and a few other wierd stations. My reception and quality was greatly improved over the amplified bunny ears I had in the same spot. I need to run a better coax cable, but a baby and lack of time are preventing it from happening. I got a TiVo Roamio refurb when it dropped down for $300 w/ Life time service and LOVE it. I got a tivo mini for $120 that allows me to connect to the Roamio as well. I use amazon prime, youtube, netflix, and some other sites when I want to watch TV. I don't feel like I lose much as when I go to a hotel or some place with cable there are soo many commercials.
I use to get 51.x on rare occasion with my old antenna, but haven't seen it come back up with my new setup.
window2000bug is offline
Old 12-08-2015, 01:05 PM
tshaff09's Avatar
51.x - ion etc is pretty strong . their tower is just south of LeRoy.. tvfool would give you direction info.
We have not had cable in 11 + years.. been using streaming devices with playon for several years.. plenty of entertainment options around
tshaff09 is offline
Old 12-09-2015, 06:45 AM
Quoted: 89 Post(s)
Liked: 5
Yeah, for it is 2edge in red located ~33 miles away. It doesn't help that I have a hill located in front of me and the tower. Also my antenna is located about 12ft high in my garage. We seldom watch anything other than the news, WXXI, and the Bills. So we are fine as is, I guess it is more to say that I have those few extra channels
Old 12-11-2015, 09:58 PM
MPNASCAR24's Avatar
Quoted: 33 Post(s)
My brother will agree with your statement about cable having too many commercials. His main tv source is netflix, youtube, etc. Since he can watch all of his favorite shows on netflix he recently canceled his basic lifeline cable because he doesn't have a need for it anymore plus he can use an antenna to get the locals for free.
Old 01-15-2016, 08:25 AM
Liked: 0
New here. Contemplating cutting TWC to internet only after looking at the proposed rate hikes starting in February. Have standard internet now, bought my own SBG-6580 a couple of years ago but recently purchased a Linksys WRT1900AC and put the cable modem in bridge mode. Last week in installed an Antennas Direct Clearstream 2V. Getting all the major (ABC, CBS, FOX, ION, NBC) and a slew of shopping channels. Next purchase will be an OTA DVR to time shift OTA programs. All my equipment (except TV) are in another room so I've been using a Logitech Harmony 900 remote control to control a Denon AVR-X2100W, Sony BDP-S550 & TWC's Samsung SMT-H3090. I'm now having a problem getting the Harmony to connect to my PC (Lenovo K450e) running Windows 10. It connects (device manager) as a network adapter : RemoteControl USB LAN LINK #2 (tried all other usb ports & only the "#2 " changes to the usb port #). Anyone have any experience with Windows 10 /Logitech Harmony connection? Gonna check with my daughter to see if her old laptop is still running Windows 7 & see if it connects.
rjbarrett is online now
