fox 26 in houston up & running in 720p - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 04-26-2004, 07:12 PM - Thread Starter
krboo's Avatar
watching bernie mac tonight and couldn't believe that it wasn't HD. So I switched my htl-hd to native output and sure enough, it was 720p. I wonder how many fox affiliates have done this?
krboo is offline
post #2 of 7 Old 04-26-2004, 11:51 PM
mitchrc's Avatar
Fox is moving west to east installing the "bit splicer" at the O&Os and the affiliates. KTTV is done. By the end of the year all of the stations that are transmitting digital should have the gear.
Mitch
mitchrc@mac.com
mitchrc is offline
post #3 of 7 Old 04-28-2004, 07:27 AM
rcbtaw's Avatar
Fox is now transmitting in 720p in Houston instead of their standard widescreen 480p? Guess I haven't seen this yet. I must admit though, FOX is only good for one thing: the NFL. I probably wouldn't notice the change until the NFL season starts.
Robert Christian Barger
rcbtaw is offline
post #4 of 7 Old 04-28-2004, 12:19 PM - Thread Starter
krboo's Avatar
I think they are still receiving programming from fox in 480p, but is then upconverted to 720p with the affilliates equipment. Correct me if I am wrong. I could definitely tell a difference.
krboo is offline
post #5 of 7 Old 04-28-2004, 12:36 PM
mitchrc's Avatar
Fox doesn't begin distributing 720p until September.
Mitch
mitchrc@mac.com
mitchrc is offline
post #6 of 7 Old 04-28-2004, 12:42 PM
foxeng's Avatar
Quoted: 165 Post(s)
Liked: 66
The HD link will not go hot until August 2nd with the first HD programming on Sept 12th. Until then, the stations are passing along FOX as they always have been, just it is 720p instead of 480p.
All opinions expressed (unless otherwise noted) are the posters and NOT the posters employers. The poster in NO WAY is/will speak for his employers. "Arguing with an engineer is like mud wrestling with a pig. After a couple of hours, you realize the pig likes it"
foxeng is offline
post #7 of 7 Old 04-28-2004, 12:52 PM
Alexmm's Avatar
The only OTA digital channel we in San Antonio have for Fox is SD. I hope they move HD broadcasting over here too. Then I will have to worry about receiving the channel because I find it it difficult (well the antenna is just on top of my TV, there is plenty I can do to improve it).
Alexmm is offline
Closed Thread Local HDTV Info and Reception
