Sacramento, CA - OTA - Page 334 - AVS Forum | Home Theater Discussions And Reviews
 47Likes
post #9991 of 10711 Old 04-08-2014, 10:10 AM
Theducksfan2010's Avatar
Liked: 57
Originally Posted by Calaveras View Post
You are in a favorable location on the west side of the valley having a little elevation over most of the valley.
My elevation is only at 89 ft.
 You're also within the service contour of Sacramento. I don't think the FCC Service Contours for full power stations extend much past 60 miles.
The service contour would have to extend past 70 mile to reach my location (how far I am from the broadcast towers). So are you saying I am in the service contours of the stations, but not the FCC Service Contours?
Josh
Theducksfan2010 is offline
post #9992 of 10711 Old 04-08-2014, 10:48 AM
Calaveras's Avatar
Quoted: 1323 Post(s)
Liked: 280
Okay. I see you are about 10 miles past the service contours of both Fresno and Sacramento but your situation makes up for it. You pretty much overlook the valley. Is the elevation of your antenna 89' or is that the ground elevation?
What determines LOS is the height of the transmitters and the height of your antenna. Here's a simple formula to determine distance to the horizon over flat earth:
Distance = SQR(H x 7912)
H= Antenna Height in Miles
KOVR is about 2000' high.
Distance = SQR(0.38 x 7912) = 54.7 miles.
If you antenna is 40' then your distance to the horizon is 7.7 miles. I could be a lot more if you're aimed over downsloping terrain.
54.7 + 7.7 = 62.4 miles is the maximum distance you could be from KOVR to get LOS over flat ground. I think your distance is farther since you're aiming over downsloping terrain which makes your antenna effectively higher.
KSEE is so high that their horizon is nearly 84 miles.
Chuck
Calaveras is online now
post #9993 of 10711 Old 04-08-2014, 11:28 AM
Liked: 57
@Calaveras So I am 2 edge from the Sacramento stations at 70 miles and LOS to 15KW KBID (1,912ft) at 90 miles, because of the additional height for their tower, same location (Meadow Lakes) as KSEE (1,972ft).
Ground elevation is 89', and my antenna is 40' above the ground.
Josh
post #9994 of 10711 Old 04-08-2014, 12:18 PM
Calaveras's Avatar
Liked: 280
I'm not sure how TVFool is coming up with 1 or 2 edges for Walnut Grove. KMAX is listed as LOS while KCRA and KQCA are listed as 2 edge. Those stations share the SAME antenna. I suspect that everything from Walnut Grove is pretty close to LOS from your antenna.
Where did 1912' for KBID come from? It is 4572' above sea level.
The horizon for your antenna then is 14 miles if the ground slopes down to near sea level towards Walnut Grove. That makes Walnut Grove very close to the limit for LOS. LOS or close to it is more important for reception than FCC service contours which just specify a field strength based on calculations with certain assumptions.
TVFool is a good guide to what you may be able receive and the service contours are a good guide to what the FCC thinks the station coverage is but neither are the final word as to what can be received in any situation.
Chuck
post #9995 of 10711 Old 04-08-2014, 11:00 PM
Liked: 57
Chuck
Maybe I misread the data??
 31‑1
24
 KBID‑LP
88.92
100°
0.15 kW
Display
Channel
Physical
Channel
Video Audio Call Sign        Network/Programming    Nickname Notes  Print
31-1  24.1 480i DD2.0  Sports "My Combat Channel"
31-2 24.2 480i DD2.0  Euronews
31-3  24.3 480i DD2.0  News (Arabic) "Al Mayadeen"
31-4  24.4 480i DD2.0  Independent "Care World TV USA"
31-5  24.5 480i DD2.0  Armenian "AMGA"
31-6  24.6 480i DD2.0  Armenian "Horizon"
Technical Data and Screencaps
FAC-ID: 23276   FCC Query   CDBS List   Correspondence external.png  RabbitEars TV Query  REC Query
TSID: 8575 (0x217F)
Add a Reception Report
Channel 24 Longley-Rice coverage map available. FRESNO, CA (SCM(Est. Pop. 1,129,354) Directional Pattern
BDISDTL-20091230ABZ (1350651) - App
BLDTL‑20140403ABF (1632866) - App
1912' 15 kW CA (  ) (37.4 mile contour / 4401.3 sq. mi. area)
(0.9 kW TPO + 12.22 dB gain = 15 kW ERP)
  91' AGL; 4573' ASL (1223835);  Stringent Filter
  Unknown or 0° Elec Beam Tilt; Kathrein K723147 ARRAY
  NAD27: N 37° 4' 25" (37.074), W 119° 25' 52" (-119.431) (S) (FMeadow Lakes (CA)
  NAD83: N 37° 4' 25" (37.074), W 119° 25' 55" (-119.432)
  TSReader Data: None Available
  Bitrate Allocation: Unknown
http://www.rabbitears.info/dxlocation.php?id=327
Josh
post #9996 of 10711 Old 04-08-2014, 11:56 PM
Liked: 57
KMUM (Rf 31) CH 15, Telemundo from Sacramento is now running Ion on both 15.1 (1080i) and 15.2 (480i). PSIP is still showing TLMD. Anyone else notice this? Why would Sac need another ION station, especially a LP with KSPX being a full power affiliate??
Josh
post #9997 of 10711 Old 04-09-2014, 06:45 AM
Calaveras's Avatar
Liked: 280
That's probably Height Above Average Terrain (HAAT). That's applicable for a large part of the country but not so much for California where most of the population lives near sea level and the transmitters are on mountains. It's better to use Above Mean Seal Level (AMSL) in that case. See the FCC Query for AMSL:
http://transition.fcc.gov/fcc-bin/tvq?state=CA&call=KBID&arn=&city=&chan=&cha2=69&serv=&type=0&facid=&asrn=&list=0&dist=&dlat2=&mlat2=&slat2=&dlon2=&mlon2=&slon2=&size=9
If the KBID antenna is at 4572' and you're at 89' then KBID at 1912' HAAT doesn't make much sense.
Chuck
post #9998 of 10711 Old 04-10-2014, 04:53 AM
Trip in VA's Avatar
Quoted: 831 Post(s)
Liked: 252
Send a message via AIM to Trip in VA
Height Above Average Terrain (HAAT) is one of those FCC ideas from the 50's which made a lot of sense at the time, when computers couldn't really do the kinds of analysis we can do today. Now, I'm not so sure.
To explain, in case you're interested, imagine that instead of a mountain range, it was a mesa. (Easier to picture an example this way.) So what is now the ridge line, and behind it, is perfectly flat, but elevated by 4,000 feet. The valley, we'll assume, is at sea level (0 feet). So for each of the eight cardinal directions, you sample every kilometer from 3.2 to 16.1 km away. On the mesa, this gives you 4,000 feet. In the valley, this is 0 feet. Since half of your points are at 4,000 feet, and half are at 0 feet, when you take the average, you get 2,000 feet. Then, if the transmitting antenna is 100 feet high (on top of the 4,000 foot mesa), you add 100 feet to the total. So, your station is now 2,100 feet above "average terrain."
I chose that example because it shows the flaw in the method. In the direction of the mountains, the tower is only 100 feet high, so its coverage is really small in that direction. By contrast, toward the valley, it has a 4,100 foot advantage, good for probably 100 miles or more of coverage. Over relatively flat terrain, this method works very well. It works significantly less well over rough terrain. If you know your own elevation, taking the difference between the height above sea level value of the station's antenna and your antenna, as Calaveras suggests, is the best way to do that calculation. That height (for the station) is available on RabbitEars, directly to the left of the words "Stringent Filter" in your copy+pasted section. AMSL is "Above Mean Sea Level." (AGL is "Above Ground Level.")
- Trip
Theducksfan2010 likes this.
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is offline
post #9999 of 10711 Old 04-10-2014, 08:56 PM
bobbyc's Avatar
Quoted: 64 Post(s)
Liked: 37
inversions (or leaves/multipath) are back! not much coming in tonight reliably at my place; time to raise the antenna to it's summer height
Bob C
bobbyc is offline
post #10000 of 10711 Old 04-13-2014, 05:32 PM
Liked: 57
@Trip in VA so AMSL would be good for the Fresno stations, but HAAT would be good for the Sacramento stations, since they are mainly on the valley floor in Walnut Grove?
Josh
post #10001 of 10711 Old 04-13-2014, 07:21 PM
Calaveras's Avatar
Liked: 280
@Trip in VA
For Walnut Grove HAAT and AMSL are almost identical.
Chuck
post #10002 of 10711 Old 04-13-2014, 07:29 PM
Calaveras's Avatar
Liked: 280
Bob C
Even though I've been gone for a few days I noticed we had some inversion issues. A couple recordings on Friday night are a bit short of an hour on KOVR. This afternoon, the time with the least ducting, Salinas stations were pounding in here. KQET was overriding KOVR. KMUV analog was full quieting. Anything on Sutro that is co-channel with Salinas was wiped out.
Chuck
post #10003 of 10711 Old 04-13-2014, 09:45 PM
Liked: 57
@Calaveras, what is (or is there any) correlation between ducting on TV and on FM? I have been noticing some crazy ducting on the radio since I hooked it up to a rooftop antenna. Is there any part of the dial where ducting on FM would be indicitive of ducting on TV?
Josh
post #10004 of 10711 Old 04-14-2014, 07:09 AM
Calaveras's Avatar
Liked: 280
@Calaveras
Yes, FM has ducting too. You'll find something going on everywhere at the same time.
Chuck
post #10005 of 10711 Old 04-14-2014, 09:22 AM
Liked: 57
Chuck
I know last year there was ducting the was bringing 102.7 The Wolf out of Fresno in perfect stereo 24 hours a day for over 2 weeks straight (normal conditions leave nothing but static on 102.7). @Larry Kenney is this the same type of ducting you are talking about for DXing during the summer?
Does the UHF band get the same type ducting? As strong and long lasting? I am definitely looking forward to seeing what happens....
Josh
post #10006 of 10711 Old 04-14-2014, 10:36 AM
Calaveras's Avatar
Liked: 280
I never see anything here that lasts 24 hours a day for 2 weeks but conditions can vary widely from location to location. There's no special ducting for one frequency band only. It usually affects all frequencies to some degree but what you receive is highly dependent on the location of the transmitter so it might appear to affect some signals/frequencies more than others.
At my location all signals from Fremont Peak and Mt. Toro seem to go up and down in unison. But signals can vary widely between Sutro Tower and Mt. San Bruno. Good conditions to Sutro rarely occur at the same time as good conditions to San Bruno.
There's a famous summertime duct that forms between Hawaii and the west coast. The duct has entry and exit elevations. On the Hawaii end you need to be far up a mountain. On the west coast end you can be low. Two way contacts have been made by amateurs on 145 MHz, 432 MHz and even 1296 MHz at the same time.
Chuck
post #10007 of 10711 Old 04-14-2014, 10:49 AM
Liked: 57
Chuck
I learn so much from you in here on a routine basis. That explains why there are times ducting only comes from the Bakersfield area, other times Bakersfield and Fresno, others Sacramento only, and still others all at the same time including Chico. As well as why I can get ducting here when its raining but sunny and warm in Bakersfield.
Josh
post #10008 of 10711 Old 04-15-2014, 12:11 AM
Larry Kenney's Avatar
Quoted: 556 Post(s)
Liked: 86
The DXing I was talking about is E-Skip where signals reflect off the E layer of the ionosphere. We very, very seldom see any of that here on the west coast. It all seems to occur east of the Rockies to the Atlantic coast.
Ducting is different and while I've heard of it, I'm not sure how it works. Seems like signals go from a specific area A to another specific area B.
Around here most of the changes in signal strength are due to inversion layers. They can build up big time in the summer months when there are no storms to wipe them out.
Larry
SF
My complete SF Bay Area DTV Station Lists: http://www.choisser.com/sfonair.html
Lots of Broadcasting links and information: http://www.choisser.com/broadcast.html
Live reception scans from my HD Home Run receivers: http://www.larrykenney.com/hdhr/
Photos and info on my antennas: http://www.larrykenney.com/tvantennas.html
Larry Kenney is online now
post #10009 of 10711 Old 04-15-2014, 01:54 AM
Liked: 57
KMUM-CD 15 Telemundo (rf 31) is still broadcasting Ion HD/SD.
How does this bode for Ion 29 KSPX (rf 48)?
Josh
post #10010 of 10711 Old 04-15-2014, 07:13 AM
Calaveras's Avatar
Liked: 280
I have no idea why KMUM is broadcasting ION but I doubt that it means anything from KSPX.
Chuck
post #10011 of 10711 Old 04-15-2014, 07:27 AM
Calaveras's Avatar
Liked: 280
Josh,
With your low VHF antenna you'll probably want to look for stations coming in via sporadic E from mid May through early August. That's the "E" season. Look on channels 2 - 6. It was much easier when there were many analog stations but it may be possible to receive some LP stations. Signals vary rapidly and there is often multipath which would make decoding the DTV signals difficult. Skip is very common on channel 2 but rare above channel 6 into the FM band. I've seen it a couple of times on 144 MHz in the ham band but never on channel 7. It's true that the east gets more of it than we do in the west.
Use this real time map of contacts made on the 50 MHz ham band as a guide to when to look on channel 2.
http://www.dxmaps.com/spots/map.php?Lan=E&Frec=50&ML=M&Map=NA&DXC=N&HF=N
Right now is is likely to be blank but that will change dramatically in about 6 weeks. Look for lots of red lines extending to northern California.
You should look for analog stations also. I received XEPM Ciudad Juarez several times a few years ago when I had a low VHF antenna up. There was a channel 5 much weaker from the same place. XEPM has a UHF DTV transmitter now so I don't know if they're on analog 2.
Chuck
post #10012 of 10711 Old 04-15-2014, 11:37 AM
Liked: 57
Does anyone know anything about this station, KEFM-LP (analog 6)? The id on the screen says Sacramento, but everything I can find online lists KEFM-LP analog 6 as a Chico repeater of KNNN-LP.
Josh
post #10013 of 10711 Old 04-15-2014, 11:47 AM
Trip in VA's Avatar
Quoted: 831 Post(s)
Liked: 252
It transmits from Sutter Butte near Yuba City. It's one of many "Franken-FMs" which are analog LPTV operations on channel 6 which pretend to be radio stations due to the channel 6 audio being at 87.7 FM.
- Trip
N4MJC
RabbitEars
post #10014 of 10711 Old 04-15-2014, 11:55 AM
Liked: 57
- Trip
It's not in your database, don't track the Franken-FM's? Apparently it used to actually be a tv station a long time ago. All of these type of stations will disappear when analog goes away next year? Or will they actually flush cut to digital (apparently they have the permit).
Josh
post #10015 of 10711 Old 04-15-2014, 01:10 PM
Trip in VA's Avatar
Quoted: 831 Post(s)
Liked: 252
I do not track analog stations, only digital stations, so it's not on RabbitEars. It's still licensed as a TV station, but is just operating like a radio station.
Yes, they will disappear when the LPTV transition to digital comes. Some will probably go off the air; the rest will convert to digital and thus become unavailable on FM.
- Trip
N4MJC
RabbitEars
post #10016 of 10711 Old 04-15-2014, 05:41 PM
Mister B's Avatar
Quoted: 17 Post(s)
Josh,
Chuck
Both analog channel 2 and 5 are still on in Juarez.
Mister B is offline
post #10017 of 10711 Old 04-25-2014, 07:21 AM
Calaveras's Avatar
Liked: 280
KFKK-LD filed for a 6 month extension of their construction permit which is for channel 32 and is located a bit east of Ceres. This is owned by DTV America, a group that claims to have big plans but only has 5 stations on the air in the entire country. I hope they never come on the air as that would spell the end of KION and KEMO for me.
Chuck
post #10018 of 10711 Old 04-26-2014, 06:24 PM
Liked: 57
Chuck
I hope it never comes on, KJEO is strong enough I can get it with a Terk indoor antenna (amplified). I wouldn't be able to get either if it did.
Josh
post #10019 of 10711 Old 04-29-2014, 06:30 PM
Quoted: 556 Post(s)
Liked: 86
We have a new channel here in the San Francisco Bay Area on channel 3, K03HY-D, transmitting from Mt. Tamalpais in Marin Country. On sub-channels 3.2, 3.3 and 3.4 it shows the PSIP ID of KKPM, so it's translating the KKPM programming.
I don't have complete information on KKPM in my Digital Channel Listings. So if someone who can see KKPM, transmitting on channel 28 from Sutter Buttes, would note what's on their various sub-channels and pass it on to me here or in a personal message I'd appreciate it. Thanks.
Larry
post #10020 of 10711 Old 05-01-2014, 12:28 AM
Liked: 57
KMUM-CD 15 (rf 31) is no longer ION, it is Telemundo again.
Josh
