Sacramento, CA - OTA - Page 339 - AVS Forum
 1Likes
post #10141 of 10153 Old 09-24-2014, 07:33 AM
slk230's Avatar
Crappy reception
Antenna is a deep fringe Weingard with a 7777 preamp on a rotator mounted about 30 agl. Last night when KOVR went bye bye, I changed over to chl 10 and the signal was almost as high as my Sony TV signal meter can go. Click back to KOVR and it dropped by over half. Checked out KCRA and it was almost max too. Something happened last night to KOVR and it wasn't the first time. It will be rock solid all summer long as long as everything is reruns, but as soon and the "new" season starts, the problems crop up. NCIS NO and person of interest were rock solid the entire night. I may go up and check out the connections this weekend as I seem to have lost my rotator meter indicator so I have to eyeball the antenna position. My only other gripe is I can get every SF station EXCEPT KPIX which just happens to be the only other CBS station I can receive. The past few weeks I've even been able to watch KOLO out of Reno with no problems. Oh well...
slk230 is offline
post #10142 of 10153 Old 09-24-2014, 09:51 AM
Calaveras's Avatar
Quoted: 103 Post(s)
Liked: 90
This is just a case of temperature inversions occurring at inopportune times. When you have this problem with KOVR you should check KTFK. It's on RF 26 right next to KOVR and the antenna is on the same tower. I've found both stations to go up and down in unison. If KOVR is bad I would expect KTFK to be bad too. KXTV is also on the same tower but VHF can act different from UHF even from the same location.
I have the same lack of a back-up CBS station. KION is too unreliable and is subject to interference from KEMO on 32 and KPIX is too weak here to be reliable.
I'm still curious if you have LOS to Walnut Grove because LOS is usually quite reliable reception. The fact that your signals go up and down so much suggests you have at least 1 edge.
Chuck
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
Calaveras is offline
post #10143 of 10153 Old 09-24-2014, 04:12 PM
slk230's Avatar
Chuck
I'm 35.92 miles not LOS. I have a ridge less than five miles from QTH blocking LOS.
I have a similar issue going towards SF. There I have two ridges, one at about 5 miles and a second higher one at 11 miles. Sutro is 26.17 miles away. I haven't seen too many issues with temp inversions / ducting or sun bore-sight interference.
I do notice any time KOVR goes on their back-up, I lose them.
Back in the analog days, I could pull in channel 12 from Chico without any problem. Based on testing I performed with a VHF radio system years ago, I discovered that for any given power, the digital signal went half the distance that the analog went. We ended up installing portable repeaters in the staff cars to compensate for the loss. The hand held radios only needed to make it to the cars and the higher power radio in the car would reach the base stations. I expected the same thing to happen with HDTV and it appears to be the case. That's why the deep fringe antenna and the preamp just to get what should be a good signal.
Longest "skip" I ever got was when I lived in Pleasant Hill and got an El Paso, Tx station one night. Came in great. Better than any SF station.
Oh Well
slk230 is offline
post #10144 of 10153 Old 09-24-2014, 10:06 PM
Calaveras's Avatar
Quoted: 103 Post(s)
Liked: 90
Oh Well
I know there was fading in the analog days too but we just put up with it and tend to forget the times when the signals were not so good. I think the "digital cliff" gives us a distorted sense of what's going on. I still receive a few analog signals here and they vary hugely in quality.
Unfortunately non LOS invites very large swings in signal strength and if your signals are a bit marginal then you'll have problems during bad times.
I don't think the kind of solar interference you mention is possible on UHF or VHF with the relatively low gain antennas and high power transmitters we have. That problem is mostly confined to high gain dishes receiving weak satellite signals.
If you haven't noticed the effects of temperature inversions it's because your signals have enough margin most of the time. I'm sure if you monitored your signals over time with a spectrum analyzer you'd see quite a bit of variation. I've monitored KSBW here and have seen 30 dB or more total swings in signal strength but the station is so strong and low multipath that it never drops out. If I had never made it a point to look at it I'd have never known what was going on.
Chuck
post #10145 of 10153 Old 09-28-2014, 08:00 AM
Calaveras's Avatar
Quoted: 103 Post(s)
Liked: 90
KOVR
Looks like KOVR is on the back-up antenna this morning. It's down about 12 dB in signal strength and the SNR is down too. KTFK is normal strength and so is KXTV both on the same tower.
What happened?
Chuck
Edit: Back to the main antenna at 8:30 am.
post #10146 of 10153 Old 09-28-2014, 12:56 PM
jhughy2010's Avatar
Quoted: 126 Post(s)
Liked: 62
Hi guys I was wondering if anyone here knows an affordable way to purchase or build a 25-30 foot tower. I see they are pretty expensive when purchased through solidsignal. Any thoughts?
Theater set-up:
AVR:  Pioneer VSX-820
Speakers:  5.1 consists of four NHT Classic Two bookshelf and an NHT TwoC center
Sub:  PSA-XV15
HTPC - ridiculously over-the-top, home-built gaming PC that I tinker with daily!
OTA antenna:  Winegard HD7698P
HDTV:  Sharp LC-60SQ15U
jhughy2010 is offline
post #10147 of 10153 Old Yesterday, 07:06 AM
Calaveras's Avatar
Quoted: 103 Post(s)
Liked: 90
What do you consider to be affordable?
Chuck
post #10148 of 10153 Old Yesterday, 09:35 AM
jhughy2010's Avatar
Quoted: 126 Post(s)
Liked: 62
Chuck
That's a good question... I think the $600 ones I see on solidsignal are a little pricey for me. I do however like the way a tower looks and wouldn't mind paying around $300 for one. After searching the net all I am really able to find are towers from solidsignal though.
Theater set-up:
Sub:  PSA-XV15
post #10149 of 10153 Old Yesterday, 12:35 PM
Calaveras's Avatar
Quoted: 103 Post(s)
Liked: 90
I'll sell you my 50' Rohn 25 tower plus all the accessories for that much.
Chuck
post #10150 of 10153 Old Yesterday, 05:41 PM
Calaveras's Avatar
Quoted: 103 Post(s)
Liked: 90
KXTV
The FCC finally approved today the KXTV application to operate a channel 36 low power translator station. Looks like the location is the tower next to their building in Sacramento.
Now the question is will it actually be built?
Chuck
post #10151 of 10153 Old Yesterday, 09:02 PM
jhughy2010's Avatar
Quoted: 126 Post(s)
Liked: 62
Chuck
Its tempting... anything in the 30' range? Is the Rohn self supporting?
Theater set-up:
Sub:  PSA-XV15
post #10152 of 10153 Old Yesterday, 09:51 PM
Calaveras's Avatar
Quoted: 103 Post(s)
Liked: 90
You could house bracket 30' but not 50'. Below is picture of when I had it up. I replaced it with a crank-up tower.
Chuck
post #10153 of 10153 Old Today, 12:27 AM
Smoke_signal's Avatar
If you just need a 25-30 foot-plus cable-supported freestanding mast and not a heavy-duty climbable tower, why not go for a Channel Master 25 or 40 foot telescoping mast?
http://www.channelmasterstore.com/An...Masts_s/42.htm
Smoke_signal is online now
User Tag List
