Sacramento, CA - OTA - Page 349 - AVS Forum | Home Theater Discussions And Reviews
 38Likes
post #10441 of 10452 Old 07-31-2015, 03:32 PM
ellisr63's Avatar
Quoted: 526 Post(s)
Liked: 313
Originally Posted by jhughy2010 View Post
Ok but what are you using to grab the signal from the HD Homerun? Are you using WMC or something similar?
Edit: Sorry about that I read a few posts up and see you are using WMC. I'll post the solution (I hope).
Thanks for the help, I was using WMC for viewing, but I am now using Openelec/Kodi for viewing (problem is still there). I am only using WMC for recording now. Is there a fix for Kodi too? The media player is a Celeron NUC if that helps. I will also look at the features you noted to see if they are on.
tia,
Ron
Krell Showcase 7.1, (3) JBL 2360As/EV DHA-1s, (3) 1/4 Pie bass bins, Xilica XP-4080 crossover, (2pr) JBL 8340As,  (1pr) JBL 8320s, PS3, XBox360, (2) Intel NUCs, Blue Jeans 7.1 Cables, Redmere HDMI cables, Monster HTPS7000, 2 DTS-10 subs, Panasonic AE8000, SeymourAV 180 (195" diagonal) scope screen, Darbee Darcet, (1) Yamaha P7000s, (1) Yamaha MX-A5000, MiniDSP DDRC-88A, and an Oppo 103.
The Ellis Family Go Big or go Home HT
ellisr63 is online now
post #10442 of 10452 Old 07-31-2015, 03:35 PM
jhughy2010's Avatar
Quoted: 625 Post(s)
Liked: 209
Did you try the fix that I mentioned in the previous post? Utilize the graphics properties for the GPU you are using.
I will research if Kodi has display settings that can contribute to contrast enhancements.
Pioneer VSX-1124-K, NHT Classic Three (L/R), Classic Two (rear) TwoC (center), PSA V1500 (x2)
HTPC/server (Emby)
OTA Winegard HD7698P
Sharp LC-60SQ15U
My DIY subwoofer build
jhughy2010 is offline
post #10443 of 10452 Old 07-31-2015, 03:36 PM
ellisr63's Avatar
Quoted: 526 Post(s)
Liked: 313
I am going to try the fixes you posted now.
jhughy2010 likes this.
post #10444 of 10452 Old 07-31-2015, 03:48 PM
ellisr63's Avatar
Quoted: 526 Post(s)
Liked: 313
@ellisr63 What I believe is happening (especially with WMC) is that the active contrast enhancements are/is causing problems with the signal KVIE delivers. I too have had this exact same problem with WMC which was utilizing Intel HD4600 GPU.
My fix was to download the latest driver here and then right click the desktop and open "graphics properties". You can do the same thing to open Nvidia graphics properties but this fix is exclusively for Intel.
Go to Video / Image Enhancement / Advanced / Contrast Enhancement ..... set the Contrast Enhancement to Disable.
If you are using a GPU from Nvidia or ATI then you'll find a similar setting in its corresponding control panel. I would go one step further and disable your panels Active Contrast or Contrast enhancement feature (each newer panel has one). Even experiment with your panels Dynamic Contrast enhancement feature. I have turned mine off because it messes with gray scale calibration.
Anyhow, this fix worked for me and I'm hopeful (kind of positive) it will work for you!
I just tried turning off the Contrast Enhancement and if it made a difference it was not much. It is hard to tell because their was not as much white displaying when i did it this time. It had a blue beach scene and it did it again.
post #10445 of 10452 Old 07-31-2015, 03:54 PM
jhughy2010's Avatar
Quoted: 625 Post(s)
Liked: 209
Specifically go to the Intel GPU display driver settings and follow this: Go to Video / Image Enhancement / Advanced / Contrast Enhancement ..... set the Contrast Enhancement to Disable.
I'm pretty sure it was this that fixed it for me. My flashing was identical as the video you showed and very specific to 6.1
ellisr63 likes this.
HTPC/server (Emby)
Sharp LC-60SQ15U
post #10446 of 10452 Old 08-01-2015, 09:28 AM
ellisr63's Avatar
Quoted: 526 Post(s)
Liked: 313
Thanks, would that be in the Bios?
post #10447 of 10452 Old 08-01-2015, 04:08 PM
jhughy2010's Avatar
Quoted: 625 Post(s)
Liked: 209
See my post below:
HTPC/server (Emby)
Sharp LC-60SQ15U
post #10448 of 10452 Old 08-02-2015, 08:56 AM
ellisr63's Avatar
Quoted: 526 Post(s)
Liked: 313
See my post below:
I am running OpenElec/Kodi remember? I don't have those settings, hence why I was asking if the last bit was in the Bios. I did the TV settings you suggested.
post #10449 of 10452 Old 08-02-2015, 11:51 AM
jhughy2010's Avatar
Quoted: 625 Post(s)
Liked: 209
So you aren't using Windows?
If you have an Intel CPU you have the properties to make the settings changes I mentioned.
post #10450 of 10452 Old 08-02-2015, 02:52 PM
ellisr63's Avatar
Quoted: 526 Post(s)
Liked: 313
I am not using Windows on that PC. It has a Intel Celeron CPU on the NUC, but the I was unable to find any settings like you were suggesting in the version of Openelec/Kodi I have. I am assuming that without windows it is not fixable? The only way I can adjust the video on that unit is from the TV unless it is a bios adjustment as far as i know.
post #10451 of 10452 Old 08-02-2015, 03:19 PM
jhughy2010's Avatar
Quoted: 625 Post(s)
Liked: 209
Oh wow that sucks. I'm not familiar with openelec. I would assume though there must be a way to adjust GPU settings.
post #10452 of 10452 Old 08-02-2015, 04:15 PM
ellisr63's Avatar
Quoted: 526 Post(s)
Liked: 313
Thanks for your help. At least I know it could work with a Windows PC...I switched to the OpenElec because Windows was just getting too slow.
