Sacramento, CA - OTA - Page 353 - AVS Forum | Home Theater Discussions And Reviews
 43Likes
post #10561 of 10563 Unread 07-18-2016, 03:56 PM
Liked: 0
Thanks, Chuck, for the information and input!
I have a lot to learn about this DTV stuff! For example, I am rather lost regarding your statement that "The most important thing for reception of 1 and2 edge signals is that your antenna has line-of-sight to the closest edge." I did read a little about what 1 and 2 edge mean, but have no clue how to identify the "closest edge." My property, luckily, is pretty devoid of tall trees and my antenna on the roof has pretty good view toward the Walnut Grove Towers. Using Google Earth's elevation and line tools, I can see that there are no taller hills on my direct line of sight to those towers.
On my way home from work Friday, before seeing your post, I stopped and purchased a ClearStream 4V antenna from Best Buy and mounted it on my roof on a short 30" J-mount. I am pretty impressed with the results. All weekend I had good reception of both Sacramento and Bay Area stations.
I still can't get KXTV (Ch 10, Sacramento) at all even though my signal meter shows a 85-95% signal (haven't checked yet on your suggestion that FM stations might interfere with channels 9-10). I do get good reception on Channel 6 (KVIE), another Hi-VHF station. Not getting Ch. 10 may not be an issue if I can get ABC on alternative UHF station (Ch 7, which came in OK).
As you said, the reception does come and go somewhat throughout the day, but in almost every case I was able to get the major networks via one of the stations that I was picking up.
A few questions for you:
1) Do you feel the Winegard HD7698P is a lot better than the 4V? I love the small footprint of the 4V and if it will work for me, especially if I add an amp, then I wouldn't want to switch to something a lot bigger unless the improvement is significant.
2) How do I source low-noise pre-amps from one-man operations? And what do you think of Antenna Direct's "Juice" preamp?
3) What is the difference between a pre-amp and a distribution amp anyway? When is one a better choice than the other? I ask because the previous owner evidently had an antenna system at one point and there is already a distribution amp in my crawl space where the cables are ran to my second TV (not hooked up yet).
Thanks again for the education and help!
Way_Cool is offline
post #10562 of 10563 Unread 07-18-2016, 06:55 PM
Calaveras's Avatar
Quoted: 913 Post(s)
Liked: 214
According to TV Fool you DON'T have line-of-sight to the transmitters. If you had LOS the Noise Margins of your stations would be around 50dB not 20 something dB. Click on the call sign of any station in your TV Fool report and it will show you terrain. I've attached the plot for KOVR with the 1st and 2nd edges marked. Looks to me that it wouldn't take much more antenna height to get above the 2nd edge. For successful reception of 1 or 2 edge signals your antenna needs to be able to see the closest edge. Additional obstacles such as trees and building attenuate the signal even more than TV Fool shows. In every case that I've personally seen where the antenna has true LOS to the closest edge reception has been successful.
In almost every case the Signal Meter is a Signal Quality meter and not a Signal Strength meter. If you have just one meter then it's an SQ meter (Signal-to-Noise Ratio). 85% to 95% is normally a good number and you should have no problem. How does that compare to the other stations?
The 4V may be good enough for you on UHF but it's severely lacking on high VHF. It's intended for reception in strong signal areas when just about anything will work. You can use a separate VHF antenna. This should be good enough:
http://www.mcmelectronics.com/produc...eo+retargeting
The HD7698P will give you equal VHF/UHF performance.
The Clearstream Juice is a good preamp and has better than average overload characteristics for stronger signal areas. The two one-man operations are Kitztech (KT-200 is the best):
http://www.kitztech.com/
and Jan Jenca from Europe:
http://www.antenne-komponenty.eu/eng...zlucovace.html
A preamp is intended to be mounted at the antenna and has enough gain to overcome coax loss and often a 2-way splitter. A distribution amp is usually lower gain and is intended to overcome the splitter loss and short coax runs. Sometimes a distribution amp can be used as a preamp.
BTW, please refrain from all the HTML formatting. It makes it really hard to read the text when responding and the forum doesn't require it.
Chuck
Calaveras is offline
post #10563 of 10563 Unread 07-19-2016, 07:29 AM
Calaveras's Avatar
Quoted: 913 Post(s)
Liked: 214
KAHC-LD
KAHC-LD is on the air and is transmitting 15KW from Sacramento. I've been having a hard time with KBCW the last few days so I looked at it on the spectrum analyzer and saw a good signal on RF 45 but it wouldn't decode. Then it dawned on me that maybe KAHC was on the air. Sure enough, moving the antenna to 300 degrees to downtown Sacramento showed another signal. I did a rescan on the TV and found these channels for KAHC. The subchannels are not a mistake.
45.1001 - Laff TV
45.1002 - Test Pattern
45.1003 - Cozi TV
45.1004 - LCHD
45.1005 - QVC
45.1006 - QVC Plus
They may be using these high sub channel numbers to avoid a conflict with KFTY-LD which is also using virtual channel 45.
The signal is surprisingly strong here for the low power, the low antenna and all the hills in the way. At one point it reached SNR 30 dB. It's almost as strong as KQCA and far less mulitpath.
Chuck
