Sacramento, CA - OTA - Page 356 - AVS Forum | Home Theater Discussions And Reviews
 46Likes
post #10651 of 10661 Old Today, 12:02 AM
888CALLFCC's Avatar
Quoted: 212 Post(s)
Liked: 30
Originally Posted by Larry Kenney View Post
I'd like to update my station list.
Larry
New channel ...43-7 Tuff-tv
888CALLFCC is offline
post #10652 of 10661 Old Today, 12:13 AM
Larry Kenney's Avatar
Quoted: 542 Post(s)
Liked: 82
Thanks, Ben!
My complete SF Bay Area DTV Station Lists: http://www.choisser.com/sfonair.html
Lots of Broadcasting links and information: http://www.choisser.com/broadcast.html
Live reception scans from my HD Home Run receivers: http://www.larrykenney.com/hdhr/
Photos and info on my antennas: http://www.larrykenney.com/tvantennas.html
Larry Kenney is online now
post #10653 of 10661 Old Today, 02:01 AM
Trip in VA's Avatar
Quoted: 708 Post(s)
Liked: 200
Send a message via AIM to Trip in VA
47-2 is Festiva TV. http://www.festivatelevision.com/
I have a direct contact at DTV America who e-mails me almost every time something changes on any of their stations (and sends a complete list to me every few months, just in case something gets missed) so the RabbitEars listings for the DTV America stations are usually pretty up to date. Larry, you're of course welcome to use RabbitEars information to update your listings as you see fit.
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is offline
post #10654 of 10661 Old Today, 09:02 AM
Calaveras's Avatar
Quoted: 1206 Post(s)
Liked: 267
Is that move done yet ? Not really seeing any type of signal advantage here over the old transmitter location. Or as the TV says "yellow" signal, not green. But works.
Yes, the move is complete. I have not seen any more transmissions from Angles Camp.
Chuck
Calaveras is offline
post #10655 of 10661 Old Today, 12:47 PM
888CALLFCC's Avatar
Quoted: 212 Post(s)
Liked: 30
- Trip
Does anybody know if a directory exists for AM-FM radio ? With transmitter locations ?
I hear some weird stuff in the car.... from far away locations.
The rock station at 1660 AM ... (guessing Bakersfield ? ) is a mystery too me.
post #10656 of 10661 Old Today, 12:52 PM
888CALLFCC's Avatar
Quoted: 212 Post(s)
Liked: 30
Chuck
You said something a few years back about amplifiers and the low VHF band. I forgot. Do they work on that band ... or not ?
Is this station a full power one ?
post #10657 of 10661 Old Today, 01:20 PM
Trip in VA's Avatar
Quoted: 708 Post(s)
Liked: 200
For FM there's this: http://db.wtfda.org/
Not aware of something similar for AM.
Unless Radio-Locator is what you're looking for.
- Trip
N4MJC
RabbitEars
post #10658 of 10661 Old Today, 03:08 PM
Calaveras's Avatar
Liked: 267
Preamps on low VHF don't improve the SNR because there's a minimum of 10 dB more noise there than on UHF. There's also much less cable attenuation on low VHF. I found that a system noise figure of less than 10 dB didn't improve the SNR for me. Even with my very long cable run the total attenuation was 4.6 dB and the distribution amp NF is 3 dB which is only 7.5 dB total. Adding a 3 dB NF preamp did noting for the SNR.
My summary for preamps:
Low VHF - no help for anyone
High VHF - can be helpful in quiet locations and for long cable runs
UHF - helpful for weak signals for almost everyone
KCSO is a low power station. They are licensed for 3KW but I think they have an STA for 5KW but I'm not really clear on that. I'm not sure what qualifies as a full power station on low VHF. 10-20KW?
Over the long run KCSO from Walnut Grove averages a Noise Margin of about 25 dB. The puts them right in the middle of the weaker UHF stations so I'd say they doing pretty good for 3KW.
I don't why you didn't see any improvement up north when they moved. What antenna were you using?
Chuck
post #10659 of 10661 Old Today, 03:16 PM
Calaveras's Avatar
Liked: 267
You can always use AM Query:
https://www.fcc.gov/media/radio/am-query
KBRE Merced is on 1660 KHz.
Chuck
post #10660 of 10661 Old Today, 05:25 PM
888CALLFCC's Avatar
Quoted: 212 Post(s)
Liked: 30
Chuck
When I go there. Two things happen. .. (I don't live there)
I bring my own battery tv, with my own antennas. And see what I get.
Then I go inside the house and compare ... with what I installed around 2005... do re-scans, etc.
The house antenna is one of those VU-2-69 "vee" type/style antenna >>>>>> (6 on each side) or 12 for VHF.
Stuffed in a 3 car garage attic, cable goes to a distribution amp before the phone/tv demarcation house cable area.
So antenna is at 13 feet elevation. Everything Walnut Grove comes in excellent. 9,10,40 are borderline overload.
I guess I thought it would be like the old analog KCRA 3 stronger. But it's 40% weaker than RF 9 & 10 at 100%
Honestly don't think they watch that station anyways
For my battery tv tests I use.
Low VHF ...... TERK TV 50 (8 foot stick) sounds like it has tons of wire/fiberglass loops inside. Contains an internal amp that blocks FM.
This model is a standout for low VHF.
High VHF.......Clearstream 5 or RCA 34792
UHF .............Double bowtie or RCA parabolic 34792
post #10661 of 10661 Old Today, 11:54 PM
Quoted: 542 Post(s)
Liked: 82
- Trip
Thanks, Trip!
Larry
