Tallahassee, FL - HDTV - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #1 of 4541 Old 05-07-2004, 06:49 AM - Thread Starter
HAMCO's Avatar
Since the Tallahassee postings have been infrequent under many old headings, I have taken the liberty of starting a new thread. I have put 2004 in the subject line rather than certain months. Both AntennaWeb and TitanTV are listing WCTV DT-46 (analog 6) as being on the air. I believe this is probably an error as I am not receiving any signal from WCTV digital wise. Would anyone in the Tallahassee/Thomasville area have any updates to report concerning WCTV or other stations in the DMA? Thank you.
HAMCO is offline
post #2 of 4541 Old 05-10-2004, 08:38 AM
Ellisfsu's Avatar
Is anyone out there getting a WCTV digital signal? I am hopeful that the titantv inclusion means something is on the way. I sent WCTV an email this morning and will post their response when i get it. --Andy
Ellisfsu is offline
post #3 of 4541 Old 05-10-2004, 08:45 AM
Ellisfsu's Avatar
Well, that was quick... WCTV's reply to my question regardind the timeline for HD launch was..
"We are in high hopes of going to HDTV by the end of June." --Andy
Ellisfsu is offline
post #4 of 4541 Old 05-11-2004, 09:32 PM
bec
bec's Avatar
I posted a link to this thread on one of the other Tallahassee threads. If anyone has information on the status of the other stations it might be good to get it summarized in this thread. The following is based on my understanding of previous posts.
PBS- CH32 is currently at full power and antenna height
NBC-CH2 is currently at full power and antenna height
ABC- CH22 is currently at low power and low on the antenna
CBS-CH46 is not broadcasting but is expected to start by the end of June (see post above)
Channel 24 (UPN I think) is broadcasting. I do not know if they are at full power or not. I have not been able to get more than a blip at my locale (Lafeyette Oaks).
I don't know the status of FOX
Anyone have corrections or updates?
bec is offline
post #5 of 4541 Old 05-11-2004, 09:57 PM
DerekFSU's Avatar
SWEET! We should also maybe list whether or not they are broadcasting in HD. Now I might actually have something to record on my HDTivo. Good news!
Go Noles
DerekFSU is offline
post #6 of 4541 Old 05-12-2004, 06:20 AM
PBSengineer's Avatar
HDTivo - so they are shipping. What I want/need/have to have is a HDTivo that is not tied to direct TV
PBSengineer is offline
post #7 of 4541 Old 05-12-2004, 06:35 AM
FaxMan's Avatar
I recently got a DishNetwork 921 HD DVR. Can't imagine watching TV without it. Now I just need to get an OTR antenna so I can see PBSengineer's feed in all its glory (and the others when they finally get around to it).
I live very near the CH40 station. Maybe I'll volunteer to let them come by to evaluate their HD signal.
FaxMan is offline
post #8 of 4541 Old 05-12-2004, 07:41 AM
sfoltz's Avatar
BEC,
What type of STB are you using? I recently upgraded from the Hughes E86 to the Samsung SIR-T360 and it makes a big difference. With the E86, I had to use a rotor to get all the digitals and I still had major droputs with UPN no matter how I pointed the antenna. Now I'm getting all the digital channels without using the rotor and UPN just has the occasional dropout. My signal meter reads around 45% on UPN. The Samsung definitely locks in to low power signals better than the Hughes.
BTW, I live in Northshire (off Roberts Road) which is approximately 5 miles north from you (as the crow flies).
Scott
sfoltz@ohfc.%com
(remove % to e-mail)
sfoltz is offline
post #9 of 4541 Old 05-12-2004, 07:46 AM
sfoltz's Avatar
Faxman,
I know that you live near WCTV's new station (under construction). Perhaps, you could stop by the site every day and encourage the construction workers to finish the job!
Scott
sfoltz@ohfc.%com
sfoltz is offline
post #10 of 4541 Old 05-12-2004, 08:09 PM
bec
bec's Avatar
Originally posted by sfoltz
BEC,
I have a Mitsubishi SRHD5. I believe it is a early generation STB made by Hughs. I have a Channel Master 4228 with attached pre-amp. I took off the back screen to make it bi-directional. I have a HDTIVO on order and hope it will be able to pull in the signals better. Signal strength is about 15 for ABC ch 22 and am optimistic the channel will come in fine when they turn the juice up and raise the height.
bec is offline
post #11 of 4541 Old 05-13-2004, 08:11 AM
Hammerheadfred's Avatar
The Tallahassee Democrat had an arcticle about Sat vs. Cable this moring. Nothing really new but here is the link.
http://www.tallahassee.com/mld/democrat/8653156.htm
Hammerheadfred is offline
post #12 of 4541 Old 05-13-2004, 10:13 AM
sfoltz's Avatar
BEC,
The Mits. is a clone of my old E86. You may want to try the "$99.00 upgrade deal" via D*'s customer retention. See the lengthy thread in the HDTV hardware forum. I threatened to go to Comcast and got the deal, plus more.
Scott
sfoltz@ohfc.%com
sfoltz is offline
post #13 of 4541 Old 05-15-2004, 09:24 PM
bec
bec's Avatar
BEC,
I have the hd tivo on order so will probably wait it out. I moved the antenna higher today and can now get get 22 reliably. It did not help with 24 which barely shows on the meter. My lot is at a low elevation and is surrounded by trees.
bec is offline
post #14 of 4541 Old 05-16-2004, 06:05 PM
DerekFSU's Avatar
You'll love the HDTivo. I switched from Ultimate TV so I cannot compare this model to the workings of other Tivos but I love it.
Go Noles
DerekFSU is offline
post #15 of 4541 Old 06-01-2004, 09:46 AM
Joseki's Avatar
Does anyone have any info on the ABC station's progress toward full HDTV goodness? I emailed the station manager and got no reply. It is going to be a sad fall season if ABC cannot get MNF up in HD! I absolutely hate Sinclair (and I hadn't even heard of them until moving to Tallahasse last fall.)
David
If one, jump two. If two, jump three.
Joseki is offline
post #16 of 4541 Old 06-07-2004, 12:16 PM
bleibow's Avatar
The notice I received in the mail from Comcast included not only the latest rate hikes, surprise surprise, but also mentioned that Comcast would be adding "several new channels in the next two weeks" does anybody know what those channels are? I'm hoping they include CBS HD, DiscoveryHD, and ABC HD, I know it's a long shot...
bleibow is offline
post #17 of 4541 Old 06-10-2004, 03:17 PM
Ellisfsu's Avatar
Just received an email from WTWC saying they are waiting on delivery of one compnent before they go HD. He estimated July as the month they would begin passing the HD signal.
Ellisfsu is offline
post #18 of 4541 Old 06-10-2004, 03:20 PM
DerekFSU's Avatar
Good news. Saw their sign the other day saying HD was coming soon. Now, if we can just get ABC then we're in business.
Go Noles
DerekFSU is offline
post #19 of 4541 Old 06-12-2004, 06:47 AM
dantz's Avatar
What signals are you able to get locally in Tallahassee?
Has anyone seen a 1080i show broadcast from a station other than PBS?
I'm excited to hear, I'll go out and buy a OTA receiver today if that's the case -- what kind of antenna's would work best in the Southwood area?
TIA,
Dantz
dantz is offline
post #20 of 4541 Old 06-12-2004, 07:03 AM
DerekFSU's Avatar
http://www.antennaweb.org/aw/welcome.aspx
Dantz, you in Southwood? There are at least 3 others in here on HD that I know of. 2 on Direct and 1 on Dish.
Go Noles
DerekFSU is offline
post #21 of 4541 Old 06-12-2004, 08:21 AM
thetoolman's Avatar
I am also HD in southwood, but with Voom.
thetoolman is offline
post #22 of 4541 Old 06-12-2004, 08:55 AM
DerekFSU's Avatar
Wow, Voom in the wood. I'm on Mulberry Park with the "For Sale" sign in front of it, 4th down from 4 Oaks. Southwood is finally coming along.
Go Noles
DerekFSU is offline
post #23 of 4541 Old 06-12-2004, 02:21 PM
dantz's Avatar
So, what channels are you guys getting 1080i broadcasts OTA on in Tally-land? Anything NBC? ABC? CBS? UPN?
TIA
dantz is offline
post #24 of 4541 Old 06-12-2004, 03:37 PM
DerekFSU's Avatar
PBS is the only OTA HD channel that I am aware of. CBS has a "HDTV Coming Soon" sign at their studios and I don't know about the rest.
Go Noles
DerekFSU is offline
post #25 of 4541 Old 06-13-2004, 06:51 AM
dantz's Avatar
That's too bad - yeah, I'm out in Southwood - seems like everyone is moving there or out to Killearn.
I just wish we could get some OTA broadcasts, I want my SuperBowl!!
dantz is offline
post #26 of 4541 Old 06-13-2004, 07:34 AM
DerekFSU's Avatar
What channel is the Superbowl on?
Go Noles
DerekFSU is offline
post #27 of 4541 Old 06-13-2004, 12:25 PM
dantz's Avatar
Superbowl is usually on CBS I think
dantz is offline
post #28 of 4541 Old 06-13-2004, 12:53 PM
DerekFSU's Avatar
You can get that now with either Direct or Dish, I know folks here in the Wood who have CBSHD. They just had to be creative with their service address.
Go Noles
DerekFSU is offline
post #29 of 4541 Old 06-13-2004, 01:30 PM
AFH
AFH's Avatar
No, no you guys have it wrong, re: Superbowl. It was on CBS this year. The Super Bowl from Jacksonville will be on Fox in Feb of 2005. I think that Fox's director or programming was here in April meeting with NFL officials and the Jacksonville Superbowl committee to discuss how Fox will handle the broadcast and what acts may perform at the halftime show.
Also, Fox corporate began in March, sending out contractors to install the hd equipment that Fox will use to broadcast hd in Sept. The equipment consist of a splicer and other relevant equipment. All Fox affils that are broadcasting a digital signal will get this splicer. The installs should be completed by late August and we will be getting glorious hd from Fox for their fall shows and the Superbowl. You can read more about this splicer technology and by doing a search for Fox and splicer over in the programming forum.
One last note, in Sept Fox will broadcast up to 6 NFL games per week in hd. Some weeks Fox will broadcast 7 and some weeks they will broadcast 5 b/c that is all of the games they will have. So no matter where you live, you will at least get to see one hd football game on Sunday as opposed to CBS, where it all depends on what NFL market you are in.
"I'm going to call them scallywags" - Ollie
Xbox Live: Stunt1on1
AFH is offline
post #30 of 4541 Old 06-13-2004, 01:49 PM
DerekFSU's Avatar
Thanks. It will probably be the same situation for us in Tallahassee. Like CBS, unless the local affiliate goes HD, we will not be able to watch it on satellite since our market is not an Owned & Operated market. Hopefully, our local will go HD and I won't have to go to someone else's house who "lives" in Jacksonville.
Go Noles
DerekFSU is offline
