Orlando, FL - OTA - Page 107 - AVS Forum
post #3181 of 3210 Old 08-06-2013, 01:30 PM
270degrees's Avatar
I noticed that Daystar 50 (Analog) has been running a banner that says:
"WDTO is going Digital. Rescan your channels."
They had an FCC CP to go Digital on channel 28 from Bithlo.
But, I get nothing new anywhere.
270degrees is offline
post #3182 of 3210 Old 08-10-2013, 06:51 AM
USFFrank's Avatar
Originally Posted by satpro View Post
RF 28 seems like another one that will be lost in the RF shadow of a full power station like WRDQ RF 27.
In other news, the latest manifestations of both 55.5 and 55.6 have again quickly evaporated, make your own conclusions!
Unless there's something I don't know about (which is probably the case), the Daystar people would be better off selling RF 28 and lease one of WACX's sub channels. Looks like they're up for grabs again. At least they would be on a better signal that no one would watch instead of what they're on now.
USFFrank is offline
post #3183 of 3210 Old 08-14-2013, 06:15 AM
james32746's Avatar
I can get WDTO-LD barely if I turn the FM trap off and turn the preamp gain to minimum on my antenna (an RS VU-190XR). with the antenna pointed towards Bithlo/Christmas. Antenna rotor is broke down in Bithlo/Christmas position so I can't get WESH's translator.
James Westerfield
Lake Mary, FL
james32746 is offline
post #3184 of 3210 Old 08-15-2013, 08:19 AM
270degrees's Avatar
Wow! You're in Lake Mary and you have a hard time. They aim it almost right at you.
After looking at the FCC site, and WDTO (28) directional pattern. I understand why I will never get them.
I'm in Titusville. And they aim almost nothing at me. Even though the Bithlo towers are LOS, 15 miles.
Have always been able to get WDTO analog (50) from Ocoee. They aim that right at me.
When that goes away, guess I will never get Daystar again.
post #3185 of 3210 Old 10-30-2013, 09:08 PM
Lord Zedd's Avatar
I had called Channel 55, They had for a time leased that spot to Rede ITV. I suggest they add HOT TV History of Television.https://www.facebook.com/photo.php?v=631126680247971&set=vb.363957807009695&type=2&theater Here is a video from their Facebook page to those who have FB
Lord Zedd is offline
post #3186 of 3210 Old 11-13-2013, 07:41 PM
Lord Zedd's Avatar
I still have a signal on 31.1, which is the same stuff on 27.3 which seems like a waste of space, with still so many Networks not playing here.
post #3187 of 3210 Old 11-13-2013, 08:03 PM
mgsports's Avatar
Comcast Orlando has Bounce TV on 214 so you can picked it on QAM Comcast.
mgsports is offline
post #3188 of 3210 Old 11-22-2013, 11:52 AM
USFFrank's Avatar
Now WOPX 56-6 is on the air running the Home Shopping Network.
USFFrank is offline
post #3189 of 3210 Old 11-27-2013, 02:35 PM
swatford141's Avatar
Hi!  I'm new to OTA and have been doing a little research.  I'm going to be making a trip over to Orlando form Tampa to help my grandmother drop BHN and switch to OTA.  I did try (about a year ago) to get an OTA signal at her house using a Terk (non-amplified) indoor antenna and was unable to get any channels to tune in.  She lives on the lower level of a condo and only has Northern and Southern facing windows, so I am assuming this is why I could not get anything to tune in.
Ideally I would like to get an outdoor antenna and hook it up where the previous sat. dish was located, and use the pre-existing coax runs (about 75-100ft) to supply an OTA signal to 3 outlets.  I'm really only interested in getting the channels that are in the 59 to 73 range.  What are my best options as far as specific antennas?  Given the distance of coax, I am assuming that I will need to be amplified, correct?
swatford141 is offline
post #3190 of 3210 Old 11-29-2013, 06:20 AM
270degrees's Avatar
All of the High Power stations are at least 20 miles away. You may find that an amplifier helps quite a bit.
The usual problem is multi-path. Only way to help with that is to get the most direct path clear.
As you already have said, that may be difficult in a condo. Hope you can get something pointed at about 75-80 degrees.
The ION (channel 48) WOPX station has a CP to move to Bithlo, but as yet they are still down near Holopaw. (South)
post #3191 of 3210 Old 12-03-2013, 07:25 AM
sdasilva's Avatar
Can anyone help me find an antenna that'll get ABC, CBS, and FOX?  Those are really the only ones that I care about.  I've tried using antenna web and have tried 3 antennas so far.  I couldn't get a single channel using our table top antenna that got all of these channels at our old house 5 miles NW.  Then we tried a Winegard Flatwave antenna and all we were able to get was HSN.  Now we're trying the clearstream 4 and can get 3 of the ION channels (56.1 ION, 56.3 ION life, 56.4 HSN).
All of the channels are within 20 degrees of the ION channels so I don't understand why we cannot get them.  The antenna needs to be in our attic.  Our HOA won't allow it on the roof or outside.
Can anyone recommend a better antenna to try or are we just out of luck?
http://www.antennaweb.org/Stations.aspx?Address=Hield+Road&City=Melbourne&State=FL&ZIP=32904&Housing=S&Accuracy=5&Height=6&Obstructed=False&StationList=&Lat=28.0391229&Lon=-80.6792887
I would greatly appreciate the help!
sdasilva is offline
post #3192 of 3210 Old 12-03-2013, 08:05 AM
ADTech's Avatar
Liked: 27
Federal law, enforced by the FCC, trumps HOA rules. See http://www.fcc.gov/guides/over-air-reception-devices-rule DBS satellite dishes fall under the same protection.
For whatever reason, your antenna is in a shadowed location, whether due to trees, your home's construction, or a neighboring structure.
My guess is that your home includes features that are common in southern Florida, features which may include stucco or stone exterior, radiant barrier insulation, metal roofing, concrete/steel construction, and low-E window glazing. All of these are signal blockers. Looking at a satellite overhead of the street in your antennaweb report, odds are high that you're in one of the residencies with trees to the north northwest , the required aiming direction.
One other note is that Orlando's CBS station operates on a VHF channel and it may not come in with a C4. Other measures may be necessary assuming you resolve the initial problems you're having.
Tech support for Antennas Direct
ADTech is offline
post #3193 of 3210 Old 12-03-2013, 08:36 AM
sdasilva's Avatar
Ok so regardless of the HOA/outside antenna issue, there isn't much that I can do?  I have no trees on my property but yes, just NW there are lots of houses with trees.  I do have low E windows and a ceramic tile roof.  Would another antenna help or should I just give up?
sdasilva is offline
post #3194 of 3210 Old 12-03-2013, 10:58 AM
ADTech's Avatar
Liked: 27
If the signal cannot get to the antenna, then the antenna needs to be moved to someplace where the signal CAN get to it.
You also need to ensure that the front of the antenna, the two loop elements, are facing in the direction of Orlando's towers which are about midway between Orlando and the coast. If the antenna is facing the wrong direction, then the signals are not admitted but are rejected.
Based on the street you live on, the signals are moderately strong. Therefore, whatever the issue is, it's most likely due to one or more of the factors mentioned.
ADTech is offline
post #3195 of 3210 Old 12-05-2013, 06:19 AM
270degrees's Avatar
SDasilva
A few things.
1) The Orlando NBC station WESH is the one on VHF. (channel 11)
2) WOPX (the ION station) has a construction permit to move to the bithlo area.
But have not moved yet. They are still out near Holopaw. (closer to you)
3) All the stations are 45 miles away. Have you tried an amplifier?
4) Low power station WMVJ is less than a mile away from you.
Even though they aim their signal North, you could still be getting some overload.
A very directional antenna (a periodic shaped like an backwards arrow) may help, if that is the problem.
But most of them are several feet long. So you have to plan for that.
Good luck.
post #3196 of 3210 Old 01-24-2014, 05:36 PM
harleyjoe43's Avatar
I noticed that RF 43 (43.1)is showing a new movie channel on 43.2 called Get Tv. My PSIP device is showing listings but no audio or video yet....interesting.
harleyjoe43 is offline
post #3197 of 3210 Old 01-24-2014, 07:57 PM
ejb1980's Avatar
Quoted: 22 Post(s)
Liked: 25
We have had GetTV for sometime in NC. Well, sort of. We've had the promoloop that says "GETTV coming ________" (insert date here.) Currently, it shows GETTV coming February 2014. We'll see. It's been running the same few very classic movies in a loop for honestly like a year!
ejb1980 is offline
post #3198 of 3210 Old 01-26-2014, 10:53 PM
diesel32's Avatar
WKMG 6.2 and 6.3 have been swapped, so Live Well is now on 6.2 and Retro has gone to 6.3
diesel32 is offline
post #3199 of 3210 Old 01-28-2014, 01:40 PM
SQLDBA's Avatar
Hi folks, new forum member living in Celebration...
Ever since Christmas/New Year I've been receiving really poor reception on WESH. I've got an attic mounted UHF antenna (AntennaCraft Y5-7-13) + VHF antenna (Solid Signal HDB8X) combined and connected to an HDHomeRun (HDHR3-US), no preamp. Prior to the holidays, ~80% signal strength, 98% signal quality, 100% symbol quality. After the holidays the signal strength and quality are the same but the symbol quality is bouncing between 0 and 100% and the channel is unwatchable. No hardware or software changes on my end.
For kicks, I removed the VHF antenna from the equation and hooked the UHF antenna directly to the HDHomeRun but saw no improvement in symbol quality. I've also repositioned the antenna but saw no change in reception.
Is anyone else having similar issues with WESH?
SQLDBA is offline
post #3200 of 3210 Old 01-28-2014, 03:18 PM
ProjectSHO89's Avatar
Quoted: 22 Post(s)
Liked: 60
You have UHF and VHF mixed up.
WESH is VHF and should be received by the AC Y5-7-13. All other stations are UHF and should be received by the UHF 8-bay.
You didn't mention how you have them combined, please do so.
Any new electrical or electronic items in or on your home of ANY type?
Which specific antenna did you disconnect?
ProjectSHO89 is offline
post #3201 of 3210 Old 01-28-2014, 04:29 PM
SQLDBA's Avatar
Doh! Copy and paste error on my part providing antenna specifics. They're combined with this: http://www.solidsignal.com/pview.asp?p=UVSJ
One change to electrical devices in the house - swapped the HTPC case and power supply from 150W to 450W.
I emailed WESH to ask if anything's changed on their end and they replied that nothing has changed.
SQLDBA is offline
post #3202 of 3210 Old 01-30-2014, 07:25 AM
270degrees's Avatar
Have you tried to get WESH on channel 18 from Orange City? It is a very good signal here in Titusville. I am 41 miles away.
post #3203 of 3210 Old 01-30-2014, 07:53 AM
SQLDBA's Avatar
Interestingly enough, shortly after hearing back from WESH and without making any further changes on my end (after re-orienting antenna, rebooting, etc. earlier in the day and still having problems), I'm now getting perfect reception again. So...no one changed anything but it's all working again. :rolleyes:
270degrees, Orange City is within range so maybe an option to look into if I run into problems with their VHF transmission again.
SQLDBA is offline
post #3204 of 3210 Old 01-30-2014, 03:55 PM
Lord Zedd's Avatar
The WACX 55.5 Color bar now has this written on the color bar, This Sub-channel available for lease to a capable and qualified programmer Over the air, full Power 24/7 commercial broadcast sub-channel tower height 1749 ft amsl population coverage to 3 million in central Florida contact 407-263-4040 ext 202 with an annoying test noise. I wonder how much they charge, I emailed Retro and suggested they look into it.
http://www.filmon.com/tv/cozi-tv-ny-wnbc-42
This site has affiliates streaming, they have the COZI TV affiliate which we don't have yet
post #3205 of 3210 Old 01-30-2014, 04:57 PM
Trip in VA's Avatar
Quoted: 23 Post(s)
Liked: 56
Send a message via AIM to Trip in VA Send a message via Yahoo to Trip in VA
Retro doesn't lease space. They only do traditional affiliation agreements.
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is online now
post #3206 of 3210 Old 02-06-2014, 03:17 PM
g3burns's Avatar
My thanks to everyone who contributed to this thread, especially "tylerSC" for your suggestion to purchase the Terk HDTVa antenna. I now have the antenna hooked up and I'm able to pull in WESH, all the other channels look much better than they did with my previous antenna, and I'm able to get many new channels.
g3burns is offline
post #3207 of 3210 Old 02-06-2014, 06:10 PM
tylerSC's Avatar
Quoted: 58 Post(s)
Liked: 89
I think the Terk HDTVa is one of the better indoor antennas, and will probably in most cases perform better than those flat Leaf style antennas. Especially with the rabbit ears for VHF which should help with WESH.
tylerSC is offline
post #3208 of 3210 Old 05-26-2014, 09:51 PM
Mitchman's Avatar
What's happened to the rest of this thread, and all the posts since Feb. 6? It was 112 pages and now it's 108 pages.
Mitchman is offline
post #3209 of 3210 Old 07-19-2014, 06:12 AM
Liked: 0
I need some advice.
I live in Viera and just went OTA with an antenna mounted in my attic. I am hooked up to a Tivo Roamio. I get channless 6-1, and 9-1 great but WESH 2-1 only occasionally. According to the Tivo WESH's strength is in the 30's while the other stations are in the 70's.
Would an amplifier solve the problem with WESH and if so which one would be a good buy and get the job done.
Thanks in Advance for your guidance
ketchingup is offline
post #3210 of 3210 Old 07-23-2014, 05:17 PM
HGN2001's Avatar
Adding a reply to this thread so it might stop showing up as unviewed.
It kept showing as a thread in my subscriptions, but every time I viewed it, it ended on page 104. By adding this reply, I can now see the later replies up to page 107.
HGN2001 is offline
User Tag List
