Orlando, FL - OTA - Page 25 - AVS Forum | Home Theater Discussions And Reviews
 22Likes
post #721 of 3412 Old 02-15-2005, 10:54 PM
Kid_Digital_NYC's Avatar
Originally posted by squeeks
WKCF WB18 is still causeing the same problems with my TV, during the HD brodcast of any of their dramas the audio cuts out repeatedly, and sometimes evern resets my TV, this never happens on any other channels.
I e-mailed the address at the begining of this thread, but got no reply, is there anyone else higher up i can e-mail? Its happened 4 times tonight in two hours, and it is getting very annoying.
I've had no problems with WB18 at all.
What's the make and model of your STB/TV?
The few times I've emailed Joe Addalia at WB18 he's always gotten back to me within 24-48 hrs. Heck, one time he replied within the hour. They're easily making a bid in my book for best DTV station in our market.
Kid_Digital_NYC is offline
post #722 of 3412 Old 02-15-2005, 11:23 PM
squeeks's Avatar
Quoted: 43 Post(s)
Liked: 29
Samsung 26" HDTV (TX-P2675WHD) so its got a build in tuner its only been doing this for the past week, and it only does it on WB18-DT, then something ive noticed is WB18-DT goes off the air after 12am
squeeks is offline
post #723 of 3412 Old 02-18-2005, 04:14 PM
squeeks's Avatar
Quoted: 43 Post(s)
Liked: 29
Joe still hasent e-mailed me back :-(
squeeks is offline
post #724 of 3412 Old 02-21-2005, 08:00 PM
Rojma's Avatar
Looks like WRBW UPN 65 is up to no good again. They have moved over their signal to 41-3 and 41-4 and they are not mapping correctly again. Both my HD DirecTivo and my Sony TV are showing nothing on 65-1 but do show it on 41-3. Aren't they supposed to be under compliance? Who can we file a complaint with? I would try and contact them directly but that has obviously done no good in the past.
Rojma is offline
post #725 of 3412 Old 02-21-2005, 08:51 PM - Thread Starter
rich21's Avatar
This is all part of their secret plan to kill the transistion to digital by making their channel unwatchable.
rich21 is offline
post #726 of 3412 Old 02-21-2005, 08:57 PM
squeeks's Avatar
Quoted: 43 Post(s)
Liked: 29
WKMG just pulled a WFTV intrupting their HD boadcast of CSI Miami to show a scroller along the bottom for their local news cast
squeeks is offline
post #727 of 3412 Old 02-22-2005, 07:40 AM
Rojma's Avatar
Well they are succeeding.
Rojma is offline
post #728 of 3412 Old 02-22-2005, 06:58 PM
squeeks's Avatar
Quoted: 43 Post(s)
Liked: 29
WB-18DT has freaked out my TV 3 times tonight in the span of 1 hour Joe hasent e-mailed my back and this is getting very annoying
squeeks is offline
post #729 of 3412 Old 02-22-2005, 06:59 PM
Rojma's Avatar
Well I'll give WRBW credit. They have already fixed the mapping issue. Unfortunately their past reputation had made me prejudge them. Let's hope they keep up the good work. Maybe rebroadcasting Enterprise in HD is next?
My Directivo is also now mapping 30-1, 30-3, and 30-4 properly to 68-1, 68-3, and 68-4. All that is left is 30-2 to 68-2. The only other station left to correct mapping and guide issues is WMFE, and that may be something that DirecTV ultimately has to fix.
Rojma is offline
post #730 of 3412 Old 02-22-2005, 07:05 PM
Rojma's Avatar
I think your problem may be with your TV and it may be something that you need to pursue with the TV manufacturer. I haven't been having any problems with WKCF WB 18 and no one else seems to have reported any problems either. Maybe this is why Joe hasn't responded. He may feel it is a TV problem. Have you contacted the TV manufacturer?
Rojma is offline
post #731 of 3412 Old 02-22-2005, 07:16 PM
squeeks's Avatar
Quoted: 43 Post(s)
Liked: 29
No other station does this, which is why i think its a WB18 issue, but i will take it up with samsung, the TV has picture issues anyway so i might need to exchange it for another one anyway so we'll see what happens there
squeeks is offline
post #732 of 3412 Old 02-22-2005, 07:26 PM
Rojma's Avatar
Maybe the issue is that the signal from WKCF WB 18 is too strong and is overloading your ATSC tuner, causing the TV to shut off. That is just a guess, but I know that the HD DirecTivo's have problems when the signal is too strong. Some users have solved the problem by putting something on the line that actually causes the signal to weaken, such as a splitter. Maybe you can give that a try.
Rojma is offline
post #733 of 3412 Old 02-22-2005, 08:40 PM
squeeks's Avatar
Quoted: 43 Post(s)
Liked: 29
Its not as strong as WFTV-DT and ive never had the problem with that station, the problem is i barely get WKMG so if i weaken it ill lose it actully as im sitting here watching it its jumped up to 9 bars out of 10 its kinda going between 8-9 signal bars, well, next time i sit down to watch Wb for a while ill take the signal booster off and see what happens
squeeks is offline
post #734 of 3412 Old 02-22-2005, 08:56 PM
squeeks's Avatar
Quoted: 43 Post(s)
Liked: 29
If we are still posting when channels have HDTV problems WKMG lost their HD stream of Judging Amy at about 10:53 this evening, its just showing the regular SD version of the show
squeeks is offline
post #735 of 3412 Old 02-22-2005, 09:32 PM
RthurDent's Avatar
Along the same lines, WESH channel 2-1 was not coming in for the first 28 minutes of the 11:00 news. My signal strength was maxed for the channel but I could not get a lock. During this same time their sub-channel, 2-2 was coming in perfectly. I tried to get them on two different HD TV's that use different antennas, so the problem was with WESH.
C-band Satellite Junkie
RthurDent is offline
post #736 of 3412 Old 02-26-2005, 07:33 AM
Barry928's Avatar
Originally posted by Rojma
I can't believe you jinxed it! And Enterprise was getting really good this season! And WRBW finally got their act together and fixed the channel mappings! Man things were going so good. Too good to be true. Can we say "Save Enterprise" writing campaign??? Hell send it to syndication or the Sci-Fi channel if you must!!!!
If anyone is interested in demonstrating in front of WRBW the World Wide Save Enterprise Rally: Orlando is happening on March 12th.
http://www.saveenterprise.com/rallies/orlando.htm
I have never been to a Star Trek convention or anything but I have been a fan of the series for 30 years and the thought of demonstrating against WRBW for any reason appeals to me.
Visit the orlandodigital.tv website
Central Florida ISF Calibration
Barry928 is offline
post #737 of 3412 Old 02-27-2005, 03:42 PM
awaschka's Avatar
Last weekend, WESH locked up my SIR-TS-360 twice. At the beginning of Law and Order SVU I had picture but no audio and the unit was unresponsive to the remote and the front panel controls, except for RESET, which cured the problem. At the end of the show it froze in a partial frame refresh. When I RESET the unit again, WESH-DT was gone....no signal. Next day it was back and OK.
I'm not sure how an incoming signal can lockup the receiver unless there is a software error or a memory leak or overlap between the video and sound FIFOs and the program memory space. Anybody seen this or know the cure?
Al
awaschka is offline
post #738 of 3412 Old 02-27-2005, 03:45 PM
awaschka's Avatar
Here's a copy of the e-mail I sent to the list at the front of this thread. If you feel the same way, maybe you could send it also...
Gentlemen (and Ladies, if any):
I have a request which, I suspect, would be echoed by most if not all of
your subscribers. When you transmit 4:3 program material, please
transmit it in 4:3, 480p or 480i (preferred) or use gray bars rather
than black bars when transmitting in a 16:9 format. When you transmit it
in a 16:9 format such as 720p or 1080i and add black bars, you prohibit
us from watching it in 4:3 and using gray bars to avoid burning in our
monitors. We must either zoom it and miss part of the picture or take
the risk or burning in our screens by keeping the shadow-box area
black. Most monitor manufacturers are now recommending gray bars as the
way to avoid burn in.
Al Waschka
Off-the-air subscriber in Melbourne Beach
awaschka is offline
post #739 of 3412 Old 02-28-2005, 01:26 PM
squeeks's Avatar
Quoted: 43 Post(s)
Liked: 29
aww, i like the black bars though, they are easier on the eyes
squeeks is offline
post #740 of 3412 Old 03-03-2005, 08:14 AM
CPanther95's Avatar
Quoted: 72 Post(s)
Liked: 94
Just an FYI:
New thread was started for Orlando, FL - Adelphia
CPanther95 is offline
post #741 of 3412 Old 03-05-2005, 08:43 PM
Rojma's Avatar
The primary WMFE HD channel is mapping back to 24-1 again. The secondary channel is mapping to 24-4. Seems that WMFE can't make up their mind where they want to be, but at least the channel is back where DirecTV has their guide data for.
Rojma is offline
post #742 of 3412 Old 03-06-2005, 08:40 AM
PeterShipp's Avatar
Al Waschka
I don't agree with your request.
First, it is my understanding that the stations can not hot swap between 720p/1080i and 480i/p. Their encoders simply will not allow this back and forth change. Therefore what they send you is always going to be 720p or 1080i no matter what you are watching. The decision they must make is should we stretch or use pillar bars. I for one am glad they do not stretch.
As for the color of the pillar bars, I think black is the better choice, but I know we could argue this forever. If you look at the future of display devices, they are DLP/LCoS/LCD, none of which burn. For those of you with plasma displays, any good model will allow you to stretch content even if it enters the display already in 720p/1080i formats. If your display does not then hopefully your OTA receiver does (as does newer BH HD receivers). If neither does you should consider either updating one of the two, or simply just be careful how long you watch channels with pillar bars. A few hours at a time in between many hours of total viewing is not going to harm any good quality plasma, and the effect is even less for CRT based devices.
Peter Shipp
ISF, HAA, SBCA, CEDIA Certified
ps@aecustom.com
PeterShipp is offline
post #743 of 3412 Old 03-07-2005, 10:16 AM
jason_j_a's Avatar
"For those of you with plasma displays, any good model will allow you to stretch content even if it enters the display already in 720p/1080i formats. "
Hmm... my Panasonic 7UY doesn't do this and I consider it a "good model".
jason_j_a is offline
post #744 of 3412 Old 03-07-2005, 12:19 PM - Thread Starter
rich21's Avatar
Looks like WBCC's mapping now has everything on 68-x with program guide info too.
Back when the stations first came on the air, WFTV and WESH had gray bars. WFTV had an issues in that theirs always had a thin black gap between the bar and the picture. WESH's bars were really dark gray and they were always playing around trying to put text in there. They also tended to forget to turn off the bars during HD programming. Both finally got rid of the bars all together.
I don't care if the gray bars are there or not, but am very much against stretching.
rich21 is offline
post #745 of 3412 Old 03-17-2005, 08:17 AM
mdh43's Avatar
has any one heard if WKMG in Orlando is going to multicast any additional NCAA basketball games this weekend? I understant CBS 10 in Tampa is going to, but here in WinterHaven I can not get Tampa 10. sorry this did not go in Orlando thread for some reason. is there any way to move it there.
mdh43 is offline
post #746 of 3412 Old 03-17-2005, 09:56 AM
CPanther95's Avatar
Quoted: 72 Post(s)
Liked: 94
Merged
post #747 of 3412 Old 03-17-2005, 11:24 AM
mdh43's Avatar
I can answer my own question. CBS 6 is multicasting the ALA-UW Mil game now. They took the news and weather feed off. Thanks WKMG.
mdh43 is offline
post #748 of 3412 Old 03-17-2005, 06:13 PM
Doctor52's Avatar
Location: Ormond Beach (Daytona Beach suburb, Orlando viewing area)
WKMG is showing the game in HD on 6.2, why are the showing the same thing in SD on 6.1? I can understand showing different games in SD, but it's waste of bandwidth to show the same thing on both subchannels.
JD
Doctor52 is offline
post #749 of 3412 Old 03-18-2005, 06:00 AM
mdh43's Avatar
Doctor52, I noticed the same thing why carry the same game, and the SD feed was not very good quality. I see tonite 6 is carrying the Syracuse game same time as the Duke game and the rest of the day they are carrying same game on both feeds?
mdh43 is offline
post #750 of 3412 Old 04-01-2005, 06:16 PM
james32746's Avatar
Where did everyone go,
There has been no activity since March 18th. And WMFE-DT PSIP has screwed up again.
James Westerfield
Lake Mary, FL
james32746 is offline
