Orlando, FL - OTA - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 30Likes
post #181 of 3359 Old 08-08-2004, 05:54 PM
PeterShipp's Avatar
Originally posted by ddeloach
Peter: since you are working with VOOM, do you have any thoughts on this?
I don't. Haven't gotten a unit set up for myself, so I can't say I'm familiar with the updates they are doing.
Originally posted by samsterdog
Which AP preamp do you recommend? 8700? 4700?
Depends how long you are going between the antenna and receivers. I use the 8700 normally, and the 8725 if its a long run with lots of splitters and receivers. They key to remember is you don't want to overdrive your receiver, it will act as if the signal is low. Try the 8700 and you should be fine, at about 17dB gain even if its real close to your receiver it probably will not overdrive it. I have never used the 4700, and I can't remember what I usually get on 11, the only benefit would be if you were getting at least -5 dB at the antenna which I don't think has ever happened to me. I would try nothing first. This is the chart with all the pre-amps. http://www.winegard.com/offair/pdf/Chart29.pdf Remember, ultimately, you can't choose what amp you need unless you know what you have at the antenna and you need a meter for that, so everything else is guess work. Hope that helps.
Peter Shipp
ISF, HAA, SBCA, CEDIA Certified
ps@aecustom.com
PeterShipp is offline
post #182 of 3359 Old 08-14-2004, 08:39 AM
RthurDent's Avatar
Anyone receiving digital channels 2, 6, 18, 24, 27, 30, 35, 41, or 56 this morning?
I mean from OTA.....I have checked....getting only 9 and 15 and both have good signal. All the rest have no signal at all.
They were on all during the storm last night....now they are gone.
C-band Satellite Junkie
RthurDent is offline
post #183 of 3359 Old 08-14-2004, 09:47 AM - Thread Starter
rich21's Avatar
41-1, 15-2 and 18-1 were on last night, the others in your list were off the air when I checked around 11pm. 15-1 had no picture and 15-2 had no sound. 41-1 was showing the WOFL news. 18-1 looked like it was running on reduced power and was breaking up pretty badly. 18-1 was better this morning before they went down. 41-1 was up earlier this morning. Probably doing work at the tower (WESH, WRBW, WBCC, WECU & WKMG share the same DT transmitter site)
Kudos to WFTV-DT for managing to stay on the air even when the power went out at the station.
rich21 is offline
post #184 of 3359 Old 08-14-2004, 12:06 PM
Thats Classified's Avatar
9-1 is all I'm getting on my OTA currently...glad to hear it's not just me.
Thats Classified is offline
post #185 of 3359 Old 08-14-2004, 04:34 PM
sysebo's Avatar
Boy, I am really regretting not being able to watch/record the Opening ceremonies last night and today. I am not in an NBC O&O market, so Iam not able to catch it on D* ch. 84, and our NBC OTA reception has been out since last night (Hurricane Charlie). So no NBC HD coverage at all!
Sysebo
sysebo is offline
post #186 of 3359 Old 08-14-2004, 06:58 PM
james32746's Avatar
ON:
WOTF-DT 20
WBCC-DT 30 (carrier only)-UPDATE 8/15: All programming is back
WCEU-DT 33
WFTV-DT 39
WRBW-DT 41 (returned to the air 8/15 @ 9:00 PM)
WOPX-DT 48
WVEN-DT 49
WKMG-DT 58 (but subchannel is blank) (returned to air 8/14 @ 7:55 PM)
All Analog Stations (except for 24)
OFF:
WESH-DT 11
WRDQ-DT 14
WKCF-DT 17
WOFL-DT 22
WMFE-DT 23
WMFE-TV 24
Unknown:
WACX-DT 40*
*There is no way for me to check because of VERY EXTREMELY LOW POWER of WACX-DT
James Westerfield
Lake Mary, FL
james32746 is offline
post #187 of 3359 Old 08-15-2004, 07:48 AM
I'm getting 6-1 & 9-1 now. Still nothing on 2, 18, or 35...
post #188 of 3359 Old 08-15-2004, 09:38 AM
dtv4u's Avatar
For those interested, WOFL-DT and WRBW-DT were taken off air voluntarily to conserve fuel for the analog transmitters, since both transmitter sites are running on emergency diesel generators until FPL can restore power, which may take several days. This was done because it was unclear when deliveries of more fuel could take place. Those deliveries have now been started and it is likely that the digital transmitters will go back on-air soon. Thanks for your patience.
dtv4u is offline
post #189 of 3359 Old 08-16-2004, 11:44 AM
Crashdsp's Avatar
It is getting closer to football season, and I need to get an OTA antenna installed. I know I asked this already, but does anyone know a company that will do this? I am not having much luck finding one. I live in the Winter Garden Area. I would really appreciate it. I want to get MOnday night football in HD.
Frank
Crashdsp is offline
post #190 of 3359 Old 08-16-2004, 01:23 PM - Thread Starter
rich21's Avatar
Private message aforlano or PeterShipp they're in the business but tend not to push their business on this forum.
rich21 is offline
post #191 of 3359 Old 08-16-2004, 09:36 PM
Rojma's Avatar
I'm still showing the following channels down:
WESH-DT NBC 2.1 11
WRDQ-DT IND 27.1 14
WOFL-DT FOX 35.1 22
WMFE-DT PBS 24.1 23
Everyone else showing the same thing? I wish WESH NBC would come back up so we could get the Olympics in HD. I know there are bigger concerns out there these days but it still would be nice...
Half of the reason I got this HD Tivo so quickly was to get the Olympics in HD (Football being the other half).
Rojma is offline
post #192 of 3359 Old 08-17-2004, 04:34 AM
donsullivan's Avatar
I'm still showing the same channels down. The only saving grace is that at least the Olympics in HD are available on DirecTV (84). Granted it's a 1 day delay but at least I'm getting something.
donsullivan is offline
post #193 of 3359 Old 08-17-2004, 05:05 AM
Rojma's Avatar
My dish is down and got damaged due to Charley so off air is my only option for Olympics right now. However, DirecTV is coming by today to replace the dish for free! Didn't know we qualified to get channel 84, so I guess I'll be watching the Olympics in HD later today!
Rojma is offline
post #194 of 3359 Old 08-17-2004, 07:22 AM - Thread Starter
rich21's Avatar
The nice thing about WESH-DT being down is that I can see WINK-TV in Ft Myers in the morning/evening to see what is happening down there.
rich21 is offline
post #195 of 3359 Old 08-17-2004, 11:55 AM
Rojma's Avatar
Huh? You can pick up Ft. Myers stations from Melbourne? How far is that?
Rojma is offline
post #196 of 3359 Old 08-17-2004, 12:19 PM - Thread Starter
rich21's Avatar
Well outside of reliable reception. Its normal Fl tropospheric progation. That's why it comes in during the morning and late evening when the noise level and atmospheric layers are low.
http://www.iprimus.ca/~hepburnw/tropo.html
http://www.tpub.com/content/neets/14...s/14182_96.htm
rich21 is offline
post #197 of 3359 Old 08-17-2004, 04:21 PM
Rojma's Avatar
Wow cool. And I've been beating my head trying to get Tampa stations from Orlando (towers are only 60 miles away).
Rojma is offline
post #198 of 3359 Old 08-17-2004, 04:35 PM
Looks like WESH-DT is back up again.
post #199 of 3359 Old 08-17-2004, 04:53 PM
Rojma's Avatar
Woohoo!! Time to go watch the Olympics.
Rojma is offline
post #200 of 3359 Old 08-17-2004, 05:57 PM
Kid_Digital_NYC's Avatar
Of the MIA stations looks like WESH-DT and WOFL-DT are back, but now WKMG has gone MIA.
Kid_Digital_NYC is offline
post #201 of 3359 Old 08-17-2004, 06:53 PM
leighnjo's Avatar
It appears they are showing the same thing as 84 and the D* local channel 2 is showing different programming!
leighnjo is offline
post #202 of 3359 Old 08-18-2004, 07:43 AM
ctbjr1309's Avatar
My longtime satellite installer has moved away. I need to find a replacement.
I have what I consider to be a fairly complicated set up which includes C/Ku Band (4dtv receiver - currently not working), HD DirecTv with 1 HD DirecTv TiVo and 2 non-HD DirecTv Tivos, and OTA antenna for local reception of digital signals.
I live near downtown Orlando. I recognize that this is a bad time to be looking for somebody new but if anybody here can help or can refer me to somebody who can, please PM me.
Many thanks in advance.
ctbjr1309 is offline
post #203 of 3359 Old 08-18-2004, 12:07 PM
lombana's Avatar
That's exactly what's going on ... the feed on D* 84 is the official NBC HD feed and it's being picked up on 2.1, 2.2 is showing regular Olympic programming for the day that's been cut up for prime time air.
I too was ticked when 2.1 was down then when I found 84 I was ok as I got to see coverage and it was in HD which I would rather watch over the daily SD feed anyday.
lombana is offline
post #204 of 3359 Old 08-18-2004, 03:05 PM
BearGator56's Avatar
Quoted: 72 Post(s)
Liked: 38
Just wanted to post about the bad experience I'm having with Mastec-the Orlando DirecTV installer.
If you can avoid using these guys-I would do so. The first tech they sent out had no concept of putting the OTA antenna in the attic. He also wanted to re-mount my new HD dish on the roof, drilling holes through my shingles(doubt it would be there now if he had since Charley came through).
I currently have a dish with a 99 signal on the side of my house. Clear view of the sky-shouldn't be an issue.
Then, he looks at my new Mitsu DLP and doesn't want to touch it because it looks too expensive. He was afraid to break it! This is someone who installs DirecTV for a living!
So I send this guy packing and set up an appointment for this past Monday between 8-12. Monday rolls around, and still no confirmation from Mastec that a guy is coming. I call at 10:40. They have no record of my appointment. I speak to a supervisor, who promises to have a guy out by the afternoon. 3pm comes, and I call again. The supervisor tells me they can't get to me. So I set it up for the next day-at 5pm since I can't just keep getting time off of work for this.
So 5pm Tuesday... Just my luck, a bad lightning storm. The tech is there. This time I'm understanding, and I don't want this poor guy out there in the bad weather. So, I set it up for today at 5pm again....
I call Mastec at 3pm to confirm with the supervisor that someone will be there at 5. Supervisor seemed a little confused and said he would call me right back. No call back by 4:30. I call, and get put on hold. Told the supervisor was on the other line and he would call me back.
5:25....no call. I call again, and get a hold of Mr. Supervisor one more time. Then he tells me that he forgot to put my appointment in the computer because he wasn't in front of a PC at the time!! So now, I have to set it up for one more time tomorrow. Unbelievable.
I called DirecTV and told them if this happens one more time, I may just switch to Brighthouse. What would you do?
BearGator56 is offline
post #205 of 3359 Old 08-18-2004, 03:09 PM
PeterShipp's Avatar
Use a reputable small local installer. There are several good ones in the area that are DirecTV authorized.
Peter Shipp
ps@aecustom.com
post #206 of 3359 Old 08-18-2004, 03:54 PM
I'm watching the Olympics on WESH-DT right now and the difference between now, (when they don't have the sub channel stealing 4Mbps from the HD feed) and primetime last night, is astounding. I wish they'd dedicate all 18.4Mbps to the HD feed through primetime.
Kudos to the WESH-DT staff for at least giving us a good picture during the day.
I wonder if the network mandates the use of the sub channel during prime-time?
post #207 of 3359 Old 08-18-2004, 06:38 PM
mike.cf's Avatar
You're right Kid, the picture is horrible right now. I was watching in the afternoon and it looked very good. Multicasting blows...
Mike
mike.cf is offline
post #208 of 3359 Old 08-18-2004, 11:43 PM
Mitchman's Avatar
ctbjr1309, Try Kissimee Music & Satellite (you might have to wait a couple of days, I don't know if they have power back yet). I don't know if they cover downtown Orlando or not but they are one of the only C-Band installers still around.
Mitchman is offline
post #209 of 3359 Old 08-19-2004, 10:47 AM
ctbjr1309's Avatar
Thanks for the suggestion, Mitch. I'll give them a call.
post #210 of 3359 Old 08-19-2004, 05:13 PM
Quoted: 72 Post(s)
Liked: 38
Well, finally got my HD installed....minus the OTA antenna because Mastec prohibits attic installations. WTF, over?
The guy left the antenna behind, and I guess I'll wire the thing up in the attic myself. For now, I just have it attached and sitting there. Works, but not great reception. It was a Winegard Sensar antenna. Kind of looks like a glider, or a spaceship off of some b-movie.
The box was a Samsung. HDnet, DiscoveryHD both have beautiful pictures. NBC WESH 2(OTA) was also very good with the Olympics. I can't wait to see some football.
More about the installation... The dish was mounted just right. 2 sats have a 100 signal, and one had a 98. I had a 99 before in the same location, so I'm happy.
After inspecting the tech's hookup, I was dumbfounded. He hooked up EVERY set of wires the Samsung came with to my TV, except for the DVI(he didn't have an adapter for the HDMI input). So he hooked up 3 component inputs from the box to the TV, AND the old S-Video. I yanked everything off except for the one component I needed to make it work.
Peter, I sent you an e-mail last week about possibly taking over the install from Mastec, but didn't get a reply. I'm still thinking about the Denon 2910, though!
