Johnstown, PA - HDTV - Page 115 - AVS | Home Theater Discussions And Reviews
 10Likes
post #3421 of 3433 Old 05-22-2015, 07:46 AM
mvcg66b3r's Avatar
Quoted: 28 Post(s)
Liked: 1
Originally Posted by PA_MainyYak View Post
So in answer to your question, the change in programming does not trigger a renegotiation.
What about changes in ownership?
One person's craziness is another person's reality. - Tim Burton
mvcg66b3r is offline
post #3422 of 3433 Old 05-22-2015, 08:18 AM
PA_MainyYak's Avatar
No. New owners inherit contract terms and conditions.
ÂOne of the few good things about modern times: If you die horribly on television, you will not have died in vain. You will have entertained us.Â
- Kurt Vonnegut
-0-
PA_MainyYak is online now
post #3423 of 3433 Old 05-28-2015, 04:04 PM
Nokorola's Avatar
Originally Posted by stingray2772 View Post
I'm not sure if this is the correct place for it or not, but I have a few questions about OTA.
I live in Houtzdale and am using an ANT-751 in the attic (actually picked it up a few years ago at Lowes for about $10). Since then I've been getting CBS(WTAJ), ABC, Fox, and This... and recently have been getting AntennaTV. My question to everyone is, are there other channels that I *could* get? I'm a complete noob. I took my cell phone up in the attic, aimed the Antenna and checked that I received the channels. My wife is against having an 'ugly antenna hanging off the roof' but if it is a matter of possibly upgrading antenna then that might be possible. I checked out the Mohu Sky but I would be hesitant to spending that much money only to find out no additional channels can be added. I do have a split in the basement running the signal to two different televisions. Ideally at some point I would like to split the signal to 3 or 4 televisions. I currently do not have an amplifer. I have a ranch home, and the cable runs about 15' then down from my attic to my basement, splits, then goes back up to the first story for the first TV. Unfortunately I can't remember exactly which way I have the antenna pointed... though I believe it is 196 degrees (pointed towards Altoona).
I would love to have NBC.
TV Fool
AntennaWeb shows the following signals...
WATM-DT 23.1 ABC
RF Channel: 24
19 miles at 196° Blue
WHVL-LP 29 MNT
RF Channel: 29
20 miles at 72° Blue
WPSU-DT 3.1 PBS
RF Channel: 15
21 miles at 346° Blue
WTAJ-DT 10.1 CBS
RF Channel: 32
WHVL-LD 29.1 MNT
RF Channel: 27
20 miles at 72° Violet
WKBS-DT 47.1 CTV
RF Channel: 46
19 miles at 196° Violet
If this isn't the right place for this, just let me know. If you can offer any input on me receiving NBC or any additional channels I would appreciate it.
I'm not sure how it would translate to your antenna and situation, but I have my antenna mounted in the attic, and I have it pointed vaguely toward State College, allowing me to receive WHVL (and occasionally WJAC's State College transmitter), and to receive the Altoona stations off the back-ish side. With this setup, I can receive all the local stations (excepting WWCP's Johnstown signal and WPCW in Pittsburgh) including WPSU (3.1-3.3), WJAC (6.1-6.3), WTAJ (10.1), WATM (23.1-23.4), WHVL-LP (analog), WHVL-LD (29.1-29.2), WKBS. Good luck.
How can I be sure in a world that's constantly changing?
Nokorola is online now
post #3424 of 3433 Old 05-28-2015, 07:22 PM
RedPenguin2's Avatar
Anybody know why GRIT6 puts a huge GRIT logo for station identification?
I know the FCC likes to require station ID and I can see if you do it like WTAJ does at the bottom of the screen.
Though, this seems like somebody got a tad carried away.
http://dl.dropbox.com/u/5544258/grit.png - With GRIT ID
http://dl.dropbox.com/u/5544258/grit2.png - Without GRIT ID
ALSO
Looks like ABB has added the new "NewsMax TV" channel.
It popped up at 63.6 and is encrypted and with a CableCard set for the Value Package was able to watch it.
It's not completely setup with a channel number or name yet, so you will not yet see it on STBs.
Appears to be 1080i and be a conservative news outlet like Fox News, though does sound like it has some good documentaries...
RedPenguin2 is offline
post #3425 of 3433 Old 05-29-2015, 08:54 AM
Newsmax showed up on chan 76 this morning but was dropping in and out. I guess they are still tweaking and adjusting.
As for the big Grit logo, I guess they want to build viewer identification. The only info the FCC requires is call letters and city (cities) of license.
- Kurt Vonnegut
-0-
post #3426 of 3433 Old 05-29-2015, 10:39 AM
That's where I see it now.
For some reason a TVGuide service I used called SchedulesDirect acts like we have 76 and 776 but I don't see any evidence of 776.
Though what's confusing is, when I was checking out the channel that's IDing as 76 now, it was putting out and HD signal as it's resolution was 1920x1080......
post #3427 of 3433 Old 05-29-2015, 10:47 AM
chum1976's Avatar
One channel ABB should add is Weather Nation. I was visiting relatives who have dish network and while the Weather Channel was showing reality shows all day Weather Nation was covering live severe weather.
chum1976 is offline
post #3428 of 3433 Old 05-29-2015, 11:16 AM
The picture on 76 fills the screen, but they're not yet sending metadata, so I cannot tell what resolution is used. It would not shock me to see more HD channels real soon, as ABB has recently started injecting local commercials on HD channels.
As for weather, there are several better alternatives to the Weather Channel, but none have managed to gain wide distribution.
- Kurt Vonnegut
-0-
post #3429 of 3433 Old 05-29-2015, 11:53 AM
Seems for some reason ABB knocked it down to SD at 720x480.
ABB Customer Service acts like there will not be an HD after all. At least for now.
Official launch date is Sunday.
EDIT: I am confused by something though. NewsMax seems to be included in the "Value" package, but the Value package in analog. So I guess it will be like Velocity where you technically get it, but only if you have a CableCard or STB.
It's on Ch 63.6, in an area that only Value and beyond subscribers could access, so I am surprised they aren't leaving it clear. In another area, they leave OWN in ClearQAM.
post #3430 of 3433 Old 06-07-2015, 04:47 PM
Anybody know why Sinclair/WJAC is still airing American Sports Net on MeTV/DT-2?
I thought they would most likely move all the programming to GRIT/DT-3.
post #3431 of 3433 Old 06-08-2015, 01:32 PM
Jake V's Avatar
TV Fool
WATM-DT 23.1 ABC
RF Channel: 24
WHVL-LP 29 MNT
RF Channel: 29
WPSU-DT 3.1 PBS
RF Channel: 15
WTAJ-DT 10.1 CBS
RF Channel: 32
WHVL-LD 29.1 MNT
RF Channel: 27
WKBS-DT 47.1 CTV
RF Channel: 46
1. The ANT-751 is not the best antenna for your location and signals.
2. Your NBC station (WTAJ - Real Channel 22) is at 207 degrees. I'd get a compass and point your antenna in that direction and see what you get. Typically, however, an attic antenna looses at least 20 dB, making channels that are not "green" in the TVFool Report unlikely. And if you have a stucco house or it is wrapped with something with foil it can be worse.
3. The Mohu products are OK but not great. I would not recommend one for your application. Even though your ANT-751 might not be the best recommendation for your location it will gather much more signal if you get it outside with a good view towards the SSW.
4. You might post your question on the forum at TVFool.com.
Jake V is offline
post #3432 of 3433 Old 06-09-2015, 05:19 AM
Just FYI, the NBC station is WJAC (6.1, 6.2, 6.3; RF 22). WTAJ is the CBS station (10.1; RF 32). Their respective transmitters ( as well as that of WATM, the ABC and FOX stations (23.1, 23.2, 23.3, 23.4; RF 24)) are located on the same antenna farm on Wopsononock Mountain near Altoona. While the WJAC translator operates at a much lower power output than either WATM or WTAJ, I suspect your existing setup might pull it in, if as suggested above, your antenna is aimed correctly. The compass method is certainly valid, but you might also use your TV's signal meter to find the highest signal level on WTAJ or WATM. Then you can try to lock in WJAC's signal. Granted, the built in signal meters offer only a rough guide, but I have used this method with some success over the years.
Nokorola likes this.
- Kurt Vonnegut
-0-
post #3433 of 3433 Old Today, 02:17 PM
Nokorola's Avatar
I see that WPSU has made 3.2 and 3.3 16x9. Create is the correct aspect ratio, but World is stretched, at least right now while NHK Newsline is on. Either way, it's nice to see shows presented in their native aspect ratio, even on my SD 4x3 TV, and it'll also fix the annoying times when the show is 16x9 (like POV) while the specific episode/content is 4x3. I'd still like to see WTAJ make an agreement with WPCW, or add an ION+ channel (even though neither would inherently be in their interest. I was happy with just a main channel on every station though. :-).
