Norfolk, VA - Cox - Page 282 - AVS Forum | Home Theater Discussions And Reviews
post #8431 of 8648 Old 01-19-2014, 11:04 AM
lupi95's Avatar
Not sure what they've done, but went to open the app on the tablet to watch some pregame stuff while games being played on the TV and it tells me I must update. Hitting update directs to some music app. Can't get the contour app to appear in the play store so I find the exact address on the pc and type it in on the tablet. At this point it tells me I can't install the app as it isn't compatible. So they now have this nice app they draped with this "contour" crap and now you can't connect at all.
lupi95 is offline
post #8432 of 8648 Old 01-21-2014, 07:48 AM
crippldogg's Avatar
Quoted: 37 Post(s)
Liked: 47
What's the most current DVR model that cox offers for the Hampton Roads area?
The Weekend Warriors
crippldogg is offline
post #8433 of 8648 Old 01-22-2014, 02:08 AM
Bryan_CoxPHX's Avatar
Quoted: 112 Post(s)
Liked: 52
Record 6 DVR - With Contour Whole Home (I do not know what the newest is w/o Contour)
http://ww2.cox.com/residential/tv/dvr.cox
It is a Cisco 9865HDC
http://www.cisco.com/en/US/prod/collateral/video/ps11488/ps12334/ps12291/9800_multi-screen.pdf
TiVo Bolt, Roamio Pro, Premiere XL4, Premiere 2TB-WD20EURS, TiVo Mini
Cisco Tuning Adapter Status Troubleshooting
Bryan_CoxPHX is offline
post #8434 of 8648 Old 01-25-2014, 09:29 PM
hokiewolf's Avatar
My Mom's VCR in the past few weeks has been displaying an erratic time. She has Cox's most basic service 68-70 channel service. Does anyone know if any of the local affiliates still broadcast a time-synchronization schedule. It used to be WHRO. Up until a few weeks ago her VCR would automatically correct itself at 9pm each evening. Mom,at age 88, rarely records anymore and basically uses the VCR as another clock. When I went to manually set the time and date, it had the year as 2043. Go figure.
hokiewolf is offline
post #8435 of 8648 Old 02-09-2014, 02:34 AM
Nmlobo's Avatar
My normal DVR startup channel selection is for channel 1010. For the past several days the DVR has started on channel 895 - this channel is identical to 1010. The preference section of the DVR reports 895 as the startup channel,- - when I change it back to 1010 it automatically reverts to 895. Is anyone else experiencing this?
Nmlobo is offline
post #8436 of 8648 Old 02-09-2014, 01:45 PM
domino92024's Avatar
Quoted: 126 Post(s)
Liked: 216
When you set the start-up channel, you are actually setting the start-up frequency/slot. The way the DVR is mapped, channel 895 is mapped as the main channel with channel 1010 mapped as a duplicate. I'm guessing, but are these
channels somehow related to NBC's Olympic coverage? If so, things will return to normal after the Olympics. Cox bundled all of NBC's Olympic channels in the 895-899 slot.
domino92024 is offline
post #8437 of 8648 Old 02-09-2014, 01:58 PM
Quoted: 126 Post(s)
Liked: 216
Cox's last non Trio (Contour) DVR is the 8240HDC/8300HDC. From there, there are the 8642HDC/8742HDC DVRs, which are Trio (Contour) 1GHz/H.264 DVRs. All new DVRs will be Trio (Contour) 1GHz/H.264 machines.
post #8438 of 8648 Old 02-09-2014, 02:29 PM
Nmlobo's Avatar
Thanks, but I doubt this has anything to do with the games. I can't think of any reason that it would. My DVR now indicates that nbchd is on chan 10, 895, and 1010. I am sure you are correct that 895 is the actual channel because no matter if I select 10 or 1010 as a startup channel, it will start on 895. A few other channels are the same way, us and, cbshd to name a couple. It seems strange.
Nmlobo is offline
post #8439 of 8648 Old 02-09-2014, 09:53 PM
Quoted: 126 Post(s)
Liked: 216
895 will disappear soon after the Olympics. You think it's a coincidence that the 890-899 channels all are duplicates of NBC Olympic channels and that they appeared just before the Olympics started?
post #8440 of 8648 Old 02-10-2014, 02:35 AM
Nmlobo's Avatar
You likely are correct, but what would be the purpose of duplicating channels? The guide now shows several channels appearing in three different places - >100, 890s, and 1000s. The channels between 800-899 are not all NBC duplicates - CBS, MSN, BBC, applear as well.......both in SD and HD. Oh well, it is not harming anything its just a nit.
Nmlobo is offline
post #8441 of 8648 Old 02-10-2014, 12:56 PM
Quoted: 126 Post(s)
Liked: 216
I can only speak to the dozen or so channels ending in 899. NBC is showing the Olympics on 5-6 NBC Universal channels - NBC, MSNBC, CNBC, USA, NBC Sports, etc. Normally, the SD version of these channels are located scattered about in the channel 2-100 range, with the HD version scattered about in the channel >1000 range. For the Olympics, Cox has duplicated all of these channels bunched together in the 890-899 range. This is to make it easier for the Olympics viewer to "channel surf" NBC's coverage.
Cox also has extensive sport specific coverage in its "2014 Sochi Olympics" VOD area.
post #8442 of 8648 Old 02-14-2014, 11:14 AM
lupi95's Avatar
He's right. We noticed it the other day when going to 10 and then using the up/down buttons and finding out we were no longer starting in the right place. Wouldn't be surprised if nbc got them to do it via some incentive as I'm not sure what direct benefit cox gets from this.
lupi95 is offline
post #8443 of 8648 Old 02-14-2014, 12:35 PM
Quoted: 126 Post(s)
Liked: 216
It's so the customer can simply scan from 890-899 and determine if there is any Olympic coverage on at that time. BTW, received an e-newsletter this morning from Cox trumpeting their channel 890-899 block, VOD coverage, and other ways that they're bringing the "upcoming" Sochi Olympics to us. Only 8-9 days late, Cox.
post #8444 of 8648 Old 02-15-2014, 02:26 AM
Nmlobo's Avatar
Late or not - - - At least you received a notice.......I've received nothing from them on Olympic coverage.
Nmlobo is offline
post #8445 of 8648 Old 02-20-2014, 11:09 AM
fdxorf's Avatar
I know this is a Cox forum, but are there any Fios users lurking in here....With the onslaught of rate increases, I am seriously looking to jump ship
fdxorf is offline
post #8446 of 8648 Old 02-20-2014, 12:18 PM
VARTV's Avatar
Quoted: 71 Post(s)
There is a FiOS forum for HR... been quiet over there though...
Robert F Corbin
VARTV.com | Virginia Media News & Information
email: editor@VARTV.com
facebook: facebook.com/VARTV
twitter: twitter.com/VARTV
linkedin: linkedin.com/in/VARTV
google+: plus.google.com
pinterest: pinterest.com/VARTV
VARTV is offline
post #8447 of 8648 Old 02-23-2014, 04:56 PM
dtv757's Avatar
local FIOS thread. http://www.avsforum.com/t/869878/hampton-roads-va-verizon
MY COMMENTS ARE MY OWN PERSONAL OPINIONS AND IN NO WAY SHAPE OR FORM REPRESENT
Bell Atlantic or its Subsidiaries
dtv757 is offline
post #8448 of 8648 Old 02-26-2014, 10:33 AM
lupi95's Avatar
I was thinking about it. Main reason I haven't is I've just about completed shifting over to homerunprimes instead of cable boxes and fios cable cards cost twice as much as cox.
lupi95 is offline
post #8449 of 8648 Old 03-02-2014, 06:52 PM
CyNor's Avatar
Just saw the FIOS commercial comparing there speeds against Cox saying that they are faster but in the fine print they was using 500mb download to Cox 100mb. That isnt a fair test at all. Come on what home needs 500mbps.
CyNor is offline
post #8450 of 8648 Old 03-03-2014, 01:04 PM
fdxorf's Avatar
I just swapped out my Motorola HDDVR box with a new Cisco box. I have the box that supports the "Contour" service but I don't have the "Contour" service....On March 1st, Cox did away with the Contour fee and now allows customers to get the box without the extra fee...I am getting the 2 record vs the 6 record....Question...The store rep gave me a filter that I needed to put on back of the box and the cable plugs into this filter. What exactly does this filter do??? Does this prevent me from using the 6 record option?? I asked the rep what it was for and she said it was "above her technical knowledge"... I was later on an online chat with tech support and they said it was to reduce static interference...No sure I buy either one of those answers.
fdxorf is offline
post #8451 of 8648 Old 03-03-2014, 05:11 PM
CyNor's Avatar
The filter is called a MOCA filter. It is needed only when you have your boxes networked. since you don't have them networked it isn't needed. I had the filter screwed straight to my dvr and when I was changing around my entertainment system I bumped into it and broke the cable port. So when I swapped mine I didn't put one back on.. I spoke with a Cox tech and that is how I found out it wasn't needed
CyNor is offline
post #8452 of 8648 Old 03-04-2014, 11:43 AM
fdxorf's Avatar
Thanks, I quickly realized that with the filter installed that I wasn't receiving all the channels I was supposed to be getting. Plus my picture would intermittently go black and I wasn't getting program info on the guide. I removed the filter and everything is good...Just trying to figure out why the store rep gave it to me. She knew exactly what I was getting.. Kind of frustrating
fdxorf is offline
post #8453 of 8648 Old 03-04-2014, 12:05 PM
Quoted: 126 Post(s)
Liked: 216
Contour is nothing more than a renamed Trio IPG. And a reason for Cox to call various things "Contour" and charge more for them.
post #8454 of 8648 Old 03-04-2014, 12:52 PM
fdxorf's Avatar
Was told as of March 1st, the Contour fee is no more....Not enough people getting so they now offer the same box that includes the extra channels that the Motorola boxes didn't have. I swapped out 4 boxes for 4 Contour boxes....Didn't cost me a dime
fdxorf is offline
post #8455 of 8648 Old 03-04-2014, 01:23 PM
Quoted: 126 Post(s)
Liked: 216
There are/were numerous fees associated with "Contour." Also, no such thing as a "Contour box." The Cisco 8642HDC, Cisco 8742HDC, and Cisco 9865HDC all have Trio (Contour) as their IPG. Are you saying that Cox no longer charges $9.99/month for a standard service fee (for 88240HDC/8300) DVRs, and $11.99/$19.99 per month service fees for Trio (Contour) based DVRs (Cisco 8642HDC/8742HDC/9865HDC) ?? I know they dropped the fee for the "Plus Pak" (Contour HD) channels, but what other "Contour" fees have they dropped?
http://ww2.cox.com/residential/tv/prices.cox
post #8456 of 8648 Old 03-06-2014, 10:48 AM
fdxorf's Avatar
Pardon my incorrect verbiage......My only purpose for the post was to state that the new box I got included all the extra channels that were unavailable with the Motorola boxes, for no additional costs to me. So that anyone with the older boxes now has the option of a newer box without incurring the fees.... I have no idea what the other charges you mentioned are for, due to the fact that I don't pay them. You might want to call CS and ask what exactly has changed
fdxorf is offline
post #8457 of 8648 Old 03-06-2014, 11:04 AM
Quoted: 126 Post(s)
Liked: 216
Depending on what model DVR you upgraded from/to, your service charge will go from $9.99 or $11.99 to $11.99 or $19.99. I'd be interested in knowing what you up graded from/to, and what your new DVR service charge is. You probably won't know for sure until you get next month's bill.
post #8458 of 8648 Old 03-06-2014, 11:14 AM
fdxorf's Avatar
Didn't upgrade to anything, I just got a new box....Doesn't cost anything to exchange equipment
fdxorf is offline
post #8459 of 8648 Old 03-06-2014, 11:48 AM
Quoted: 126 Post(s)
Liked: 216
As I said, I'd be interested in what Service Fee appears on your next full bill, especially if you upgraded from a Motorola to the 6-tuner 9865HDC.
post #8460 of 8648 Old 03-06-2014, 01:13 PM
fdxorf's Avatar
Sure, I will let you know.....The rep at the store that there would be no additional costs for what I did....She was looking at her computer when she said it
fdxorf is offline
