Norfolk, VA - Cox - Page 287 - AVS | Home Theater Discussions And Reviews
post #8581 of 8610 Old 12-30-2014, 07:34 AM
VARTV's Avatar
Quoted: 25 Post(s)
Originally Posted by 8vsb4me View Post
That's consistent with what you previously reported for 3-1 (17+Mbps) prior to this new development. Then why is WAVY so lousy on COX with only 1 sub channel?
I "think" it's two things. First, they give Bounce much more bandwidth than WTKR gives to thistv. But secondly, it could be the equipment WAVY is using... older equipment. I watched Bounce for a minute and the PQ is not very good (blurry) for getting all of that bandwidth. Then I switched to thistv. MUCH more sharper picture with almost half the bandwidth. I can easily read the "fine print" on commercials on thistv. No way I could watching Bounce (too blurry)... Whatever WTKR is doing/using, they are doing it right...
Robert F Corbin
VARTV.com | Virginia Media News & Information
email: editor@VARTV.com
facebook: facebook.com/VARTV
twitter: twitter.com/VARTV
linkedin: linkedin.com/in/VARTV
google+: plus.google.com
pinterest: pinterest.com/VARTV
VARTV is offline
post #8582 of 8610 Old 12-30-2014, 08:48 AM
8vsb4me's Avatar
I guess nothing changes. In the 60s I recall WTAR always had the strongest signal and best picture, while WAVY and especially WVEC were low-budget, backwater stations. The real mystery is who the heck watches these low-rez sub-channels?
8vsb4me is offline
post #8583 of 8610 Old 12-30-2014, 09:20 AM
VARTV's Avatar
Quoted: 25 Post(s)
If the subchannels can get on Cox, FiOS, Charter, etc, they could potentially get some viewers. Its my understanding that BounceTV is probably the most successful diginet out of all of them. I saw multiple local ads on Bounce when I looked at it an hour ago...
Robert F Corbin
VARTV is offline
post #8584 of 8610 Old 12-30-2014, 01:35 PM
8vsb4me's Avatar
I sent an email to WAVY about their HD PQ but according to their Engineer Charles Stutsman they don't see a problem:
"Thank you for contacting WAVY-TV. We have not seen the problem you are referring on our monitors here at the television studio, so I contacted the engineering department at Cox to see if there were other viewers expressing your concern. I was told they have not have any other viewer calls and neither have we. I don’t know from your email if this is an ongoing problem, or if it has happened just once or twice.
I would like to recommend after talking to Cox that you call Cox customer service to have them come and check your cable and your cable box to see if either has developed a problem. They would be in a better position to deal with a cable hardware problem then we would."
Apparently they can only see the problem if they get a sufficient number of complaints.
8vsb4me is offline
post #8585 of 8610 Old 12-31-2014, 09:01 AM
VARTV's Avatar
Quoted: 25 Post(s)
Maybe if he watched Bounce then flipped it over to thistv, he would see the difference. PQ is much sharper on thistv with almost half the bandwidth of Bounce...
Robert F Corbin
VARTV is offline
post #8586 of 8610 Old 01-08-2015, 06:42 AM
lupi95's Avatar
Noticed on last statement that the new sports pak will have longhorn network added to it soon.
As for CBS and picture quality, I've noticed before that on Cox watching the CBS feed is easiest way to tell if you are having signal problems with your line transmission as it was the one that would fail to lock in while most others stayed viewable.
lupi95 is offline
post #8587 of 8610 Old 01-13-2015, 01:29 PM
turbo327's Avatar
Contour - how to change from component out to hdmi?
Quick question that seems simple but am not finding the resolution.
I have a Cox Contour (Cisco) box that was originally setup and installed so the component output would feed my Samsung TV. It was done that way because this 8 year old Samsung HD box only had 2 HDMI ports. So I relegated the Cox signal to the Samsung's component input in order to allow my Tivo and BluRay DVD player to connect via the 2 HDMI ports.
I have a new Samsung TV coming later this week that has additional HDMI input ports, so I can now accomodate the Contour via HDMI.
Figured it would be a good idea to test how this needs to be changed over... setting it up with no component output cables, and with an HDMI to my existing Samsung, no go. Cold boot on the Contour = no go. Must be a trick to getting the Contour box to stop using its component output and switch over to its HDMI output?
The pdf file for the updated users manual says run Setup, but that is not working with the box starting up on component, it does not want to switch over.
Wanting to think I am obviously missing some simple step? ( like call for a reset ? Ugh ) Well...late minute thought here, but I'll post anyway. Perhaps having the component connected while the HDMI is also connected.... hmmm... (edit: Nope, that did not work)
Getting old is... well... you know. Sheez!!!!!!!
Thanks in advance!!
Gerry-
Retired Network Janitor
turbo327 is offline
post #8588 of 8610 Old 01-13-2015, 10:32 PM
domino92024's Avatar
Quoted: 83 Post(s)
Liked: 184
Make sure your TV is switched to the proper HDMI input. That's the only thing that comes to mind. What model is your DVR?
domino92024 is online now
post #8589 of 8610 Old 01-14-2015, 07:34 AM
turbo327's Avatar
Thanks for the assist, looks like I have this figured out now.
The Cox DVR is the Contour /Cisco box. I did find a nuance with my aging Samsung flat screen. It's 2 HDMI ports attempt to make sense of active devices connected, and do not want to linger on an HDMI port that appears 'dead'. Yesterday I connected the HDMI port of the Contour/Cisco box to my Samsung and fortunately found a way to get the Samsung to linger on that port long enough for the rebooting of the Cisco box to 'see' my Samsung TV. It was a kludge but in fact that was the brunt of the issue as you suspected, i.e. the TV would not sit on the port long enough to wait for the Cisco to see it.
Now... it appears the Contour/Cisco box has stored a config indicating its HDMI port can be active, and I can readily switch between TV inputs of component and HDM1-2 and see the Contour/Cisco box output. Suspect I need to disable the component output once I get the new Samsung TV. And hopefully the new Samsung TV will behave a bit different, but at least I've found the work around.
Thanks again!
Gerry-
turbo327 is offline
post #8590 of 8610 Old 01-14-2015, 10:11 AM
lupi95's Avatar
Those ports can be a bit tricky. When I first had an old moto box, I had it out putting hdmi and component simultaneously. When I tried the home dvr system, plugging into the hdmi port would cancel output via the component connection. Later they must have changed this in an update as eventually it did allow both to output again simultaneously.
lupi95 is offline
post #8591 of 8610 Old 01-14-2015, 01:39 PM
Quoted: 83 Post(s)
Liked: 184
Gerry-
All Cisco boxes have a model number on the front panel. On a 8642HDC, it's in the upper right corner. On a 8742HDC or a 9865HDC, it's on the left side above the ON/OFF button. All three DVRs run on the Contour IPG.
post #8592 of 8610 Old 01-14-2015, 03:17 PM
turbo327's Avatar
This one is a 9865HDC. I have not followed the Cisco boxes that Cox has been using. Don't want to hijack my own thread... but boy... I really do not care for the Cisco user interface. Bleck!
A Tivo has been on my setup going back to '99 or 2000 and a Series 1. Boy... do I remember THAT Christmas. Gave it to my sweet wife for a 'family' gift... and she said... yea.. I know you bought this for you. Then 3 weeks later she said it was the best gift I'd ever given to her. Ha!!
Current one is a dual tuner + antenna Tivo 4 Premiere and just cannot fathom how anyone uses the Cox/Cisco interface without lots of gnashing of teeth. We do make good use of the Cisco box for recording some extra viewing, but having just put a new and larger drive in the Premiere... we're good for a while. Guess with 4k down the road... gonna need some more technology in there.
turbo327 is offline
post #8593 of 8610 Old 01-14-2015, 09:13 PM
Quoted: 83 Post(s)
Liked: 184
The user interface is not a function of the hardware. It is the function of the firmware/IPG, which is Contour in this case. I have been using Trio/Contour for more than two years. The interface took a little getting used to, but over time it sorta "grew" on me. I hated the 4:3 aspect ratio limitation of the old guide interface.
post #8594 of 8610 Old 01-15-2015, 06:58 AM
turbo327's Avatar
Clearly understand the firmware and UI being part of the Cox offering, was not clearly aware of the Trio legacy till you mentioned it and I looked back on its roots. Thanks. I put many years in the basics of the Cisco IOS, which could really take some getting used to. But with that you had no choice. Guess I lumped this in their column by association. You get used to what is in front of you, nuances and shortcomings both. Tivo and Trio, curiously different for sure.
Gerry-
Retired Network Janitor -
turbo327 is offline
post #8595 of 8610 Old 01-16-2015, 01:43 AM
Bryan_CoxPHX's Avatar
Quoted: 41 Post(s)
Liked: 25
Just curious, since you are already familiar with, and prefer the TiVo User Interface, why would you not just get a TiVo Roamio Plus or Pro? With an eBay discount code you can get a Roamio Pro - 6 Tuner, 3TB w/ Lifetime Service for $699.99.
It sounds like you may also qualify for the unadvertised, 10 Year Loyalty discount. If you call TiVo and pay full price on the Roamio Plus or Pro and ask for the $99 Lifetime Service they should offer it. There have been many reports of success getting that deal.
The Roamio hardware is so much faster and smoother than the Premiere Series 4 units.
Throw in a TiVo Mini if needed and just stay with the uniform TiVo experience?
TiVo Roamio Pro, Premiere XL4, Premiere 2TB-WD20EURS, TiVo Mini
Win7 WMC SiliconDust HDHomeRun Prime, Cisco Tuning Adapter Status Troubleshooting
Bryan_CoxPHX is online now
post #8596 of 8610 Old 01-16-2015, 06:10 AM
turbo327's Avatar
Bryan,
Thanks for the heads up on this loyalty program. Sure scores multiple hits close to my heart ( and then my wallet... ugh) If I look back at my years of paying $12-14 a month for my Tivo programming subscription I horribly misjudged my investment. The lifetime subscription in 2000 or so was a pittance by comparison. The new Roamio/Plus/Pro are much quicker no doubt and certainly the additional 2-4 tuners, whoa...
I had looked at these about a year ago, and the antenna component goes away after the straight up Roamio with 4 tuners ( IIRC ), and I hesitated over that fact. Should likely reconsider since I am certain I will not relinquish my Tivo any time soon. Hmmm....
Thanks Bryan!! Most excellent suggestion!
Gerry-
turbo327 is offline
post #8597 of 8610 Old 02-03-2015, 08:19 AM
lupi95's Avatar
Anyone know the current details on available channels for the internet connection? After having extreme slowdown problem the other day, I noticed that after rebooting my modem and router that I am only connecting with 2 upstream channels and getting Tier 3 errors on the other 2. Not sure if this is a problem or if they are only running 2 upstreams.
lupi95 is offline
post #8598 of 8610 Old 02-03-2015, 08:29 AM
kes601's Avatar
I have 4 upstream channels on my connection.
Name:	Screen Shot 2015-02-03 at 11.29.00 AM.png
kes601 is offline
post #8599 of 8610 Old 02-16-2015, 05:07 PM
unixdude's Avatar
After using a Contour with Whole House DVR (or whatever it's called) for over a year, and running into a snafu - I'm going back to Tivo.
We were out of town for 2 weeks, and, the Contour DVR recorded everything just fine, it was the end of January, so, there were a lot of new/old shows starting backup. When we got back all looked fine, but, after a day we noticed we couldn't record any new things - the current list of what to record was still working, but, we couldn't add to it - got a "due to technical difficulties" message, we couldn't add new recordings, or, record live. After a couple of days of that, I decided to "reset" the DVR by unplugging it and plugging it back in. It looked like it fixed the situation, however, about 20 minutes after doing this, my wife came downstairs saying that there were no recordings available on the Contour upstairs. I checked the one downstairs (the main DVR) and sure enough it had wiped all the recordings as well as the list of shows to record! Months of saved recordings lost, not the end of the world, but, a seriously f*** up scenario. I also noticed at that point that while the DVR indicated it would record shows, it did not in fact do so - it became a simple receiver while indicating it was still a DVR. I had to leave town for a few days, so, I figured I would wait until I got back to deal with this.
On returning home on Saturday, I called Cox, to their credit they sent someone out Sunday AM at 8AM (excellent service IMHO). The Contour DVR was swapped out and service was restored.
Later on I figured I would call Cox Customer service. My faith in their technology was shaken, what good is a DVR that wipes itself, and, a company that says "sorry about that". My call to them was useless, they didn't even apologize for what occurred, just said, oh well.
That said and done, I was tempted to move to Dish or DirecTV, but, that would be a pain. I did however decide to dump their DVR's and go back to Tivo. Tivo is offering an excellent deal, so, it will pay for itself in 6 months, not to mention the better interface etc...
I've always been happy with Cox's customer service, however their lack of response on this scenario is disturbing, who tells a customer "oh well" when told of a major snafu.
unixdude is offline
post #8600 of 8610 Old 03-01-2015, 10:45 AM
Skeletor's Avatar
Question for people who only have Cox internet...
Do you still get any channels if you connect to your HDTV? I'm thinking about going ota and keeping the broadband service. My only hangup is my daughter having access to even the most basic cable. Thanks.
Skeletor is offline
post #8601 of 8610 Old 03-03-2015, 04:37 AM
kes601's Avatar
You do realize that would be classified as stealing cable even if it did work?
Beyond that, what should happen is that Cox will install a filter on your incoming line that will prevent the theft from occurring. Also, moving forward Cox is moving to non-analog and no clear QAM on their system. In other words you need a box to get any channels at all.
kes601 is offline
post #8602 of 8610 Old 03-03-2015, 03:49 PM
Skeletor's Avatar
Yes, the filter being installed is what should happen. I'm dern sure not climbing a pole to mess with it. I just didn't know if anyone had any experience with it. Either way, that's what I figured. Even if they offered a box-less option for cheap I'd pay for it for the most basic channels. Thanks.
Skeletor is offline
post #8603 of 8610 Old 03-03-2015, 04:02 PM
kes601's Avatar
They do have FlexTV, which is what I have. It's the 50Mbps Internet option along with the locals, TBS, Animal Planet, HBO, and Starz. Includes one set top box. I think we pay $80 total, that includes renting a 2nd set top box.
kes601 is offline
post #8604 of 8610 Old 03-03-2015, 04:39 PM
Skeletor's Avatar
Interesting. I'm keeping the internet so this may be an option. I got myself an ota TiVo for the den so I may be able to use the box in my kid's room. Thanks.
Skeletor is offline
post #8605 of 8610 Old 03-07-2015, 11:32 AM
turbo327's Avatar
Bryan,
Well I called Tivo after mulling this over. Stellar idea sir, glad you got those thoughts to me. Suffice it to say I purchased a new Roamio Pro and Tivo Mini-2, Tivo made me a great offer on the combination, plus offered me Lifetime Service on my existing Premiere XL for $99! And tossed in a new Tivo Slide Remote.
I contacted Cox Support, they shipped me an additional cable card and tuning adapter and we are at a standstill. That arrived, I followed all the setups, got it working to the point where it would receive a number of channels, but evidently not (SDV?) channels. Today and some 8 support calls over 2 days, 2 trips to the Norfolk Cox Support center for 'new' parts. Finally today did some research, found the Roamio won't connect to the Motorola 700 tuning adapter unless it has at least firmware version 1.40.
This is a well documented fact on the Cox TV Support forum, from back in December in a different Cox region. Called back to Cox support, the tech pushed a firmware update but no joy. They could not tell from their end what version they were pushing.
So... still DIW here. Will wait for the tech tomorrow. Can't flash these locally from what I've read. Sure would help me resolve the problem without a tech showing up ... I've got about 6 hours in this and 2 trips to the Cox store.
Lovely. 31 years with Cox and JUST when I was thinking all was good with their support. Wham.
Gerry-
turbo327 is offline
post #8606 of 8610 Old 03-09-2015, 11:14 AM
turbo327's Avatar
Update at 2 PM EST 9 March 2015. The Cox phone support tech Ron out of Ohio has made this work. We swapped my existing Motorola Tuning Adapter (with the known 1.40 firmware) over to the new Tivo and all works perfectly. Putting the 2nd new out of the box Tuner Adapter on my old Tivo allowed it to handshake with the Tivo, and it displayed firmware version 1.33 from 2009. Sort of clears the air. Now the 'new' 2nd out of the box Tuning Adapter still will not respond to resets from the Cox support end in Ohio. Completely ignored. But it does talk to my older Tivo ( Premiere XL ) and tells us firmware is 1.33. It also attempts to display all my subscribed channels that are switched digital video. But its amber light will not stop blinking, which indicates a continued issue. Ron has verified a on site tech call for tomorrow, and that my trouble ticket is marked for expedite for today if someone becomes available. Not ideal but no way to influence this from my end.
turbo327 is offline
post #8607 of 8610 Old 03-11-2015, 08:25 AM
turbo327's Avatar
This was completed yesterday without any issue. Joe G. the Cox onsite gent had it all working in just 15 minutes or so. He put a new Motorola tuning adapter on, got it updated to the 1.40 firmware and all things came to where they should be. He said the tuner adapter I was having issues with was corrupt, likely from an interrupted firmware update due to a reset or power being removed while troubleshooting. My take as a longtime tech is yes, it is not nice to interrupt any device while it is updating firmware. He also suspected that might have been what happened to the first tuning adapter. Did I really just have to go through all this because of some procedural error at the remote end? :-(
turbo327 is offline
post #8608 of 8610 Old Today, 07:02 AM
lupi95's Avatar
Everyone enjoying the across the board price increases.
lupi95 is offline
post #8609 of 8610 Old Today, 11:41 AM
robertawillisjr's Avatar
Are we going to get BBC News or do we have it already?
robertawillisjr is offline
post #8610 of 8610 Old Today, 06:42 PM
oriolesmagic's Avatar
Quoted: 27 Post(s)
Liked: 39
Northern Virginia has BBC World News, but in SD only. They are the only Cox market to have it. They are also the only Cox market to have Ovation (SD only) and Smithsonian Channel (SD only), but it appears to be launching some other places.
oriolesmagic is offline
