Huntsville, AL - HDTV - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #271 of 2999 Old 04-04-2005, 08:53 PM
manthatsnice's Avatar
I live in Madison (Wall Triana) and have the Sony KDF42WE655 with built-in tuner. There are no large trees or anything blocking my 1-story house. What HD channels could I expect to receive by installing a simple indoor antenna from BestBuy or Radioshak?
Also, would it be possible to get the same HD quality with the antenna in my attic? (I don't like the look of one in my living room)
manthatsnice is offline
post #272 of 2999 Old 04-05-2005, 07:48 AM
odinala's Avatar
I'm further north than you, a couple of miles west of Wall Triana in Harvest (but close to Hwy 72). I have a Zenith Silver Sensor on top of my set and get all the local channels to include WAAY (although they're not broadcasting in HD). You can probably get a stronger signal in the attic, it depends on the antenna, the type of roof you have, and the location of the antenna among other things.
odinala is online now
post #273 of 2999 Old 04-11-2005, 06:22 AM
pacofs7's Avatar
I live in southeast Huntsville and am considering the Sony KDF42WE655. I plan on using an antenna to pick up the local HD broadcasts. I currently have comcast analog cable, and was wondering how the 42WE655 does with the SD broadcasts ... is it at least as good as you would get with a standard analog set? TIA
pacofs7 is offline
post #274 of 2999 Old 04-12-2005, 10:27 AM - Thread Starter
Wolfie's Avatar
Quoted: 20 Post(s)
Damn the torpedoes, FULL SPEED AHEAD! You should have no problem with indoor equipment, except getting WHDF-D, but they don't broadcast in HD anyway, so it don't matter.
BTW, some news on the WAAY-HD situation and it ain't good. A reliable source says they don't have any of the HD equipment yet, so July doesn't look promising.
Wolfie
Wolfie is offline
post #275 of 2999 Old 04-17-2005, 06:00 PM
kpfleming's Avatar
Wow, what a ton of useful info here!
I'm moving to Huntsville in June, will be living at Colonial Village at Research Park (Rime Village Drive and Enterprise Way). Will be in top-floor unit, south exposure, and will have DirecTivo HD for everything non-local. It appears based on my location that I should have zero problems getting all the OTA HD channels, even with a Silver Sensor antenna (given to me by a friend). Is this a valid assumption? If so, that's one less thing I need to worry about!
kpfleming is offline
post #276 of 2999 Old 04-18-2005, 07:50 AM
odinala's Avatar
kpfleming - That's a good assumption. I live about eight miles further northwest than the location you're referring to and use a Silver Sensor to get all the local digital channels.
post #277 of 2999 Old 04-19-2005, 01:27 PM - Thread Starter
Wolfie's Avatar
Quoted: 20 Post(s)
Welcome to Huntsville, kp. You'll love the humidity
Wolfie
Wolfie is offline
post #278 of 2999 Old 04-20-2005, 11:26 AM
curban's Avatar
Hello. I live in madison off wall triana. I bought a walmart indoor antenna that didnt work well. I bought a UHF only from radioshack that worked better in my test but still not great. I plan on installing something in the attic. I might try the radioshack one in the attic or buy something better. BTW, my house is a big two story. Any recommendations for an attic antenna? Also, I have Coax running to 7 rooms with knology cable running on them, the tv i want to get OTA HD is downstairs so I was thinking of using a diplexer to add the ANT signal to the cable for that tv and then another diplexer to split it at the tv. Will this work, i know it works for satellite but not sure about cabletv. Eventually I may go with DirectTV and then run the OTA ANT into the multiswitch.
Thanks for any help and suggestions
curban is offline
post #279 of 2999 Old 04-20-2005, 11:55 AM
taz291819's Avatar
Diplexers degrade signal, I wouldn't recommend it.
If you won't install the antenna outside, I'd put a Channel Master 4228 in the attic, with a direct run of RG6.
Currently testing 3D with Sammy DLP, shutter glasses, and HTPC
taz291819 is offline
post #280 of 2999 Old 04-20-2005, 12:30 PM
curban's Avatar
Still might have to try the diplexers, not sure i can get a cable run to the downstairs from the attic. Will probably try the channelmaster as I have seen some good things about them. Anything else i need other than the antenna? Preamp? Any good places locally to buy the 4228?
thanks again
curban is offline
post #281 of 2999 Old 04-20-2005, 02:08 PM
odinala's Avatar
Curban - Try a Zenith Silver Sensor, can't say enough good things about it. I live off of Wall Triana, but further northwest from you (actually have a Harvest address) and I'm using the Silver Sensor to get all the local digital stations.
post #282 of 2999 Old 04-20-2005, 05:55 PM
Montezuma58's Avatar
You should be able to pick up the channel master antenna a Mock Electornics. They usually have them in stock. The 4 bay version should work just as well. That's what I use in my attic. I live off of Balch Rd. The loss from the diplexers should not be an issue for your location. I use them and don't have a problem but I'm using satellite. I don't know if the cable frequencies will clash with the OTA frequencies. My gut feeling tells me it will. I'd run another line if possible in your case.
I've used the Silver Sensor. It can pull in all of the stations. But it can be tricky to find a position where it will get all of the station reliably without having to adjust it. If you get one of the Channel Master multi bowtie antennas you can pretty much just point it towards Montesanto Mountain and not have to worry about it.
Brad
Montezuma58 is offline
post #283 of 2999 Old 04-21-2005, 08:42 AM
taz291819's Avatar
The 4-bay Channel Master is the 4221 and the 8-bay is the 4228, just in case you need to know.
post #284 of 2999 Old 04-24-2005, 07:16 PM
taz291819's Avatar
Looks like tennesseevalleyhd.net got hacked. By Xtech Inc.
post #285 of 2999 Old 04-24-2005, 11:49 PM
MrZoid's Avatar
Quoted: 43 Post(s)
Liked: 46
Yep. Just noticed that. I also noticed this website got hacked as well. Here's the pic.
Mr Zoid
A GF that bought me a PS3 and a HD-A2? I'm a lucky man!
MrZoid is offline
post #286 of 2999 Old 04-25-2005, 11:48 AM
odinala's Avatar
You can still get to the web site through this link http://tennesseevalleyhd.net/index.php
post #287 of 2999 Old 04-26-2005, 07:06 AM
RG13's Avatar
I live in Decatur and just switch to PCL (Athens City Cable) for HD and works great with no additional charge for 8 HD channels. BUT, the major Networks are not included so I will be installing antenna for OTA HD. I provide update once I get that up but your inputs should help me then, thx
RTx
RG13 is offline
post #288 of 2999 Old 05-23-2005, 01:07 PM
spaceghost's Avatar
Is 5c enabled on the cable boxes?
Know what I say when I say you know what I mean?
spaceghost is offline
post #289 of 2999 Old 05-28-2005, 11:17 AM
Irishkmo's Avatar
Any news on waay hd?
Irishkmo is offline
post #290 of 2999 Old 05-31-2005, 11:51 AM
odinala's Avatar
I called the station and they claim they will be broadcasting HD on 1 July.
post #291 of 2999 Old 06-05-2005, 09:21 AM
Irishkmo's Avatar
Thanks for the info. Lets hope they mean it!
Irishkmo is offline
post #292 of 2999 Old 06-23-2005, 02:26 AM
MrZoid's Avatar
Quoted: 43 Post(s)
Liked: 46
Does anyone know if and when the local CableCos will begin to broadcast WAAY after they go HD?
Mr Zoid
MrZoid is offline
post #293 of 2999 Old 06-23-2005, 07:34 AM
RG13's Avatar
I have PCL (Athens Cable) in Decatur and it only gives me WXDX (CBS) and and WHNT (FOX). There is no additional charge for these so I am not complaining. Does someone have good info on the LG LST-3510A DVD/HD Receiver? I am not sure if it is providing me all of the HD channels available from PCL. I call them and they sent a technician and he could not help but he did increase the signal level to the unit by removing splitters they had.
RTx
RG13 is offline
post #294 of 2999 Old 06-23-2005, 11:19 AM
taz291819's Avatar
Actually, Fox is WZDX and CBS is WHNT. No biggie though.
post #295 of 2999 Old 07-01-2005, 11:10 AM
Irishkmo's Avatar
did waay go hd today? anyone know when comcast will include them on their hd line up?
Irishkmo is offline
post #296 of 2999 Old 07-05-2005, 07:14 AM
odinala's Avatar
No.
post #297 of 2999 Old 07-11-2005, 01:02 PM - Thread Starter
Wolfie's Avatar
Quoted: 20 Post(s)
Wolfie
Wolfie is offline
post #298 of 2999 Old 07-11-2005, 01:29 PM
brianm0520's Avatar
Do you guys think it would be possible for me to pick up stations from Birmingham? I live near Russellville. The main station I was wanting to receive was channel 26 (WTJP). I attached a picture that shows the stations broadcast range. If you think it's possible, what kind of outdoor antenna would you recommend?
brianm0520 is offline
post #299 of 2999 Old 07-17-2005, 08:35 AM
auburn2's Avatar
If so what do you think of it?
I'm moving to Madison later this month, and I am debating E* vs mediacom (comcast is not available in my neighborhood and knology sucks).
According to a post in another forum, mediacom has more HD channels than E* (Voom not withstanding), including ESPN-2 HD which will be a real boost come football season.
Does anyone know how thier picture quality (both HD and SD) compares with E*?
auburn2 is offline
post #300 of 2999 Old 07-17-2005, 03:25 PM
MrZoid's Avatar
Quoted: 43 Post(s)
Liked: 46
I'd like to know this as well. Customer service reactions, offerings, prices, etc. A coworker of mine currently has Mediacom, and is seriously giving thought to purchasing a HD display, and he wants to know if it's worth it. He's not interested in the movie channels, just mainly the other channels.
Mr Zoid
MrZoid is offline
