Huntsville, AL - HDTV - Page 15 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
Old 09-27-2005, 08:16 PM
taz291819's Avatar
I noticed Boston Legal started in HD, then went SD (well, upconverted 720p). That's a good sign.
Bad thing was, their signal was terrible, it used to be 100%, now it's about 25%. Hope they turn it back up.
Currently testing 3D with Sammy DLP, shutter glasses, and HTPC
taz291819 is offline
Old 09-27-2005, 10:25 PM
redwingsfan19's Avatar
Originally Posted by alwilli View Post
I have had a calibration and several touchups (although I will skip this year since I got my Spyder2 Pro colorimeter to play around with). Calibrations can add up. I had Gregg Loewen from Lion AV do mine. I can not recommend having a calibration done by Gregg enough. It was worth it for me but your mileage may vary. If you have a CRT RPTV I would highly advise it...not so much if you have a fixed pixel digital with DVE or Avia.
Alvin
What kind of TV do you have? An now since you have a colormeter, are you going to try an do some calibrating on the side?
"A Hero Need Not Speak. When He Is Gone, The World Will Speak For Him."
redwingsfan19 is offline
Old 09-28-2005, 05:56 AM
alwilli's Avatar
I can not speak for the future, but for now I have no plans to calibrate on the side. If I did I would have to invest in more accurate (and more expensive) equipment. And most importantly, I would need the experience and knowledge of color science to feel comfortable charging people. I bought the colorimeter as a cheap alternative to having my units recalibrated over and over as I change components. See this thread for info:
http://www.avsforum.com/avs-vb/showthread.php?t=572098
I have a Toshiba 42H82 CRT RPTV, an Infocus 4800 DLP front projector, and a Samsung HLP-5063W DLP. HT is my hobby and is very expensive. And I have low budget equipment and a modest setup! I don't plan on buying anything else anytime soon (5 years). I have other things more important now financially.
alwilli is offline
Old 09-28-2005, 06:03 AM
TAKECOVER's Avatar
Did anyone here watch "NCIS" last night? My audio was terrible last night.
TAKECOVER is offline
Old 09-28-2005, 07:03 AM
odinala's Avatar
Ditto.
odinala is offline
Old 09-28-2005, 07:40 AM
drichard's Avatar
WAAY now has the side bars. They must be getting ready to go HD if not already. It is 8:30am. 31.1 channel. At last
drichard is offline
Old 09-28-2005, 08:09 AM - Thread Starter
Wolfie's Avatar
Quoted: 20 Post(s)
Yes...WAAY will have "Lost" and "Invasion" in HD tonight...if they don't mess it up.
Wolfie
Wolfie is offline
Old 09-28-2005, 08:45 AM
MarkW's Avatar
Wolfie have you got that from somone at WAAY. They had what appeared to be the capability last night for there HD shows but didn't "flip the switch".....
Mark...
MarkW is offline
Old 09-28-2005, 09:01 AM
odinala's Avatar
Their first show last night was in HD, I believe it was Life With Jim??? It appears they were still testing since at one point you could see when they switched from 720p to 480i and back again.
odinala is offline
Old 09-28-2005, 10:15 AM
taz291819's Avatar
I never saw it go to 480i, just from true 720p HD to 720p Upconvert. Just analyzed their signal remotely and here's what I saw:
31.1 is listed as WAAY-HD
31.2 doesn't have a name
Their PIDs look correct, so there shouldn't be a problem with viewers receivers.
31.1 is of course 1280x720p @ 15Mbps, DD2.0 @ 192kbs
31.2 is 720x480i @ 4Mbps, DD2.0 @ 192kbs
Let's give them the rest of the week or so to work out the bugs.
Old 09-28-2005, 10:55 AM
MarkW's Avatar
Voicemail from Chief Engineer at WAAY saying the are up with HD and experiencing some minor hickups but are good to go..... Awesome. (To bad it is a week past when my beloved Redskins played there only MNF game)
Mark...
MarkW is offline
Old 09-28-2005, 01:29 PM
TAKECOVER's Avatar
Taz, how did "Life with Jim" look??
Old 09-28-2005, 03:04 PM
Character_Zero's Avatar
Quoted: 372 Post(s)
Liked: 234
Whats the power level like. A couple of weeks ago i was getting WAAY very good and was pleased sinc ei have had trouble getting a signal in the past. recently it has been very hard to get a signal. Have they upped the power back to what it was or maybe i need to rescan the channel.
Character_Zero is offline
Old 09-28-2005, 03:42 PM
taz291819's Avatar
I didn't check out "Life with Jim". I lucked out even flipping to WAAY when I did (after "House"). Like I said, it was only HD for a few seconds so I couldn't really get a good look at it. Since Lost is on tonight, that'll be a good measuring stick. At 15Mbps, it should be enough for 720p, though I don't know what kind of encoder they have.
btw, just remotely checked signal levels, they look a lot better now than they did last night.
Old 09-28-2005, 04:37 PM
Quoted: 372 Post(s)
Liked: 234
thanks taz
Old 09-28-2005, 04:41 PM
DiamondRat's Avatar
Life with Jim looked incredible last night. It was broadcast in hd for the first 20 or 30 minutes before it switched back. Power level was at 90% ota in south Huntsville.
DiamondRat is offline
Old 09-28-2005, 06:18 PM
rushr1's Avatar
Anyone know whether WAAYHD (assuming it really close to being a reality) will be offered on comcast?
rushr1 is offline
Old 09-28-2005, 06:30 PM
austinmm6's Avatar
I hope Comcast picks it up ASAP. I'm watching Lost in OTA HD right now and it looks beautiful, but the sound is coming from my tv speakers since my 5.1 is hooked up through the Comcast HDDVR. I can't complain about the picture, but I hate waiting for Comcast
austinmm6 is online now
Old 09-28-2005, 07:06 PM
manthatsnice's Avatar
Hallelujah!! "Lost" in HD.
manthatsnice is offline
Old 09-28-2005, 07:09 PM
drichard's Avatar
call comcast and ask them when they are going to have channel 31 in hd. we all need to do this.
drichard is offline
Old 09-28-2005, 08:02 PM
TAKECOVER's Avatar
I will call Comcast first thing in the morning, man it sure does look good right now!! (OTA also)
My brother has Knology, and he just has a blank screen in his HD section for WAAY.
Thanks so much guys at WAAY for jumping on board!
Old 09-28-2005, 08:27 PM
Butch50's Avatar
That is what I am getting too.
Actually, I'm having trouble getting good consistant HD signals from Knology for about the past week. Some of the HD channels show up as 480i instead of 1080i, and ESPN and Fox show up as 1080i instead of 720p.
Butch50 is offline
Old 09-28-2005, 08:56 PM
steve24's Avatar
Sweet! I can't believe HD on ABC is finally here!
On a good night I can pick up a weak signal out of Nashville, but it usually had so many dropouts, it isn't worth watching. So now, hopefully, I won't have to worry with it anymore.
steve24
steve24 is offline
Old 09-28-2005, 09:47 PM
drichard's Avatar
Really nice watching abc hd. now we will be able to see all the sports in hd. we now have almost all of the stations. we now need espn2 hd on comcast, i have been calling, hope you are too.
drichard is offline
Old 09-29-2005, 07:08 AM
Quoted: 372 Post(s)
Liked: 234
Saw the ABC in HD like the others here. I would like to congradulate WAAY on a job.....done.
Old 09-29-2005, 07:55 AM
freemoose's Avatar
Does anyone know what channel on Comcast is the ABC HD?
freemoose is offline
Old 09-29-2005, 08:02 AM
drichard's Avatar
They dont have abc on comcast yet. call and let them know you are waiting for it.
drichard is offline
Old 09-29-2005, 08:16 AM - Thread Starter
Wolfie's Avatar
Quoted: 20 Post(s)
Did ya notice that "Lost" was superb PQ, but "Invasion" was lacking. I guess the higher rated shows get the best PQ.
Wolfie
Wolfie is offline
Old 09-29-2005, 09:21 AM
Andrew Hornfeck's Avatar
Quoted: 30 Post(s)
While I'm as glad as the rest of you that WAAY-31 has joined the HD arena, it's all for not if the reception is broken. JUST this morning I'm experiencing heavy dropouts on all DTV broadcasts with PBS being the only exception --> they're a STEADY 90%
I have not made any adjustments to my antenna(s) but this odd phenomenon reaks of atmospheric effects with the heavy cloud cover... although WZDX hasn't been stable in a while. How's your reception?
Andrew Hornfeck is offline
Old 09-29-2005, 09:27 AM
taz291819's Avatar
WAAY's reception was all over the place last night, I finally switched to another channel. All other channels were fine.
