Miami / Ft. Lauderdale, FL - HDTV - Page 14 - AVS Forum | Home Theater Discussions And Reviews
post #391 of 6834 Old 01-23-2002, 12:11 PM
Rudy1's Avatar
Quoted: 964 Post(s)
Liked: 1276
I watched the first hour in SD widescreen. Don't know what happened after that.
ASKHOLE: (n.) A person who constantly asks for your advice, yet always does the opposite of what you told them.
Rudy1 is offline
post #392 of 6834 Old 01-23-2002, 01:12 PM
WingFat's Avatar
Got the antenna installers over right now... I'm getting a Winegard HD9095 which will be mounted over my roof- 2 stories up. The mounting pole is huge!- and it telescopes... Why are they digging a hole in the lawn?.....oh my!
Will report back after installation is finished..
WingFat is offline
post #393 of 6834 Old 01-23-2002, 01:27 PM
aviators99's Avatar
Hmmm...I had channel 2-3 which had letterboxed, and channel 2-100, which had nothing. Where was the SD widescreen?
aviators99 is offline
post #394 of 6834 Old 01-23-2002, 03:57 PM
WingFat's Avatar
Ok...
Installation is complete...
Dansco Services of Lake Worth installed a Winegard HD9095 with Winegard amp (19 DB gain). Its mounted on a 35 foot mast anchored in the ground. This thing goes up the back of my house, mounted about 3 feet above my deeply slanting roof.
Reception of OTA analog signals ie Ch 39 is better than cable. (Adelphia of course) Actually as good as satellite.
My Samsung is still enroute from Vanns so I can't really play yet.
I'm assuming that if I receive a low power station like ch59 nicely, I will have no problem with the digital stations?
Jeff
WingFat is offline
post #395 of 6834 Old 01-23-2002, 05:05 PM
Rudy1's Avatar
Quoted: 964 Post(s)
Liked: 1276
I don't really know. The INFO banner came up as Channel 2-3 (and 16:9, not Letterbox) when I first turned it on. But I was using my old DTC100, so that may be the reason why I didn't realize it was letterboxed. I haven't used that unit in several months, so it's possible that I made a mistake.
Rudy1 is offline
post #396 of 6834 Old 01-23-2002, 05:41 PM
jluzbet's Avatar
WSVN-Fox will transmit 480p the superbowl in our area ? Last I heard they were trying hard but nothing confirmed yet...
ÂNothing attempted, nothing achievedÂ
jluzbet is offline
post #397 of 6834 Old 01-23-2002, 06:07 PM
aviators99's Avatar
It was since confirmed (in this thread even) that the answer is
no.
post #398 of 6834 Old 01-23-2002, 06:51 PM
aviators99's Avatar
Is there something wrong with my equipment or is American Family not on WPBT-DT?
post #399 of 6834 Old 01-23-2002, 09:27 PM
Rudy1's Avatar
Quoted: 964 Post(s)
Liked: 1276
I was only able to catch a few minutes of this, but it was on tonight on WPBT-DT (in DD 2.0). There was a short documentary on following that, then a musical review (in DD 5.1) afterwards. I was busy doing something else so I didn't actually watch the programs, but I did check the HD tuners and the AV receivers for the transmission info.
Rudy1 is offline
post #400 of 6834 Old 01-24-2002, 10:03 AM
holtwm's Avatar
I still can't receive WPBT 2-1 on my Sony SAT-HD100! I scanned for this channel last night during the HighDef programs and it couldn't find it. This was working about a month ago but ever since I started receiving WBZL I can only receive 2-3. This channel however just shows a blank screen during HighDef broadcasts. I am getting signal strength of over 90.
What could be causing this problem? Do I need some kind of filter on my antenna or something? Is anyone else in So Fla able to receive WPBT 2-1 HighDef broadcasts on their HD100? Thanks in advance.
Will
holtwm is offline
post #401 of 6834 Old 01-24-2002, 04:18 PM
aviators99's Avatar
Will
I was not receiving it last night either, on my DTC-100. Apparently others were.
post #402 of 6834 Old 01-24-2002, 06:45 PM
aviators99's Avatar
Still not receiving it tonight with DTC-100 and good signal strength. Neither is Propeller....
post #403 of 6834 Old 01-24-2002, 08:07 PM
gene inger's Avatar
probably the problem is that anyone re-scanning an HD100 to get all the digital channels, will not get 2.1 unless you scan while an HDTV (rather than 2.3 digital, but not HD) program is on. Surely this is tough unless you check the schedule, or call them to find out when the national feed loop is being carried, or there is a show (such as earlier tonight) in HD. I know it's confusing, both because the HD100 (unlike the integrated sony tuner sets) will only rescan, and can lose a previously scanned channel if not on, and as WPBT is the only local station doing anything approaching multincasting...ie: 2.0, 2.1, 2.3 as they determine...sometimes it's awhile between HD programs, and they have announced some delay in carrying all the national programs...surprised there has not been more complaining about this, as they were doing an awfully lot at the outset. Good luck!
gene
www.ingerletter.com
gene
___________________
www.ingerletter.com
gene inger is offline
post #404 of 6834 Old 01-26-2002, 07:52 AM
George33027's Avatar
I read somewhere that Fox will transmit 480P wide screen superbowl.
Are you sure south florida will not get the same?
George33027 is offline
post #405 of 6834 Old 01-26-2002, 04:38 PM
aviators99's Avatar
Yes, I'm sure. That's why I went and bought the Expressvu equipment and hooked it up yesterday. You are welcome to come to my superbowl party, since you live down the road.
post #406 of 6834 Old 01-26-2002, 04:41 PM
online2much's Avatar
I just got done rescanning, and now pick up 2-1 (but it looks like an analog feed....fuzzy and scrolling scan lines?!?!) 2-3 and 2-100. Both 2-3 and 2-100 have some sort of demo loop running...
FYI - I live about 5 miles from the broadcast tower..
online2much is offline
post #407 of 6834 Old 01-26-2002, 06:56 PM
romy101's Avatar
How are you sure Fox wil broadcast it in 480p in South Florida? Did someone call and ask? I would not put it past wsvn to be hairbrained and not broadcast0 the feed.
In addition have they ever broadcast anything other than 480i before to give us at least a hint that they know what they are doing? I would hate to tell my friends to come over for the game just to have egg on my face when all I see on my projector is crappy ntsc.
romy101 is offline
post #408 of 6834 Old 01-26-2002, 08:26 PM
aviators99's Avatar
Yes I called. I spoke with the chief engineer and others. It will definitely not be broadcast in 480p. I've never heard anyone suggest otherwise.
post #409 of 6834 Old 01-28-2002, 02:42 PM
WingFat's Avatar
Got my Samsung SIR-T150 today...
I'm speechless...
Just a few programming/Channel questions....
I'm getting a HD loop on PBS while titian.com lists other programming?
WFOR-DT is fine and reprogrammed to channel 4-1
Can't get 19-WBZL-DT... is there a trick to this?
This picture is so fine that I could sit and watch grass grow...
Jeff
WingFat is offline
post #410 of 6834 Old 01-28-2002, 02:48 PM
jluzbet's Avatar
Jeff
WBZL - Is only on air from 5:00-12:00 AM
jluzbet is offline
post #411 of 6834 Old 01-28-2002, 07:13 PM
WingFat's Avatar
Thank for the info on the start time for WBZL-DT...
I have another newbie question...
Tonight I'm watching the HD programs on CBS and while they look good, they do not approach the sample programming on PBS this afternoon. I though both are being transmitted at 1080i.
Why did the PBS programming seem better?
Jeff
WingFat is offline
post #412 of 6834 Old 01-28-2002, 09:31 PM
aviators99's Avatar
Anyone interested in coming over to watch the Super Bowl in EDTV via Expressvu on a 50" plasma, send me a PM, so I can gauge interest.
Ron
post #413 of 6834 Old 01-29-2002, 06:13 AM
David McRoy's Avatar
Jeff
You're seeing the difference between film (CBS primetime dramas and sitcoms) and electronic video (PBS demo loop). If you have a chance, see "The Young & the Restless", a CBS soap that's shot on 1080i video.
HiDefDave
WPTV/WFLX West Palm Beach, FL
David McRoy is offline
post #414 of 6834 Old 02-01-2002, 08:37 AM
Venkat's Avatar
I live close to Hypoluxo/Haagen Ranch and am using SIRT 150. I kind of hate looking at WFOR 4:3 broadcast with bars. IS there a way in SIRT150 that will allow me to fill the picture while watching WFOR (4:1) 4:3 digital broadcasts that are not HD.
Venkat is offline
post #415 of 6834 Old 02-01-2002, 10:58 AM
Rudy1's Avatar
Quoted: 964 Post(s)
Liked: 1276
Go into the SETUP menu, select 4:3 instead of 16:9 as your screen format, and then you'll be able to zoom up the upconverted 4:3 broadcasts from WFOR. Just remember to reverse the procedure when you want to watch actual HD programming on WFOR.
Rudy1 is offline
post #416 of 6834 Old 03-01-2002, 08:28 PM
gireesh's Avatar
It is much easier on the Dish6000, at the press of button you can toggle between Normal and Full Zoom!
Gireesh
Once in a while I feel the need to visit this thread
gireesh is offline
post #417 of 6834 Old 03-10-2002, 08:02 AM
It is March 2002, and still no information on what is happening to NBC - DT.
I heard that something was going on, and a "hint" of olympics in HD, which turned out to be on HDNET.
But, I know some programming is going on HD, and some is being aired somewhere, but not in So. Florida.
Sooooooooooo,
Does anyone know what the latest excuse is (maybe it is even a reason, but I don't think so)?
post #418 of 6834 Old 03-10-2002, 09:56 PM
mmburke's Avatar
NBC - WTVJ's DTV request is hung up with the FCC. I spoke to an FCC manager in Jan and was told it would be approved in one month. This is probably beaurocratese for 6+ months.
After FCC approval somebody heard it would take WTVJ about a year to be ready for DTV transmission.
Mark
mmburke is offline
post #419 of 6834 Old 03-10-2002, 10:32 PM
pogo's Avatar
I live close to Hypoluxo/Haagen Ranch and am using SIRT 150. ... WFOR
Question: Do you see occasional retrace lines when watching WFOR?
How many bars show on the "reception meter" when you watch WFOR?
Are you using a pre-amp in the signal path?
Alan
(@ Gateway and Jog)
pogo is offline
post #420 of 6834 Old 03-11-2002, 09:06 AM
That is odd.
I remember when WFOR was putting up their antenna, and was waiting for NBC's antenna.
Then there was this FCC application to change channels, which would cause the antenna to be modified because of different frequency. Since the frequencies were so close, I don't buy that too much, but it may be true for high power efficiency and impedance matching.
Anyway, it doesn't appear to take that long, unless they intend to drag their feet.
But, it did take WFOR a good 6 months to go from install antenna to full power.
Question is how long will it take NBC to go from FCC approval to install antenna.
I though I read their goal was May 2002.
