Miami / Ft. Lauderdale, FL - HDTV - Page 220 - AVS Forum | Home Theater Discussions And Reviews
post #6571 of 6834 Old 12-07-2009, 07:58 AM
stonecrd's Avatar
Originally Posted by 97Strat View Post
I do know, however, that nothing's been disturbed for at least a mile in any direction from my home. So I'm assuming that they ran something to a point further away, then they connect that to the existing phone lines. Good guess or bad guess?
AT&T will install the VRAD somewhere local to you, probably next to their other equipment. They run Fiber to the VRAD and then wire up the local copper line to your house using your existing phone lines. The location of the VRAD is critical to your ability to get service levels as the copper line is the weak link in their architecture. A VRAD looks like:
The problem with the gene pool is that there is no lifeguard and the shallow end is much too large
stonecrd is offline
post #6572 of 6834 Old 12-07-2009, 12:37 PM
p1rates's Avatar
Any updates on Comcast in South Florida? Is Davie still the only city with the new HD channels?
p1rates is offline
post #6573 of 6834 Old 12-07-2009, 01:39 PM
ortegaj's Avatar
There have been a lot of hickups with some of the system. Examples with some channels not showing any information on the channel lineup and some channels that I pay for not showing up such as NFL redzone saying i have no authorization. I called and they said many are having these problems, so I think until they iron out the hickups it might be a little while for the rest of you guys.
ortegaj is offline
post #6574 of 6834 Old 12-07-2009, 06:01 PM
97Strat's Avatar
Originally Posted by stonecrd View Post
AT&T will install the VRAD somewhere local to you, probably next to their other equipment. They run Fiber to the VRAD and then wire up the local copper line to your house using your existing phone lines. The location of the VRAD is critical to your ability to get service levels as the copper line is the weak link in their architecture. (snipped image)
stonecrd, thanks for the visual and the info. Time to go looking for one of these beasts to get an approximation.
A couple more questions:
a) If they use my existing phone line, would that affect my POTS (or vice-versa)?
b) Since I already have a roof antenna hooked up to my in-house coax wiring, would I still be able to use that as is?
Thanks in advance.
97Strat is offline
post #6575 of 6834 Old 12-08-2009, 05:49 AM
p1rates's Avatar
Oh wow. Thanks for the update ortegaj!
I just noticed that Comcast added a new HD channel to my lineup last night.
465 - Lifetime HD
Granted I don't watch Lifetime but I'm glad at least the process as begun. I live in Coral Springs/Parkland area in North Broward. I would advise other Comcast customers in that area to see if any other HD channels has been added to their collection.
p1rates is offline
post #6576 of 6834 Old 12-08-2009, 07:55 AM
stonecrd's Avatar
Thanks in advance.
A) yes you can leave your phone line and they will split it or you can subscribe to their VOIP service. If you have DSL coming in that has to be shutdown as they will convert you to the AT&T VDSL service
B) Depends, the STBs are connected to the Router either by RG45 or Coax (HPNA), if your house is wired for ethernet then the RG45 is best if not they may wire this for you if it is easy (ask politely) or try to use the existing coax. If they use the existing coax then you would need a seperate segment for the antenna since you cannot mix the HPNA with any other signal.
stonecrd is offline
post #6577 of 6834 Old 12-08-2009, 03:53 PM
97Strat's Avatar
My DSL is already split off from the POTS (aka "home run" I believe), as the house is wired for 2 discreet POTS lines. If I wanted to keep my POTS as is, could they use the other line already used by the DSL modem for U-verse?
Aside from the 2-line POTS wiring, the house only has coax (really meant for cable) coming in from outside through a central point going up to the attic, then branching out to various rooms from there via splitters. Right now the coax is connected to my roof antenna.
In trying to figure out the complete wiring, it appears that:
a) Fiber optic goes from some central AT&T location to each of the VRADs.
b) Existing copper that the POTS runs on carries everything from the VRAD to each house.
c) Within the house, a router (or some device) is connected to a wall phone jack, and everything is distributed from there via Coax or ethernet (TV/Internet), or POTS wiring (digital phone).
Am I close?
97Strat is offline
post #6578 of 6834 Old 12-08-2009, 04:23 PM
slimoli's Avatar
Quoted: 654 Post(s)
Liked: 299
Just ordered the 18mbps U-Verse high-speed to replace my 6mbps DSL. I will be using just the internet service since I live in a building with Directv included in the common charges. I hope I can keep my netwok "as is' and just use the residential Gateway as a modem to my wireless N router. The U-Verse gateway sucks with wireless G only.
I was so happy without HDR...
slimoli is offline
post #6579 of 6834 Old 12-10-2009, 08:43 AM
stonecrd's Avatar
Am I close?
Not sure about your POTS, I would think so.
The copper line is terminated with somethign called a NID. The NID can be twisted pair or coax. If coax they run a line to a diplexer and this goes to the Router (RG) if not coax then it is just twisted pair ethernet. The coax line is bidirectional for the RG, the coax is split at teh diplexer and fed back into your home coax through a splitter. UV requires good coax to work correctly so they will replace all of the cable ends with compression ends both on the jacks and any cables you use to the STB.
Again if twisted pair they just run a line from the RG to the STB. You can also be mixed so in my system the RG is next to my HT and I use ethernet to the STB for my 65" DLP and use coax for all of the other rooms.
stonecrd is offline
post #6580 of 6834 Old 12-10-2009, 08:47 AM
stonecrd's Avatar
You can set it up so that your wireless lan sits in the DMZ of the UV router and it will work fine. I do this as I segregate the TV traffic from the computer traffic. You just have to use to different IP networks, turn off the internal UV wireless and let your N router do the DHCP.
stonecrd is offline
post #6581 of 6834 Old 12-10-2009, 09:17 AM
slimoli's Avatar
Quoted: 654 Post(s)
Liked: 299
Thanks for the info. I actually plan to run everything from the existing router and use the RG exclusively as a modem. There will be just 1 network, the one I already have.I can use the other LAN ports on the RG to hook up devices that will only use the internet but not the local network, like my TV for example. Tech is coming and I will know how things go very soon.
slimoli is offline
post #6582 of 6834 Old 12-10-2009, 06:42 PM
slimoli's Avatar
Quoted: 654 Post(s)
Liked: 299
Got everyting working but I have an issue wih my Xbox-360. I connected everything wih my D-Link dir-655 router but left the Xbox connected directly to the Residential Gateway. There is nothing I can do to make a device connected directly to the RG to be recognized by my local network, managed by the router. In other words, I can't make he Xbox see the other devices connected to the router, including my PC.
I put the DIR-655 in the DMZplus mode on the RG and that's basically the only thing I changed ,besides deactivating the RG wireless. How can I make the devices hooked to the RG see the other ones connected to the router ?
slimoli is offline
post #6583 of 6834 Old 12-10-2009, 08:11 PM
97Strat's Avatar
stonecrd, thanks very much for all the info. Super big help.
97Strat is offline
post #6584 of 6834 Old 12-11-2009, 10:33 AM
stonecrd's Avatar
Try checking the internet forum on UTalk, they have some very technical IT people doing more advanced routing and can probably help.
http://utalk.att.com/utalk/board?board.id=HSIA
stonecrd is offline
post #6585 of 6834 Old 12-12-2009, 10:37 PM
Christine85's Avatar
465 - Lifetime HD
Also noticed 479 - MLB Network HD a few days ago.
Christine85 is offline
post #6586 of 6834 Old 12-13-2009, 10:02 AM
ortegaj's Avatar
most importantly NFL Redzone HD Ch. 390
ortegaj is offline
post #6587 of 6834 Old 12-22-2009, 11:52 AM
vtpsystems's Avatar
Question for those using ota. I noticed WLTV TV 23 signal is now displaying with the black bars on the sides including their hd. I noticed the same for Telefutura. Why? WPLG for example displays the black bars for its non hd but displays full screen during the hd news for example not so with WLTV 23 or Telefutura. Therefore it appears to be an issue with the stations I mentioned as all others have seen no change in the way the image self adjust
On another note I remember about a year ago The Doctors transmitted hd in full screen for several weeks then went back to bars on the side. So is all hd now going the route of the bars on the side like WLTV even on hd programming? that makes no sense at all.
EDIT: I just found this which makes even less sense http://www.univision.com/content/con...ml?cid=2194649
So they're claiming I will now see black bars on the screen after their Dec 21, 2009 on their station. They say you will know its hd because the image will be "spectacular" and you will see a "symbol" on the screen. Wait what? so now I get to see a spectacular image with black bars on the side on my big screen unlike others that transmit hd program where you not only know its on hd because of the sharpness but also because "THEY EXPAND THE IMAGE".
Don't stay in bed, unless you can make money in bed. - George Burns
vtpsystems is offline
post #6588 of 6834 Old 12-22-2009, 01:39 PM
Trip in VA's Avatar
Quoted: 858 Post(s)
Liked: 255
Send a message via AIM to Trip in VA
As far as I'm aware, Univision has no HD programming at this time. They've started converting their stations over, but no actual HD programming yet.
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is online now
post #6589 of 6834 Old 12-22-2009, 06:34 PM
vtpsystems's Avatar
- Trip
Hello Trip, would that explain why in other stations the image expands in some programs and the news for example and in 23 everything is with the black bars on the sides? Does that mean their news is also not hd either? I see no difference in Channel 23 image quality now vs old other than those annoying black bars they now have.
post #6590 of 6834 Old 12-22-2009, 06:47 PM
Trip in VA's Avatar
Quoted: 858 Post(s)
Liked: 255
When the image expands, that is HD content, or at the very least wide SD. When the black bars are shown, you're seeing SD content that's being upconverted to HD.
- Trip
N4MJC
RabbitEars
post #6591 of 6834 Old 12-26-2009, 04:22 PM
WillTech's Avatar
Catch WLTV first program" Tournament of Roses Parade" in high definition, which will be seen in 16x9 HD live on January 1st.
WillTech is offline
post #6592 of 6834 Old 12-27-2009, 03:40 AM
nortynorty's Avatar
Two questions for those in Weston and Coral Springs with Advanced Cable Communications. The DVR I have (I believe) is the DCH6416. I recently bought a wireless bridge and switch to connect my BD player and Panny to the internet. The DCH has an input for ethernet connection but I don't know if that is active and if so what it does. Anyone know?
The other question has to do with program information which is transmitted from ACC. When I connect my two TVs to OTA, I get the station identifier, program name, remaining time and brief synopsis of the program. No program information is received when going through the cable card on my 2nd TV. I guess that is because it is assumed that the guide would be used, which of course is not available on the cable card. This is probably more of a statement then a question as I don't expect that this is a user setting.
nortynorty is offline
post #6593 of 6834 Old 01-01-2010, 09:37 AM
acesk8er's Avatar
WLTV (Tournament of Roses parade) and WAMI (Telefutura dubbed movie, HD and SD versions of the same program).
Univision HD TSReader Captures 1-1-10.zip 3.9013671875k . file
File Type: zip Univision HD TSReader Captures 1-1-10.zip (3.9 KB, 22 views)
acesk8er is offline
post #6594 of 6834 Old 01-01-2010, 09:49 AM
Trip in VA's Avatar
Quoted: 858 Post(s)
Liked: 255
- Trip
N4MJC
RabbitEars
post #6595 of 6834 Old 01-01-2010, 06:16 PM
snidely's Avatar
Quoted: 198 Post(s)
Liked: 44
Have they announced when they are going all digital - meaning we will need to get their (free) data converter box?
If when that happens, we should get additional HD about 6 months later.
In our Oakland home they started to push everyone to get the data box (necessary to watch digital channels), about 4 months before they went all digital, Even so, some number of people wondered why they lost their picture despite a large number of Comcast announcements on TV and mailing inserts and notices on bills. In less than a month, a couple dozen new (mostly HD) channels were added.
...mike
Most of the SF Bay Area now has the expanded lineup - called out there - The World of MORE (WOM). They started most of the expansion in the past 10 months there.
snidely is offline
post #6596 of 6834 Old 01-01-2010, 07:48 PM
vtpsystems's Avatar
Saw something about this airing on pbs and thought I would share it.
Life on Mars
Thu 1/14 9:00-10:00pm 2.1 WPBTDT
Premiere: Jul 24, 2006
Original Network: BBC America
post #6597 of 6834 Old 01-01-2010, 09:07 PM
97Strat's Avatar
Life on Mars
Also saw this. It's the original show that the ABC show was cloned from. Should be interesting.
97Strat is offline
post #6598 of 6834 Old 01-12-2010, 08:25 AM
vtpsystems's Avatar
Strat have you experienced any issues with your Samsung recently? Anyone else experience any issues with Samsung or other.
Samsung hdtv is using ota.
Upon startup the set displays only a black screen and repeatedly scrolls through all channels without stopping. Refuses to shut down. Not responding. At least once the volume bar also displayed and filled up while above was going on.
post #6599 of 6834 Old 01-12-2010, 11:26 AM
bigyellowtuna's Avatar
test
bigyellowtuna is offline
post #6600 of 6834 Old 01-12-2010, 11:29 AM
Does anyone know the status of the vod feeds on Advanced Cable's Coral Springs system? I use to watch unencrypted feeds on a Samsung with Qam tuner on channels 107, 108, 109, and 110. The feeds went away several months ago and I haven't seen them since. Did they move or did Advanced start encrypting these channels so they won't work with Qam tuners?
