Miami / Ft. Lauderdale, FL - HDTV - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 6834 Old 06-06-2001, 07:48 AM
wjbjr's Avatar
Originally posted by hardrock:
Did anyone watch the 11:00 news on CBS tonight? When I tuned in at about 11:25 they were showing JAG in HDTV.
Yes. The timing was right for it to have been the west coast JAG network feed. It was on the DT channel only. The analog channel had the news. Strange.
Bill Brenner
B
wjbjr is offline
post #92 of 6834 Old 06-08-2001, 04:03 PM
bernster2001's Avatar
Quoted: 25 Post(s)
Liked: 51
Hi
I am 1/2 mile south of griffin rd and 1/2 mile east of 441 in Hollywood and only get a 28 signal on WFOR. My tv will not show any picture at this level. When will WFOR increase signal strength? I get 88+ signal on all other local channels. Also, why do many shows on 7 and 10 digital look so bad?
Bernie
bernster2001 is offline
post #93 of 6834 Old 06-08-2001, 05:09 PM
hardrock's Avatar
bernie,
What STB are you using?
USA
hardrock is offline
post #94 of 6834 Old 06-08-2001, 06:26 PM
Haole's Avatar
I have an RCA P61300 . it has the HD decoder (?) built in, so no STB. I live near Sample Rd and US 1, and I cannot receive any digital signal. I am using a small radio shack UHF antenna connected to the Ant B input, but after a scan, only analog signals. I don't want to go through the expense of an outdoor antenna if it's not going to help. Can anybody help!!
Scott
Haole is offline
post #95 of 6834 Old 06-08-2001, 07:17 PM
Quoted: 25 Post(s)
Liked: 51
Hardrock,
I have a DTC-100 and RCA MM36110.
Bernie
post #96 of 6834 Old 06-09-2001, 06:16 AM
George33027's Avatar
Try another antenna. UHF is very directional, and you have to point it almost exactly in the right direction.
It also takes time for the tuner to lock on, so you can't just move it fast and see a pix pop up.
Go out an buy a indoor VHF and UHF antenna (I used a RCA amplified one that I got in K-mart).
Channels 8 & 9 are VHF with good strong signals, and will translate to 7-1 and 10-1 DT. Not HD, but will check out your digital section of your tuner.
Only HD (some of the time) channels down here are 18 UHF which translates to 2-1 and 22 ==> to 4-1 (best in prime time).
Hardrock will keep us informed when another DT channels comes on the air.
George33027 is offline
post #97 of 6834 Old 06-09-2001, 12:40 PM
Dave McRoy's Avatar
Bernie, WFOR-DT expects to be at full power in September.
HiDefDave
STOP HDCP!
HiDefDave
STOP HDCP!
Dave McRoy is offline
post #98 of 6834 Old 06-09-2001, 01:02 PM
hardrock's Avatar
Bernie,
You should be able to receive WFOR's signal regardless of the fact that they are not yet at full power.
USA
hardrock is offline
post #99 of 6834 Old 06-09-2001, 09:39 PM
hardrock's Avatar
Bernie,
Do you have the RCA MM36110 connected to the DTC-100 via component cables?
RCA MM36110 Owner's Manual
USA
hardrock is offline
post #100 of 6834 Old 06-10-2001, 06:03 PM
hardrock's Avatar
"Something to Talk About" on WFOR is not being shown in HDTV.
USA
hardrock is offline
post #101 of 6834 Old 06-10-2001, 06:09 PM
hardrock's Avatar
They flipped the switch.
USA
hardrock is offline
post #102 of 6834 Old 06-11-2001, 03:11 AM
Quoted: 25 Post(s)
Liked: 51
Hardrock,
I have the RCA MM36110 connected to the DTC-100 via vga cable and am using Terk 55 antenna mounted about 25 feet up under roof overhang. Signal is 28. Screen is blacked out on WFOR with weak signal message.
Bernie
post #103 of 6834 Old 06-11-2001, 10:07 AM
hardrock's Avatar
Bernie,
You have indicated that shows on 7 and 10 digital look bad.
I assume when you refer to channels 7 and 10 digital, you mean channels 8 and 9 respectively.
Have you chosen the "UHF/VHF Antenna" "Signal Type" as indicated on the top of page 31 in your Owners' Manual? Your manual indicates that "Signal Type" does not appear in the "Channel menu" if you have set up the "GUIDE Plus+ System".
Have you set the "SAT/CABLE CHANNEL" to (S)VGA2 as indicated on the bottom of Page 42 in the RCA MM36110 Owner's Manual ?
Channel 8 and 9 are VHF. Channel 22 is UHF. A New York Times article described how it was necessary to carefully aim the antenna to receive 8-VSB service. The article reported that one broadcaster viewing the demonstration stated that "You have to work to find a signal" with the 8-VSB system.
I repositioned my Terk TV42 antenna with internal amplifier which is mounted on my chimney at a height of about 20 feet; and, the signal I now receive from WFOR-DT averages about 85 percent - which equates to a gain of 27 percent (85 minus 67 = 18 units) (18 divided by 67 = 27 percent gain). I'm sure that I can further improve my reception by swapping the standard coaxial cable I am using with a high quality RG-6 cable.
You may also want to try WPBT's Channel 18 sometime after 5 PM when they begin broadcasting everyday. WPBT has a strong stable signal and their transmitter is located on the same antenna farm as WFOR.
If all else fails, try another antenna.
USA
hardrock is offline
post #104 of 6834 Old 06-11-2001, 10:19 AM
rodmanbra's Avatar
I am in different time zone. Wfor did not start the movie in HD!! However.. the sponcered by panasonic was right on time!!
rodmanbra is offline
post #105 of 6834 Old 06-12-2001, 07:16 PM
hardrock's Avatar
Someone at WPLG forgot to flip the switch for NYPD Blue.
USA
hardrock is offline
post #106 of 6834 Old 06-12-2001, 08:00 PM
hardrock's Avatar
WPLG finally threw the switch at 10:29.
USA
hardrock is offline
post #107 of 6834 Old 06-12-2001, 10:43 PM
rodmanbra's Avatar
Big deal or is it? Another plot of NYPD blue gets shot by sandy's 9mm!
The bigger ? is does anyone care! I think i will ask some A/V dealers....
post #108 of 6834 Old 06-13-2001, 04:34 AM
Quoted: 25 Post(s)
Liked: 51
Hardrock,
Thanks for all the advice. Channels 2,7, and 10 come is as 18,8, and 9. 2 and 10 always looks great in HD. 7 and 10 in digital are so-so. Antenna info screen shows 4 as 22 with strength of 28 and no picture.
You stated:
>Have you chosen the "UHF/VHF Antenna" "Signal Type" as >indicated on the top of page 31 in your Owners' Manual? >Your manual indicates that "Signal Type" does not appear >in the "Channel menu" if you have set up the "GUIDE Plus+ >System".
I did set up Guide Plus. I can't figure out how to eliminate it. Will unplugging set for a couple of hours do the trick? I do not have Signal Type option on menu. Will having this option affect performance since I already get great picture when HD is broadcast on 2 and 10?
SAT/CABLE CHANNEL is set to (S)VGA2. If I do not set it this way digital channels are listed as 2-1,4-1,7-1 and 10-1. Does this affect performance?
My amplified Terk antenna is under roof overhang about 25 feet up. Repositioning is the only thing I did not try. But I do get 88+ on 18, 8 and 9 so I am reluctant to do that. Might have to wait til September for WFOR.
Bernie
B]Bernie,
If all else fails, try another antenna.[/b]
post #109 of 6834 Old 06-13-2001, 07:28 AM
hardrock's Avatar
Questions about operating or setting up your Multimedia Monitor? Call RCA toll free at 1-877-766-2728
USA
hardrock is offline
post #110 of 6834 Old 06-14-2001, 08:11 AM
Haole's Avatar
is WPLG on the air now? i was getting a good signal last week, but now i'm getting a weak signal. i get channels 8, 18, and 22, but no 9. i believe 8 and 9 are on the same antenna, no?
Scott
Haole is offline
post #111 of 6834 Old 06-14-2001, 08:19 AM
Dave McRoy's Avatar
Their towers appear to be right next to each other, according to www.100000watts.com .
Interesting to note that WSVN-DT is currently operating at 14.4 kw but has a Construction Permit to go to 145 kw (a typo? www.fcc.gov says "145. kw" [another typo?])
WPLG-DT is currently at 15.8 kw and has a CP to go up to 30 kw.
HiDefDave
STOP HDCP!
[This message has been edited by Dave McRoy (edited 06-14-2001).]
HiDefDave
STOP HDCP!
post #112 of 6834 Old 06-14-2001, 10:16 AM
rodmanbra's Avatar
I do NOT understand why ABC can not do 1 series in HDTV right. I do understand that the a/v dealers (aka viewers) do not care...
As for WFOR, they are conserving energy at night. There was no signal at 3 am!
post #113 of 6834 Old 06-15-2001, 08:51 PM
Haole's Avatar
i'm curious. is anybody getting the wplg feed on 9-1?
Haole is offline
post #114 of 6834 Old 06-15-2001, 09:05 PM
hardrock's Avatar
Haole,
WPLG is coming in loud and clear.
USA
hardrock is offline
post #115 of 6834 Old 06-16-2001, 08:42 AM
Haole's Avatar
thanks, hardrock. gotta tweak the antenna!!
Scott
Haole is offline
post #116 of 6834 Old 06-16-2001, 09:07 PM
wjbjr's Avatar
Try 10-1
Bill Brenner
B
wjbjr is offline
post #117 of 6834 Old 06-17-2001, 09:10 PM
Haole's Avatar
thanks, bill, but no luck. This is my dilemma. i bought a Radio Shack antenna. i placed it in my attic, and connected it to my tv. all 4 channels ( 8-1, 9-1, 18-1, and 22-3)came in great . i then hung the antenna from the rafters, and promptly lost all signal on 9-1. i believe that wsvn and wplg are on the same tower, or very close. looking at other sites, i see that wplg puts out a stronger signal than wsvn. why, then, can i not receive WPLG at all?
i am very new to this, so forgive if my questions seem dumb.
Scott
Haole is offline
post #118 of 6834 Old 06-18-2001, 05:11 AM
holtwm's Avatar
Is WFOR broadcasting full power yet? If not, when will they start? I can't seem to get this station using my existing antenna which works fine for the other digital channels. Thanks.
Will
holtwm is offline
post #119 of 6834 Old 06-18-2001, 05:20 AM
Dave McRoy's Avatar
Hi,
WFOR-DT is currently broadcasting with 71 kw ERP. They should be at full power (nearly 1,000 kw) in September.
HiDefDave
STOP HDCP!
HiDefDave
STOP HDCP!
post #120 of 6834 Old 06-18-2001, 03:03 PM
hardrock's Avatar
WBZL-DT - Channel 19 - WB39
June 29, 2001 per TitanTV
July, 2001 per HD Pictures
Phone: (954) 925-3939
Email: wbzl@tribune.com
WHDT-DT - Channel 59 - MIG
Anticipated Debut - before July 31, 2001
Work remaining - Build & Install Antenna
Phone: (561) 471-9200
Email: info@whdt.net
USA
hardrock is offline
