Reno, NV - HDTV - Page 23 - AVS Forum
post #661 of 686 Old 08-06-2010, 09:53 AM
SierraTech's Avatar
Jerry,
Do a scan on your TV, Charter moved channels all over the map and added FOX/PBS and changed where the networks and sports channels (Digital and analog) are located.
Also they changed their music services based on the sheet sent in my Cable Bill. BASIC/BASIC plans lost several channels.
SierraTech is offline
post #662 of 686 Old 08-17-2010, 09:56 AM
sum_random_fan's Avatar
Originally Posted by jfca View Post
Channel 14 in the Reno area is set to hit the air soon.
JFCA, what's Channel 14 going to carry? I am in Truckee and get Fox11, KOLO, and KTVN pretty well. Glad to see KOLO8 finally went HD on their newscasts.
sum_random_fan is offline
post #663 of 686 Old 08-22-2010, 05:09 PM
dasanii19's Avatar
Anyone in Reno looking to go in on a HT subwoofer? I'm looking to buy a Rhythmic or a Epik Empire. (discounts when you buy more). I Figured since there are a bunch of locals on this thread I would take a shot before I pulled the trigger. PM me if interested.
MY NAME IS SUE!!! HOW DO YOU DO!!!
"I started out with nothing, and I still have most of it."
dasanii19 is offline
post #664 of 686 Old 08-29-2010, 12:12 AM
jerryyyyy's Avatar
Originally Posted by SierraTech View Post
Jerry,
Rescan worked!
I scanned and now have:
2.1 2.2
8.1 8.2
11.1 11.2
21.1 21.2
27.1 27.2 27.3
I am only using OTA. I see PBS's transmitter is located a bit north and west of Slide Mtn.... probably out of range?
Seems like 4 and 2 use the same tower. Wonder why I do not get 4? I see that 21 is transmitting a little to the East, and I get the best signal from them. I am afraid I am into my trees, but still not bad given the location.
I used the TV fool downloads to get details on locations:
http://www.tvfool.com/index.php?opti...ask=view&id=21
Via Google Earth.
jerryyyyy is offline
post #665 of 686 Old 09-06-2010, 12:37 PM
lfox's Avatar
You are right that KRNV and KTVN use the same transmit antenna. KRNV (NBC on digial 4.1) transmits on channel 7. Do you have an antenna with good VHF performance? KTVN is on channel 13 which being a higher frequency is more likely to be received by antennas primarily designed to receive UHF. Hope this helps.
lfox is offline
post #666 of 686 Old 09-06-2010, 01:04 PM
SierraTech's Avatar
Originally Posted by jerryyyyy View Post
Rescan worked!
2.1 2.2
8.1 8.2
11.1 11.2
21.1 21.2
27.1 27.2 27.3
Via Google Earth.
Thanks for the website, I will need to investigate more closely. I haven't tried terrestrial, but will earmark some time to experiment. In South Incline we might not have a straight shot at Slide Peak due to topology of the mountains. It would be interesting to test it, but may be expensive. I did use antennaweb.org, and it tells me I need a very "HIGH-GAIN" antenna for over the air reception. This might pose a problem since I wish to put the antenna in the attic over the garage, and I have a metal roof.
Thanks for the feedback!
-Bob
post #667 of 686 Old 10-07-2010, 09:59 PM
the_bear89451's Avatar
...This might pose a problem since I wish to put the antenna in the attic over the garage, and I have a metal roof. ...
I think you might be SOL with the attic. I am in about the center of Incline. When I first started, my antenna was in the attic above my second story. I could only watch TV about half the time.
the_bear89451 is offline
post #668 of 686 Old 10-08-2010, 10:29 AM
SierraTech's Avatar
Thanks for the report! From my roof (when I was building my house I spent a lot of time on that metal roof which was not the most comforting feeling) there is no line of site to Slide Peak, I see the mountain where the streets Driver and Fairview intersect and lots of trees so I may end up with nothing in our area.
I saw AT&T working nearby the other day and asked if they are pulling a fiber, and they confirmed that they were upgrading DSL speeds with Fiber which tells me U-Verse may be available soon. I pre-wired for a dish antenna but I have so many trees south of my house that locating a dish would be a challenge. So if U-Verse comes to Incline then I will be very interested (I currently cannot upgrade to Elite DSL speed, but now maybe higher DSL speeds and IPTV will be available).
post #669 of 686 Old 10-31-2010, 02:12 PM
Did KNPB increase their signal in Truckee? I just did a re-scan this weekend and it went from never coming in to now around 80%. Nice to see, I can get all the majors now in Truckee (Tahoe Donner).
post #670 of 686 Old 11-15-2010, 03:04 PM
joebloggs10's Avatar
I'm in Carson City, down at the south end of town. I have a high-VHF/UHF antenna mounted on my roof. I currently can pick up channels 2, 4, 5, 11, 21, and 27. Channel 8 comes in very sporadically; typically it's very pixelated or has no signal at all.
It's my understanding that Channel 8 is coming from Mount Rose, along with 2 and 4. Is there any reason why I get perfect reception on all channels except 8?
joebloggs10 is offline
post #671 of 686 Old 11-15-2010, 03:44 PM
SierraTech's Avatar
The phone company has been working occasionally on the next street over and accidentally broke my main phone line (while he was rewiring the pedestal). I went and informed the tech working on it (who was moving the lines with DSL in preparation for the Fiber) and told him my line has been dead for about 3 hours, he confirmed it got accidentally broke (NO DSL on that line).
I asked him if Uverse will be part of the upgraded Fiber services and he said, "No, AT&T only has it only in Reno". So I guess we are stuck with CATV or Satellite (if you have a free view of the southern horizon).
post #672 of 686 Old 11-22-2010, 08:53 PM
lfox's Avatar
Joe Blogggs - If you can move the antenna a couple of feet you may find your problem goes away. I have an antenna in my attic in east Reno. I have a perftect line of sight to Peavine where KRXI transmits their main signal. Could not get it. I moved the antenna about a foot and have never had a problem since. You could be in a null for KOLO. They transmit on channel 8, high VHF. You could look for bad cable/splitter/amplifier connections too. I can't think of a reason you should not get it.
lfox is offline
post #673 of 686 Old 12-09-2010, 11:22 PM
jerryyyyy's Avatar
I am out of Tahoe now but I had the same Joe B problem with 8 near Tahoe City. In theory it should be the same as the others, but not in my experience. Wonder if their transmitter just does not put out the same amount of juice....
post #674 of 686 Old 12-27-2010, 12:01 AM
agus0103's Avatar
During an attempt to see if any additions could be made to the Over-the-air HDTV News Stations table in the HDTV Programming subfourm, I checked out the websites of KRXI and KTVN, the two Reno stations not listed. I see that they both definitely have widescreen news, but does anyone know if their news is also in HD? Feel free to post in the Is your local news in HD? thread if you know.
agus0103 is offline
post #675 of 686 Old 01-05-2011, 07:03 PM
lfox's Avatar
KTVN's newscast is not yet in HD but wide screen SD. I believe the 10p news on KRXI is in HD.
lfox is offline
post #676 of 686 Old 05-03-2011, 03:55 PM
baja7475's Avatar
Quoted: 30 Post(s)
Liked: 42
charter is going to add 27 new hd channels to the Reno market on May 17th.
http://www.myaccount.charter.com/Vis...Y.xbin?ID=2659
baja7475 is offline
post #677 of 686 Old 05-03-2011, 04:41 PM
SierraTech's Avatar
It appears that most of these HD channels requires a Box or Cable Card to enjoy the added HD & Digital Channels (extended Service). I didn't see any Chanel Lineup insert in Incline Village Cable bill on changes (I will check again), so this may be the Reno area only. From the looks of things it appears very few channels have been added (except Weather Channel moved back down to "Basic Service" (this is welcomed) and the return of the History channel on Expanded Basic). Services added to QAM are minimum (appears FOX-HD moved into Basic Service where it belongs). Expanded Basic is only Analog, all HD channels in this tier requires Cable Card or Box.
The rental of a Cable Card or Box still pushes the price too high. Still hoping AT&T Uverse comes to Incline (the infrastructure is being put in place), anything to keep the costs down would be welcomed. Again this may not even affect Incline Village since we have our own 'Head-in'. AT&T has been pulling fiber to various neighborhoods, for Internet speed improvement, but I think Uverse is not too far behind.
Thanks for sharing!
post #678 of 686 Old 05-03-2011, 08:05 PM
baja7475's Avatar
Quoted: 30 Post(s)
Liked: 42
Incline is on a totally different headend. This update only includes Reno and Sparks. I think the 2662 pdf might be your area. You can copy and paste the link above and change the #'s for different areas.
baja7475 is offline
post #679 of 686 Old 06-13-2011, 08:35 AM
njeske's Avatar
Does anyone know what HD-DVR Charter is currently using for new installs? I have been with satellite companies for the past few years since the channel lineup and hardware from Charter sucked. Now with these additional HD channels, I'm hoping their hardware has improved as well.
njeske is offline
post #680 of 686 Old 06-14-2011, 05:49 PM
[H]gregnash's Avatar
Ok so this is getting real F#(*ing frustrating for me and wife. Have had Charter in the same location for going on 3yrs now without much issue. Suddenly within the last couple months they have been doing the "digital switching" change over and all our expanded digital and premiums (basically 100 on up) are complete f'ed. Had four techs out and Charter keeps blaming the Tivos (S3 TivoHD and new Premiere). It goes from working completely to nothing working except for a few sparing channels. Had the cablecards replaced, signal strength checked and what-not, and nothing is wrong.
Hoping that the Charter Rep that usually watches this thread is watching today because last night I called, scheduled a tech (because once again we got nothing above 100) and instructed them to send out a supervisor with multiple Mcards and even a GD forsaken tuning adapter so that we can get this working and they sent out a young guy with nothing from Prince Communications. Read to call it quits with Charter over this.
[H]gregnash is offline
post #681 of 686 Old 06-15-2011, 01:12 AM
RenoDavid's Avatar
I'm not having any problems (well, I had one) with the quality of my service, but I'm about ready to drop Charter because they aren't showing enough Giants games in HD. About time I tested the DirecTV or U-Verse waters....
RenoDavid is offline
post #682 of 686 Old 06-16-2011, 09:32 AM
Yeah unfortunately for me this has been going on since February, multiple technicians out to replace cards, add tuning adapter, tuning adapter isn't needed, etc. Just real frustrating because in Carson we don't have much of an option; either go with Charter or go with one of the dishes. In my experience, if we get bad weather the Dish (whether Dish or DTv) gets messed up and you lose signal. While we do not watch a ton of TV we want it there when we do want to watch it.
Ended up talking (yes talking not yelling) with a Charter tech and we are supposed to have a Supervisor Tech here this morning to remedy the issue. Sorry but paying close to $200 a month with internet and cable and for this **** to only work sparingly at best is a bit ridiculous to me.
post #683 of 686 Old 06-17-2011, 10:22 AM
RenoDavid's Avatar
Good luck with that. I just found out that I can't get U-Verse at my location yet.
post #684 of 686 Old 07-05-2011, 06:48 PM
jerryyyyy's Avatar
Guys,
Was just up at Tahoe and rescanned my channels. I have gotten what I have in the past (2, 8,11, 21, 27), but a very feeble signal on 4. Is this the weakest sister of the transmitters?
PS Still no PBS visible....
post #685 of 686 Old 10-15-2011, 09:26 AM
rdvegas's Avatar
Quoted: 45 Post(s)
Liked: 29
Watch for Antenna TV to appear as soon as the first of November on KTVN.
The first of January seems to be a realistic launch date, inspite of some info suggesting November.
Wanting a strong FCC to say no to the Wireless lobby. Keep the tv broadcast band for ota television broadcasters.
rdvegas is offline
post #686 of 686 Old 01-04-2015, 05:52 PM
boogerhead's Avatar
Quoted: 13 Post(s)
Liked: 0
Reno/Sparks Fox KRXI 11.1 and 11.2
I was wondering if anyone in the Spanish Springs area has had issues with Fox channels after the windstorm a couple weeks ago?
It broke one of my antenna mounts so I figured thats why I lost those 2 channels. Funny thing is both my antennas never moved from their locations but I had to point my UHF at least 46-56 degrees south from where they were to get the channels back on all but one TV? A couple days ago they went wiggy again, so today I started tweeking. I'm just about back to where it was before the storm? Did the wind move KRXI's equipment on Peavine and they finally got to it or what? Any insight? I'm using a 91xg for UHF and an old Radioshack combo for VHF and the Southern UHF channels. CM 7777 pre-amp with the combiner unlike the new version.
Also, I have my 2 antennas approx 4 feet apart (1 above the other) and found that they interact with each other in a way I don't like. Should that distance be further? I was using a signal meter to try to tune them again and left one disconnected from the pre-amp while tuning the other. Did both that way but when hooked back up normally when done, signal was weaker on all stations.
And whats the deal with the local CW? Can't these guys keep signal on BOTH 46.1 and 27.2 channels at the same time? At the same level?
boogerhead is offline
