Youngstown, OH - HDTV - Page 64 - AVS Forum | Home Theater Discussions And Reviews
post #1891 of 1986 Old 01-02-2012, 12:37 PM
milee's Avatar
thank you for the information.........I don't mind local stations but husband loves many different shows available only on cable. I will have to live with a cable bill.
milee is offline
post #1892 of 1986 Old 01-11-2012, 06:47 PM
fmcomputer's Avatar
Attention Dish Network subscribers:
As of midnight on January 15, 2012, you will no longer be able to view WKBN.
fmcomputer is offline
post #1893 of 1986 Old 01-15-2012, 10:46 AM
Inundated's Avatar
Quoted: 103 Post(s)
Liked: 36
Is that midnight last night/early this morning or midnight tonight?
Are WKBN/WYTV/WYFX still up on Dish?
Inundated is offline
post #1894 of 1986 Old 02-09-2012, 08:32 PM
fmcomputer's Avatar
FOX the Finder no audio
post #1895 of 1986 Old 02-13-2012, 09:13 AM
Freekick123's Avatar
Quoted: 17 Post(s)
Finally got to this show on the DVR. I have surround sound. One segment was missing the center channel where all the dialog is.
Freekick123 is offline
post #1896 of 1986 Old 02-13-2012, 09:01 PM
Vchat20's Avatar
Nothing new. Can't tell you how many times over the past numerous years (hint: I've lost count) that WKYC/WYTV has exhibited this issue.
Vchat20 is offline
post #1897 of 1986 Old 03-11-2012, 04:03 PM
dxernut's Avatar
Does anyone know the outpower of WKBN ? I used to receive them regularly, before they moved their DTV antenna further up the tower.I only receive them now during troppo conditions. I live in the Pittsburgh area and do receive WFMJ quite regular.
dxernut is offline
post #1898 of 1986 Old 03-11-2012, 06:25 PM
ajg0711's Avatar
TV Fool shows it as 570 KW. Antenna Point says 700 KW. I know they are stronger than WFMJ, I would think you should get it. I pick up KDKA, WPXI and WPGH, and when things are right your channels 16,19, & 22.
Here are the links to tv fool and antenna point.
http://www.tvfool.com/?option=com_wrapper&Itemid=29
http://www.antennapoint.com/
ajg0711 is offline
post #1899 of 1986 Old 03-11-2012, 06:45 PM
Trip in VA's Avatar
Quoted: 514 Post(s)
Liked: 143
Send a message via AIM to Trip in VA
WKBN is at 650 kW.
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is online now
post #1900 of 1986 Old 03-14-2012, 08:10 PM
dxernut's Avatar
Yeah it's strange, I know I should receive WKBN regularly,instead of WFMJ, but when I received analog signals from these stations WFMJ always came in better.I have walked the entire roof with a 4228 antenna and haven't found that sweet spot for WKBN. Next I'll have to try a channel master signal amp, but that antenna is already heavy.
dxernut is offline
post #1901 of 1986 Old 03-14-2012, 08:14 PM
dxernut's Avatar
Originally Posted by Trip in VA View Post
WKBN is at 650 kW.
- Trip
Thanks Trip for the information. Its nice to receive these tri state stations, as I like to see what weather conditions are coming my way, and get a different prospective of the news of their cities as opposed to the Pittsburgh news stations which do the news to death!
dxernut is offline
post #1902 of 1986 Old 03-17-2012, 05:33 PM
dxernut's Avatar
Well On this past friday I took down my antenna system and added a Channel Master 7777 pre amp thinking it would slightly improve my reception of WFMJ and WKBN . I lost the signal that I had, and was reduced to 1 bar flashing even at night.I thought during this mornings fog I would at least pick up some early morning reception-no chance nothing. That made my take down the whole thing and eliminate the 7777 altogether.Now WFMJ is showing signs of coming back,nothing yet with WKBN. I had been using the 7777 for my attic antenna for the past couple of years now with improved results. The setup on the roof has only a 25ft run of rg6 cable.
dxernut is offline
post #1903 of 1986 Old 03-17-2012, 07:55 PM
ajg0711's Avatar
I can't believe it didn't help. I have the CM 4228 (the old style) with the CM 7777 amp and I get cleveland, pittsburgh, erie, and stubanville stations. I did have a problem one time with the balum (went bad) but I changed it and it's been fine. I know the new 4228 doesn't need the balum.
ajg0711 is offline
post #1904 of 1986 Old 03-18-2012, 11:01 AM
Sammer's Avatar
I can believe it because dxernut lists his location as West Mifflin. That's probably too close to a number of Pittsburgh TV and FM stations to use the CM 7777 with an outdoor antenna.
Sammer is offline
post #1905 of 1986 Old 03-22-2012, 03:22 PM
dxernut's Avatar
Yeah I have the old style 4228 and I agree it is a great antenna,although heavy. I remover the 7777 amp and now I receive WFMJ early morn and late at night. 1 morning even received WKBN.
dxernut is offline
post #1906 of 1986 Old 04-22-2012, 11:07 AM
fmcomputer's Avatar
Can we have Fox 19.1 listed in Dish Networks EPG Guide
post #1907 of 1986 Old 05-07-2012, 01:15 PM
reckoniez's Avatar
LIN Buying New Vision Stations For $342M
http://www.tvnewscheck.com/article/2...tions-for-342mWKBN/WYFX/WYTV
reckoniez is offline
post #1908 of 1986 Old 07-15-2012, 04:34 PM
fmcomputer's Avatar
How long is WFJM 21 be off the air for Dish Network ....
post #1909 of 1986 Old 10-16-2012, 04:01 PM
HDTV Fanatic's Avatar
The news on 21 WFMJ is FINALLY in HD!
HDTV Fanatic is offline
post #1910 of 1986 Old 10-16-2012, 04:06 PM
blkballoon925's Avatar
I know! I caught it yesterday at 6 PM, but they didn't say anything about it on air, so I'm not sure if it happened at 6 or if their Mid-day and WFMJ Today broadcasts were the first. It's definitely about time, but I have to say the graphics and video quality look amazing. Makes it clear that even though 27.1 is broadcasting a 1080i carrier, it is still a 720p production.
blkballoon925 is offline
post #1911 of 1986 Old 10-16-2012, 10:21 PM
Vchat20's Avatar
About time! I no longer live in the area so curious if anyone can provide a screenshot or two or even a video clip? Very curious to see the improvement!
Vchat20 is offline
post #1912 of 1986 Old 10-16-2012, 10:34 PM
https://www.youtube.com/watch?v=zjYJQ8t--0E
https://www.youtube.com/watch?v=sCTxtTGV6Ek
post #1913 of 1986 Old 10-17-2012, 07:33 PM
It's too bad that the sound is still screwed up! It's still surging up and down all the time. RIDICULOUS!!
post #1914 of 1986 Old 10-18-2012, 08:53 AM
Vchat20's Avatar
Very nice. Still seems kinda on the bland side and needs a bit more work, but given this much outdated upgrade is in place is a welcome sight. Even prior to this it seemed like the SD upconvert was especially bad even for SD. Granted, youtube doesn't help much either. Thinking next time I go up to visit I am dragging my laptop along and capping some clean screenshots.
Vchat20 is offline
post #1915 of 1986 Old 11-16-2012, 01:39 PM
dxernut's Avatar
Yeah it would be nice to see. Since the cold weather I havent been able to pick them up. Did they change the set any?
dxernut is offline
post #1916 of 1986 Old 11-17-2012, 06:19 AM
Vchat20's Avatar
I'll actually be up that way visiting family over Christmas so I will try to pull some screencaps and video clips.
Vchat20 is offline
post #1917 of 1986 Old 12-08-2012, 09:31 PM
They painted parts of the set a while ago. They're also using virtual sets for their national news and health segments.
post #1918 of 1986 Old 12-13-2012, 08:43 AM
dxernut's Avatar
Was able to see for the first time WFMJ in HD ! Only tuned in during the Today Show Breakin. Looked good,wish I received the signal all the time.smile.gif
dxernut is offline
post #1919 of 1986 Old 12-17-2012, 09:01 PM
Tim Lones's Avatar
Quoted: 14 Post(s)
I posted this in the Cleveland OTA thread..Thought it would be of interest here as well..
"Here's something I thought might be of interest. WEWS-TV 5's Video Vault on it's website has posted a very rare 1953 Documentary called RIGHT BEFORE YOUR EYES. It is a history of Cleveland Television up to October, 1953..The 20-minute documentary covers:
Planned power increases for all Cleveland VHF Stations, along with Channel 4 moving to 3 and 9 moving to 8
Progress of Youngstown Channels 27 and 73(later 21)
Progress of Ashtabula Channel 15
Progress of Akron Channel 49
Planned stations on Channels 19 and 65 for Cleveland and 23 for Massillon-Canton..
There is also vintage film of city skylines, as well as some film of programs in progress at each station already on the air..
http://www.newsnet5.com/dpp/news/news_archives/video-vault-cleveland-tv-right-before-your-eyes
This is about as old a complete program you'll find locally..Fascinatng..
Tim Lones is offline
post #1920 of 1986 Old 08-17-2013, 02:12 PM
Hardcore Legend's Avatar
has anyone noticed a considerable framerate issue with WKBN HD and WYFX HD? They both seems to be coming through at an unnatural frame rate.
Hardcore Legend is offline
